IBF15-100DD125X125
IBF15-100DD125X125
    TDK(东电化)
    RF ABSORBING SHEET IBF FLEXIELD
IBF15-100DD125X125 数据手册
M A G N E T I C S H E E T June 2016 Magnetic Sheets for RFID Flexield IFL/IBF series (2/8) MAGNETIC SHEET REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS When mounting on live electrical parts directly, there is a fear that an insulation accident is caused, so please consider on the design in case of use. There is a fear that sullenness of double sided adhesive tape occurs, so please refrain from the use to a part where you wind repeatedly by which it's for the hinge part. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. When the damage occurs by having been used the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please understand that the responsibility cannot be taken. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When using these products in general purposes and standard use, it is recommended that protection circuits are used, devices are secured, and backup circuits are kept for increased safety. 20160609 / magnetic-sheet_rfid_en.fm (3/8) MAGNETIC SHEET Magnetic Sheets for RFID Product compatible with RoHS directive Flexield Overview of IFL/IBF Series FEATURES High permeability, low magnetic loss (13.56MHz). It's also possible to load on a little gap because it's thin type. Has flexibility , it does not crack by impact or the like . Offer by a roll shape is possible (IFL04). APPLICATION For improving reception performance in RFID reader/writers. Integrate IC cards with metal. Integrate IC tags with metal. Improved antenna reception sensitivity. STANDARD SHAPE LIST Material Thickness (mm) 0.05 0.1 0.2 0.1 0.18 IFL04 IBF15 Roll Sheet dimensions (mm) Width (mm) Length (m) 300×200 300 100 125×125 — — IFL IBF Sheet Roll Sheet RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/ Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160609 / magnetic-sheet_rfid_en.fm (4/8) MAGNETIC SHEET IFL Series Sheet Type PART NUMBER CONSTRUCTION IFL Series name 04 Material symbol 04 050 N Magnetic material thickness (mm) 050 0.05 100 0.10 200 0.20 Surface film thickness (mm) N No R 0.038 R: Release type B 300 Double-sided tape thickness (mm) N No B 0.01 D 0.03 × Length (mm) 300 200 Width (mm) 300 200 200 Surface film Magnetic sheet Double-sided Release liner Length Width STANDARD PART NUMBER LIST Material IFL04 Standard dimensionss Thickness (mm) 0.05 300×200 0.1 0.2 Part number IFL04-050NB300×200 IFL04-100NB300×200 IFL04-200ND300×200 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160609 / magnetic-sheet_rfid_en.fm (5/8) MAGNETIC SHEET IFL Series Roll Type PART NUMBER CONSTRUCTION IFL Series name 04 Material symbol 04 050 Magnetic material thickness (mm) 050 0.05 100 0.10 R Surface film thickness (mm) N No R 0.038 R: Release type N Double-sided tape thickness (mm) N No B 0.01 D 0.03 1HR × Length (m) 1HR 300 Width (mm) 100 300 300 Surface film Magnetic sheet Double-sided Release liner Length Width STANDARD PART NUMBER LIST Material Width (mm) Length (m) IFL04 300 100 Thickness Part number (mm) 0.05 IFL04-050RN1HRX300 0.1 IFL04-100RN1HRX300 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160609 / magnetic-sheet_rfid_en.fm (6/8) MAGNETIC SHEET IFL Series MATERIAL CHARACTERISTIC MATERIAL CHARACTERISTIC SPECIFICATION TABLE Material name Relative permeability μ' [at 13.56MHz] typ. IFL04 45 Relative permeability μ" Surface resistivity [at 13.56MHz] (:/sq.)min typ. 1.3 10k Thermal conductivity (W/m・K) 1.5 Operating temperature range (°C) –40 to +85 RELATIVE PERMEABILITY 180 160 Relative permeability 140 120 100 80 60 IFL04 μ’ 40 20 IFL04 μ’’ 0 1 10 Frequency (MHz) 100 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160609 / magnetic-sheet_rfid_en.fm (7/8) MAGNETIC SHEET IBF Series MATERIAL CHARACTERISTIC IBF Series name 15 Material symbol 15 100 D D 125 Magnetic material thickness (mm) 100 0.10 180 0.18 Surface film thickness (mm) D 0.03 Double-sided tape thickness (mm) D 0.03 × Length (m) 125 125 Width (mm) 125 125 125 Surface film Magnetic sheet Double-sided Length Release liner Width STANDARD PART NUMBER LIST Material Standard dimensions (mm) IBF15 125×125 Thickness Part number (mm) 0.1 IBF15-100DD125X125 0.18 IBF15-180DD125X125 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160609 / magnetic-sheet_rfid_en.fm (8/8) MAGNETIC SHEET IBF Series MATERIAL CHARACTERISTIC MATERIAL CHARACTERISTIC SPECIFICATION TABLE Material name Relative permeability μ' [at 13.56MHz] typ. IBF15 150 Relative permeability μ" Surface resistivity [at 13.56MHz] (:/sq.)min typ. 5 1G Thermal conductivity (W/m・K) — Operating temperature range (°C) –40 to +85 RELATIVE PERMEABILITY 180 160 Relative permeability 140 IBF15 μ’ 120 100 80 60 40 20 0 IBF15 μ’’ 1 10 Frequency (MHz) 100 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160609 / magnetic-sheet_rfid_en.fm
IBF15-100DD125X125 价格&库存
很抱歉,暂时无法提供与“IBF15-100DD125X125”相匹配的价格&库存,您可以联系我们找货
