ICG-20330
ICG-20330
    TDK(东电化)
    ICG-20330
ICG-20330 数据手册
ICG-20330  High Performance 3-Axis OIS/EIS Optimized MEMS Gyro APPLICATIONS  GENERAL DESCRIPTION   The ICG-20330 is a 3-axis MotionTracking® device that includes a 3-axis gyroscope in a small 3x3x 0.75 mm (16-pin LGA) package.     High performance specs o Gyroscope sensitivity error: ±1% o Gyroscope noise: 5 mdps/Hz FEATURES   Includes 512-byte FIFO to reduce traffic on the serial bus interface, and reduce power consumption by allowing the system processor to burst read sensor data and then go into a low-power mode EIS FSYNC support 1% Gyro initial sensitivity eliminates OIS dynamic calibration Optimized OIS/EIS programmable gyro FSR of ±31.25dps, ±62.5dps, ±125ps and ±250dps High Resolution at up to 1048 LSB/(º/s) Low 5mdps/√Hz Noise User-programmable interrupts Wake-on-motion interrupt for low power operation of applications processor 512-byte FIFO buffer enables the applications processor to read the data in bursts On-Chip 16-bit ADCs and Programmable Filters Host interface: 7 MHz SPI or 400 kHz Fast Mode I2C Digital-output temperature sensor VDD operating range of 1.71 V to 3.45 V MEMS structure hermetically sealed and bonded at wafer level RoHS and Green compliant      ICG-20330 includes on-chip 16-bit ADCs, programmable digital filters, an embedded temperature sensor, and programmable interrupts. The device features an operating voltage range down to 1.71V. Communication ports include I2C and high-speed SPI at 7 MHz.    ORDERING INFORMATION  PART  OIS (Optical Image Stabilization) in phone camera modules, DSLR, and DSC EIS (Electronic Image Stabilization) in DSC, and phone camera modules AXES TEMP RANGE  PACKAGE  ICG‐20330†   X,Y,Z  ‐40°C to +85°C  16‐Pin LGA      †Denotes RoHS and Green-Compliant Package TYPICAL OPERATING CIRCUIT  BLOCK DIAGRAM  1.8 – 3.3VDC 16 INT X Gyro Self test Y Gyro Self test Z Gyro ADC ADC ADC Interrupt Status Register Signal Conditioning Self test VDDIO 1.8 – 3.3 VDC CS Slave I2C and SPI Serial Interface FIFO C3, 10 nF SA0 / SDO SCL / SPC SDA / SDI RESV VDD C4, 2.2 F C2, 0.1 F ICG-20330 SCL SCL/SPC SDA SDA/SDI AD0 SA0/SDO VDDIO User & Config Registers CS REGOUT 15 14 C1, 0.47 F GND 1 13 2 12 NC 11 NC 3 ICG-20330 4 10 5 9 NC NC FSYNC Sensor Registers Bias & LDOs VDD InvenSense reserves the right to change the detail specifications as may be required to permit improvements in the design of its products. GND 7 8 FSYNC Charge Pump 6 INT ADC RESV Temp Sensor REGOUT InvenSense Inc. 1745 Technology Drive, San Jose, CA 95110 U.S.A +1(408) 988–7339 www.invensense.com Document Number: DS-000127 Revision: 1.0 Release Date: 06/15/2016 ICG-20330 TABLE OF CONTENTS  General Description ........................................................................................................................................ 1  Ordering Information ...................................................................................................................................... 1  Block Diagram ................................................................................................................................................. 1  Applications .................................................................................................................................................... 1  Features .......................................................................................................................................................... 1  Typical Operating Circuit ................................................................................................................................. 1  1  2  3  INTRODUCTION ........................................................................................................................................... 7  1.1  Purpose and Scope ............................................................................................................................... 7  1.2  Product Overview................................................................................................................................. 7  1.3  Applications .......................................................................................................................................... 7  Features ....................................................................................................................................................... 8  2.1  Gyroscope Features ............................................................................................................................. 8  2.2  Additional Features .............................................................................................................................. 8  Electrical Characteristics ............................................................................................................................. 9  3.1  Gyroscope Specifications ..................................................................................................................... 9  3.2  Electrical Specifications ...................................................................................................................... 10  3.2.2  D.C. Electrical Characteristics ..................................................................................................... 10  3.2.2  A.C. Electrical Characteristics ...................................................................................................... 11  3.2.3  Other Electrical Specifications .................................................................................................... 12  4  3.3  I2C Timing Characterization ................................................................................................................ 13  3.4  SPI Timing Characterization ............................................................................................................... 14  3.5  Absolute Maximum Ratings ............................................................................................................... 15  Applications Information ........................................................................................................................... 16  4.1  Pin Out Diagram and Signal Description ............................................................................................ 16  4.2  Typical Operating Circuit .................................................................................................................... 17  4.3  Bill of Materials for External Components ......................................................................................... 17  4.4  Block Diagram .................................................................................................................................... 18  4.5  Overview ............................................................................................................................................ 18  4.6  Three‐Axis MEMS Gyroscope with 16‐bit ADCs and Signal Conditioning .......................................... 18  4.7  I2C and SPI Serial Communications Interfaces ................................................................................... 19  4.7.1  ICG‐20330 Solution Using I2C Interface ...................................................................................... 19  4.7.2  ICG‐20330 Solution Using SPI Interface ...................................................................................... 20  Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 2 of 56 ICG-20330 4.8  Self‐Test .............................................................................................................................................. 20  4.9  Clocking .............................................................................................................................................. 21  4.10  Sensor Data Registers ........................................................................................................................ 21  4.11  FIFO .................................................................................................................................................... 21  4.12  Interrupts ........................................................................................................................................... 21  4.13  Digital‐Output Temperature Sensor .................................................................................................. 21  4.14  Bias and LDOs ..................................................................................................................................... 21  4.15  Charge Pump ...................................................................................................................................... 22  4.16  Standard Power Modes ...................................................................................................................... 22  5  Programmable Interrupts .......................................................................................................................... 23  6  Digital Interface ......................................................................................................................................... 24  6.1  I2C and SPI Serial Interfaces ............................................................................................................... 24  6.2  I2C Interface ........................................................................................................................................ 24  6.3  I2C Communications Protocol ............................................................................................................ 24  6.4  I2C Terms ............................................................................................................................................ 27  6.5  SPI Interface ....................................................................................................................................... 