HWS1000-24
HWS1000-24
    TDK(东电化)
    HWS1000-24
HWS1000-24 数据手册
HWS300-1500 Series https://product.tdk.com/en/power/hws www.emea.lambda.tdk.com/hws 300-1500W Single Output Industrial Power Supplies The ultra reliable, conservatively rated HWS series of 300W to 1500W AC-DC power supplies has a limited lifetime warranty, unique to the industry. The series accepts a wide range 85 to 265Vac input with output voltages from 3.3V to 48V. The products are certified to IEC 62368-1, UL 508 (select models) and are SEMI F47 compliant. They also meet conducted and radiated emission standards without additional filtering or shielding. Features Benefits • Limited Lifetime Warranty • Low Cost of Ownership • Very Conservative Electrolytic Capacitor Ratings • Long Service Life • Class B Conducted and Radiated EMI • Easier System EMC Compliance • UL 508 Certified on Select Models • Suitable For Industrial Control Equipment Model Selector Model HWS300-3 HWS600-3 HWS1000-3 HWS1500-3 HWS300-5 HWS600-5 HWS1000-5 HWS1500-5 HWS1000-6 HWS1500-6 HWS1000-7 HWS1500-7 HWS300-12 HWS600-12 HWS1000-12 HWS1500-12 HWS300-15 HWS600-15 HWS1000-15 HWS1500-15 HWS300-24 HWS600-24 HWS1000-24 HWS1500-24 HWS1000-36 HWS1500-36 HWS300-48 HWS600-48 HWS1000-48 HWS1500-48 HWS1000-60 HWS1500-60 Output Voltage (V) Adjustment Range (V) Maximum Current (A) Peak Current (A) (1) Load Reg (mV) Line Reg (mV) 3.3 3.3 3.3 3.3 5 5 5 5 6 6 7.5 7.5 12 12 12 12 15 15 15 15 24 24 24 24 36 36 48 48 48 48 60 60 2.64 - 3.96 2.64 - 3.96 2.64 - 3.96 2.64 - 3.96 4.0 - 6.0 4.0 - 6.0 4.0 - 6.0 4.0 - 6.0 4.8 - 7.2 4.8 - 7.2 6.0 - 9.0 6.0 - 9.0 9.6 - 14.4 9.6 - 14.4 9.6 - 14.4 9.6 - 14.4 12.0 - 18.0 12.0 - 18.0 12.0 - 18.0 12.0 - 18.0 19.2 - 28.8 19.2 - 28.8 19.2 - 28.8 19.2 - 28.8 28.8 - 43.2 28.8 - 43.2 38.4 - 52.8 38.4 - 52.8 38.4 - 52.8 38.4 - 52.8 48.0 - 66.0 48.0 - 66.0 60 120 200 300 60 120 200 300 167 250 134 200 27 53 88 125 22 43 70 100 14 27 44 65/70(2) 29.3 42/46.5(2) 7 13 22 32 17.6 25.6/28(2) - - - - - - - - - 300 160 240 - - 100 - - - 80 - 16.5 31 50 105 33.3 70 - - 25 - 20 42 30 30 40 60 30 30 40 60 60 60 60 60 96 96 100 72 120 120 120 90 192 192 150 144 150 150 384 384 300 288 360 360 20 20 20 36 20 20 20 36 36 36 36 40 48 48 48 48 60 60 60 60 96 96 96 96 144 144 192 192 192 192 240 240 HWS300-1500 Series Ripple Noise Overvoltage (mV) (V) 120 120 120 150 120 120 120 150 150 150 150 150 120 120 150 150 150 150 150 150 150 150 150 200 200 200 200 200 200 200 400 400 4.13 - 4.95 4.13 - 4.95 4.13 - 4.95 4.12 - 4.95 6.25 - 7.25 6.25 - 7.25 6.25 - 7.0 6.25 - 7.0 7.5 - 8.4 7.5 - 8.4 9.38 - 10.5 9.37 - 10.5 15.0 - 17.4 15.0 - 17.4 15.0 - 17.4 15.0 - 17.4 18.8 - 21.8 18.8 - 21.8 18.8 - 21.8 18.7 - 21.8 30.0 - 34.8 30.0 - 34.8 30.0 - 34.8 30.0 - 34.8 45.0 - 49.7 45.0 - 49.7 55.2 - 64.8 55.2 - 64.8 55.2 - 64.8 55.2 - 64.8 69.0 - 75.0 69.0 - 75.0 Efficiency (115/230Vac) (%) 74 / 77 75 / 78 71 / 73 72 / 75 79 / 82 80 / 83 76 / 78 77 / 81 79 / 81 79 / 82 80 / 82 81 / 83 80 / 83 80 / 83 83 / 85 82 / 85 82 / 85 82 / 85 83 / 85 83 / 87 82 / 85 82 / 85 85 / 87 84 / 88 85 / 88 84 / 88 82 / 85 82 / 85 86 / 88 86 / 90 85 / 88 86 / 90 1 HWS Series 300 - Nominal power level and product size 3 / Output voltage 3 (3.3V), 5, 6, 7 (7.5) 12, 15, 24, 36, 48, 60 blank /A /PV /HD /ME No options Not applicable. The HWS300-1500 models have a cover fitted as standard 1 to 6V output program voltage for HWS300, 600. Standard on HWS1000 & 1500 See HWS/HD datasheet for details. -40°C start-up & pcb coating See HWS/ME datasheet for details. IEC60601-1 medical certification Specifications Model HWS300 HWS600 HWS1000 HWS1500 Input AC Input Voltage Range Vac 85 - 265 Input Frequency Hz 47 - 63 DC Input Voltage range(3) Vdc 120 - 330 Input Current (100/200Vac)(4) A 5V: 3.8/1.9; 5V: 7.5/3.6; 3.3V: 9.6/5.0; 3.3V: 15.0/8.0 12-48V: 4.2/2.1 12-48V: 8.1/3.9 5-60V: 13.5/7.0 5-60V: 19.5/10.0 Inrush Current (100/200Vac) A 20 / 40 (Typical at cold start) Leakage Current (240Vac, 60Hz) mA 100 at 25°C, 70%RH & 500Vdc Vibration (Non-operating) - 10-55Hz (Sweep for 1min.), 19.6m/s2 Constant X,Y,Z 1 hour each Shock (Non-operating) - Less than 196m/s2 Other Weight (Typ) g 1,000 1,600 3,200 4,000 (
HWS1000-24 价格&库存
很抱歉,暂时无法提供与“HWS1000-24”相匹配的价格&库存,您可以联系我们找货
