• Standard DOSA SIP Footprint
• 6.0-14VDC Input
• 0.8-5.5V Outputs
• Through Hole Mounting
• Low 13.97mm Profile
• Non Isolated Output
Key Market Segments & Applications
Telecom/Datcom
Datacom
Process Control
Wireless Network
Measurement & Test
iAD Series
16A Point of Load Converters
iAD Features and Benefits
Features
Benefits
• High operating efficiency (up to 94%)
• Constant switching frequency
• Starts with pre-biased output
• Reduced system heating
• Easier system filtering
• Supports complex digital systems
Specifications
MODEL
ITEMS
Nominal Output Voltage
Input Voltage Range
Input Current (max)
Output Voltage Tolerance
Ripple & Noise (max) (pk-pk)
Line Regulation (max)
Load Regulation (max)
Overload Protection
Overvoltage Protection
Remote Sense
Remote On / Off
Sequencing
Temperature (operating)
Temperature (storage)
Humidity (operating)
Humidity (storage)
Cooling
Isolation Voltage
Vibration (non-operating)
Shock
Safety Agency Certifications
Weight (max)
Size (LxWxH)
Warranty
VDC
VDC
A
VDC
mV
mV
mV
°C
°C
g
mm
yrs
iAD
0.8 - 5.5V
6 - 14V
18A
N/A
100
15
22
Inception - 28A; Short circuit - auto recovery
N/A
Yes
Positive or Negative Logic available, see Feature Set
Yes, see feature set
-40°C to +125°C
-55°C to +125°C
20 - 95% RH Non condensing
10 - 95% RH Non condensing
Convection or forced air
none
5 to 50Hz@0.5g (4.9m/s2), & 50 to 500Hz@1.5g (14.7m/s2) per Bellcore TR-EOP-000063-5.4.4
196.1m/s2
UL60950 (US and Canada), VDE0805 (IEC60950), CB scheme (IEC60950)
12
50.8 x 7.9 x 14
3
iAD Series
1
Model Selector
Output
Voltage (V)
Output
Adjust (V)
Output
Curr. (A)
Max. Output
Power (W)
Efficiency at
Full Load (%)
iAD12016A008V-000-R
0.80 - 5.5
0.80 - 5.5
16
80
94% at 5V
iAD12016A008V-001-R
0.80 - 5.5
0.80 - 5.5
16
80
94% at 5V
Model
NB other configurations on request
Feature Set
Pinout
Feat.
Set
Pos. Logic
On / Off
00*
01
02
03
04
05
06
07
X
Neg. Logic
On / Off
X
X
X
X
X
X
X
Input
Voltage
6 - 14V
6 - 14V
6 - 14V
6 - 14V
6 - 14V
6 - 14V
6 - 14V
6 - 14V
Seq.
X
X
0.13"
Pin
0.2"
Pin
PIN
1
2
3
4
5
X
X
X
X
X
X
X
X
X
X
Function
PIN
Function
Vout
Vout
Sense
Vout
GND
6
7
8
9
10
11
GND
Vin
Vin
Sequencing
Trim
On / Off
* Preferred feature set
Model Number Example: iAD12016A008V-001-R
Outline Drawing iAD Series
Recommended Hole Pattern (Top View)
Mechanical Specifications:
Dimensions are in mm [in]. Unless otherwise specificed tolerances
are: x.x ±0.5 [0.02], x.xx ±0.25 [0.010]
2
iAD Series
TDK-LAMBDA EMEA
www.emea.tdk-lambda.com
TDK-Lambda France SAS
TDK-Lambda UK Ltd.
Route de Grivery
ZAC des Delaches
CS 41077
91978 Courtaboeuf Cedex
France
Tel: +33 1 60 12 71 65
Fax: +33 1 60 12 71 66
france@fr.tdk-lambda.com
www.fr.tdk-lambda.com
Kingsley Avenue
Ilfracombe
Devon EX34 8ES
United Kingdom
Tel: +44 (0) 12 71 85 66 66
Fax: +44 (0) 12 71 86 48 94
powersolutions@uk.tdk-lambda.com
www.uk.tdk-lambda.com
Italy Sales Office
Nemic Lambda Ltd.
Via dei Lavoratori 128/130
20092 Cinisello Balsamo (MI)
Italy
Tel: +39 02 61 29 38 63
Fax: +39 02 61 29 09 00
info.italia@it.tdk-lambda.com
www.it.tdk-lambda.com
Kibbutz
Givat Hashlosha 48800
Israel
Tel: +9 723 902 4333
Fax: +9 723 902 4777
info@nemic.co.il
www.nemic.co.il
TDK-Lambda Germany GmbH
Russia
Karl-Bold-Strasse 40
77855 Achern
Germany
Tel: +49 7841 666 0
Fax: +49 7841 5000
info.germany@de.tdk-lambda.com
www.de.tdk-lambda.com
Technical Support:
St Petersburg
Tel: +7 (812) 6580463
Sales:
Moscow
Tel: +7 (499) 7557732
info@tdk-lambda.ru
www.tdk-lambda.ru
Austria Sales Office
Aredstrasse 22
2544 Leobersdorf
Austria
Tel: +43 2256 655 84
Fax: +43 2256 645 12
LOCAL DISTRIBUTION
iAD June11 v3
3
iAD Series
IAD12016A008V-001-R 价格&库存
很抱歉,暂时无法提供与“IAD12016A008V-001-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 180+301.97148180+39.05830
