HWS Series
Single Output Industrial Power Supplies
Features
Limited Lifetime Warranty
UL508 approved
SEMI F47 Compliant (high line AC)
Universal Input (85 - 265VAC)
High Efficiency
Wide Range AC Input
Key Market Segments & Applications
Specifications
Model
Input Voltage range
Input Current (Typ)
(1)
Inrush Current
(1)
Power Factor
Temperature Coefficient
Overcurrent Protection
Overvoltage Protection
Hold Up Time (Typ)
Leakage Current (max)
Remote Sense
Indicator
Operating Temperature (no cover)
Storage Temperature
Humidity (non condensing)
Cooling
Withstand Voltage
Isolation Resistance
Vibration (non operating)
Shock
Safety Agency Certifications
Line Dip
Conducted & Radiated EMI
Recommended EMI Filter
Immunity
Weight (Typ)
Size (WxHxD)
Size (WxHxD) /A version
Warranty
HWS15
A
A
V
ms
mA
°C
°C
g
in
yrs
HWS30
HWS50
HWS100
HWS150
85 - 265VAC (47 - 63Hz) or 120 - 370VDC
0.4 / 0.2
0.8 / 0.4
0.7 / 0.35
1.3 / 0.65
1.9 / 0.95
14 / 28
Meets EN61000-3-2
104%
Yes (See page 2)
100M at 25°C & 70%RH, Output to Ground 500VDC
10 - 55Hz (1 minute sweep), 19.6m/s2 constant X, Y, Z 1 hour
< 196.1m/s2
UL60950-1, CSA60950-1, EN60950-1, EN50178, UL508, CE Mark(3)
Complies with SEMI F47 (200VAC line only)
EN55011 / EN55022-B, FCC-B, VCCI-B
RSEL-2001W
RSEL-2002W
RSEL-2003W
IEC61000-4-2 (Level 3,2), -3, -4, -5, -6 (Level 3), -8, -11 (Level 4)
180
220
280
450
500
1.04x3.23x3.15
1.04x3.23x3.74 1.04x3.23x4.72 1.1x3.23x6.3
1.46x3.23x6.3
1.24x3.23x3.15
1.24x3.23x3.74 1.24x3.23x4.72 1.3x3.23x6.3
1.65x3.23x6.3
Limited lifetime warranty (See Lambda’s terms & conditions)
(1) 100/200VAC
(2) -40°C Start up, see options table
(3) UL60601-1, EN60601-1, see options table
N o t Rec o m en d e d Fo r Ne w D e s i gns
1-800-526-2324 • www.us.tdk-lambda.com/lp/
76
Disclaimer: us.tdk-lambda.com/lp/legal.htm
HWS Series
(10.1)
L A E AD US MEN
SEE N
EC
LED
5-M3.5
(67.5)
F
82 1
68 0.5
7.3
AC(L)
8.4
AC(N)
8
(17)
(14)
(10)
62 0.5
1 MA
8
80 1
31.5 1
NAME PLA E
SEE N
EA
SEE N
EB
HWS15 - 5 /A
17
NAME PLA E
BARC DE
15
R
MADE IN APAN
(5)
HWS15 - 5 /A
67 0.5
(5.5)
D
HWS15 - 5 /A
Eff.
typ
% (1)
68/71
70/73
76/78
78/81
78/81
77/79
77/80
82/84
83/86
83/86
80/81
81/83
81/83
83/86
83/86
80/81
81/83
81/83
83/86
83/86
82/83
83/86
82/84
84/87
85/88
80/80
82/83
83/85
84/87
85/88
N
Over
voltage
V
4.13-4.95
4.13-4.95
4.13-4.95
4.13-4.95
4.13-4.95
6.25-7.25
6.25-7.25
6.25-7.25
6.25-7.25
6.25-7.25
15-17.4
15-17.4
15-17.4
15-17.4
15-17.4
18.8-21.8
18.8-21.8
18.8-21.8
18.8-21.8
18.8-21.8
30-34.8
30-34.8
30-34.8
30-34.8
30-34.8
55.2-64.8
55.2-64.8
55.2-64.8
55.2-64.8
55.2-64.8
L
Ripple
Noise
mV
120
120
120
120
120
120
120
120
120
120
150
150
150
150
150
150
150
150
150
150
200
200
150
150
150
200
200
200
200
200
F
Load Line
Reg Reg
mV
mV
40
48
96
48
96
48
96
48
96
48
120
60
120
60
120
60
120
60
120
60
192
96
192
96
192
96
192
96
192
96
384 192
384 192
384 192
384 192
384 192
Max
Curr.