28  7  Serial Interface Considerations ................................................................................................................. 29  7.1  8  ICG‐20330 Supported Interfaces ........................................................................................................ 29  Assembly ................................................................................................................................................... 30  8.1  Orientation of Axes ............................................................................................................................ 30  8.2  Package Dimensions ........................................................................................................................... 31  9  Part Number Package Marking ................................................................................................................. 33  10  Reference ............................................................................................................................................... 34  11  Register Map .......................................................................................................................................... 35  12  Register Descriptions ............................................................................................................................. 37  12.1  Registers 0 to 2 – Gyroscope Self‐Test Registers ............................................................................... 37  12.2  Register 4 – Gyroscope Offset Temperature Compensation (TC) Register ........................................ 38  12.3  Register 5 – Gyroscope Offset Temperature Compensation (TC) Register ........................................ 38  12.4  Register 07 – Gyroscope Offset Temperature Compensation (TC) Register ...................................... 39  Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 3 of 56 ICG-20330 12.5  Register 08 – Gyroscope Offset Temperature Compensation (TC) Register ...................................... 39  12.6  Register 10 – Gyroscope Offset Temperature Compensation (TC) Register ...................................... 39  12.7  Register 11 – Gyroscope Offset Temperature Compensation (TC) Register ...................................... 40  12.8  Registers 19 – Gyro Offset Adjustment Register ............................................................................... 40  12.9  Registers 20 – Gyro Offset Adjustment Register ............................................................................... 40  12.10  Registers 21 – Gyro Offset Adjustment Register ............................................................................ 41  12.11  Registers 22 – Gyro Offset Adjustment Register ............................................................................ 41  12.12  Registers 23 – Gyro Offset Adjustment Register ............................................................................ 41  12.13  Register 24 – Gyro Offset Adjustment Register ............................................................................. 42  12.14  Register 25 – Sample Rate Divider ................................................................................................. 42  12.15  Register 26 – Configuration ............................................................................................................ 43  12.16  Register 27 – Gyroscope Configuration .......................................................................................... 44  12.17  Register 35 – FIFO Enable ............................................................................................................... 45  12.18  Register 54 – FSYNC Interrupt Status ............................................................................................. 46  12.19  Register 55 – INT Pin / Bypass Enable Configuration ..................................................................... 46  12.20  Register 56 – Interrupt Enable ....................................................................................................... 47  12.21  Register 58 – Interrupt Status ........................................................................................................ 47  12.22  Registers 65 and 66 – Temperature Measurement ....................................................................... 48  12.23  Registers 67 to 72 – Gyroscope Measurements ............................................................................. 49  12.24  Register 104 – Signal Path Reset .................................................................................................... 50  12.24  Register 106 – User Control............................................................................................................ 51  12.25  Register 107 – Power Management 1 ............................................................................................ 52  12 26  Register 108 – Power Management 2 ............................................................................................ 53  12.27  Register 114 and 115 – FIFO Count Registers ................................................................................ 53  12.28  Register 116 – FIFO Read Write ...................................................................................................... 54  12.29  Register 117 – Who Am I ................................................................................................................ 54  13  Revision History ..................................................................................................................................... 55      Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016   Page 4 of 56 ICG-20330 LIST OF FIGURES  Figure 1. I2C Bus Timing Diagram ...................................................................................................................... 13  Figure 2. SPI Bus Timing Diagram ..................................................................................................................... 14  Figure 3. Pin‐out Diagram for ICG‐20330 3.0x3.0x0.75 mm LGA ..................................................................... 16  Figure 4. ICG‐20330 LGA Application Schematic .............................................................................................. 17  Figure 5. ICG‐20330 Block Diagram .................................................................................................................. 18  Figure 6. ICG‐20330 Solution Using I2C Interface ............................................................................................. 19  Figure 7. ICG‐20330 Solution Using SPI Interface ............................................................................................. 20  Figure 8. START and STOP Conditions .............................................................................................................. 25  Figure 9. Acknowledge on the I2C Bus .............................................................................................................. 25  Figure 10. Complete I2C Data Transfer ............................................................................................................. 26  Figure 11. Typical SPI Master / Slave Configuration ......................................................................................... 28  Figure 12. I/O Levels and Connections ............................................................................................................. 29  Figure 13. Orientation of Axes of Sensitivity and Polarity of Rotation ............................................................. 30  Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 5 of 56 ICG-20330 LIST OF TABLES  Table 1. Gyroscope Specifications ...................................................................................................................... 9  Table 2. D.C. Electrical Characteristics .............................................................................................................. 10  Table 3. A.C. Electrical Characteristics .............................................................................................................. 12  Table 4. Other Electrical Specifications ............................................................................................................ 12  Table 5. I2C Timing Characteristics ................................................................................................................... 13  Table 6. SPI Timing Characteristics (7 MHz Operation) .................................................................................... 14  Table 7. Absolute Maximum Ratings ................................................................................................................ 15  Table 8. Signal Descriptions .............................................................................................................................. 16  Table 9. Bill of Materials ................................................................................................................................... 17  Table 10. Standard Power Modes for ICG‐20330 ............................................................................................. 22  Table 11. Table of Interrupt Sources ................................................................................................................ 23  Table 12. Serial Interface .................................................................................................................................. 24  Table 13. I2C Terms ........................................................................................................................................... 27  Table 14. ICG‐20330 Register Map ................................................................................................................... 