HFE2500-24/S
HFE2500-24/S
    TDK(东电化)
    Module
    前端 AC DC 转换器 1 输出 24V 85 ~ 265 VAC 输入
HFE2500-24/S 数据手册
HFE2500 Series https://product.tdk.com/en/power/hfe 2500W 1U Front End Power Supplies www.emea.lambda.tdk.com/uk/products/hfe The HFE2500 AC-DC industrial power supplies can be operated in a hot-swap redundant configuration, or used to provide up to 9,500W of bulk power. Up to four power supplies can be fitted in a variety of 19” 1U high racks, for configuration as a single output. The HFE supplies have internal ORing MOSFETs and current share for automatic parallel operation. Communication is possible with the power supplies using the optional isolated PMBus™ (I2C) interface or a plug-in LAN module. AC fail, DC good, remote output adjust, remote on/off and a 12V auxiliary output are fitted as standard. Features Benefits • Internal ORing MOSFET and Current Share • Suitable For N+1 Redundancy • Up to 9500W in 1U Rack • Utilizes Less System Space • Full Array of Signals Available • Easy Remote Monitoring • PMBusTM (I2C) and LAN options • Industry Standard Communication Interfaces • Analog Output Adjustment • Simple External Resistance or Voltage Connection Model Selector Model HFE2500-12 HFE2500-24 HFE2500-48 Output Adjustment Max Current (A) Voltage (V) Range (V)(1) (Vin>180Vac) 12 24 48 9.6 - 13.2 19.2 - 29 38.4V - 58 HFE2500- Max Power (W) (Vin>180Vac) Max Current (A) (100
HFE2500-24/S 价格&库存
很抱歉,暂时无法提供与“HFE2500-24/S”相匹配的价格&库存,您可以联系我们找货
