HF30ACC321611-T
HF30ACC321611-T
    TDK(东电化)
    FERRITE BEAD 19 OHM 1206 1LN
HF30ACC321611-T 数据手册
E M C C o m p o n e n t s July 2016 Chip beads For power line HF-ACC series HFxxACC3216 HFxxACC3216 [1206 inch]* * Dimensions code JIS[EIA] Type (2/8) E M C C o m p o n e n t s Reminders for using these products Before using these products, be sure to request the delivery specifications. Safety reminders Please pay sufficient attention to the warnings for safe designing when using this products. Reminders The storage period is less than 12 months.Be sure to follow the storage conditions (temperature:5 to 40°C, humidity:10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. 20160722 / beads_commercial_power_hfxxacc3216_en.fm (3/8) E M C C o m p o n e n t s Product compatible with RoHS directive Halogen-free Compatible with lead-free solders Chip beads For power line Overview of HFxxACC3216 type FEATURES Noise reduction solution for power line. Achieves various frequency characteristics by using 3 materials with different features. There is no directivity. APPLICATION Power line noise removal for DSCs, DVCs, PCs, TVs, printers, game machines, smart grids, wireless base stations, industrial equipment PART NUMBER CONSTRUCTION HF70 ACC Material name Series name HF70 HF50 HF30 321611 - L×W×T dimensions (mm) 321611 3.2×1.6×1.1 T Packaging style T Taping OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT Temperature ranges Operating Storage temperature temperature (°C) (°C) HFxxACC3216 –40 to +125 –40 to +125 The storage temperature range is for after the circuit board is mounted. Package quantity Individual weight (pieces/reel) 2,000 (mg) 22 Type RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html Halogen-free: indicates that Cl content is less than 900ppm, Br content is less than 900ppm, and that the total Cl and Br content is less than 1500ppm. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160722 / beads_commercial_power_hfxxacc3216_en.fm (4/8) E M C C o m p o n e n t s HFxxACC3216 type RECOMMENDED REFLOW PROFILE Preheating Soldering Natural cooling Peak T: Temperature T4 T3 T2 T3 t3 T1 t1 t2 t: Time Preheating Temp. T1 T2 150°C 180°C Time t1 60 to 120s Soldering Temp. Time T3 t2 230°C 30 to 60s Peak Temp. T4 250 to 260°C Time t3 10s Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160722 / beads_commercial_power_hfxxacc3216_en.fm (5/8) E M C C o m p o n e n t s HFxxACC3216 type SHAPE & DIMENSIONS 3.20±0.20 1.10±0.20 Terminal electrode 1.60±0.20 Ferrite 0.30±0.20 0.30±0.20 Insulation resin Dimensions in mm 1.4 RECOMMENDED LAND PATTERN 1.1 2.2 1.1 Dimensions in mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160722 / beads_commercial_power_hfxxacc3216_en.fm (6/8) E M C C o m p o n e n t s HFxxACC3216 type ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE Impedance [100MHz] ( ) 26 31 19 Tolerance ±25% ±25% ±25% DC resistance Rated current Part No. ( )max. 0.04 0.04 0.04 (A)max. 1.5 1.5 1.5 HF70ACC321611-T HF50ACC321611-T HF30ACC321611-T Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160722 / beads_commercial_power_hfxxacc3216_en.fm (7/8) E M C C o m p o n e n t s HFxxACC3216 type ELECTRICAL CHARACTERISTICS Z, X, R VS. FREQUENCY CHARACTERISTICS HF70ACC321611 HF50ACC321611 100 Z 10 100 Z 10 X 100 Z X 10 X R 1 1 1000 Z, X, R (Ω) 1000 Z, X, R (Ω) Z, X, R (Ω) 1000 HF30ACC321611 10 100 Frequency (MHz) 1000 1 1 R R 10 100 Frequency (MHz) 1000 1 1 10 100 1000 Frequency (MHz) Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160722 / beads_commercial_power_hfxxacc3216_en.fm (8/8) E M C C o m p o n e n t s HFxxACC3216 type PACKAGING STYLE REEL DIMENSIONS 2.0±0.5 W1 8.4+2.0/–0.0 W2 14.4max. N ø60min. N Type HFxxACC3216 1.0 ø13±0.2 W1 ø21±0.8 W2 ø180±2.0 Dimensions in mm 4.0±0.1 t B W 2.0±0.05 F 1.5 +0.1 0 1.75±0.1 TAPE DIMENSIONS A P1 K Dimensions in mm Type HFxxACC3216 40 to 80 A 1.75±0.1 Taping B 3.45±0.1 F 3.5±0.05 P1 4.0±0.1 W 8.0±0.3 K 1.4max. t 0.3max. 440min. Drawing direction Dimensions in mm 500 to 560 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160722 / beads_commercial_power_hfxxacc3216_en.fm
HF30ACC321611-T 价格&库存
很抱歉,暂时无法提供与“HF30ACC321611-T”相匹配的价格&库存,您可以联系我们找货
