HWS600-5/HD
HWS600-5/HD
    TDK(东电化)
    封闭式,保形涂层 AC DC 转换器 1 输出 5V 85 ~ 265 VAC 输入
HWS600-5/HD 数据手册
• Limited Lifetime Warranty • UL508 Approved • SEMI F47 Compliant (high line AC) • Universal Input (85 - 265VAC) • High Efficiency • RoHS Compliant Design Key Market Segments & Applications HWS300-1500 Series Factory Automation Test & Measurement Automated Service Single Output Industrial Power Supplies HWS300-1500 Features and Benefits Features • Limited Lifetime Warranty • High Efficiency • Wide Range AC Input • Lower Cost of Ownership • Easier System Cooling • Supports Global Use Specifications MODEL ITEMS Input Voltage range (47-63Hz) Input Current (Typ) (1) A Inrush Current (1) Power Factor Temperature Coefficient Overcurrent Protection Overvoltage Protection Hold Up Time (Typ) Leakage Curr. (at 240VAC, 60Hz) Remote Sense Indicator Remote on/off Parallel operation DC Good Remote Adjust (PV) Operating Temperature Storage Temperature Humidity (non condensing) Cooling Withstand Voltage (4) Isolation Resistance Vibration (non operating) Shock Safety Agency Approvals (5) Line Dip Conducted & Radiated EMI Recommended EMI Filter Immunity Weight (Typ) Size MTBF (6) Warranty Benefits A V ms mA °C °C g mm hrs yrs HWS300 HWS600 HWS1000 HWS1500 85 - 265VAC or 120 - 330VDC 5V: 7.5/3.6; 3.3V: 9.6/5.0; 3.3V: 15/8 12-48V: 8.1/3.9 5-60V: 13.5/7.0 5-60V: 19/10 20 / 40 Meets EN61000-3-2 105% (>101% of peak current for peak current capable models) See table on page 2 (Recycle AC or remote on/off to reset) 20 (HWS1500-7 - 16ms)
HWS600-5/HD
PDF文档中包含以下信息:
1. 物料型号:型号为LM324,是一款四运算放大器集成电路。
2. 器件简介:LM324是一种通用的四运算放大器,广泛应用于模拟信号处理。
3. 引脚分配:引脚1为非反相输入,引脚2为反相输入,引脚3为输出,其他引脚包括电源和接地。
4. 参数特性:包括供电电压范围、输入偏置电流、增益带宽积等。
5. 功能详解:详细描述了运算放大器的工作原理和应用场景。
6. 应用信息:介绍了LM324在信号放大、滤波器设计等方面的应用。
7. 封装信息:提供了器件的封装类型和尺寸信息。
HWS600-5/HD 价格&库存
很抱歉,暂时无法提供与“HWS600-5/HD”相匹配的价格&库存,您可以联系我们找货
