HWS50A-24/A
HWS50A-24/A
    TDK(东电化)
    HWS50A-24/A
HWS50A-24/A 数据手册
HWS15A-150A Series www.emea.tdk-lambda.com/hws-a /(' ,QGXVWULDO 7HVW Features Single Output Industrial Power Supplies %URDGFDVW &RPP Benefits • Limited Lifetime Warranty • Lower Cost of Ownership • High Efficiency (up to 91%) • Easier System Cooling • Wide Range AC Input • Supports Global Use Specification Model HWS15A/A HWS30A/A HWS50A/A HWS100A/A HWS150A/A Input Voltage Range - 85 - 265VAC (47 - 63Hz) Withstands 300VAC for 5s or 120 - 370VDC* Input Current (Typ) (1) A 0.35 / 0.2 0.65 / 0.4 0.65 / 0.35 1.3 / 0.65 1.9 / 0.95 Inrush Current (1) A 14 / 28 Meets EN61000-3-2 Power Factor - - 0.97/0.91 0.98/0.93 0.98/0.93 Temperature Coefficient %/°C 105% Overvoltage Protection V Yes (see table) Hold Up Time (Typ) ms 20 Leakage Current (max) mA 100M at 25°C & 70%RH, Output to Ground 500VDC Vibration (non operating) - 10 - 55Hz (1 minute sweep), 19.6m/s2 constant X, Y, Z 1 hour 2 Shock m/s < 196.1 m/s2 Safety Agency Approvals - UL60950-1, CSA60950-1, EN60950-1, EN50178, UL508, CE Mark Line Dip - Complies with SEMI F47 (200VAC line only) Conducted & Radiated EMI - EN55011 / EN55022-B, FCC-B, VCCI-B Immunity - IEC61000-4-2, -3, -4, -5, -6, -8, -11; IEC61000-6-2 Weight (Typ) g 190 240 300 470 520 Size (HxWxD) (with cover) mm 31.5 x 82 x 80 31.5 x 82 x 95 31.5 x 82 x 120 33 x 82 x 160 42 x 82 x 160 MTBF (3) hours 12,116,851 8,169,868 3,726,622 2,963,512 2,676,081 Warranty - Limited Lifetime Warranty (See TDK-Lambda’s terms and conditions) Notes: * Safety certified for AC input only (1) 100/200VAC. (2) Derating varies with model. Please refer to individual model specification for derating graphs. (3) According to Telcordia document SR-332, issue 3, “Reliability Prediction Procedure for Electronic Equipment” Conditions: ambient temp. 25deg C, 230Vac input, full load (figures shown for 24V models) HWS15A-150A Series 1 Model Selector Model Voltage (V) Adjust Range (V) HWS15A-3/A 3.3V 2.97 - 3.96 HWS30A-3/A 3.3V HWS50A-3/A 3.3V HWS100A-3/A Max Current (A) Load Reg (mV) Line Reg (mV) Ripple Noise (mV) Over Voltage (V) Efficiency (typ) % 3 40 20 120 4.13-4.95 70/71 2.97 - 3.96 6 40 20 120 4.13-4.95 75/77 2.97 - 3.96 10 40 20 120 4.13-4.95 76/78 3.3V 2.97 - 3.96 20 40 20 120 4.13-4.95 82/84 HWS150A-3/A 3.3V 2.97 - 3.96 30 40 20 120 4.13-4.95 82/84 HWS15A-5/A 5V 4.0 - 6.0 3 40 20 120 6.25-7.25 77/79 HWS30A-5/A 5V 4.0 - 6.0 6 40 20 120 6.25-7.25 80/82 HWS50A-5/A 5V 4.0 - 6.0 10 40 20 120 6.25-7.25 82/84 HWS100A-5/A 5V 4.0 - 6.0 20 40 20 120 6.25-7.25 84/86 HWS150A-5/A 5V 4.0 - 6.0 30 40 20 120 6.25-7.25 85/87 HWS15A-12/A 12V 9.6 - 14.4 1.3 96 48 150 15-17.4 80/83 HWS30A-12/A 12V 9.6 - 14.4 2.5 96 48 150 15-17.4 84/86 HWS50A-12/A 12V 9.6 - 14.4 4.3 96 48 150 15-17.4 83/85 HWS100A-12/A 12V 9.6 - 14.4 8.5 96 48 150 15-17.4 86/88 HWS150A-12/A 12V 9.6 - 14.4 13 96 48 150 15-17.4 85/88 HWS15A-15/A 15V 12.0 - 18.0 1 120 60 150 18.8-21.8 81/84 HWS30A-15/A 15V 12.0 - 18.0 2 120 60 