36  Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 6 of 56 ICG-20330 1 INTRODUCTION  1.1  PURPOSE AND SCOPE  This document is a preliminary product specification, providing a description, specifications, and design related information on the ICG-20330 MotionTracking device for imaging applications, such as Optical Image Stabilization, OIS, or Electronic Image Stabilization, EIS. The device is housed in a small 3x3x0.75 mm 16-pin LGA package. 1.2  PRODUCT OVERVIEW  The ICG-20330 is a 3-axis MotionTracking device that has a 3-axis gyroscope in a small 3x3x0.75 mm (16-pin LGA) package. It also features a 512-byte FIFO for EIS applications to lower the traffic on the serial bus interface, and reduce power consumption by allowing the system processor to burst read sensor data for a given video frame. The unique support for FSYNC (frame sync), facilitates synchronization of Video Frame Sync from Image sensors and Motion data from gyro collected during a given frame via an interrupt to the host. The gyroscope has a programmable full-scale range of ±31.25, ±62.5, ±125 and ±250 degrees/sec, optimized for Image Stabilization applications. Other industry-leading features include on-chip 16-bit ADCs, programmable digital filters, an embedded temperature sensor, and programmable interrupts. The device features I2C and SPI serial interfaces, a VDD operating range of 1.71 V to 3.6 V, and a separate digital IO supply, VDDIO from 1.71 V to 3.6 V. Communication with all registers of the device is performed using either I2C at 400 kHz or SPI at 7 MHz. By leveraging its patented and volume-proven CMOS-MEMS fabrication platform, which integrates MEMS wafers with companion CMOS electronics through wafer-level bonding, InvenSense has driven the package size down to a footprint and thickness of 3x3x0.75 mm (16-pin LGA), to provide a very small yet high-performance, low-cost package. The device provides high robustness by supporting 10,000g shock reliability. 1.3  APPLICATIONS    OIS, Optical Image Stabilization in phone camera modules, DSLR, and DSC EIS, Electronic Image Stabilization in DSC, and phone camera modules Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 7 of 56 ICG-20330 2 FEATURES  2.1  GYROSCOPE FEATURES  The triple-axis MEMS gyroscope in the ICG-20330 includes a wide range of features:     Digital-output X-, Y-, and Z-axis angular rate sensors (gyroscopes) with a user-programmable fullscale range of ±31.25, ±62.5, ±125 and ±250 °/sec and integrated 16-bit ADCs Digitally-programmable low-pass filter Factory calibrated sensitivity scale factor Self-test 2.2  ADDITIONAL FEATURES  The ICG-20330 includes the following additional features:         512-byte FIFO buffer enable the applications processor to read the data in bursts Digital-output temperature sensor User-programmable digital filters for gyroscope and temp sensor 10,000 g shock tolerant 400-kHz Fast Mode I2C for communicating with all registers 7-MHz SPI serial interface for communicating with all registers MEMS structure hermetically sealed and bonded at wafer level RoHS and Green compliant Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 8 of 56 ICG-20330 3 ELECTRICAL CHARACTERISTICS  3.1  GYROSCOPE SPECIFICATIONS  Typical Operating Circuit of section 0, VDD = 1.8 V, VDDIO = 1.8 V, TA = 25°C, unless otherwise noted. PARAMETER CONDITIONS MIN TYP MAX UNITS NOTES GYROSCOPE SENSITIVITY Full-Scale Range ADC Word Length Sensitivity Scale Factor Sensitivity Scale Factor Tolerance Sensitivity Scale Factor Variation Over Temperature Nonlinearity Cross-Axis Sensitivity FS_SEL= 0 FS_SEL= 1 FS_SEL= 2 FS_SEL= 3 FS_SEL= 0 FS_SEL=1 FS_SEL= 2 FS_SEL= 3 25°C -20°C to +75°C Best fit straight line; 25°C ±31.25 ±62.5 ±125 ±250 16 1048 524 262 131 ±1 ±3 º/s º/s º/s º/s bits LSB/(º/s) LSB/(º/s) LSB/(º/s) LSB/(º/s) % % 3 3 3 3 3 3 3 3 3 1 1 ±0.1 ±2 % % 1 1 ±5 ±5 º/s º/s 2 1 0.06 0.30 0.005 º/s-rms º/s-p-p º/s/√Hz 2 2 2 29 KHz KHz 250 Hz 2 1 3 ms 1 ZERO-RATE OUTPUT (ZRO) Initial ZRO Tolerance ZRO Variation Over Temperature 25°C -20°C to +75°C GYROSCOPE NOISE PERFORMANCE (FS_SEL=0) Total RMS Noise Total Peak-to-Peak Noise Rate Noise Spectral Density GYROSCOPE MECHANICAL Mechanical Frequency Sensor Mechanical Bandwidth LOW PASS FILTER RESPONSE DLPFCFG = 2 (92 Hz) DLPFCFG = 2 (92 Hz) At 10 Hz 25 1.6 Programmable Range 92 80 GYROSCOPE START-UP TIME OUTPUT DATA RATE 27 Programmable, Normal (Filtered) mode 1000 8000 Table 1. Gyroscope Specifications Notes: 1. 2. 3. 4. Derived from validation or characterization of parts on PCB, not guaranteed in production. Tested in production. Guaranteed by design. Calculated from Total RMS Noise. Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 9 of 56 Hz 1 ICG-20330 3.2  ELECTRICAL SPECIFICATIONS  3.2.2  D.C. Electrical Characteristics  Typical Operating Circuit of section 0, VDD = 1.8 V, VDDIO = 1.8 V, TA = 25°C, unless otherwise noted. PARAMETER CONDITIONS MIN TYP MAX UNITS NOTES VDD 1.71 1.8 3.45 V 1 VDDIO 1.71 1.8 3.45 V 1 SUPPLY VOLTAGES SUPPLY CURRENTS & BOOT TIME Active Current Full-Chip Sleep Mode Boot Time 3-Axis Gyroscope 2.9 mA 1 VDD on to first register write 10 50 µA ms 1 1 °C 1 TEMPERATURE RANGE Operating Temperature Range -40 +85 Table 2. D.C. Electrical Characteristics Notes: 1. Derived from validation or characterization of parts, not guaranteed in production. 2. Based on simulation. Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 10 of 56 ICG-20330 3.2.2  A.C. Electrical Characteristics  Typical Operating Circuit of section 0, VDD = 1.8 V, VDDIO = 1.8 V, TA = 25°C, unless otherwise noted. Parameter Conditions MIN TYP MAX UNITS NOTES 100 ms 1 85 °C 1 0 °C 1 326.8 LSB/°C 1 100 ms 1 100 ms 1 0.3*VDDIO V V pF 1 SUPPLIES Supply Ramp Time Monotonic ramp. Ramp rate is 10% to 90% of the final value 0.01 TEMPERATURE SENSOR Operating Range Ambient Room Temperature Offset 25°C Sensitivity Untrimmed -40 Power-On RESET Supply Ramp Time (TRAMP) Valid power-on RESET Start-up time for register read/write From power-up I2C ADDRESS SA0 = 0 SA0 = 1 0.01 11 1101000 1101001 DIGITAL INPUTS (FSYNC, SA0, SPC, SDI, CS) VIH, High Level Input Voltage VIL, Low Level Input Voltage CI, Input Capacitance 0.7*VDDIO < 10 DIGITAL OUTPUT (SDO, INT) VOH, High Level Output Voltage VOL1, LOW-Level Output Voltage VOL.INT, INT Low-Level Output Voltage Output Leakage Current tINT, INT Pulse Width RLOAD = 1MΩ; RLOAD = 1MΩ; 0.9*VDDIO 0.1*VDDIO 0.1 OPEN = 1, 0.3 mA sink Current OPEN = 1 LATCH_INT_EN = 0 100 50 V V V 1 nA µs I2C I/O (SCL, SDA) VIL, LOW Level Input Voltage VIH, HIGH-Level Input Voltage Vhys, Hysteresis VOL, LOW-Level Output Voltage IOL, LOW-Level Output Current Output Leakage Current tof, Output Fall Time from VIHmax to VILmax -0.5V 0.7*VDDIO 0.3*VDDIO VDDIO + 0.5V 0.1*VDDIO 3 mA sink current VOL = 0.4V VOL = 0.6 V Cb bus capacitance in pf 0 0.4 3 6 100 300 20+0.1Cb V V V V mA mA nA ns 1 INTERNAL CLOCK SOURCE Sample Rate Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 FCHOICE_B = 1,2,3 SMPLRT_DIV = 0 FCHOICE_B = 0; DLPFCFG = 0 or 7 SMPLRT_DIV = 0 FCHOICE_B = 0; DLPFCFG = 1,2,3,4,5,6; SMPLRT_DIV = 0 32 kHz 2 8 kHz 2 1 kHz 2 Page 11 of 56 ICG-20330 Parameter Clock Frequency Initial Tolerance Frequency Variation over Temperature Conditions CLK_SEL = 0, 6 or gyro inactive; 25°C CLK_SEL = 1,2,3,4,5 and gyro active; 25°C CLK_SEL = 0,6 or gyro inactive CLK_SEL = 1,2,3,4,5 and gyro active MIN MAX UNITS -5 TYP +5 % 1 -1 +1 % 1 -10 +10 % 1 % 1 ±1 NOTES Table 3. A.C. Electrical Characteristics Notes: 1. Derived from validation or characterization of parts, not guaranteed in production. 2. Guaranteed by design. 3.2.3  Other Electrical Specifications  Typical Operating Circuit of section 0, VDD = 1.8 V, VDDIO = 1.8 V, TA = 25°C, unless otherwise noted. PARAMETER CONDITIONS MIN TYP MAX UNITS NOTES kHz 1 7 MHz 1, 2 400 100 kHz kHz 1 1 SERIAL INTERFACE SPI Operating Frequency, All Registers Read/Write Low Speed Characterization High Speed Characterization SPI Modes I2C Operating Frequency 100 ±10% 1 Modes 0 and 3 All registers, Fast-mode All registers, Standard-mode Table 4. Other Electrical Specifications Notes: 1. Derived from validation or characterization of parts, not guaranteed in production. 2. SPI clock duty cycle between 45% and 55% should be used for 7-MHz operation. Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 12 of 56 ICG-20330 3.3  I2C TIMING CHARACTERIZATION  Typical Operating Circuit of section 0, VDD = 1.8 V, VDDIO = 1.8 V, TA = 25°C, unless otherwise noted. Parameters I2C TIMING fSCL, SCL Clock Frequency tHD.STA, (Repeated) START Condition Hold Time Conditions I2C FAST-MODE MIN MAX UNITS NOTES 400 0.6 kHz µs 1 1 1.3 0.6 0.6 µs µs µs 1 1 1 0 100 20+0.1Cb 20+0.1Cb 0.6 µs ns ns ns µs 1 1 1 1 1 µs 1 pF µs µs 1 1 1 tLOW, SCL Low Period tHIGH, SCL High Period tSU.STA, Repeated START Condition Setup Time tHD.DAT, SDA Data Hold Time tSU.DAT, SDA Data Setup Time tr, SDA and SCL Rise Time tf, SDA and SCL Fall Time tSU.STO, STOP Condition Setup Time Cb bus cap. from 10 to 400 pF Cb bus cap. from 10 to 400 pF tBUF, Bus Free Time Between STOP and START Condition Cb, Capacitive Load for each Bus Line tVD.DAT, Data Valid Time tVD.ACK, Data Valid Acknowledge Time TYP 300 300 1.3 < 400 0.9 0.9 Table 5. I2C Timing Characteristics Notes: 1. Based on characterization of 5 parts over temperature and voltage as mounted on evaluation board or in sockets. tf SDA tSU.DAT tr 70% 30% 70% 30% continued below at tf SCL tr 70% 30 % S tVD.DAT 70% 30 % tHD.DAT tHD.STA 1/fSCL tLOW 1st clock cycle 9th clock cycle tHIGH tBUF SDA 70 % 30 % A tSU. STA tHD.STA SCL 70% 30 % Sr tSU.STO tVD.ACK 9th clock cycle P S Figure 1. I2C Bus Timing Diagram Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 13 of 56 A ICG-20330 3.4  SPI TIMING CHARACTERIZATION   Typical Operating Circuit of section 0, VDD = 1.8 V, VDDIO = 1.8 V, TA = 25°C, unless otherwise noted. Parameters MIN Conditions TYP MAX UNITS 7 MHz NOTES SPI TIMING fSCLK, SCLK Clock Frequency tLOW, SCLK Low Period 64 ns tHIGH, SCLK High Period 64 ns tSU.CS, CS Setup Time 8 ns tHD.CS, CS Hold Time 500 ns 5 ns tSU.SDI, SDI Setup Time tHD.SDI, SDI Hold Time 7 tVD.SDO, SDO Valid Time Cload = 20pF tHD.SDO, SDO Hold Time Cload = 20pF ns 59 ns 50 ns 6 tDIS.SDO, SDO Output Disable Time ns Table 6. SPI Timing Characteristics (7 MHz Operation) Notes: 1. CS Based on characterization of 5 parts over temperature and voltage as mounted on evaluation board or in sockets. 