IBD12007A008V-000-R
IBD12007A008V-000-R
    TDK(东电化)
    SIP6 模块
    非隔离 PoL 模块 直流转换器 1 输出 0.8 ~ 5.5V 7A 6V - 14V 输入
IBD12007A008V-000-R 数据手册
• Standard SIP Footprint (DOSA) • 6.0-14VDC Input • 0.8 - 5.5V Outputs • Through Hole Mounting • Low 12.7mm Profile • Non Isolated Output Key Market Segments & Applications Telecom/Datcom Datacom Process Control Wireless Network Measurement & Test iBD Series 7A point of load converter iBD Features and Benefits Features Benefits • High operating efficiency (up to 92%) • Constant 240kHz switching frequency • Starts with pre-biased output • Reduced system heating • Easier system filtering • Supports complex digital systems Specifications MODEL ITEMS Nominal Output Voltage Input Voltage Range Input Current (max) Output Voltage Tolerance Ripple & Noise (max) (pk - pk) Line Regulation (max) Load Regulation (typical) Overload Protection Overvoltage Protection Remote Sense Remote On / Off Sequencing Temperature (operating) Temperature (storage) Humidity (operating) Humidity (storage) Cooling Isolation Voltage Vibration (non operating) Shock Safety Agency Certifications Weight (max) Size (LxWxH) Warranty VDC VDC A % mV % mV A °C °C %RH %RH g mm yrs iBD 0.8 - 5.5V 6 - 14V 7A ±3.5 125 0.2% 20 Inception- 11.5A; Short circuit - auto recovery N/A Yes Positive Logic standard. Negative logic available, see detailed datasheet Yes -40 to 105 (See detailed datasheet for derating) -55 to 125 20-95 Non condensing 10-95 Non condensing Convection or forced air (See detailed datasheet for derating) None 5 to 50Hz@0.5g(4.9m/s2), & 50 to 500Hz@1.5g(14.7m/s2) per Bellcore TR-EOP-000063-5.4.4 196.1m/s2 Pending - UL60950 (US and Canada), VDE0805 (IEC60950), CB scheme (IEC60950) 6 25.4 x 8.51 x 12.7 3 Years iBD Series 1 Model Selector Model Output Voltage iBD12007A008V-000-R 0.80 - 5.5 Output Adjust Output Curr. (A) Max. Output Power (W) Efficiency at Full Load (%) 0.80 - 5.5 7 35 92% at 5V Outline Drawing iBD Pinout PIN 1 2 3 A 4 5 2 Function Vout Trim GND Sequencing Vin On / Off iBD Series TDK-LAMBDA EMEA www.emea.tdk-lambda.com TDK-Lambda France SAS TDK-Lambda UK Ltd. Route de Grivery ZAC des Delaches CS 41077 91978 Courtaboeuf Cedex France Tel: +33 1 60 12 71 65 Fax: +33 1 60 12 71 66 france@fr.tdk-lambda.com www.fr.tdk-lambda.com Kingsley Avenue Ilfracombe Devon EX34 8ES United Kingdom Tel: +44 (0) 12 71 85 66 66 Fax: +44 (0) 12 71 86 48 94 powersolutions@uk.tdk-lambda.com www.uk.tdk-lambda.com Italy Sales Office Nemic Lambda Ltd. Via dei Lavoratori 128/130 20092 Cinisello Balsamo (MI) Italy Tel: +39 02 61 29 38 63 Fax: +39 02 61 29 09 00 info.italia@it.tdk-lambda.com www.it.tdk-lambda.com Kibbutz Givat Hashlosha 48800 Israel Tel: +9 723 902 4333 Fax: +9 723 902 4777 info@nemic.co.il www.nemic.co.il TDK-Lambda Germany GmbH Russia Karl-Bold-Strasse 40 77855 Achern Germany Tel: +49 7841 666 0 Fax: +49 7841 5000 info.germany@de.tdk-lambda.com www.de.tdk-lambda.com Technical Support: St Petersburg Tel: +7 (812) 6580463 Sales: Moscow Tel: +7 (499) 7557732 info@tdk-lambda.ru www.tdk-lambda.ru Austria Sales Office Aredstrasse 22 2544 Leobersdorf Austria Tel: +43 2256 655 84 Fax: +43 2256 645 12 info.germany@de.tdk-lambda.com www.de.tdk-lambda.com LOCAL DISTRIBUTION iBD June11 v2 3 iBD Series
IBD12007A008V-000-R 价格&库存
很抱歉,暂时无法提供与“IBD12007A008V-000-R”相匹配的价格&库存,您可以联系我们找货
