P
Data Sheet
PRODUCTS
HLP-3003C Hybrid Log Periodic Antenna
Product Overview
Ultra Wide Range The TDK HLP-3003C Hybrid
Log Periodic Antenna is an extended frequency
broadband antenna intended for measurements in
an anechoic chamber, open area test site, or in
situ. Its 30 MHz to 3 GHz range makes it especially suited for wideband testing of radiated emissions from electrical and electronic equipment. This
new design offers unequaled performance over
this range for an antenna of this form factor.
High Performance/Compact Size The HLP3003C uses a unique low frequency hybrid element to extend the low frequency performance
while maintaining a compact size. The low frequency elements of the antenna are removable for
convenient storage. The HLP-3003C fits easily into
an optional carrying case for portability between
test sites. The antenna can be mounted on a conventional tripod or antenna tower.
Features
Efficient design especially suited for compact
chambers
Shortest antenna length available for the operating frequency range
Unique low frequency hybrid element extends
performance
Moderate power handling capability
Individually calibrated according to ANSI
C63.5, with signed certificate of calibration
The TDK HLP-3003C Hybrid Log Periodic antenna offers unequaled performance over the
ultra wide frequency range of 30 MHz to 3
GHz and an efficient, compact design.
Applications
Immunity and Emissions testing
Anechoic chamber, OATS, in situ testing
Options
MVM-200R Manual Vertical Mast
TRI-150R Tripod
AM-PIVOT-HLP Pivot mount for use on tripod
HLP-CC Carrying Case
1101 Cypress Creek Road Cedar Park, Texas 78613, USA 1-512-258-9478 FAX 1-512-258-0740
P
PRODUCTS
Antenna Data
Mechanical Specifications
Overall Dimensions:
Width:
156 cm (61.5 in.)
Depth:
71 cm (28 in.)
Height:
69 cm (27 in.)
Weight:
3.6 kg (8 lbs.)
Construction:
Aluminum with gold
chromate finish
RF Connector:
Type N female
Electrical Characteristics
Ordering Information
Frequency Range:
30 MHz to 3 GHz
Product:
Gain:
6 dBi typical
Hybrid Periodic Log
Antenna
VSWR:
2:1 average
Model Number:
HLP-3003C
Polarization:
Linear
Warranty:
1 year limited
Power Handling:
100 W
Input Impedance:
50 ohms nominal
To place an order or to learn more about the
TDK products that best meet your needs, contact your TDK sales representative:
TDK RF Solutions Inc.
1101 Cypress Creek Rd.
Cedar Park, Texas 78613 USA
Phone:
1-512-258-9478
Fax:
1-512-258-0740
E-mail:
info@tdkrf.com
World Wide Web:
www.tdkrfsolutions.com
T O T A L I R F
S
SYSTEMS
C
CHAMBERS
E X P E R T I S E ™
P
PRODUCTS
SW TS
SOFTWARE
TEST SERVICES
To learn more about TDK’s wide range of innovative test products, solutions and services visit www.tdkrfsolutions.com
Copyright © TDK RF Solutions Inc. All rights reserved. Specifications subject to change without notice.
Rev. 2011-08-02
很抱歉,暂时无法提供与“HLP-3003C”相匹配的价格&库存,您可以联系我们找货