70% 30% tSU;CS SCLK tHIGH tHD;CS 1/fCLK 70% 30% tSU;SDI SDI 70% 30% tHD;SDI tLOW LSB IN MSB IN tDIS;SDO tVD;SDO SDO MSB OUT 70% 30% LSB OUT Figure 2. SPI Bus Timing Diagram Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 14 of 56 ICG-20330 3.5  ABSOLUTE MAXIMUM RATINGS  Stress above those listed as “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these conditions is not implied. Exposure to the absolute maximum ratings conditions for extended periods may affect device reliability. Parameter Rating Supply Voltage, VDD -0.5 V to +4 V Supply Voltage, VDDIO -0.5 V to +4 V REGOUT -0.5 V to 2 V Input Voltage Level (SA0, FSYNC, SCL, SDA) -0.5 V to VDD + 0.5 V Acceleration (Any Axis, unpowered) 10,000g for 0.2 ms Storage Temperature Range -40°C to +125°C 2 kV (HBM); 250 V (MM) Electrostatic Discharge (ESD) Protection Latch-up JEDEC Class II (2),125°C ±100 mA Table 7. Absolute Maximum Ratings Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 15 of 56 ICG-20330 4 APPLICATIONS INFORMATION  4.1  PIN OUT DIAGRAM AND SIGNAL DESCRIPTION  Pin Number Pin Name 1 VDDIO Pin Description 2 SCL/SPC I2C serial clock (SCL); SPI serial clock (SPC) 3 SDA/SDI I2C serial data (SDA); SPI serial data input (SDI) 4 SA0/SDO I2C slave address LSB (SA0); SPI serial data output (SDO) Digital I/O supply voltage 5 CS Chip select (0 = SPI mode; 1 = I2C mode) 6 INT Interrupt digital output (totem pole or open-drain) 7 RESV 8 FSYNC Reserved. Do not connect. 9 NC Connect to GND or do not connect 10 NC Connect to GND or do not connect 11 NC Connect to GND or do not connect 12 NC Connect to GND or do not connect 13 GND 14 REGOUT 15 RESV 16 VDD Synchronization digital input (optional). Connect to GND if unused. Connect to GND Regulator filter capacitor connection Reserved. Connect to GND Power Supply Table 8. Signal Descriptions REGOUT 14 VDD RESV 16 15 VDDIO 1 13 GND SCL/SPC 2 12 NC ICG-20330 SDA/SDI 3 11 NC SA0/SDO 4 10 NC CS 5 9 NC 6 7 8 INT RESV FSYNC LGA Package (Top View) 16-pin, 3 mm x 3 mm x 0.75 mm Typical Footprint and thickness +Z IC G20 +Y 33 0 +X Orientation of Axes of Sensitivity and Polarity of Rotation Figure 3. Pin-out Diagram for ICG-20330 3.0x3.0x0.75 mm LGA Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 16 of 56 ICG-20330 4.2  TYPICAL OPERATING CIRCUIT   1.8 – 3.3VDC RESV VDD C4, 2.2 F C2, 0.1 F 16 VDDIO 1.8 – 3.3 VDC C3, 10 nF SCL SCL/SPC SDA AD0 VDDIO SDA/SDI SA0/SDO CS REGOUT 15 14 C1, 0.47 F GND 1 13 2 12 NC 11 NC 3 ICG-20330 4 10 5 9 7 NC INT RESV 8 FSYNC 6 NC Figure 4. ICG-20330 LGA Application Schematic 4.3  BILL OF MATERIALS FOR EXTERNAL COMPONENTS  Component REGOUT Capacitor VDD Bypass Capacitors VDDIO Bypass Capacitor Label Specification Quantity C1 Ceramic, X7R, 0.47 µF ±10%, 2 V 1 C2 Ceramic, X7R, 0.1 µF ±10%, 4 V 1 C4 Ceramic, X7R, 2.2 µF ±10%, 4 V 1 C3 Ceramic, X7R, 10 nF ±10%, 4 V 1 Table 9. Bill of Materials Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 17 of 56 ICG-20330 4.4  BLOCK DIAGRAM   ICG-20330 INT X Gyro ADC Self test Y Gyro ADC Self test Z Gyro ADC Interrupt Status Register Signal Conditioning Self test CS Slave I2C and SPI Serial Interface FIFO SA0 / SDO SCL / SPC SDA / SDI User & Config Registers FSYNC Temp Sensor ADC Sensor Registers Charge Pump Bias & LDOs VDD GND REGOUT Figure 5. ICG-20330 Block Diagram 4.5  OVERVIEW  The ICG-20330 is comprised of the following key blocks and functions:            Three-axis MEMS rate gyroscope sensor with 16-bit ADCs and signal conditioning Primary I2C and SPI serial communications interfaces Self-Test Clocking Sensor Data Registers FIFO Interrupts Digital-Output Temperature Sensor Bias and LDOs Charge Pump Standard Power Modes 4.6  THREE‐AXIS MEMS GYROSCOPE WITH 16‐BIT ADCS AND SIGNAL CONDITIONING  The ICG-20330 consists of three independent vibratory MEMS rate gyroscopes, which detect rotation about the X-, Y-, and Z- Axes. When the gyros are rotated about any of the sense axes, the Coriolis Effect causes a vibration that is detected by a capacitive pickoff. The resulting signal is amplified, demodulated, and filtered to produce a voltage that is proportional to the angular rate. This voltage is digitized using individual on-chip 16-bit Analog-to-Digital Converters (ADCs) to sample each axis. The full-scale range of the gyro sensors may be digitally programmed to ±31.25, ±62.5, ±125 and ±250 degrees per second (dps). The ADC sample rate is programmable up to 8,000 samples per second with user-selectable low-pass filters that enable a wide range of cut-off frequencies. Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 18 of 56 ICG-20330 4.7  I2C AND SPI SERIAL COMMUNICATIONS INTERFACES  The ICG-20330 communicates to a system processor using either a SPI or an I2C serial interface. The ICG20330 always acts as a slave when communicating to the system processor. The LSB of the I2C slave address is set by pin 4 (SA0). 4.7.1  ICG‐20330 Solution Using I2C Interface  In the figure below, the system processor is an I2C master to the ICG-20330. Figure 6. ICG-20330 Solution Using I2C Interface Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 19 of 56 ICG-20330 4.7.2  ICG‐20330 Solution Using SPI Interface  In the figure below, the system processor is an SPI master to the ICG-20330. Pins 2, 3, 4, and 5 are used to support the SPC, SDI, SDO, and CS signals for SPI communications. Interrupt Status Register Processor SPI Bus : for reading all data INT CS ICG-20330 2 Slave I C or SPI Serial Interface nCS SDO SDI SPC SPC SDI SDO System Processor FIFO Config Register Sensor Register Factory Calibration Bias & LDOs VDD GND REGOUT Figure 7. ICG-20330 Solution Using SPI Interface 4.8  SELF‐TEST  Self-test allows for the testing of the mechanical and electrical portions of the sensors. The self-test for each measurement axis can be activated by means of the gyroscope self-test registers (registers 27 and 28). When the self-test is activated, the electronics cause the sensors to be actuated and produce an output signal. The output signal is used to observe the self-test response. The self-test response is defined as follows: Self-test response = Sensor output with self-test enabled – Sensor output with self-test disabled The self-test response for each gyroscope axis is defined in the gyroscope specification table. When the value of the self-test response is within the specified min/max limits of the product specification, the part has passed self-test. When the self-test response exceeds the min/max values, the part is deemed to have failed self-test. It is recommended to use InvenSense MotionApps software for executing self-test. For further information on Self-Test, please refer to the register map of ICG-20330. Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 20 of 56 ICG-20330 4.9  CLOCKING  The ICG-20330 has a flexible clocking scheme, allowing a variety of internal clock sources to be used for the internal synchronous circuitry. This synchronous circuitry includes the signal conditioning and ADCs, and various control circuits and registers. An on-chip PLL provides flexibility in the allowable inputs for generating this clock. Allowable internal sources for generating the internal clock are: a) An internal relaxation oscillator b) Auto-select between internal relaxation oscillator and gyroscope MEMS oscillator to use the best available source The only setting supporting specified performance in all modes is option b). It is recommended that option b) be used. 4.10  SENSOR DATA REGISTERS   The sensor data registers contain the latest gyroscope and temperature measurement data. They are readonly registers, and are accessed via the serial interface. Data from these registers may be read anytime. 4.11  FIFO  The ICG-20330 contains a 512-byte FIFO register that is accessible via the Serial Interface. The FIFO configuration register determines which data is written into the FIFO. Possible choices include gyro data and temperature readings, and FSYNC input. A FIFO counter keeps track of how many bytes of valid data are contained in the FIFO. The FIFO register supports burst reads. The interrupt function may be used to determine when new data is available. For further information regarding the FIFO, please refer to the register map of ICG-20330. 4.12  INTERRUPTS  Interrupt functionality is configured via the Interrupt Configuration register. Items that are configurable include the INT pin configuration, the interrupt latching and clearing method, and triggers for the interrupt. Items that can trigger an interrupt are (1) Clock generator locked to new reference oscillator (used when switching clock sources); (2) new data is available to be read (from the FIFO and Data registers); (3) FIFO overflow. The interrupt status can be read from the Interrupt Status register. 4.13  DIGITAL‐OUTPUT TEMPERATURE SENSOR  An on-chip temperature sensor and ADC are used to measure the ICG-20330 die temperature. The readings from the ADC can be read from the FIFO or the Sensor Data registers. 4.14  BIAS AND LDOS  The bias and LDO section generates the internal supply and the reference voltages and currents required by the ICG-20330. Its two inputs are an unregulated VDD and a VDDIO logic reference supply voltage. The LDO output is bypassed by a capacitor at REGOUT. For further details on the capacitor, please refer to the Bill of Materials for External Components. Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 21 of 56 ICG-20330 4.15  CHARGE PUMP  An on-chip charge pump generates the high voltage required for the MEMS oscillator. 4.16  STANDARD POWER MODES  The following table lists the user-accessible power modes for ICG-20330. Mode Name 1 Sleep Mode 2 Standby Mode Gyro Off Drive On Table 10. Standard Power Modes for ICG-20330 Notes: 1. Power consumption for individual modes can be found in section 0. Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 22 of 56 ICG-20330 5 PROGRAMMABLE INTERRUPTS  The ICG-20330 has a programmable interrupt system which can generate an interrupt signal on the INT pin. Status flags indicate the source of an interrupt. Interrupt sources may be enabled and disabled individually. Interrupt Name Module FIFO Overflow FIFO Data Ready Sensor Registers Table 11. Table of Interrupt Sources For information regarding the interrupt enable/disable registers and flag registers, please refer to the register map of ICG-20330 in this document. Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 23 of 56 ICG-20330 6 DIGITAL INTERFACE  6.1  I2C AND SPI SERIAL INTERFACES  The internal registers and memory of the ICG-20330 can be accessed using either I2C at 400 kHz or SPI at 7 MHz. SPI operates in four-wire mode. Pin Number Pin Name 1 VDDIO Pin Description 4 SA0 / SDO I2C Slave Address LSB (SA0); SPI serial data output (SDO) 2 SCL / SPC I2C serial clock (SCL); SPI serial clock (SPC) 3 SDA / SDI I2C serial data (SDA); SPI serial data input (SDI) Digital I/O supply voltage. Table 12. Serial Interface Note: To prevent switching into I2C mode when using SPI, the I2C interface should be disabled by setting the I2C_IF_DIS configuration bit. Setting this bit should be performed immediately after waiting for the time specified by the “Start-Up Time for Register Read/Write” in Section 6.3. For further information regarding the I2C_IF_DIS bit, please refer to the register map of ICG-20330. 6.2  I2C INTERFACE  I2C is a two-wire interface comprised of the signals serial data (SDA) and serial clock (SCL). In general, the lines are open-drain and bi-directional. In a generalized I2C interface implementation, attached devices can be a master or a slave. The master device puts the slave address on the bus, and the slave device with the matching address acknowledges the master. The ICG-20330 always operates as a slave device when communicating to the system processor, which thus acts as the master. SDA and SCL lines typically need pull-up resistors to VDD. The maximum bus speed is 400 kHz. The slave address of the ICG-20330 is b110100X which is 7 bits long. The LSB bit of the 7-bit address is determined by the logic level on pin SA0. This allows two ICG-20330s to be connected to the same I2C bus. When used in this configuration, the address of one of the devices should be b1101000 (pin SA0 is logic low) and the address of the other should be b1101001 (pin SA0 is logic high). 6.3  I2C COMMUNICATIONS PROTOCOL  START (S) and STOP (P) Conditions Communication on the I2C bus starts when the master puts the START condition (S) on the bus, which is defined as a HIGH-to-LOW transition of the SDA line while SCL line is HIGH (see figure below). The bus is considered to be busy until the master puts a STOP condition (P) on the bus, which is defined as a LOW to HIGH transition on the SDA line while SCL is HIGH (see figure below). Additionally, the bus remains busy if a repeated START (Sr) is generated instead of a STOP condition. Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 24 of 56 ICG-20330 SDA SCL S P START condition STOP condition Figure 8. START and STOP Conditions Data Format / Acknowledge I2C data bytes are defined to be 8 bits long. There is no restriction to the number of bytes transmitted per data transfer. Each byte transferred must be followed by an acknowledge (ACK) signal. The clock for the acknowledge signal is generated by the master, while the receiver generates the actual acknowledge signal by pulling down SDA and holding it low during the HIGH portion of the acknowledge clock pulse. If a slave is busy and cannot transmit or receive another byte of data until some other task has been performed, it can hold SCL LOW, thus forcing the master into a wait state. Normal data transfer resumes when the slave is ready, and releases the clock line (refer to the following figure). DATA OUTPUT BY TRANSMITTER (SDA) not acknowledge DATA OUTPUT BY RECEIVER (SDA) acknowledge SCL FROM MASTER 1 2 START condition 8 9 clock pulse for acknowledgement Figure 9. Acknowledge on the I2C Bus Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 25 of 56 ICG-20330 Communications After beginning communications with the START condition (S), the master sends a 7-bit slave address followed by an 8th bit, the read/write bit. The read/write bit indicates whether the master is receiving data from or is writing to the slave device. Then, the master releases the SDA line and waits for the acknowledge signal (ACK) from the slave device. Each byte transferred must be followed by an acknowledge bit. To acknowledge, the slave device pulls the SDA line LOW and keeps it LOW for the high period of the SCL line. Data transmission is always terminated by the master with a STOP condition (P), thus freeing the communications line. However, the master can generate a repeated START condition (Sr), and address another slave without first generating a STOP condition (P). A LOW to HIGH transition on the SDA line while SCL is HIGH defines the stop condition. All SDA changes should take place when SCL is low, with the exception of start and stop conditions. SDA SCL 1 –7 8 9 1–7 8 9 1–7 8 9 S P START ADDRESS condition ACK R/W DATA ACK DATA ACK STOP condition Figure 10. Complete I2C Data Transfer To write the internal ICG-20330 registers, the master transmits the start condition (S), followed by the I2C address and the write bit (0). At the 9th clock cycle (when the clock is high), the ICG-20330 acknowledges the transfer. Then the master puts the register address (RA) on the bus. After the ICG-20330 acknowledges the reception of the register address, the master puts the register data onto the bus. This is followed by the ACK signal, and data transfer may be concluded by the stop condition (P). To write multiple bytes after the last ACK signal, the master can continue outputting data rather than transmitting a stop signal. In this case, the ICG20330 automatically increments the register address and loads the data to the appropriate register. The following figures show single and two-byte write sequences. Single-Byte Write Sequence Master S AD+W Slave RA ACK DATA ACK P ACK Burst Write Sequence Master S AD+W Slave Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 RA ACK DATA ACK DATA ACK P ACK Page 26 of 56 ICG-20330 To read the internal ICG-20330 registers, the master sends a start condition, followed by the I2C address and a write bit, and then the register address that is going to be read. Upon receiving the ACK signal from the ICG20330, the master transmits a start signal followed by the slave address and read bit. As a result, the ICG20330 sends an ACK signal and the data. The communication ends with a not acknowledge (NACK) signal and a stop bit from master. The NACK condition is defined such that the SDA line remains high at the 9th clock cycle. The following figures show single and two-byte read sequences. Single-Byte Read Sequence Master S AD+W Slave RA ACK S AD+R ACK NACK ACK P DATA Burst Read Sequence Master S AD+W Slave RA ACK S ACK AD+R ACK ACK DATA NACK DATA 6.4  I2C TERMS  Signal S AD W R ACK NACK RA DATA P Description Start Condition: SDA goes from high to low while SCL is high Slave I2C address Write bit (0) Read bit (1) Acknowledge: SDA line is low while the SCL line is high at the 9th clock cycle Not-Acknowledge: SDA line stays high at the 9th clock cycle ICG-20330 internal register address Transmit or received data Stop condition: SDA going from low to high while SCL is high Table 13. I2C Terms   Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016   Page 27 of 56 P ICG-20330 6.5  SPI INTERFACE  SPI is a 4-wire synchronous serial interface that uses two control lines and two data lines. The ICG-20330 always operates as a Slave device during standard Master-Slave SPI operation. With respect to the Master, the Serial Clock output (SPC), the Serial Data Output (SDO) and the Serial Data Input (SDI) are shared among the Slave devices. Each SPI slave device requires its own Chip Select (CS) line from the master. CS goes low (active) at the start of transmission and goes back high (inactive) at the end. Only one CS line is active at a time, ensuring that only one slave is selected at any given time. The CS lines of the non-selected slave devices are held high, causing their SDO lines to remain in a high-impedance (high-z) state so that they do not interfere with any active devices. SPI Operational Features 1. 2. 3. 4. 5. Data is delivered MSB first and LSB last Data is latched on the rising edge of SPC Data should be transitioned on the falling edge of SPC The maximum frequency of SPC is 7 MHz SPI read and write operations are completed in 16 or more clock cycles (two or more bytes). The first byte contains the SPI Address, and the following byte(s) contain(s) the SPI data. The first bit of the first byte contains the Read/Write bit and indicates the Read (1) or Write (0) operation. The following 7 bits contain the Register Address. In cases of multiple-byte Read/Writes, data is two or more bytes: SPI Address format MSB R/W A6 A5 A4 SPI Data format MSB D7 D6 D5 D4 A3 D3 A2 D2 A1 LSB A0 D1 LSB D0 6. Supports Single or Burst Read/Writes. SPC SDI SPI Master SDO CS1 SPI Slave 1 CS CS2 SPC SDI SDO CS SPI Slave 2 Figure 11. Typical SPI Master / Slave Configuration Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 28 of 56 ICG-20330 7 SERIAL INTERFACE CONSIDERATIONS  7.1  ICG‐20330 SUPPORTED INTERFACES  The ICG-20330 supports I2C communications on its serial interface. The ICG-20330’s I/O logic levels are set to be VDDIO. The figure below depicts a sample circuit of ICG-20330. It shows the relevant logic levels and voltage connections. VDDIO (0V ‐ VDDIO) SYSTEM BUS VDD VDDIO VDD INT SDA (0V ‐ VDDIO) SCL VDD_IO System  Processor IO (0V ‐ VDDIO) (0V ‐ VDDIO) (0V ‐ VDDIO) SYNC VDDIO ICG‐20330 VDDIO (0V, VDDIO) SA0 Figure 12. I/O Levels and Connections Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 29 of 56 ICG-20330 8 ASSEMBLY  This section provides general guidelines for assembling InvenSense Micro Electro-Mechanical Systems (MEMS) gyros packaged in LGA package. 