HWS600-24/HD
HWS600-24/HD
    TDK(东电化)
    HWS600-24/HD
HWS600-24/HD 数据手册
TDK-Lambda HWS600/HD SPECIFICATIONS A232-01-01/HD-B HWS600 HWS600 HWS600 HWS600 HWS600 -5/HD -12/HD -15/HD -24/HD -48/HD 5 12 15 24 48 1 V 120 53 43 27(31) 13 2 A 600 636 645 648 624 3 W 80 80 81 82 83 4 % 83 83 84 85 86 % 5 85 - 265VAC (47 - 63Hz) or 120 - 330VDC 5.4/2.6 7.5/3.6 6 A 8.1/3.9 7 20A at 100VAC, 40A at 200VAC 8 Designed to meet IEC61000-3-2 9 0.99/0.95 2.64-3.96 4.0-6.0 9.6-14.4 12.0-18.0 19.2-28.8 38.4-52.8 10 V 120 120 150 150 150 350 11 mV 180 180 200 200 200 400 mV 20 20 48 60 96 192 12 mV 30 30 72 90 144 288 13 mV 14 Less than 0.02% / °C 126 < 126 < 55.7 < 45.2 < 31.4 < 13.7 < 15 A 4.13-4.95 6.25-7.25 15.0-17.4 18.8-21.8 30.0-34.8 55.2-64.8 16 V 17 20ms 18 Less than 0.75mA. 0.2mA(Typ) at 100VAC / 0.44mA(Typ) at 230VAC 19 Possible 20 Possible 21 PF(Open Collector Output) 22 Possible 23 Possible 24 -10 to +71°C (-10 to +50°C:100%,+71°C:50%) Guarantee Start up at -40°C to -10°C 25 Operating Humidity 10 to 90%RH (No dewdrop) 26 Storage Temperature -40 to +85°C 27 Storage Humidity 10 to 95%RH (No dewdrop) 28 Cooling Forced Air By Blower Fan 29 Withstand Voltage Input - FG : 2.5kVAC (20mA), Input - Output : 3kVAC (20mA) Output - FG : 500VAC (100mA),Output - CNT : 100VAC(100mA) for 1min 30 Isolation Resistance More than 100MΩ Output - FG : 500VDC More than 10MΩ Output - CNT : 100VDC at 25°C and 70%RH 31 Vibration (*14) At no operating, 10 - 55Hz (Sweep for 1min) 19.6m/s2 Constant, X,Y,Z 1hour each. Designed to meet MIL-STD-810F 514.5 Category 4, 10 32 Shock (In package) Less than 196.1m/s2 Designed to meet MIL-STD-810F 516.5 Procedure I, VI 33 Safety (*15) Approved by UL62368-1, CSA62368-1, EN62368-1, UL60950-1, CSA60950-1, EN60950-1 (Expire date of 60950-1 : 20/12/2020), EN50178, Designed to meet DENAN 34 Line DIP Designed to meet SEMI-F47 (200VAC Line only) 35 Conducted Emission Designed to meet EN55011/EN55032-B, FCC-B, VCCI-B 36 Radiated Emission Designed to meet EN55011/EN55032-B, FCC-B, VCCI-B 37 Immunity Designed to meet IEC61000-4-2(Level 2,3), -3(Level 3), -4(Level 3), -5(Level 3,4), -6(Level 3), -8(Level 4), -11 38 Weight(Typ.) 1.6kg 39 Size (W x H x D) mm 100 x 82 x 165 ( Refer to Outline Drawing ) * Read instruction manual carefully, before using the power supply unit. =NOTES= *1. ( ): Peak output current at 200VAC. Operating time at peak output is less than 10sec, duty is less than 35%. *2. At 100/200VAC, Ta=25°C and maximum output power. *3. For cases where conformance to various safety specs (UL, CSA, EN) are required, to be described as 100 - 240VAC(50/60Hz). *4. Not applicable for the in-rush current to Noise Filter for less than 0.2ms. Inrush Current is 30A(Typ) when PFHC start-up. *5. Measure with JEITA RC-9131A probe, Bandwidth of scope : 100MHz. *6. 85 - 265VAC, constant load. *7. No load - Full load, constant input voltage. *8. 3V and 5V model: Constant current limit and hiccup with automatic recovery. 12 - 48V model: Constant current limit with automatic recovery. Avoid to operate at over load or short circuit condition for more than 30seconds. *9. OVP circuit will shut the output down, manual reset (CNT reset or Re-power on). *10. At 100/200VAC, nominal output voltage and maximum output current. *11. Measured by the each measuring method of UL, CSA, EN and DENAN(at 60Hz), Ta=25°C. *12. Ratings - Derating at standard mounting. /Refer to output derating curve.(A232-01-02/HD-_ ) - Load (%) is percent of maximum output power or maximum output current, whichever is greater. *13. For -40°C - -10°C need 3minutes to stabilize the output voltage. *14. Category 4 exposure levels : Truck transportation over U.S. highways, Composite two-wheeled trailer. *15. As for DENAN, designed to meet at 100VAC. MODEL ITEMS Nominal Output Voltage Maximum Output Current (*1) Maximum Output Power Efficiency (Typ) (*2) 100VAC 200VAC Input Voltage Range (*3) Input Current (100/200VAC)(Typ) (*2) Inrush Current (Typ) (*4) PFHC Power Factor (100/200VAC)(Typ) (*2) Output Voltage Range Maximum Ripple & Noise 0
HWS600-24/HD 价格&库存
很抱歉,暂时无法提供与“HWS600-24/HD”相匹配的价格&库存,您可以联系我们找货
HWS600-24/HD
  • 1+6506.88822
库存:10
