I6A4W010A033V-0S1-R
I6A4W010A033V-0S1-R
    TDK(东电化)
    SIP20_18Pin
    DC DC CONVERTER 3.3-40V 250W
I6A4W010A033V-0S1-R 数据手册
i6A Series DC-DC Power Module Series 9-53 V Wide Input, 250 W Buck/Step-Down Converter, 1/16th Brick Footprint i6A4W power modules perform local voltage conversion from a 12 V, 24 V, or well-regulated 48 V bus. The i6A4W series utilizes a low component count that results in both a low-cost structure and a high level of performance. The open-frame and compact design features a low profile and weight that allow for extremely flexible and robust manufacturing processes. The ultra-high efficiency allows for a high amount of useable power even in demanding thermal environments. Features  Size – 33mm x 22.9 mm x 12.1 mm (1.30 in. x 0.90 in. x 0.47 in.)  Maximum weight 15g (0.53 oz.)  Through-hole pins 3.68mm (0.145 in)  Industry standard 1/16th brick form factor  Up to 250W of output power in high ambient temperature, low airflow environments with minimal power derating  Wide output voltage adjustment range  Negative logic On/Off  Optimized dynamic voltage response with minimal external capacitors  Low noise  Constant switching frequency  Remote Sense  Full, auto-recovery protection: - Input under voltage - Short circuit - Thermal limit  ISO Certified manufacturing facilities February 21, 2022 v5 Optional Features  Positive logic On/Off  Power Good  Frequency Synchronization  Output Voltage Sequencing  Short 2.79 mm (0.110 in) pin length  Long 4.57 mm (0.180 in”) pin length Applications  Contact technical support for applications requiring constant current operation Specifications – i6A4W Series 1 / 22 Ordering Information: Product Identifier Package Size Platform Input Voltage Output Current Units Main Output Voltage # of Outputs i 6 A 4W 020 A 033 V TDKLambda 33 mm x 22.9 mm i6A 9 to 53 V 010 – 10 020 – 20 Amps 3.3 V Single - Safety Class Feature Set 0 01 See option table RoHS indicator - R R=RoHS Compliant Option Table: Negative Logic On/Off Full Feature (Power Good, SYNC, SEQ) Enhanced Feature (Power Good, SYNC) 0.145” Pin Length 0.180” Pin Length Yes - - - Yes - - Yes - - Yes - -002 Yes - Yes - Yes - -003 - Yes Yes - Yes - -005 - Yes - Yes Yes - -007 - Yes - - - Yes -009 - Yes Yes - - Yes Feature Set Positive Logic On/Off -000 -001 Product Offering: Product Code Input Voltage (V) Output Voltage (V) Output Current (A) Maximum Output Power (W) Efficiency i6A4W020A033V 9 - 53 3.3 - 15 20 250 97% i6A4W010A033V 9 - 53 3.3 - 40 10 250 97% February 21, 2022 v5 Specifications – i6A4W Series 2 / 22 Typical Application Circuit: i6A Series DC/DC 1 Vin(+) Vout(+) 8 7 SENSE(+) Cin 2 + TRIM ON/OFF Cout 6 + 100uF Vin 0.1uF 22uF * Rup 3 3.3V Vin(-) Vout(-) Power Good SYNC 5 32 33 4 User application MS SEQ 3.3V 34 10k 10k Optional features Recommendation 1. TRIM resistor Rup should be connected to the i6A module as close as possible. February 21, 2022 v5 Specifications – i6A4W Series 3 / 22 Mechanical Specification: Dimensions are in mm [in]. Unless otherwise specified tolerances are: x.x  0.5 [0.02], x.xx  0.25 [0.010]. 