8.1  ORIENTATION OF AXES  The diagram below shows the orientation of the axes of sensitivity and the polarity of rotation. Note the pin 1 identifier (•) in the figure. +Z ICG -2 033 +Y 0 +X Figure 13. Orientation of Axes of Sensitivity and Polarity of Rotation Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 30 of 56 ICG-20330 8.2  PACKAGE DIMENSIONS  16 Lead LGA (3x3x0.75) mm NiAu pad finish Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 31 of 56 ICG-20330      DIMENSIONS IN MILLIMETERS    SYMBOLS  Total Thickness  Substrate Thickness  Mold Thickness  A  A1  A2  MIN NOM MAX 0.7  0.75  0.8                                    0.105                       REF                                     0.63                        REF  D  2.9  3  E  2.9  3  3.1  Lead Width  W  0.2  0.25  0.3  Lead Length  L  e  n  0.3  0.35  0.4                                     0.5                           BSC  16  D1                                       2                            BSC  E1                                       1                            BSC  Body Size  Lead Pitch  Lead Count  Edge Ball Center to Center  Body Center to Contact Ball  Ball Width  Ball Diameter  Ball Opening  Ball Pitch  Ball Count  Pre‐Solder  Package Edge Tolerance  Mold Flatness  Coplanarity  Ball Offset (Package)  Ball Offset (Ball)  Lead Edge to Package Edge  Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 3.1  SD                                      ‐‐‐                           BSC  SE  b      e1  n1                                        ‐‐‐                           BSC  ‐‐‐  ‐‐‐  ‐‐‐  ‐‐‐  ‐‐‐  ‐‐‐  ‐‐‐  ‐‐‐  ‐‐‐  ‐‐‐  aaa  bbb  ddd  eee  fff  M  0.01  0.1  0.2  0.08  ‐‐‐  ‐‐‐  0.06  0.11  Page 32 of 56 ICG-20330 9 PART NUMBER PACKAGE MARKING  The part number package marking for ICG-20330 devices is summarized below: Part Number Part Number Package Marking ICG-20330 IC2330 Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 33 of 56 ICG-20330 10 REFERENCE  Please refer to “InvenSense MEMS Handling Application Note (AN-IVS-0002A-00)” for the following information:  Manufacturing Recommendations o Assembly Guidelines and Recommendations o PCB Design Guidelines and Recommendations o MEMS Handling Instructions o ESD Considerations o Reflow Specification o Storage Specifications o Package Marking Specification o Tape & Reel Specification o Reel & Pizza Box Label o Packaging o Representative Shipping Carton Label  Compliance o Environmental Compliance o DRC Compliance o Compliance Declaration Disclaimer Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 34 of 56 ICG-20330 11 REGISTER MAP  The following table lists the register map for the ICG-20330. The device will come up in sleep mode upon power-up. In order to take the device out of the sleep mode set the PWR_MGMT_1[6] = 0 in register 107 (sleep mode bit in power management register). Addr (Hex) Addr (Dec.) Register Name Serial I/F Accessible in Sleep and LPA Modes? 00 00 SELF_TEST_X_GYRO READ/ WRITE N XG_ST_DATA[7:0] 01 01 SELF_TEST_Y_GYRO READ/ WRITE N YG_ST_DATA[7:0] 02 02 SELF_TEST_Z_GYRO READ/ WRITE N ZG_ST_DATA[7:0] 04 04 XG_OFFS_TC_H READ/ WRITE N 05 05 XG_OFFS_TC_L READ/ WRITE N 07 07 YG_OFFS_TC_H READ/ WRITE N 08 08 YG_OFFS_TC_L READ/ WRITE N 0A 10 ZG_OFFS_TC_H READ/ WRITE N 0B 11 ZG_OFFS_TC_L READ/ WRITE N ZG_OFFS_TC_L [7:0] 13 19 XG_OFFS_USRH READ/ WRITE N X_OFFS_USR [15:8] N X_OFFS_USR [7:0] Bit7 - Bit6 - Bit5 Bit4 - Bit3 - - Bit1 Bit0 - XG_OFFS_ TC_H [9] XG_OFFS_ TC_H [8] - YG_OFFS_ TC_H [9] YG_OFFS_ TC_H [8] - ZG_OFFS_ TC_H [9] ZG_OFFS_ TC_H [8] XG_OFFS_TC_L [7:0] - - - - - YG_OFFS_TC_L [7:0] - - - - - 14 20 XG_OFFS_USRL READ/ WRITE 15 21 YG_OFFS_USRH READ/ WRITE N Y_OFFS_USR [15:8] 16 22 YG_OFFS_USRL READ/ WRITE N Y_OFFS_USR [7:0] N Z_OFFS_USR [15:8] Z_OFFS_USR [7:0] 17 23 ZG_OFFS_USRH READ/ WRITE 18 24 ZG_OFFS_USRL READ/ WRITE N 19 25 SMPLRT_DIV READ/ WRITE Y N - FIFO_ MODE SMPLRT_DIV[7:0] 1A 26 CONFIG READ/ WRITE 1B 27 GYRO_CONFIG READ/ WRITE N XG_ST YG_ST ZG_ST 23 35 FIFO_EN READ/ WRITE N TEMP _FIFO_EN XG_FIFO_E N YG_FIFO_E N ZG_FIFO_E N 36 54 FSYNC_INT READ to CLEA R N FSYNC_IN T - - 37 55 INT_PIN_CFG READ/ WRITE Y - INT_OPEN LATCH _INT_EN 38 56 INT_ENABLE READ/ WRITE Y 3A 58 INT_STATUS READ to CLEA R N Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Bit2 EXT_SYNC_SET[2:0] WOM_EN - - - DLPF_CFG[2:0] FS_SEL [1:0] - FCHOICE_B[1:0] - - - - - - - - - INT_RD _CLEAR FSYNC_INT _LEVEL FSYNC _INT_MOD E_EN - - FIFO _OFLOW _EN - GDRIVE_IN T_EN - DATA_RDY _INT_EN FIFO _OFLOW _INT - GDRIVE_IN T - DATA _RDY_INT Page 35 of 56 ICG-20330 Addr (Hex) Addr (Dec.) Register Name Serial I/F Accessible in Sleep and LPA Modes? 41 65 TEMP_OUT_H READ N 42 66 TEMP_OUT_L READ N TEMP_OUT[7:0] 43 67 GYRO_XOUT_H READ N GYRO_XOUT[15:8] Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 TEMP_OUT[15:8] 44 68 GYRO_XOUT_L READ N GYRO_XOUT[7:0] 45 69 GYRO_YOUT_H READ N GYRO_YOUT[15:8] 46 70 GYRO_YOUT_L READ N GYRO_YOUT[7:0] 47 71 GYRO_ZOUT_H READ N GYRO_ZOUT[15:8] 48 72 GYRO_ZOUT_L READ N GYRO_ZOUT[7:0] N - - - - - - - TEMP _RST FIFO _RST - SIG_COND _RST 68 104 SIGNAL_PATH_RESET READ/ WRITE 6A 106 USER_CTRL READ/ WRITE N - FIFO_EN - I2C_IF _DIS - 6B 107 PWR_MGMT_1 READ/ WRITE Y DEVICE_ RESET SLEEP - GYRO_ STANDBY TEMP_DIS 6C 108 PWR_MGMT_2 READ/ WRITE Y - - - - - 72 114 FIFO_COUNTH READ Y 73 115 FIFO_COUNTL READ Y FIFO_COUNT[7:0] 74 116 FIFO_R_W READ/ WRITE Y FIFO_DATA[7:0] 75 117 WHO_AM_I READ N WHOAMI[7:0] - CLKSEL[2:0] STBY_XG STBY_YG FIFO_COUNT[12:8] Table 14. ICG-20330 Register Map Note: Register Names ending in _H and _L contain the high and low bytes, respectively, of an internal register value. In the detailed register tables that follow, register names are in capital letters, while register values are in capital letters and italicized. For example, the GYRO_XOUT_H register (Register 59) contains the 8 most significant bits, GYRO_XOUT[15:8], of the 16-bit X-Axis Gyroscope measurement, GYRO_XOUT. The reset value is 0x00 for all registers other than the registers below, also the self-test registers contain preprogrammed values and will not be 0x00 after reset.   Register 107 (0x01) Power Management 1 Register 117 (0x92) WHO_AM_I Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 36 of 56 STBY_ZG ICG-20330 12 REGISTER DESCRIPTIONS  This section describes the function and contents of each register within the ICG-20330. Note: The device will come up in active mode upon power-up. 12.1  REGISTERS 0 TO 2 – GYROSCOPE SELF‐TEST REGISTERS  Register Name: SELF_TEST_X_GYRO, SELF_TEST_Y_GYRO, SELF_TEST_Z_GYRO Type: READ/WRITE Register Address: 00, 01, 02 (Decimal); 00, 01, 02 (Hex) REGISTER SELF_TEST_X_GYRO SELF_TEST_Y_GYRO SELF_TEST_Z_GYRO BIT [7:0] [7:0] [7:0] NAME FUNCTION XG_ST_DATA[7:0] The value in this register indicates the self-test output generated during manufacturing tests. This value is to be used to check against subsequent self-test outputs performed by the end user. YG_ST_DATA[7:0] The value in this register indicates the self-test output generated during manufacturing tests. This value is to be used to check against subsequent self-test outputs performed by the end user. ZG_ST_DATA[7:0] The value in this register indicates the self-test output generated during manufacturing tests. This value is to be used to check against subsequent self-test outputs performed by the end user. The equation to convert self-test codes in OTP to factory self-test measurement is: ST _ OTP  ( 2620 / 2 FS ) * 1 .01( ST _ code 1) (lsb) where ST_OTP is the value that is stored in OTP of the device, FS is the Full Scale value, and ST_code is based on the Self-Test value (ST_ FAC) determined in InvenSense’s factory final test and calculated based on the following equation: ST _ code  round ( Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 log(ST _ FAC /(2620 / 2 FS )) ) 1 log(1.01) Page 37 of 56 ICG-20330 12.2  REGISTER 4 – GYROSCOPE OFFSET TEMPERATURE COMPENSATION (TC) REGISTER  Register Name: XG_OFFS_TC_H Register Type: READ/WRITE Register Address: 04 (Decimal); 04 (Hex) BIT NAME FUNCTION [7:2] - Reserved [1:0] XG_OFFS_TC_H[9:8] Bits 9 and 8 of the 10-bit offset of X gyroscope (2’s complement) 12.3  REGISTER 5 – GYROSCOPE OFFSET TEMPERATURE COMPENSATION (TC) REGISTER  Register Name: XG_OFFS_TC_L Type: READ/WRITE Register Address: 05 (Decimal); 05 (Hex) BIT NAME FUNCTION [7:0] XG_OFFS_TC_L[7:0]] Bits 7 to 0 of the 10-bit offset of X gyroscope (2’s complement) Description: The temperature compensation (TC) registers are used to reduce gyro offset variation due to temperature change. The TC feature is always enabled. However, the compensation only happens when a TC coefficient is programed during factory trim which gets loaded into these registers at power up or after a DEVICE_RESET. If these registers contain a value of zero, temperature compensation has no effect on the offset of the chip. The TC registers have a 10bit magnitude and sign adjustment in all full scale modes with a resolution of 2.52 mdps/C steps. If these registers contain a non-zero value after power up, the user may write zeros to them to see the offset values without TC with temperature variation. Note that doing so may result in offset values that exceed data sheet “Initial ZRO Tolerance” in other than normal ambient temperature (~25 °C). The TC coefficients maybe restored by the user with a power up or a DEVICE_RESET. The above description also applies to registers 7-8 and 10-11.   Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 38 of 56 ICG-20330 12.4  REGISTER 07 – GYROSCOPE OFFSET TEMPERATURE COMPENSATION (TC) REGISTER  Register Name: YG_OFFS_TC_H Register Type: READ/WRITE Register Address: 07 (Decimal); 07 (Hex) BIT NAME FUNCTION [7:2] - Reserved [1:0] YG_OFFS_TC_H[9:8] Bits 9 and 8 of the 10-bit offset of Y gyroscope (2’s complement) 12.5  REGISTER 08 – GYROSCOPE OFFSET TEMPERATURE COMPENSATION (TC) REGISTER  Register Name: YG_OFFS_TC_L Register Type: READ/WRITE Register Address: 08 (Decimal); 08 (Hex) BIT NAME FUNCTION [7:0] YG_OFFS_TC_L[7:0]] Bits 7 to 0 of the 10-bit offset of Y gyroscope (2’s complement)   12.6  REGISTER 10 – GYROSCOPE OFFSET TEMPERATURE COMPENSATION (TC) REGISTER  Register Name: ZG_OFFS_TC_H Register Type: READ/WRITE Register Address: 10 (Decimal); 0A (Hex) BIT NAME FUNCTION [7:2] - Reserved [1:0] ZG_OFFS_TC_H[9:8] Bits 9 and 8 of the 10-bit offset of Z gyroscope (2’s complement)   Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 39 of 56 ICG-20330 12.7  REGISTER 11 – GYROSCOPE OFFSET TEMPERATURE COMPENSATION (TC) REGISTER  Register Name: ZG_OFFS_TC_L Register Type: READ/WRITE Register Address: 11 (Decimal); 0B (Hex) BIT NAME FUNCTION ZG_OFFS_TC_L[7:0]] Bits 7 to 0 of the 10-bit offset of Z gyroscope (2’s complement) [7:0]   12.8  REGISTERS 19 – GYRO OFFSET ADJUSTMENT REGISTER  Register Name: XG_OFFS_USRH Register Type: READ/WRITE Register Address: 19 (Decimal); 13 (Hex) BIT [7:0] NAME FUNCTION X_OFFS_USR[15:8] Bits 15 to 8 of the 16-bit offset of X gyroscope (2’s complement). This register is used to remove DC bias from the sensor output. The value in this register is added to the gyroscope sensor value before going into the sensor register. 12.9  REGISTERS 20 – GYRO OFFSET ADJUSTMENT REGISTER  Register Name: XG_OFFS_USRL Register Type: READ/WRITE Register Address: 20 (Decimal); 14 (Hex) BIT [7:0] NAME FUNCTION X_OFFS_USR[7:0] Bits 7 to 0 of the 16-bit offset of X gyroscope (2’s complement). This register is used to remove DC bias from the sensor output. The value in this register is added to the gyroscope sensor value before going into the sensor register.     Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 40 of 56 ICG-20330 12.10  REGISTERS 21 – GYRO OFFSET ADJUSTMENT REGISTER  Register Name: YG_OFFS_USRH Register Type: READ/WRITE Register Address: 21 (Decimal); 15 (Hex) BIT [7:0] NAME FUNCTION Y_OFFS_USR[15:8] Bits 15 to 8 of the 16-bit offset of Y gyroscope (2’s complement). This register is used to remove DC bias from the sensor output. The value in this register is added to the gyroscope sensor value before going into the sensor register. 12.11  REGISTERS 22 – GYRO OFFSET ADJUSTMENT REGISTER  Register Name: YG_OFFS_USRL Register Type: READ/WRITE Register Address: 22 (Decimal); 16 (Hex) BIT [7:0] NAME FUNCTION Y_OFFS_USR[7:0] Bits 7 to 0 of the 16-bit offset of Y gyroscope (2’s complement). This register is used to remove DC bias from the sensor output. The value in this register is added to the gyroscope sensor value before going into the sensor register.   12.12  REGISTERS 23 – GYRO OFFSET ADJUSTMENT REGISTER  Register Name: ZG_OFFS_USRH Register Type: READ/WRITE Register Address: 23 (Decimal); 17 (Hex) BIT [7:0] NAME FUNCTION Z_OFFS_USR[15:8] Bits 15 to 8 of the 16-bit offset of Z gyroscope (2’s complement). This register is used to remove DC bias from the sensor output. The value in this register is added to the gyroscope sensor value before going into the sensor register.   Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 41 of 56 ICG-20330 12.13  REGISTER 24 – GYRO OFFSET ADJUSTMENT REGISTER  Register Name: ZG_OFFS_USRL Register Type: READ/WRITE Register Address: 24 (Decimal); 18 (Hex) BIT [7:0] NAME FUNCTION Z_OFFS_USR[7:0] Bits 7 to 0 of the 16-bit offset of Z gyroscope (2’s complement). This register is used to remove DC bias from the sensor output. The value in this register is added to the gyroscope sensor value before going into the sensor register.   12.14  REGISTER 25 – SAMPLE RATE DIVIDER  Register Name: SMPLRT_DIV Register Type: READ/WRITE Register Address: 25 (Decimal); 19 (Hex) BIT [7:0] NAME SMPLRT_DIV[7:0] FUNCTION Divides the internal sample rate (see register CONFIG) to generate the sample rate that controls sensor data output rate, FIFO sample rate. NOTE: This register is only effective when FCHOICE_B register bits are 2’b00, and (0 < DLPF_CFG < 7). This is the update rate of the sensor register: SAMPLE_RATE = INTERNAL_SAMPLE_RATE / (1 + SMPLRT_DIV) Where INTERNAL_SAMPLE_RATE = 1kHz Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 42 of 56 ICG-20330 12.15  REGISTER 26 – CONFIGURATION  Register Name: CONFIG Register Type: READ/WRITE Register Address: 26 (Decimal); 1A (Hex) BIT NAME FUNCTION [7] - [6] FIFO_MODE Reserved. When set to ‘1’, when the FIFO is full, additional writes will not be written to FIFO. When set to ‘0’, when the FIFO is full, additional writes will be written to the FIFO, replacing the oldest data. [5:3] EXT_SYNC_SET[2:0] Enables the FSYNC pin data to be sampled. EXT_SYNC_SET FSYNC bit location 0 function disabled 1 TEMP_OUT_L[0] 2 GYRO_XOUT_L[0] 3 GYRO_YOUT_L[0] 4 GYRO_ZOUT_L[0] FSYNC will be latched to capture short strobes. This will be done such that if FSYNC toggles, the latched value toggles, but won’t toggle again until the new latched value is captured by the sample rate strobe. [2:0] DLPF_CFG[2:0] For the DLPF to be used, FCHOICE_B[1:0] is 2’b00. See the table below. The DLPF is configured by DLPF_CFG, when FCHOICE_B [1:0] = 2b’00. The gyroscope and temperature sensor are filtered according to the value of DLPF_CFG and FCHOICE_B as shown in the table below. FCHOICE_B DLPF_CFG X 1 0 0 0 0 1 0 0 0 0 0 Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Temperature Sensor Gyroscope X X 0 1 2 7 3-dB BW (Hz) 8173 3281 250 176 92 3281 Noise BW (Hz) Rate (kHz) Delay (ms) 3-dB BW (Hz) 8595.1 3451.0 306.6 177.0 108.6 3451.0 32 32 8 1 1 8 0.064 0.11 0.97 2.9 3.9 0.17 4000 4000 4000 188 98 4000 Page 43 of 56 ICG-20330 12.16  REGISTER 27 – GYROSCOPE CONFIGURATION  Register Name: GYRO_CONFIG Register Type: READ/WRITE Register Address: 27 (Decimal); 1B (Hex)   BIT NAME FUNCTION [7] XG_ST X Gyro self-test. [6] YG_ST Y Gyro self-test. [5] ZG_ST Z Gyro self-test. Gyro Full Scale Select: 00 = ±31.25 dps [4:3] FS_SEL[1:0] 01= ±62.5 dps 10 = ±125 dps 11= ±250 dps [2] - Reserved. [1:0] FCHOICE_B[1:0] Used to bypass DLPF as shown in table 1 above. Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 44 of 56 ICG-20330 12.17  REGISTER 35 – FIFO ENABLE  Register Name: FIFO_EN Register Type: READ/WRITE Register Address: 35 (Decimal); 23 (Hex) BIT NAME FUNCTION [7] TEMP_FIFO_EN 1 – Write TEMP_OUT_H and TEMP_OUT_L to the FIFO at the sample rate; If enabled, buffering of data occurs even if data path is in standby. 0 – Function is disabled. [6] XG_FIFO_EN 1 – Write GYRO_XOUT_H and GYRO_XOUT_L to the FIFO at the sample rate; If enabled, buffering of data occurs even if data path is in standby. 0 – Function is disabled. 1 – Write GYRO_YOUT_H and GYRO_YOUT_L to the FIFO at the sample rate; If enabled, buffering of data occurs even if data path is in standby. [5] [4] YG_FIFO_EN 0 – Function is disabled. ZG_FIFO_EN Note: Enabling any one of the bits corresponding to the Gyros or Temp data paths, data is buffered into the FIFO even though that data path is not enabled. 1 – Write GYRO_ZOUT_H and GYRO_ZOUT_L to the FIFO at the sample rate; If enabled, buffering of data occurs even if data path is in standby. 0 – Function is disabled. [3] - Reserved. [2:0] - Reserved.   Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 45 of 56 ICG-20330 12.18  REGISTER 54 – FSYNC INTERRUPT STATUS    Register Name: FSYNC_INT Register Type: READ to CLEAR Register Address: 54 (Decimal); 36 (Hex) BIT NAME FUNCTION [7] FSYNC_INT This bit automatically sets to 1 when a FSYNC interrupt has been generated. The bit clears to 0 after the register has been read.   12.19  REGISTER 55 – INT PIN / BYPASS ENABLE CONFIGURATION  Register Name: INT_PIN_CFG Register Type: READ/WRITE Register Address: 55 (Decimal); 37 (Hex) BIT NAME FUNCTION [7] INT_LEVEL [6] INT_OPEN [5] LATCH_INT_EN [4] INT_RD_CLEAR [3] FSYNC_INT_LEVEL [2] FSYNC_INT_MODE_EN [1] - When this bit is equal to 1, the FSYNC pin will trigger an interrupt when it transitions to the level specified by FSYNC_INT_LEVEL. When this bit is equal to 0, the FSYNC pin is disabled from causing an interrupt. Reserved. [0] - Reserved. 1 – The logic level for INT pin is active low. 0 – The logic level for INT pin is active high. 1 – INT pin is configured as open drain. 0 – INT pin is configured as push-pull. 1 – INT pin level held until interrupt status is cleared. 0 – INT pin indicates interrupt pulse’s width is 50 s. 1 – Interrupt status is cleared if any read operation is performed. 0 – Interrupt status is cleared only by reading INT_STATUS register. 1 – The logic level for the FSYNC pin as an interrupt is active low. 0 – The logic level for the FSYNC pin as an interrupt is active high.   Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 46 of 56 ICG-20330 12.20  REGISTER 56 – INTERRUPT ENABLE  Register Name: INT_ENABLE Register Type: READ/WRITE Register Address: 56 (Decimal); 38 (Hex) BIT NAME FUNCTION [7:5] WOM_EN [4] FIFO_OFLOW_EN [3] - Reserved. [2] GDRIVE_INT_EN Gyroscope Drive System Ready interrupt enable. [1] - Reserved. [0] DATA_RDY_INT_EN Data ready interrupt enable. ‘111’ – Enable WoM interrupt. ‘000’ – Disable WoM interrupt. This is the default setting. 1 – Enables a FIFO buffer overflow to generate an interrupt. 0 – Function is disabled.   12.21  REGISTER 58 – INTERRUPT STATUS  Register Name: INT_STATUS Register Type: READ to CLEAR Register Address: 58 (Decimal); 3A (Hex) BIT NAME FUNCTION [7] - Reserved. [6] - Reserved. [5] - Reserved. [4] FIFO_OFLOW_INT This bit automatically sets to 1 when a FIFO buffer overflow has been generated. The bit clears to 0 after the register has been read. [3] - Reserved. [2] GDRIVE_INT Gyroscope Drive System Ready interrupt. [1] - Reserved. [0] DATA_RDY_INT This bit automatically sets to 1 when a Data Ready interrupt is generated. The bit clears to 0 after the register has been read.     Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 47 of 56 ICG-20330 12.22  REGISTERS 65 AND 66 – TEMPERATURE MEASUREMENT  Register Name: TEMP_OUT_H Register Type: READ only Register Address: 65 (Decimal); 41 (Hex) BIT NAME FUNCTION [7:0] TEMP_OUT[15:8] High byte of the temperature sensor output. Register Name: TEMP_OUT_L Register Type: READ only Register Address: 66 (Decimal); 42 (Hex) BIT NAME FUNCTION Low byte of the temperature sensor output. [7:0] TEMP_degC TEMP_OUT[7:0] = ((TEMP_OUT – RoomTemp_Offset)/Temp_Sensitivity) + 25degC     Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 48 of 56 ICG-20330 12.23  REGISTERS 67 TO 72 – GYROSCOPE MEASUREMENTS  Register Name: GYRO_XOUT_H Register Type: READ only Register Address: 67 (Decimal); 43 (Hex) BIT NAME FUNCTION [7:0] GYRO_XOUT[15:8] High byte of the X-Axis gyroscope output. Register Name: GYRO_XOUT_L Register Type: READ only Register Address: 68 (Decimal); 44 (Hex) BIT NAME FUNCTION Low byte of the X-Axis gyroscope output. [7:0] GYRO_XOUT[7:0] GYRO_XOUT = Gyro_Sensitivity * X_angular_rate Nominal FS_SEL = 0 Conditions Gyro_Sensitivity = 131 LSB/(º/s) Register Name: GYRO_YOUT_H Register Type: READ only Register Address: 69 (Decimal); 45 (Hex) BIT NAME FUNCTION [7:0] GYRO_YOUT[15:8] High byte of the Y-Axis gyroscope output. Register Name: GYRO_YOUT_L Register Type: READ only Register Address: 70 (Decimal); 46 (Hex) BIT NAME FUNCTION Low byte of the Y-Axis gyroscope output. [7:0] GYRO_YOUT[7:0] Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 GYRO_YOUT = Gyro_Sensitivity * Y_angular_rate Nominal FS_SEL = 0 Conditions Gyro_Sensitivity = 131 LSB/(º/s) Page 49 of 56 ICG-20330 Register Name: GYRO_ZOUT_H Register Type: READ only Register Address: 71 (Decimal); 47 (Hex) BIT NAME FUNCTION [7:0] GYRO_ZOUT[15:8] High byte of the Z-Axis gyroscope output. Register Name: GYRO_ZOUT_L Register Type: READ only Register Address: 72 (Decimal); 48 (Hex) BIT NAME FUNCTION Low byte of the Z-Axis gyroscope output. GYRO_ZOUT[7:0] [7:0] GYRO_ZOUT = Gyro_Sensitivity * Z_angular_rate Nominal Conditions FS_SEL = 0 Gyro_Sensitivity = 131 LSB/(º/s)   12.24  REGISTER 104 – SIGNAL PATH RESET  Register Name: SIGNAL_PATH_RESET Register Type: READ/WRITE Register Address: 104 (Decimal); 68 (Hex) BIT NAME FUNCTION [7:1] - Reserved. Reset temp digital signal path. [0] TEMP_RST Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Note: Sensor registers are not cleared. Use SIG_COND_RST to clear sensor registers. Page 50 of 56 ICG-20330 12.24  REGISTER 106 – USER CONTROL  Register Name: USER_CTRL Register Type: READ/WRITE Register Address: 106 (Decimal); 6A (Hex) BIT NAME FUNCTION [7] - Reserved. 1 – Enable FIFO operation mode. [6] FIFO_EN 0 – Disable FIFO access from serial interface. To disable FIFO writes by DMA, use FIFO_EN register. [5] - Reserved. [4] I2C_IF_DIS 1 – Reset I2C Slave module and put the serial interface in SPI mode only. This bit auto clears after one clock cycle of the internal 20 MHz clock. [3] - Reserved. [2] FIFO_RST 1 – Reset FIFO module. Reset is asynchronous. This bit auto clears after one clock cycle of the internal 20 MHz clock. [1] - Reserved [0] SIG_COND_RST 1 – Reset all gyro digital signal path and temp digital signal path. This bit also clears all the sensor registers. Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 51 of 56 ICG-20330  12.25  REGISTER 107 – POWER MANAGEMENT 1  Register Name: PWR_MGMT_1 Register Type: READ/WRITE Register Address: 107 (Decimal); 6B (Hex) BIT NAME FUNCTION [7] DEVICE_RESET 1 – Reset the internal registers and restores the default settings. The bit automatically clears to 0 once the reset is done. [6] SLEEP When set to 1, the chip is set to sleep mode. [5] - Reserved. [4] GYRO_STANDBY When set, the gyro drive and pll circuitry are enabled, but the sense paths are disabled. This is a low power mode that allows quick enabling of the gyros. [3] TEMP_DIS When set to 1, this bit disables the temperature sensor. Code [2:0] CLKSEL[2:0] Clock Source 0 Internal 20 MHz oscillator 1 Auto selects the best available clock source – PLL if ready, else use the Internal oscillator. 2 Auto selects the best available clock source – PLL if ready, else use the Internal oscillator. 3 Auto selects the best available clock source – PLL if ready, else use the Internal oscillator. 4 Auto selects the best available clock source – PLL if ready, else use the Internal oscillator. 5 Auto selects the best available clock source – PLL if ready, else use the Internal oscillator. 6 Internal 20 MHz oscillator. 7 Stops the clock and keeps timing generator in reset. Note: The default value of CLKSEL[2:0] is 000. It is required that CLKSEL[2:0] be set to 001 to achieve full gyroscope performance. Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 52 of 56 ICG-20330 12 26 REGISTER 108 – POWER MANAGEMENT 2  Register Name: PWR_MGMT_2 Register Type: READ/WRITE Register Address: 108 (Decimal); 6C (Hex) BIT NAME FUNCTION [7] - Reserved. [6] - Reserved. [5] - Reserved. [4] - Reserved. [3] - Reserved. [2] STBY_XG [1] STBY_YG [0] STBY_ZG 1 – X gyro is disabled. 0 – X gyro is on. 1 – Y gyro is disabled. 0 – Y gyro is on. 1 – Z gyro is disabled. 0 – Z gyro is on. 12.27  REGISTER 114 AND 115 – FIFO COUNT REGISTERS  Register Name: FIFO_COUNTH Register Type: READ Only Register Address: 114 (Decimal); 72 (Hex) BIT NAME FUNCTION [7:5] - Reserved. [4:0] FIFO_COUNT[12:8] High bits. Count indicates the number of written bytes in the FIFO. Reading this byte latches the data for both FIFO_COUNTH, and FIFO_COUNTL. Register Name: FIFO_COUNTL Register Type: READ Only Register Address: 115 (Decimal); 73 (Hex) BIT NAME FUNCTION Low Bits. Count indicates the number of written bytes in the FIFO. [7:0] FIFO_COUNT[7:0] Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Note: Must read FIFO_COUNTH to latch new data for both FIFO_COUNTH and FIFO_COUNTL. Page 53 of 56 ICG-20330 12.28  REGISTER 116 – FIFO READ WRITE  Register Name: FIFO_R_W Register Type: READ/WRITE Register Address: 116 (Decimal); 74 (Hex) BIT NAME FUNCTION [7:0] FIFO_DATA[7:0] Read/Write command provides Read or Write operation for the FIFO. Description: This register is used to read and write data from the FIFO buffer. Data is written to the FIFO in order of register number (from lowest to highest). If all the FIFO enable flags (see below) are enabled, the contents of registers 59 through 72 will be written in order at the Sample Rate. The contents of the sensor data registers (Registers 59 to 72) are written into the FIFO buffer when their corresponding FIFO enable flags are set to 1 in FIFO_EN (Register 35). If the FIFO buffer has overflowed, the status bit FIFO_OFLOW_INT is automatically set to 1. This bit is located in INT_STATUS (Register 58). When the FIFO buffer has overflowed, the oldest data will be lost and new data will be written to the FIFO unless register 26 CONFIG, bit[6] FIFO_MODE = 1. If the FIFO buffer is empty, reading register FIFO_DATA will return a unique value of 0xFF until new data is available. Normal data is precluded from ever indicating 0xFF, so 0xFF gives a trustworthy indication of FIFO empty. 12.29  REGISTER 117 – WHO AM I  Register Name: WHO_AM_I Register Type: READ only Register Address: 117 (Decimal); 75 (Hex) BIT NAME FUNCTION [7:0] WHOAMI Register to indicate to user which device is being accessed. This register is used to verify the identity of the device. The contents of WHOAMI is an 8-bit device ID. The default value of the register is 0x92. This is different from the I2C address of the device as seen on the slave I2C controller by the applications processor. The I2C address of the ICG-20330 is 0x68 or 0x69 depending upon the value driven on AD0 pin. Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 54 of 56 ICG-20330 13 REVISION HISTORY  REVISION DATE REVISION DESCRIPTION 06/15/2016 1.0 Initial Release Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 55 of 56 ICG-20330 This information furnished by InvenSense is believed to be accurate and reliable. However, no responsibility is assumed by InvenSense for its use, or for any infringements of patents or other rights of third parties that may result from its use. Specifications are subject to change without notice. InvenSense reserves the right to make changes to this product, including its circuits and software, in order to improve its design and/or performance, without prior notice. InvenSense makes no warranties, neither expressed nor implied, regarding the information and specifications contained in this document. InvenSense assumes no responsibility for any claims or damages arising from information contained in this document, or from the use of products and services detailed therein. This includes, but is not limited to, claims or damages based on the infringement of patents, copyrights, mask work and/or other intellectual property rights. Certain intellectual property owned by InvenSense and described in this document is patent protected. No license is granted by implication or otherwise under any patent or patent rights of InvenSense. This publication supersedes and replaces all information previously supplied. Trademarks that are registered trademarks are the property of their respective companies. InvenSense sensors should not be used or sold in the development, storage, production or utilization of any conventional or mass-destructive weapons or for any other weapons or life threatening applications, as well as in any other life critical applications such as medical equipment, transportation, aerospace and nuclear instruments, undersea equipment, power plant equipment, disaster prevention and crime prevention equipment. ©2016 InvenSense, Inc. All rights reserved. InvenSense, MotionTracking, MotionProcessing, MotionProcessor, MotionFusion, MotionApps, Digital Motion Processor, AAR, and the InvenSense logo are trademarks of InvenSense, Inc. Other company and product names may be trademarks of the respective companies with which they are associated. ©2016 InvenSense, Inc. All rights reserved. Document Number: DS-000127 Revision: 1.0 Rev Date: 06/15/2016 Page 56 of 56
ICG-20330 价格&库存
很抱歉,暂时无法提供与“ICG-20330”相匹配的价格&库存,您可以联系我们找货
