I6A24014A033V-000-R
I6A24014A033V-000-R
    TDK(东电化)
    I6A24014A033V-000-R
I6A24014A033V-000-R 数据手册
i6A Series 250W, 9 to 40V Input Non-Isolated Step-Down DC-DC Buck Converter https://product.tdk.com/en/power/i6a www.emea.lambda.tdk.com/i6a The i6A series of non-isolated DC-DC step-down converters are ideal for creating additional high current output voltage rails from a single output 12V or 24V AC-DC or DC-DC power supply. The highly efficient i6A series accepts a wide DC input and has a wide output adjustment range in compact 1/16th brick package. Output trim, remote sense, negative or positive logic remote On-Off comes as standard features. Power good, frequency synchronization and output sequencing are optional features. Features Benefits • Up to 250 W in a 1/16th brick package • High Power Density, Less Board Area Needed • High Efficiency Up to 98% • Longer Battery Life / Less Power Consumed • Wide Output Adjustment 3.3 to 24 V • One Part Supports Multiple System Voltages • 9 to 40V Input Range • Can Operate From Different DC Source Voltages Including Batteries • Low Component Count With Minimal External Components • Low Cost • Minimal Derating Requirements in Low Airflow Environments • Easy to Cool in End System Model Selector Model i6A24014A033V-000-R i6A24014A033V-001-R i6A24014A033V-002-R i6A24014A033V-003-R Input Voltage (V) 9 - 40 9 - 40 9 - 40 9 - 40 Output Voltage (V) 3.3 - 24 3.3 - 24 3.3 - 24 3.3 - 24 Max Current (A) 14 14 14 14 Max Power (W) 250 250 250 250 Negative Logic On/Off Positive Logic On/Off Full Feature - Yes - Yes Yes - Yes - Yes Yes Preferred model Related Products Type Part Number Description DC-DC Buck Converter DC-DC Buck Converter DC-DC Buck Converter Ruggedized DC-DC Buck Converter DC-DC Buck Converter DC-DC Buck-Boost Converter Evaluation Kit Evaluation Kit Evaluation Kit i3A i6A4W i6AN RGA i7A i7C i6A14A-C01-EVK-S1 i6A14A-001-EVK-S1PX i6A14A-001-EVK-D2PN 100W, Input 9-53V, Output 5-30V 4.5A or 3.3-16.5V 8A 250W, Input 9-53V, Output 3.3-40V 10A or 3.3-15V 20A 75W, Input 9-40V, Negative Output -3.3 to -30V, 8A 250W, Input 9-40V or 9-53V, Output 3.3-24V or 3.3 up to 40V 500-750W, Input 18-60V or 18-32V, Output 3.3-24V 33A or 3.3-18V 45A 300W, Input 9-53V or 9-36V, Output 9.6-48V 8A, 5-28V 12.5A or 8-24V 20A Compact Evaluation kit with i6A24014A033V-001-R module Evaluation kit with i6A24014A033V-001-R module Evaluation kit with i6A24014A033V-001-R module and i6A24008A033V-N01-R modules i6A Series 1 Specification Model i6A24014A033V Input Input Voltage Range Vdc 9 - 40 Input Current (max) A 15 Turn-ON Input Voltage Vdc 8 Turn-OFF Input Voltage Vdc 7 - 9 Efficiency % 92.5 - 98 Safety Certifications and Markings - IEC/UL/CSA/EN 62368-1, 60950-1, CE Mark and UKCA Mark Output Output Voltage Tolerance % ± 4 Line Regulation % 0.3 Load Regulation % 1 External Load Capacitance uF 0 - 2000 Ripple & Noise mVpp 20 Switching Frequency kHz 400 Overcurrent Protection Threshold (typ) A 22 Overtemperature Protection - Yes Output Voltage Adjustment Range 3.3 to 24 