HWS15A-5/A
HWS15A-5/A
    TDK(东电化)
    HWS15A-5/A
HWS15A-5/A 数据手册
HWS15A-150A Series https://product.tdk.com/en/power/hws-a 10-150W Single Output Industrial Power Supplies www.emea.lambda.tdk.com/hws-a The ultra reliable, conservatively rated HWS-A series of 10W to 150W AC-DC power supplies has a limited lifetime warranty (1), unique to the industry. The series accepts a wide range 85 to 265Vac (300Vac peak for 5s) input with output voltages from 3.3V to 48V. The products are certified to IEC 62368-1, UL 508 and EN 62477-1 OVC III (HWS150A) and are SEMI F47 compliant . They also meet Class B conducted and radiated emissions without additional filtering or shielding. Features Benefits • Limited Lifetime Warranty • Low Cost of Ownership (1) • Very Conservative Electrolytic Capacitor Ratings • Long Service Life • Class B Conducted and Radiated EMI • Easier System EMC Compliance • Low Off-Load Power Consumption • Energy Saving • UL 508 Certified • Suitable For Industrial Control Equipment Model Selector Model HWS15A-3/A HWS30A-3/A HWS50A-3/A HWS100A-3/A HWS150A-3/A HWS15A-5/A HWS30A-5/A HWS50A-5/A HWS100A-5/A HWS150A-5/A HWS15A-12/A HWS30A-12/A HWS50A-12/A HWS100A-12/A HWS150A-12/A HWS15A-15/A HWS30A-15/A HWS50A-15/A HWS100A-15/A HWS150A-15/A HWS15A-24/A HWS30A-24/A HWS50A-24/A HWS100A-24/A HWS150A-24/A HWS15A-48/A HWS30A-48/A HWS50A-48/A HWS100A-48/A HWS150A-48/A Output Adjustment Maximum Voltage (V) Range (V) Current(A) 3.3 3.3 3.3 3.3 3.3 5 5 5 5 5 12 12 12 12 12 15 15 15 15 15 24 24 24 24 24 48 48 48 48 48 2.97 - 3.96 2.97 - 3.96 2.97 - 3.96 2.97 - 3.96 2.97 - 3.96 4.0 - 6.0 4.0 - 6.0 4.0 - 6.0 4.0 - 6.0 4.0 - 6.0 9.6 - 14.4 9.6 - 14.4 9.6 - 14.4 9.6 - 14.4 9.6 - 14.4 12.0 - 18.0 12.0 - 18.0 12.0 - 18.0 12.0 - 18.0 12.0 - 18.0 19.2 - 28.8 19.2 - 28.8 19.2 - 28.8 19.2 - 28.8 19.2 - 28.8 38.4 - 52.8 38.4 - 52.8 38.4 - 52.8 38.4 - 52.8 38.4 - 52.8 3 6 10 20 30 3 6 10 20 30 1.3 2.5 4.3 8.5 13 1 2 3.5 7 10 0.65 1.3 2.2 4.5 6.5 0.33 0.65 1.1 2.1 3.3 Maximum Output Power (W) Line Reg (mV) Load Reg (mV) 10 20 33 66 99 15 30 50 100 150 16 30 52 102 156 15 30 53 105 150 16 31 53 108 156 16 31 53 101 158 20 20 20 20 20 20 20 20 20 20 48 48 48 48 48 60 60 60 60 60 96 96 96 96 96 192 192 192 192 192 120 120 120 120 120 120 120 120 120 120 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 200 200 200 200 200 HWS15A-150A Series Overvoltage Efficiency (V) (115/230Vac)(%) 4.13 - 4.95 4.13 - 4.95 4.13 - 4.95 4.13 - 4.95 4.13 - 4.95 6.25 - 7.25 6.25 - 7.25 6.25 - 7.25 6.25 - 7.25 6.25 - 7.25 15 - 17.4 15 - 17.4 15 - 17.4 15 - 17.4 15 - 17.4 18.8 - 21.8 18.8 - 21.8 18.8 - 21.8 18.8 - 21.8 18.8 - 21.8 30 - 34.8 30 - 34.8 30 - 34.8 30 - 34.8 30 - 34.8 55.2 - 64.8 55.2 - 64.8 55.2 - 64.8 55.2 - 64.8 55.2 - 64.8 70 / 71 75 / 77 76 / 78 82 / 84 82 / 84 77 / 79 80 / 82 82 / 84 84 / 86 85 / 87 80 / 83 84 / 86 83 / 85 86 / 88 85 / 88 81 / 84 85 / 87 83 / 86 86 / 88 86 / 89 82 / 85 86 / 88 84 / 87 87 / 89 88 / 90 80 / 80 82 / 83 84 / 86 88 / 90 89 / 91 1 HWS150A - 3 Series and nominal power level / Output voltage 3 (3.3V), 5, 12, 15, 24, 48 A /A Cover blank No cover /HD See HWS/HD