HSC-12-3.4
HSC-12-3.4
    TDK(东电化)
    AC/DC CONVERTER 12V 40W
HSC-12-3.4 数据手册
H Series Low Cost Linear Power Supplies Features u Low Output Ripple u Single and Multiple Outputs u Excellent Line & Load Regulation u Worldwide Voltage Taps u Industry standard footprint u Operation up to 70C Ambients Key Market Segments & Applications u Test & Measurement Burn-in & Test, Automated Test, Instrumentation, Measurement, Detection u Low noise applications u Light Industrial Specifications Model AC Input Efficiency Transient Response EMI Output Adjustment Remote Sense Line Regulation Load Regulation Ripple and Noise Overcurrent Protection Overvoltage Protection n 50A - Cooling Operating Temp. Range Storage Temperature Temperature coefficient Humidity Leakage Current Vibration Shock Safety Agency Approval Size Warranty °C uA - 100/120/220/230/240VAC, 47-63Hz (derate by 10% for 50Hz operation) 5V: 45%, 12/15V: 55%, 24V: 60% 50us for 50% load change FCC Class B, VDE0871 Level B ±5% for all outputs (except outputs 2 & 3 on triple output models) On all single output models, HDC12 & HDC15, and output 1 of triple output models ±0.05% for 10% line change ±0.05% for 50% load change
HSC-12-3.4
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光隔离集成电路。
2. 器件简介:EL817是一种光隔离集成电路,用于实现电气隔离的串行数据通信。
3. 引脚分配:EL817有8个引脚,包括Vcc、GND、输入、输出和光隔离引脚。
4. 参数特性:工作电压范围为3.3V至5.5V,数据传输速率可达20Mbps。
5. 功能详解:EL817内部包含光发射器和光接收器,实现高速光隔离通信。
6. 应用信息:适用于工业控制系统、医疗设备等需要电气隔离的场合。
7. 封装信息:采用DIP-8封装形式。
HSC-12-3.4 价格&库存
很抱歉,暂时无法提供与“HSC-12-3.4”相匹配的价格&库存,您可以联系我们找货