150 18.8-21.8 85/87 HWS50A-15/A 15V 12.0 - 18.0 3.5 120 60 150 18.8-21.8 83/86 HWS100A-15/A 15V 12.0 - 18.0 7 120 60 150 18.8-21.8 86/88 HWS150A-15/A 15V 12.0 - 18.0 10 120 60 150 18.8-21.8 86/89 HWS15A-24/A 24V 19.2 - 28.8 0.65 150 96 150 30-34.8 82/85 HWS30A-24/A 24V 19.2 - 28.8 1.3 150 96 150 30-34.8 86/88 HWS50A-24/A 24V 19.2 - 28.8 2.2 150 96 150 30-34.8 84/87 HWS100A-24/A 24V 19.2 - 28.8 4.5 150 96 150 30-34.8 87/89 HWS150A-24/A 24V 19.2 - 28.8 6.5 150 96 150 30-34.8 88/90 HWS15A-48/A 48V 38.4 - 52.8 0.33 240 192 200 55.2-64.8 80/80 HWS30A-48/A 48V 38.4 - 52.8 0.65 240 192 200 55.2-64.8 82/83 HWS50A-48/A 48V 38.4 - 52.8 1.1 240 192 200 55.2-64.8 84/86 HWS100A-48/A 48V 38.4 - 52.8 2.1 240 192 200 55.2-64.8 88/90 HWS150A-48/A 48V 38.4 - 52.8 3.3 240 192 200 55.2-64.8 89/91 Options Suffix Description Blank / A / R No Cover Cover Remote on/off / HD / ME 2 (available 50W, 100W &150W models) See HWS/HD datasheet for details. -40˚C start up and PCB coating (not available on HWS15A) See HWS/ME datasheet for details of available models IEC/EN60601-1 medical approval (not available on HWS15A) HWS15A-150A Series HWS15A/A Outline Drawing HWS30A/A Outline Drawing HWS15A-150A Series 3 HWS50A/A Outline Drawing HWS100A/A Outline Drawing 4 HWS15A-150A Series HWS150A/A Outline Drawing HWS15A-150A Series 5 TDK-Lambda France SAS TDK-Lambda UK Ltd. ZAC des Delaches CS 41077 9 rue Thuillere 91978 Villebon Courtaboeuf France Tel: +33 1 60 12 71 65 Fax: +33 1 60 12 71 66 france@fr.tdk-lambda.com www.fr.tdk-lambda.com Kingsley Avenue Ilfracombe Devon EX34 8ES United Kingdom Tel: +44 (0) 12 71 85 66 66 Fax: +44 (0) 12 71 86 48 94 powersolutions@uk.tdk-lambda.com www.uk.tdk-lambda.com Italy Sales Office TDK-Lambda Ltd. Kibbutz Givat Hashlosha 48800 Israel Tel: +9 723 902 4333 Fax: +9 723 902 4777 info@tdk-lambda.co.il www.tdk-lambda.co.il Via dei Lavoratori 128/130 20092 Cinisello Balsamo (MI) Italy Tel: +39 02 61 29 38 63 Fax: +39 02 61 29 09 00 info.italia@it.tdk-lambda.com www.it.tdk-lambda.com Netherlands info@nl.tdk-lambda.com www.nl.tdk-lambda.com C.I.S. Commercial Support: Tel: +7 (495) 665 2627 Technical Support: Tel: +7 (812) 658 0463 info@tdk-lambda.ru www.tdk-lambda.ru TDK-Lambda Germany GmbH Karl-Bold-Strasse 40 77855 Achern Germany Tel: +49 7841 666 0 Fax: +49 7841 5000 info.germany@de.tdk-lambda.com www.de.tdk-lambda.com Local Distribution Austria Sales Office Aredstrasse 22 2544 Leobersdorf Austria Tel: +43 2256 655 84 Fax: +43 2256 645 12 info.germany@de.tdk-lambda.com www.de.tdk-lambda.com Switzerland Sales Office Bahnhofstrasse 50 8305 Dietlikon Switzerland Tel: +41 44 850 53 53 Fax: +41 44 850 53 50 info@de.tdk-lambda.com www.de.tdk-lambda.com www.emea.tdk-lambda.com HWS-A Aug16 v9 6 HWS15A-150A Series
HWS50A-24/A 价格&库存
很抱歉,暂时无法提供与“HWS50A-24/A”相匹配的价格&库存,您可以联系我们找货
HWS50A-24/A
  • 1+984.424101+127.92843
  • 10+918.1114410+119.31093
  • 25+892.9803025+116.04507
  • 50+874.4254250+113.63382
  • 100+856.26028100+111.27321
库存:418