datasheet. -40oC start up & pcb coating /ME See HWS/ME datasheet. Medical certification /R Remote on/off (HWS50A, 100A and 150A only) Preferred Option Specifications Model Input Input Voltage Range (Operating) Nominal Input Voltage Range Input Surge Voltage Input Frequency DC Input Voltage range Input Current (100/200Vac) Inrush Current (100/200Vac) Leakage Current Power Factor (100/200Vac) Harmonic Compliance No Load Power Consumption Hold Up Time (typ) Efficiency Conducted & Radiated EMI Immunity Safety Certifications and Markings Vac Vac Vac Hz Vdc A A mA - - W ms - - - - HWS15A HWS30A HWS50A HWS100A HWS150A 85 - 265 100 - 240 (Note: Safety certified for 90-264Vac) 300 for 5s 47 - 63 (Note: Safety certified for 50/60Hz only) 120 - 370 (Note: Safety certified for AC input only) 0.35 / 0.2 0.65 / 0.4 0.65 / 0.35 1.3 / 0.65 1.9 / 0.95 14 / 28 (Typical at cold start) >0.5 (Typically 0.2 at 100Vac, 0.4 at 230Vac) - - 0.97/0.91 0.98/0.93 0.98/0.93 Meets IEC61000-3-2 Class A Between 0.3 and 4.6 (model dependent). See evaluation data on website 20 See Model Selector Table EN55011 / EN55032-B, FCC-B, VCCI-B See immunity table IEC/EN/UL/CSA62368-1, 60950-1, EN50178-1 OVC III (HWS150A only), UL508, CE Mark and UKCA Mark Immunity Test Standard ESD EN61000-4-2 Radiated Susceptibility EN61000-4-3 Electrical Fast Transient Burst EN61000-4-4 Surge EN61000-4-5 Conducted Susceptibility EN61000-4-6 Magnetic Fields EN61000-4-8 Voltage Dips EN61000-4-11 SEMI F47 Line Dip SEMI F47 2 Test Level Criteria Notes (See IEC61000 immunity test report on website) Air ± 8kV and contact ± 6kV B 80M -1GHz: 10V/m 1.4 - 2.0GHz: 3V/m A 2.0 - 2.7GHz: 1V/m ± 2kV B Normal ± 2kV B Common ± 4kV 10Vrms A 30A/m A 30% 500ms A 60% 200ms A 100% 20ms A 100% 5000ms B - - At input voltages > 200Vac HWS15A-150A Series Specifications Model HWS15A HWS30A HWS50A HWS100A HWS150A Output Switching Frequency kHz HWS15A-50A; 100, HWS100A-150A; 120, PFC converter 65 Line Regulation mV See Model Selector Table Load Regulation mV See Model Selector Table 3.3V, 5V: 10,000 3.3V, 5V: 10,000 3.3V, 5V: 10,000 External Load Capacitance (Maximum) uF 12V: 5,000, 15V: 2,000 12V, 15V: 5,000 12V, 15V: 10,000 24V: 1,000, 48V: 500 24V: 2,000, 48V: 500 24V: 5,000, 48V: 1,000 Ripple & Noise mV 3.3V, 5V: 120, 12V, 15V, 24V: 150, 48V: 200 Temperature Coefficient %/°C 0.02 Minimum Load - No minimum load required Overcurrent Protection - HWS15A-50A; >105%. Hiccup with automatic recovery HWS100A-150A; >105%. Constant current and Hiccup with automatic recovery Overvoltage Protection V See model selector table. Latching (unit shutdown), cycle AC input to reset Overtemperature Protection - Remote Sense On HWS100A-150A models only Remote On/Off Optional /R suffix on HWS50A, HWS100A and HWS150A Indicators - Green LED indicates DC is OK Parallel Operation - Not possible Environmental Operating Temperature °C HWS15A: -10 to +70, derate linearly to 50% load from 50 to 70 (Cover models, /A suffix) HWS30A to 150A: -10 to +70, derate linearly to 20% load from 50 to 70 Storage Temperature °C -30 to +85 Humidity (non condensing) %RH Operating: 