A
3
6
10
3
6
10
1.3
2.5
4.3
8.5
13
1
2
3.5
7
10
0.65
1.3
2.2
4.5
6.5
0.33
0.65
1.1
2.1
3.3
Adjust
Model
Voltage Range
HWS15-3/A
3.3V 2.97 - 3.96
HWS30-3/A
3.3V 2.97 - 3.96
HWS50-3/A
3.3V 2.97 - 3.96
HWS100-3/A
3.3V 2.97 - 3.96
HWS150-3/A
3.3V 2.97 - 3.96
HWS15-5/A
5V
4.0 - 6.0
HWS30-5/A
5V
4.0 - 6.0
HWS50-5/A
5V
4.0 - 6.0
HWS100-5/A
5V
4.0 - 6.0
HWS150-5/A
5V
4.0 - 6.0
HWS15-12/A
12V
9.6 - 14.4
HWS30-12/A
12V
9.6 - 14.4
HWS50-12/A
12V
9.6 - 14.4
HWS100-12/A 12V
9.6 - 14.4
HWS150-12/A 12V
9.6 - 14.4
HWS15-15/A
15V 12.0 - 18.0
HWS30-15/A
15V 12.0 - 18.0
HWS50-15/A
15V 12.0 - 18.0
HWS100-15/A 15V 12.0 - 18.0
HWS150-15/A 15V 12.0 - 18.0
HWS15-24/A
24V 19.2 - 28.8
HWS30-24/A
24V 19.2 - 28.8
HWS50-24/A
24V 19.2 - 28.8
HWS100-24/A 24V 19.2 - 28.8
HWS150-24/A 24V 19.2 - 28.8
HWS15-48/A
48V 38.4 - 52.8
HWS30-48/A
48V 38.4 - 52.8
HWS50-48/A
48V 38.4 - 52.8
HWS100-48/A 48V 38.4 - 52.8
HWS150-48/A 48V 38.4 - 52.8
HWS15 Outline Drawing
R
Output Ratings
8
HWS150 Outline Drawing
(10.7)
VOLTAGE ADJUSTMENT
SEE NOTE C
LED
+S
8.4
L
AC(L)
8
(9)
N
AC(N)
(17)
(14.6)
135±0.5
SEE NOTE B
NAME PLATE
SEE NOTE A
NAME PLATE
HWS150 - 5 /A
18.5
OUTPUT : 5 V
17
INPUT : 100-240VAC 2.0 A
50 / 60Hz
30 A
BARCODE
R
HWS150 - 5 /A
INPUT : 100-240VA 2.0 A 50/60Hz
OUTPUT : 5 V
(6.1)
30 A
(15)
131±0.5
14
R
HWS150 - 5 /A
300 to 1800W
500W to 1500W Single output
10W to 480W DIN Rail Mount
30 A
MADE IN JAPAN
OUTPUT : 5 V
Example: HWS50-24/RA
HWS300-1800
LZSA
DPP, DLP & DSP
8
160±1
19MAX
42±1
45JB
IND.CONT.EQ.
Other Industrial Products
82±1
(75)
FG
7.3
FG
68±0.5
10
9.2
-S
-S
/ME
-V
-V
Description
Screw terminals, no cover
Screw terminals, cover
Remote on/off (50-150W only)
See HWS50-1500/HD Datasheet for details. -40 to
+71(74)°C operation, conformally coated PCBs
See HWS30-1500/ME Datasheet for details.
UL60601-1, EN60601-1 medical approvals
M4
Suffix
Blank
/A
/R
/HD
+V
+V
5-M3.5
M4
Options
+S
8.6
2-M4
For Additional Information, please visit
us.tdk-lambda.com/lp/products/hws-series.htm
77
Revision B4: Sept. 2014
很抱歉,暂时无法提供与“HWS30-48/A”相匹配的价格&库存,您可以联系我们找货
