HFE1600-48
HFE1600-48
    TDK(东电化)
    1600W 1U前端工业电源模块
HFE1600-48 数据手册
HFE1600 Series https://product.tdk.com/en/power/hfe 1600W 1U Front End Power Supplies www.emea.lambda.tdk.com/uk/products/hfe The HFE1600 AC-DC industrial power supplies can be operated in a hot-swap redundant configuration, or used to provide up to 7,600W of bulk power. Up to five power supplies can be fitted in a variety of 19” 1U high racks, for configuration as a single or dual output. The HFE supplies have internal ORing MOSFETs and current share for automatic parallel operation. Communication is possible with the power supplies using the optional isolated PMBus™ (I2C) interface or a plug-in LAN module. AC fail, DC good, remote output adjust, remote on/off and a 12V auxiliary output are fitted as standard. Features Benefits • Internal ORing MOSFET and Current Share • Suitable For N+1 Redundancy • Up to 7600W in 1U Rack • Utilizes Less System Space • Full Array of Signals Available • Easy Remote Monitoring • PMBusTM (I2C) and LAN options • Industry Standard Communication Interfaces • Analog Output Adjustment • Simple External Resistance or Voltage Connection Model Selector Model HFE1600-12 HFE1600-24 HFE1600-32 HFE1600-48 Output Adjustment Max Current (A) Voltage (V) Range (V)(1) (Vin>170Vac) 12 24 32 48 9.6 - 13.2 19.2 - 29 25.6 - 38.4 38.4 - 58 HFE1600- Max Power (W) (Vin>170Vac) Max Current (A) (100100 at 25°C, 70%RH & Output to Ground 500Vdc Vibration (Non-operating) - Meets IEC60068-2-64 (Basic Transportation) Shock (Non-operating) - Meets IEC60068-2-27 (Basic Transportation) Other Weight (Typ) g Power Supply: 1550, Rack: 4800 Size (LxWxH) mm Power Supply: 300 x 85 x 41; Rack: 365 x 445 x 43.6 Size (LxWxH) Inches Power Supply: 11.8 x 3.35 x 1.61; Rack: 14.4 x 17.5 x 1.72 TM 2 PMBus / I C Interface (1) - Isolated from output, Add suffix /S, PMBusTM compatible MTBF - Telcordia Hours 210,143 Warranty Years Three Notes (1) See installation manual for detailed specifications and test methods (2) Derate output power linearly1%/V from 100Vac to 85Vac input (3) Reverse air - contact factory (4) At 75% load, 115 / 230Vac input HFE1600 Series 3 Outline Drawing HFE1600 Outline Drawing HFE1600-S1U 4 HFE1600 Series Outline Drawing HFE1600-S1U-TB Outline Drawing HFE1600-D1U HFE1600 Series 5 Outline Drawing HFE1600-D1U-TB Outline Drawing HFE1600-LAN 6 HFE1600 Series TDK-Lambda France SAS TDK-Lambda Americas Tel: +33 1 60 12 71 65 france@fr.tdk-lambda.com Tel: +1 800-LAMBDA-4 or 1-800-526-2324 powersolutions@us.tdk-lambda.com www.us.lambda.tdk.com www.emea.lambda.tdk.com/fr Italy Sales Office Tel: +39 02 61 29 38 63 info.italia@it.tdk-lambda.com www.emea.lambda.tdk.com/it TDK Electronics do Brasil Ltda Tel: +55 11 3289-9599 sales.br@tdk-electronics.tdk.com www.tdk-electronics.tdk.com/en Netherlands info@nl.tdk-lambda.com www.emea.lambda.tdk.com/nl TDK-Lambda Germany GmbH Tel: +49 7841 666 0 info@de.tdk-lambda.com www.emea.lambda.tdk.com/de TDK-Lambda Corporation Tel: +81-3-6778-1113 www.jp.lambda.tdk.com TDK-Lambda (China) Electronics Co. Ltd. Tel: +86 21 6485-0777 powersolutions@cn.tdk-lambda.com www.lambda.tdk.com.cn TDK-Lambda Singapore Pte Ltd. Tel: +65 6251 7211 tls.mkt@sg.tdk-lambda.com www.sg.lambda.tdk.com Austria Sales Office Tel: +43 2256 655 84 info@at.tdk-lambda.com www.emea.lambda.tdk.com/at TDK India Private Limited, Power Supply Division Switzerland Sales Office Tel: +91 80 4039-0660 mathew.philip@in.tdk-lambda.com www.sg.lambda.tdk.com Tel: +41 44 850 53 53 info@ch.tdk-lambda.com www.emea.lambda.tdk.com/ch Nordic Sales Office Tel: +45 8853 8086 info@dk.tdk-lambda.com www.emea.lambda.tdk.com/dk TDK-Lambda UK Ltd. Tel: +44 (0) 12 71 85 66 66 info@uk.tdk-lambda.com www.emea.lambda.tdk.com/uk TDK-Lambda Ltd. Tel: +9 723 902 4333 info@tdk-lambda.co.il www.emea.lambda.tdk.com/il C.I.S. Commercial Support: Tel: +7 (495) 665 2627 Technical Support: Tel: +7 (812) 658 0463 info@tdk-lambda.ru www.emea.lambda.tdk.com/ru For Additional Information, please visit https://product.tdk.com/en/power/ HFE1600_Datasheet_ 260824 February 9th, 2022 v2 HFE1600 Series 7
HFE1600-48 价格&库存
很抱歉,暂时无法提供与“HFE1600-48”相匹配的价格&库存,您可以联系我们找货
