HWS300-1500 Series
https://product.tdk.com/en/power/hws
www.emea.lambda.tdk.com/hws
300-1500W Single Output Industrial Power Supplies
The ultra reliable, conservatively rated HWS series of 300W to 1500W AC-DC power supplies has a limited lifetime warranty, unique to the industry. The series accepts
a wide range 85 to 265Vac input with output voltages from 3.3V to 48V. The products are certified to IEC 62368-1, UL 508 (select models) and are SEMI F47 compliant.
They also meet conducted and radiated emission standards without additional filtering or shielding.
Features
Benefits
• Limited Lifetime Warranty
• Low Cost of Ownership
• Very Conservative Electrolytic Capacitor Ratings
• Long Service Life
• Class B Conducted and Radiated EMI
• Easier System EMC Compliance
• UL 508 Certified on Select Models
• Suitable For Industrial Control Equipment
Model Selector
Model
HWS300-3
HWS600-3
HWS1000-3
HWS1500-3
HWS300-5
HWS600-5
HWS1000-5
HWS1500-5
HWS1000-6
HWS1500-6
HWS1000-7
HWS1500-7
HWS300-12
HWS600-12
HWS1000-12
HWS1500-12
HWS300-15
HWS600-15
HWS1000-15
HWS1500-15
HWS300-24
HWS600-24
HWS1000-24
HWS1500-24
HWS1000-36
HWS1500-36
HWS300-48
HWS600-48
HWS1000-48
HWS1500-48
HWS1000-60
HWS1500-60
Output
Voltage
(V)
Adjustment
Range
(V)
Maximum
Current
(A)
Peak
Current
(A) (1)
Load
Reg
(mV)
Line
Reg
(mV)
3.3
3.3
3.3
3.3
5
5
5
5
6
6
7.5
7.5
12
12
12
12
15
15
15
15
24
24
24
24
36
36
48
48
48
48
60
60
2.64 - 3.96
2.64 - 3.96
2.64 - 3.96
2.64 - 3.96
4.0 - 6.0
4.0 - 6.0
4.0 - 6.0
4.0 - 6.0
4.8 - 7.2
4.8 - 7.2
6.0 - 9.0
6.0 - 9.0
9.6 - 14.4
9.6 - 14.4
9.6 - 14.4
9.6 - 14.4
12.0 - 18.0
12.0 - 18.0
12.0 - 18.0
12.0 - 18.0
19.2 - 28.8
19.2 - 28.8
19.2 - 28.8
19.2 - 28.8
28.8 - 43.2
28.8 - 43.2
38.4 - 52.8
38.4 - 52.8
38.4 - 52.8
38.4 - 52.8
48.0 - 66.0
48.0 - 66.0
60
120
200
300
60
120
200
300
167
250
134
200
27
53
88
125
22
43
70
100
14
27
44
65/70(2)
29.3
42/46.5(2)
7
13
22
32
17.6
25.6/28(2)
300
160
240
100
80
16.5
31
50
105
33.3
70
25
30
30
40
60
30
30
40
60
60
60
60
60
96
96
100
72
120
120
120
90
192
192
150
144
150
150
384
384
300
288
360
360
36
36
36
40
48
48
48
48
60
60
60
60
96
96
96
96
144
144
192
192
192
192
240
240
HWS300-1500 Series
Ripple
Noise
Overvoltage
(mV)
(V)
120
120
120
150
120
120
120
150
150
150
150
150
120
120
150
150
150
150
150
150
150
150
150
200
200
200
200
200
200
200
400
400
4.13 - 4.95
4.13 - 4.95
4.13 - 4.95
4.12 - 4.95
6.25 - 7.25
6.25 - 7.25
6.25 - 7.0
6.25 - 7.0
7.5 - 8.4
7.5 - 8.4
9.38 - 10.5
9.37 - 10.5
15.0 - 17.4
15.0 - 17.4
15.0 - 17.4
15.0 - 17.4
18.8 - 21.8
18.8 - 21.8
18.8 - 21.8
18.7 - 21.8
30.0 - 34.8
30.0 - 34.8
30.0 - 34.8
30.0 - 34.8
45.0 - 49.7
45.0 - 49.7
55.2 - 64.8
55.2 - 64.8
55.2 - 64.8
55.2 - 64.8
69.0 - 75.0
69.0 - 75.0
Efficiency
(115/230Vac)
74 / 77
75 / 78
71 / 73
72 / 75
79 / 82
80 / 83
76 / 78
77 / 81
79 / 81
79 / 82
80 / 82
81 / 83
80 / 83
80 / 83
83 / 85
82 / 85
82 / 85
82 / 85
83 / 85
83 / 87
82 / 85
82 / 85
85 / 87
84 / 88
85 / 88
84 / 88
82 / 85
82 / 85
86 / 88
86 / 90
85 / 88
86 / 90
1
HWS
Series
300 -
Nominal power level
and product size
3
Output voltage
3 (3.3V), 5, 6, 7 (7.5)
12, 15, 24, 36, 48, 60
blank
/A
/PV
/HD
/ME
No options
Not applicable. The HWS300-1500 models
have a cover fitted as standard
1 to 6V output program voltage for
HWS300, 600. Standard on HWS1000 & 1500
See HWS/HD datasheet for details.
-40°C start-up & pcb coating
See HWS/ME datasheet for details.
IEC60601-1 medical certification
Specifications
Model
HWS300
HWS600
HWS1000
HWS1500
Input
AC Input Voltage Range
Vac
85 - 265
Input Frequency
Hz
47 - 63
DC Input Voltage range(3)
Vdc
120 - 330
Input Current (100/200Vac)(4)
A
5V: 3.8/1.9;
5V: 7.5/3.6;
3.3V: 9.6/5.0;
3.3V: 15.0/8.0
12-48V: 4.2/2.1
12-48V: 8.1/3.9
5-60V: 13.5/7.0
5-60V: 19.5/10.0
Inrush Current (100/200Vac)
A 20 / 40 (Typical at cold start)
Leakage Current (240Vac, 60Hz)
mA
100 at 25°C, 70%RH & 500Vdc
Vibration (Non-operating)
10-55Hz (Sweep for 1min.), 19.6m/s2 Constant X,Y,Z 1 hour each
Shock (Non-operating)
Less than 196m/s2
Other
Weight (Typ)
g
1,000
1,600
3,200
4,000 (
很抱歉,暂时无法提供与“HWS1000-15”相匹配的价格&库存,您可以联系我们找货