30 - 90, Non operating 10 - 95 Cooling - Convection Altitude m 4,000 Withstand Voltage (For 1 minute) Vac Input to ground 2,000, Input to output 3,000, Output to ground 500 for 1 minute Isolation Resistance MΩ >100 at 25°C, 70%RH & 500Vdc 10-55Hz (Sweep for 1min.) Vibration (Non-operating) 19.6m/s2 Constant X,Y,Z 1 hour each Shock (Non-operating) - Less than 196m/s2 Other Weight (Typ) g 190 240 300 470 520 Size (WxHxD) (with cover /A) mm 31.5 x 82 x 80 31.5 x 82 x 95 31.5 x 82 x 120 33.5 x 83 x 160.5 42 x 82 x 160 Size (WxHxD) (with cover /A) Inches 1.24 x 3.23 x 3.15 1.24 x 3.23 x 3.74 1.24 x 3.23 x 4.72 1.32 x 3.27 x 6.32 1.65 x 3.23 x 6.3 Connectors - Screw terminals Case Material - Aluminum MTBF - Telcordia SR-332 issue 3* 12,116,851 8,169,868 3,726,622 2,963,512 2,676,081 Warranty yrs Limited lifetime (1) or 5 years Notes See website for detailed specifications, test methods and installation manual (1) The Americas and EMEA regions: limited lifetime warranty. Other regions: 5 years. See applicable regional terms of sale. *24V output model, 55°C ambient, full load, 230Vac input HWS15A-150A Series 3 HWS15A/A Outline Drawing HWS30A/A Outline Drawing 4 HWS15A-150A Series HWS50A/A Outline Drawing HWS100A/A Outline Drawing HWS15A-150A Series 5 HWS150A/A Outline Drawing 6 HWS15A-150A Series TDK-Lambda France SAS TDK-Lambda Americas Tel: +33 1 60 12 71 65 tlf.fr.powersolutions@tdk.com Tel: +1 800-LAMBDA-4 or 1-800-526-2324 tla.powersolutions@tdk.com www.us.lambda.tdk.com www.emea.lambda.tdk.com/fr Italy Sales Office Tel: +39 02 61 29 38 63 tlf.it.powersolutions@tdk.com www.emea.lambda.tdk.com/it Netherlands tlf.nl.powersolutions@tdk.com TDK Electronics do Brasil Ltda Tel: +55 11 3289-9599 sales.br@tdk-electronics.tdk.com www.tdk-electronics.tdk.com/en www.emea.lambda.tdk.com/nl TDK-Lambda Germany GmbH Tel: +49 7841 666 0 tlg.powersolutions@tdk.com www.emea.lambda.tdk.com/de TDK-Lambda Corporation Tel: +81-3-6778-1113 www.jp.lambda.tdk.com TDK-Lambda (China) Electronics Co. Ltd. Tel: +86 21 6485-0777 tlc.powersolutions@tdk.com www.lambda.tdk.com.cn Austria Sales Office Tel: +43 2256 655 84 tlg.at.powersolutions@tdk.com TDK-Lambda Singapore Pte Ltd. Switzerland Sales Office Tel: +65 6251 7211 tls.marketing@tdk.com www.sg.lambda.tdk.com Tel: +41 44 850 53 53 tlg.ch.powersolutions@tdk.com TDK India Private Limited, Power Supply Division www.emea.lambda.tdk.com/at www.emea.lambda.tdk.com/ch Nordic Sales Office Tel: +91 80 4039-0660 mathew.philip@tdk.com www.sg.lambda.tdk.com Tel: +45 8853 8086 tlg.dk.powersolutions@tdk.com www.emea.lambda.tdk.com/dk TDK-Lambda UK Ltd. Tel: +44 (0) 12 71 85 66 66 tlu.powersolutions@tdk.com www.emea.lambda.tdk.com/uk TDK-Lambda Ltd. Tel: +9 723 902 4333 tli.powersolutions@tdk.com www.emea.lambda.tdk.com/il-en For Additional Information, please visit https://product.tdk.com/en/power/ HWS15-150A/A_260847 June 27th, 2023 V3 HWS15A-150A Series 7
HWS15A-5/A 价格&库存
很抱歉,暂时无法提供与“HWS15A-5/A”相匹配的价格&库存,您可以联系我们找货
HWS15A-5/A
  • 1+389.44627
库存:18
HWS15A-5/A
  • 1+461.118781+59.84480
  • 10+442.4859610+57.42660
HWS15A-5/A
  • 1+350.19548
库存:6
