HWS1000-36/HD
HWS1000-36/HD
    TDK(东电化)
    HWS1000-36/HD
HWS1000-36/HD 数据手册
TDK-Lambda HWS1000/HD SPECIFICATIONS DA032-01-01/HD-I HWS1000 HWS1000 HWS1000 HWS1000 HWS1000 HWS1000 HWS1000 HWS1000 HWS1000 HWS1000 -3/HD -5/HD -6/HD -7/HD -12/HD -15/HD -24/HD -36/HD -48/HD -60/HD V 3.3 5 6 7.5 12 15 24 36 48 60 A 200 200 167 134 88 70 46 30.7 23 18.4 A - - - 160 100 80 58.5 39 29.2 23.4 W 660 1000 1002 1005 1056 1050 1104 1104 1104 1104 *3. First in-rush current. Not applicable to the first 0.2ms in-rush current flowing into the power supply noise filter. *4. Measure with JEITA RC-9131A probe, Bandwidth of scope :100MHz. MODEL ITEMS 1 Nominal Output Voltage 2 Maximum Output Current 3 Peak output Current (*13) 4 Maximum Output Power 5 6 Peak Output Power (*13) Efficiency (Typ) (*1) at 200VAC W - - - 1200 1200 1200 1404 1404 1404 1404 at 100VAC % 71 76 79 80 82 83 85 85 86 85 at 200VAC % 73 78 81 82 85 85 87 88 88 88 at 200VAC 7 Input Voltage Range (*2) - 8 Input Current (100/200VAC)(Typ) (*1) A 9 Inrush Current (100/200VAC)(Typ) (*3) A 20/40 10 PFHC - Designed to meet IEC6100-3-2 11 Power Factor (100/200VAC)(Typ) - 12 13 0.98/0.95 9.6-14.4 12.0-18.0 Maximum Ripple & Noise (*1) 85 - 265VAC (47 - 63Hz) or 120 - 330VDC 13.5/7.0 9.6/5.0 *Read instruction manual carefully, before using the power supply unit. =NOTES= *1. At Ta=25°C and maximum output power. *2. For cases where conformance to various safety specs (UL, CSA,EN) are required, input voltage range will be 100 - 240VAC (50/60Hz). (at 100uF electric capacitor and 0.47uF film capacitor on the test fixture board.) *5. 85 - 265VAC , constant load. *6. No load-Full load, constant input voltage. *7. Constant current limit with automatic recovery. Over current condition for more than 5 seconds will cause the output to shutdown. Output current exceeding maximum rated output current for more than 10 seconds continuously will result to output shutdown. 2.64-3.96 4.0-6.0 4.8-7.2 6.0-9.0 19.2-28.8 28.8-43.2 38.4-52.8 48.0-66.0 0 - +71°C mV 120 120 150 150 150 150 150 200 200 400 -10 - 0°C mV 160 160 180 180 180 180 180 240 500 600 Maximum Line Regulation (*5) mV 20 20 36 36 48 60 96 144 192 240 15 Maximum Load Regulation (*6) mV 40 40 60 60 100 120 150 150 300 360 16 Temperature Coefficient 17 Over Current Protection (*7) - 18 Over Voltage Protection (*8) V 19 Hold-up Time (Typ) (*9) - 20ms 20 Leakage Current (*10) - 1.2mA MAX at 100VAC / 240VAC 21 Remote Sensing - Possible *12. As for DENAN, designed to meet at 100VAC. 22 Remote ON/OFF control - Possible 23 Monitoring Signal - PF(Open Collector Output) *13. Peak output current is less than 10 seconds, and duty 35% max.(200VAC Line only) *14. Category 4 exposure levels : Truck transportation over U.S. highways. 24 Output Voltage External Control - Possible 25 Parallel Operation - Possible 26 Series Operation - 27 Operating Temperature Possible -10 - + 71°C, Guarantee Start up -40 - -10°C Output Voltage Range V (*4) 14 - (*11) Less than 0.02% / °C 105% - (Peak Output Current) 105% - (Maximum Output Current) 4.12-4.62 6.25-7.0 - 7.5-8.4 9.37-10.5 15.0-17.4 18.7-21.8 30.0-34.8 45.0-49.7 +50°C % 83.9 +71°C % 50 *11. Ratings - Derating at standard mounting. 55.2-60.0 100 50 29 Storage Temperature - -40 - +85°C 30 Storage Humidity - 10 - 95%RH (No Condensing) 10 - 90%RH (No Condensing) 31 Cooling - Forced Air By Blower Fan 32 Withstand Voltage - Input - FG : 2kVAC (20mA), Input - Output : 3kVAC (20mA) 33 Isolation Resistance - 34 Vibration Output - FG : 500VAC (300mA), (60V model 651VAC(390mA)), Output - CNT:100VAC (100mA) for 1min. More than 100Mohm Output - FG ... 