IBC12007A008V-001-R
IBC12007A008V-001-R
    TDK(东电化)
    SMD-6P,27.9x11.4mm
    DC DC CONVERTER 0.8-5V 35W
IBC12007A008V-001-R 数据手册
• Standard Industry Footprint (DOSA) • 3.0-5.5V and 6.0-14.0V Input • 0.8-5.0V Nominal Output • Surface Mount • Low 8.38mm Profile • Non Isolated Output Key Market Segments & Applications Telecom/Datcom Datacom Process Control Wireless Network Measurement & Test iBA/iBC Series 7 to 8A point of load converter iBA/iBC Features and Benefits Features Benefits • High operating efficiency (up to 95%) • Constant switching frequency • Starts with pre-biased output • Reduced system heating • Easier system filtering • Supports complex digital systems Specifications MODEL ITEMS Nominal Output Voltage VDC Input Voltage Range (2) VDC Input Current (max) A Output Voltage Tolerance VDC Ripple & Noise (max) (pk to pk) (3) mV Line Regulation (max) mV Load Regulation (max) mV Overload Protection % Overvoltage Protection Remote Sense Remote On / Off Sequencing Temperature (operating) °C Temperature (storage) °C Humidity (operating) Humidity (storage) Cooling Isolation Voltage VDC Vibration (non operating) Shock Safety Agency Approvals Weight (max) g Size mm Warranty - Notes: iBA05008A008V iBC12007A008V 0.75 - 3.63 3.0 - 5.5 0.8 - 5.0 6.0(1) - 14 or 9.6 - 14 8.5 N/A 75 100 5 20 10 30 Inception- 185-215% of rated output; Short circuit - auto recovery N/A No Positive or Negative Logic available, see Feature Set No Yes -40 to 125 -55 to 125 20-95% RH Non condensing Per IPC / JEDEC J-STD-020, for MSL-2 (3.63V (2 4.5-5.5V when output is >3.0V (3) Measured across one 0.1uF ceramic capacitor and one 47uF ceramic capacitor; BW = 20MHz iBA/iBC Series 1 Model Selector Model iBA05008A008V-000-R iBA05008A008V-001-R iBC12007A008V-000-R iBC12007A008V-001-R iBC12007A008V-002-R Output Voltage Output Adjust Output Curr. (A) Max. Output Power (W) Efficiency at Full Load (%) 0.75 - 3.63 0.75 - 3.63 0.8 - 5.0 0.8 - 5.0 0.8 - 5.0 0.75 - 3.63 0.75 - 3.63 0.8 - 5.0 0.8 - 5.0 0.8 - 5.0 8 8 7 7 7 26.4 26.4 35 35 35 94 94 93 93 93 NB other configurations on request Recommended Footprint iBA iBC Series (Top View) iBA iBC Feature Set Feature Set Pos. Logic On / Off iBA 00 01 X 00 01* 02 03 05 06 X iBC Pinout Neg. Logic On / Off Sequencing (6-14V) Input Rng PIN iBA X X X X 1 2 3 4 5 6 Vin Gnd Trim Vout On/Off - X X X X X X X X X * Preferred feature set Model Number Example: iBC12007A008V-001-R 2 iBA/iBC Series Function iBC On/Off Vin Seq Gnd Trim Vout TDK-LAMBDA EMEA www.emea.tdk-lambda.com TDK-Lambda France SAS TDK-Lambda UK Ltd. Route de Grivery ZAC des Delaches CS 41077 91978 Courtaboeuf Cedex France Tel: +33 1 60 12 71 65 Fax: +33 1 60 12 71 66 france@fr.tdk-lambda.com www.fr.tdk-lambda.com Kingsley Avenue Ilfracombe Devon EX34 8ES United Kingdom Tel: +44 (0) 12 71 85 66 66 Fax: +44 (0) 12 71 86 48 94 powersolutions@uk.tdk-lambda.com www.uk.tdk-lambda.com Italy Sales Office Nemic Lambda Ltd. Via dei Lavoratori 128/130 20092 Cinisello Balsamo (MI) Italy Tel: +39 02 61 29 38 63 Fax: +39 02 61 29 09 00 info.italia@it.tdk-lambda.com www.it.tdk-lambda.com Kibbutz Givat Hashlosha 48800 Israel Tel: +9 723 902 4333 Fax: +9 723 902 4777 info@nemic.co.il www.nemic.co.il TDK-Lambda Germany GmbH Russia Karl-Bold-Strasse 40 77855 Achern Germany Tel: +49 7841 666 0 Fax: +49 7841 5000 info.germany@de.tdk-lambda.com www.de.tdk-lambda.com Technical Support: St Petersburg Tel: +7 (812) 6580463 Sales: Moscow Tel: +7 (499) 7557732 info@tdk-lambda.ru www.tdk-lambda.ru Austria Sales Office Aredstrasse 22 2544 Leobersdorf Austria Tel: +43 2256 655 84 Fax: +43 2256 645 12 info.germany@de.tdk-lambda.com www.de.tdk-lambda.com LOCAL DISTRIBUTION iBA/iBC June11 v3 3 iBA/iBC Series
IBC12007A008V-001-R 价格&库存
很抱歉,暂时无法提供与“IBC12007A008V-001-R”相匹配的价格&库存,您可以联系我们找货