See product specifications for output trim equation Remote Sense - (+) Sense, compensating up to 5% of output voltage Remote On/Off - Negative or Positive Logic Power Good - Optional (Full Feature Version) Frequency Synchronization - Optional (Full Feature Version) Output Sequencing - Optional (Full Feature Version) Environmental Operating Temperature (Tref) °C -40 to 125 Storage Temperature °C -55 to 125 Humidity (non condensing) %RH 5 - 95 (Operating & Storgae) Cooling - Convection or forced air Other Weight (Typ) g 15 Size (LxWxH) mm 33.0 x 22.9 x 12.1 Size (LxWxH) Inches 1.30 x 0.90 x 0.47 MTBF - Telcordia SR-332 - > 10 MHrs; 100% Load; Ta = 40 °C Warranty yrs 3 years See website for detailed product specifications. Pinout PIN Function PIN Function 1 Vin (+) 2 On / Off 3 Vin (-) / GND 4 Vout (-) / GND 5 Power Good (Option) 6 Trim 7 8 32 33 34 Sense + Vout (+) SYNC (Option) MS (Option) SEQ (Option) Pin base material is brass or copper with gold over nickel plating. 2 i6A Series Typical Application Circuit (i6A) Recommendation: 1. TRIM resistor Rup should be connected to the i6A module as close as possible. Output vs. Input Voltage Operating Range i6A Series 3 Mechanical Specification Dimensions are in mm [in]. Unless otherwise specified tolerances are: x.x ± 0.5 [0.02], x.xx ± 0.25 [0.010] Recommended Hole Pattern (Top View) 4 i6A Series TDK-Lambda France SAS TDK-Lambda Americas Tel: +33 1 60 12 71 65 tlf.fr.powersolutions@tdk.com Tel: +1 800-LAMBDA-4 or 1-800-526-2324 tla.powersolutions@tdk.com www.us.lambda.tdk.com www.emea.lambda.tdk.com/fr Italy Sales Office Tel: +39 02 61 29 38 63 tlf.it.powersolutions@tdk.com www.emea.lambda.tdk.com/it TDK Electronics do Brasil Ltda Tel: +55 11 3289-9599 sales.br@tdk-electronics.tdk.com www.tdk-electronics.tdk.com/en Netherlands tlf.nl.powersolutions@tdk.com www.emea.lambda.tdk.com/nl TDK-Lambda Germany GmbH TDK-Lambda Corporation Tel: +49 7841 666 0 tlg.powersolutions@tdk.com www.emea.lambda.tdk.com/de Tel: +81-3-6778-1113 www.jp.lambda.tdk.com TDK-Lambda (China) Electronics Co. Ltd. Tel: +86 21 6485-0777 tlc.powersolutions@tdk.com www.lambda.tdk.com.cn Austria Sales Office Tel: +43 2256 655 84 tlg.at.powersolutions@tdk.com TDK-Lambda Singapore Pte Ltd. Switzerland Sales Office Tel: +65 6251 7211 tls.marketing@tdk.com www.sg.lambda.tdk.com Tel: +41 44 850 53 53 tlg.ch.powersolutions@tdk.com TDK India Private Limited, Power Supply Division www.emea.lambda.tdk.com/at www.emea.lambda.tdk.com/ch Tel: +91 80 4039-0660 mathew.philip@tdk.com www.sg.lambda.tdk.com Nordic Sales Office Tel: +45 8853 8086 tlg.dk.powersolutions@tdk.com www.emea.lambda.tdk.com/dk TDK-Lambda UK Ltd. Tel: +44 (0) 12 71 85 66 66 tlu.powersolutions@tdk.com www.emea.lambda.tdk.com/uk TDK-Lambda Ltd. Tel: +9 723 902 4333 tli.powersolutions@tdk.com www.emea.lambda.tdk.com/il-en For Additional Information, please visit https://product.tdk.com/en/power/ i6A 260814 December 6th, 2022 V3 i6A Series 5
I6A24014A033V-000-R 价格&库存
很抱歉,暂时无法提供与“I6A24014A033V-000-R”相匹配的价格&库存,您可以联系我们找货