500VDC More than 10Mohm Output - CNT ... 100VDC at 25°C and 70%RH At no operating, 10 - 55Hz (Sweep for 1min.) 19.6m/s2 Constant, X,Y,Z 1h each. Designed to meet MIL-STD-810F 514.5 Category 4 figure 514.5C-1, category 10 35 Shock (In package) (*15) - Less than 196.1m/s2 Designed to meet MIL-STD-810F 516.5 Procedure I 36 Safety (*12) - Approved by UL62368-1, CSA62368-1, EN62368-1, UL60950-1, CSA60950-1, EN60950-1 (Expire date of 60950-1 : 20/12/2020), EN50178. Designed to meet DENAN. 37 Line DIP - - Load (%) is percent of maximum output power or maximum output current,whichever is greater. - For conditions of start up at -40°C - -10°C, refer to derating curve ( DA032-01-03/HD-_ ). and MIL-STD-810F 516.5. Refer to DA032-01-04/HD-_. - (*15) 69.0-75.0 *15. It is compulsory to fix BRACKET onto product for MIL-STD-810F 514.5 Operating Humidity - *9. At 100/200VAC, nominal output voltage and maximum output current. - As for other mountings, refer to derating curve ( DA032-01-02/HD-_ ). 28 (*14) maximum output current or more with 100VAC input line. *8. OVP circuit will shut down output, manual reset (Power cycle) or ON/OFF CNT signal reset. *10. Measured by the each measuring method of UL, CSA, EN and DENAN (at 60Hz), Ta=25°C. 100 -10 - +40°C % For peak current capable model, over current protection triggers at 105% of Designed to meet SEMI-F47 (200VAC Line only) 38 Conducted Emission - Designed to meet EN55011/EN55032-B, FCC-ClassB, VCCI-ClassB, CISPR-ClassB. 39 Radiated Emission - 40 Immunity - Designed to meet EN55011/EN55032-B, FCC-ClassB, VCCI-ClassB, CISPR-ClassB. Designed to meet IEC61000-4-2(Level 2,3), -3(Level 3), -4(Level 3), 41 Weight g MAX 3200 42 Size (W x H x D) mm 126.5 x 82 x 240 ( Refer to Outline Drawing ) 43 Other - PCB Coating on solder side and component side. -5(Level 3,4), -6(Level 3), -8(Level 4), -11 TDK-Lambda HWS1000/HD DA032-01-02/HD OUTPUT DERATING 3, 5V Ta(°C) 6-60V Ta(°C) LOAD(%) MOUNTING A,B,C,D -10 ~+40 -10 ~+50 85V 80 90V~ 100 71 71 40 50 OUTPUT DERATING CURVE 85V 100 90V~ 85V(3, 5V model) LOAD(%) 80 90V~(3, 5V model) 60 40 20 0 -10 0 10 20 30 40 50 60 70 80 Ta(°C) MOUNTING A MOUNTING B MOUNTING C (STANDARD MOUNTING) MOUNTING D Inhibit TDK-Lambda HWS1000/HD DA032-01-03/HD-A OUTPUT DERATING FOR START UP GUARANTEE LOAD(%) MOUNTING A,B,C,D Ta(°C) -40 ~-20 85V 40 90V~ 40 -20 80 100 -10 80 100 OUTPUT DERATING CURVE 120 100 LOAD(%) 80 85V 60 90V~ 40 20 0 -50 -40 -30 Ta(°C) ==NOTES== *1. Input voltage : Not gradual start up. *2. No condensing. -20 -10 TDK-Lambda HWS1000/HD DA032-01-04/HD-A POWER SUPPLY MOUNTING FOR MIL-STD When MIL vibration(MIL-STD-810F 514.5 Category 4 figure 514.5C-1, Category 10) & MIL shock(MIL-STD-810F 516.5 Procedure I) specification is necessary, mount the power supply using the BRACKET or equivalent. Fix one set of BRACKET to the power supply with sixteen M4 screws when mounting the power supply. Two pieces of BRACKET is considered as one set. The M4 screw is 8mm in length, washer and spring washer are also required. Screw must not penetrate into power supply by more than 6mm. 8pcs of M4x8 SEMS SCREW is used on both sides which total up to 16pcs. 16-M4x8 SEMS SCREW BRACKET QTY : 2pcs
HWS1000-36/HD 价格&库存
很抱歉,暂时无法提供与“HWS1000-36/HD”相匹配的价格&库存,您可以联系我们找货