33.0 [1.30] 22.9 [0.90] 12.1 [0.474] MAX 1.57 [0.062] DIA Pins 2.59 [0.102] DIA Stand-offs 2 Places 1.02 [0.040] DIA Pins 1.78 [0.070] DIA Stand-offs up to 9 Places 3.7 [0.14] 4.6 [0.18] Optional Pin Length Pin 1 Chamfer 1.3 [0.05] 1.3 [0.05] February 21, 2022 v5 Specifications – i6A4W Series 4 / 22 Recommended Hole Pattern – STANDARD – 000-R/-001-R/-007-R (Top View): 33.0 [1.30] 3.8 [0.15] 3.8 [0.15] Pin1 Pin8 3.8 [0.150] Pin7 7.6 [0.300] 7.6 [0.300] 15.2 [0.600] Pin6 Pin2 15.2 [0.600] 22.9 [0.90] Pin4 Pin3 2.5 [0.10] 2.5 [0.10] 27.9 [1.100] Recommended Hole Pattern – FULL FEATURE –002-R/-003-R/-005-R**/-009-R (Top View): 33.0 [1.30] 3.8 [0.15] 3.8 [0.15] Pin1 Pin8 Pin34 Pin7 Pin2 Pin6 3.8 [0.150] 3.8 [0.150] 7.6 [0.300] 7.6 [0.300] 15.2 [0.600] Pin33 Pin3 Pin32 15.2 [0.600] 11.4 [0.450] 22.9 [0.90] Pin5 Pin4 2.5 [0.10] 20.3 [0.800] 24.1 [0.950] 2.5 [0.10] 2.5 [0.10] 27.9 [1.100] Pin Assignment: PIN Function PIN Function 1 Vin (+) 7 SENSE + 2 On / Off 8 Vout (+) 3 Vin (-) / GND 32 SYNC (Option) 4 Vout (-) / GND 33 MS (Option) 5 Power Good (Option) 34 SEQ (Option) 6 TRIM February 21, 2022 v5 Note: Pin base material is brass or copper with gold over nickel plating. Maximum Weight: 15g (0.53 oz.) ** For option code –005-R, pin 34 (SEQ-Sequencing) is not present. Specifications – i6A4W Series 5 / 22 Absolute Maximum Ratings: Stress in excess of Absolute Maximum Ratings may cause permanent damage to the device. Characteristic Min Max Unit Continuous Input Voltage -0.25 55 Vdc Isolation Voltage --- --- Vdc Storage Temperature -55 125 ˚C Operating Temperature Range (Tc) -40 125* ˚C Notes & Conditions None Measured at the location specified in the thermal measurement figure; maximum temperature varies with output current – see curve in the thermal performance section of the data sheet. * Engineering Estimate Input Characteristics: Unless otherwise specified, specifications apply over all rated Input Voltage, Resistive Load, and Temperature conditions. Characteristic Min Typ Max Unit Notes & Conditions Operating Input Voltage 10 --- 53 Vdc Vin > Vo Maximum Input Current --- --- 20 A Stand-by Input current --- 1.5 --- mA Vin = Vin,nom, On/Off = Off Startup Delay Time from application of input voltage --- 4 --- ms Vo = 0 to 0.1*Vo,set; On/Off = On, Io = Io,max, Tc = 25˚C Startup Delay Time from On/Off --- 3 --- ms Vo = 0 to 0.1*Vo,set; Vin = Vin,nom, Io = Io,max,Tc = 25˚C Output Voltage Rise Time --- 10 --- ms Io = Io,max,Tc = 25˚C, Vo = 0.1 to 0.9*Vo,set Input Ripple Rejection --- 50* --- dB @ 120 Hz Turn on input voltage --- 8 --- V Turn off input voltage *Engineering Estimate --- 7 9 V Vin = Vin,min to Vin,max; Io = Io,max Caution: The power modules are not internally fused. An external input line normal blow fuse with a maximum value of 30A is required, see the Safety Considerations section of the data sheet. February 21, 2022 v5 Specifications – i6A4W Series 6 / 22 Electrical Characteristics: i6A4W020A033V (20 A) Characteristic Min Typ Max Unit Notes & Conditions Output Voltage Initial Setpoint -2 - +2 % Vo = 3.3 V setting, Vin = Vin,nom; Io = Io,min; Tc = 25 ˚C Output Voltage Tolerance -4 - +4 % Overall rated input voltage, load, and temperature conditions to end of life Efficiency Vo = 5 V Vo = 9 V ----- 95 97 ----- % % Vin = 12 V; Io = Io,max; Tc = 25 ˚C Efficiency Vo = 5 V Vo = 12 V ----- 93 97 ----- % % Vin = 24 V; Io = Io,max; Tc = 25 ˚C Efficiency Vo = 5 V Vo = 12 V ----- 90 95 ----- % % Vin = 48 V; Io = Io,max; Tc = 25 ˚C Line Regulation --- 0.4 --- % Vin = Vin,min to Vin,max Load Regulation --- 1.2 --- % Io = Io,min to Io,max Output Current 0 --- 20 A Observe maximum power limit Output Current Limiting Threshold --- 27 --- A Vo = 0.9*Vo,nom, Tc
I6A4W010A033V-0S1-R 价格&库存
很抱歉,暂时无法提供与“I6A4W010A033V-0S1-R”相匹配的价格&库存,您可以联系我们找货
I6A4W010A033V-0S1-R
  • 1+10921.29292
  • 2+10702.86269
  • 4+10488.80627
库存:17
I6A4W010A033V-0S1-R
  • 1+363.99485
  • 8+356.71558
  • 15+349.57169
库存:17
I6A4W010A033V-0S1-R
  • 1+379.112071+49.27533
