ICG05006A006V-007-R
ICG05006A006V-007-R
    TDK(东电化)
    DC DC CONVERTER 0.6-3.63V 22W
ICG05006A006V-007-R 数据手册
Advance Data Sheet: iCG Series – Non-isolated SMT Power Module iCG Series DC/DC Power Modules 4.5-14V Input, 6A Output Surface Mount Power Module iCG power modules perform local voltage conversion from either a 5V or 12V bus. The iCG12006A007V utilizes a low component count that results in both a low cost structure and a high level of performance. The open-frame, compact, surface mountable design features a low profile and weight as well as additional edge plated pads that allow for extremely flexible and robust manufacturing processes. Features • Size – 12.2mm x 12.2 mm x 8.5 mm (0.48 in. x 0.48 in. x 0.335 in.) • DOSA Compatible Footprint • Edge plated castellations for forming inspectable solder joints • Surface mountable • Maximum weight 3g (0.106 oz) • Up to 33W of output power in high ambient temperature, low airflow environments with no power derating • Positive logic on/off • Flexible Output Voltage Sequencing • Starts with pre-biased output • Output voltage adjustment – industry standard • Outstanding transient response without the need for external loop tuning components • Constant switching frequency • Remote Sense • Power Good • Full, auto-recovery protection: o Input under voltage o Short circuit o Thermal limit • ISO Certified manufacturing facilities • Patent pending Optional Features • Negative logic on/off • No output voltage sequencing • Solder bumping for enhanced solderability on the EPC footprint ℡ 1-800-526-2324 ©2015 TDK - Lambda Americas Inc. iCG12_Full_Datasheet_100312_rev 1.2.doc rev. 1.2 1/18/2017 1/16 Advance Data Sheet: iCG Series – Non-isolated SMT Power Module This page intentionally left blank ℡ 1-800-526-2324 ©2015 TDK - Lambda Americas Inc. iCG12_Full_Datasheet_100312_rev 1.2.doc rev. 1.2 1/18/2017 2/16 Advance Data Sheet: iCG Series – Non-isolated SMT Power Module Mechanical Specification: Dimensions are in mm [in]. Unless otherwise specified tolerances are: x.x ± 0.5 [0.02], x.xx ± 0.25 [0.010] -A- -A- See ordering information for solder bumping options A A Pin Locations: (bottom view) DOSA PINS EPC PINS Pin Assignment: PIN FUNCTION PIN FUNCTION 1 2 ON/OFF VIN 6 7 TRIM GND 3 GND 8 NC 4 VOUT 9 SEQ 5 SENSE 10 PW GOOD ℡ 1-800-526-2324 ©2015 TDK - Lambda Americas Inc. iCG12_Full_Datasheet_100312_rev 1.2.doc rev. 1.2 1/18/2017 3/16 Advance Data Sheet: iCG Series – Non-isolated SMT Power Module Recommended Footprint (top view): FOR DOSA STANDARD PADS ℡ 1-800-526-2324 ©2015 TDK - Lambda Americas Inc. iCG12_Full_Datasheet_100312_rev 1.2.doc rev. 1.2 1/18/2017 FOR EPC PADS 4/16 Advance Data Sheet: iCG Series – Non-isolated SMT Power Module Absolute Maximum Ratings: Stress in excess of Absolute Maximum Ratings may cause permanent damage to the device. Characteristic Min Continuous Input Voltage Max Unit -0.25 15 Vdc Storage Temperature -55 125 ˚C Operating Temperature Range (Tc) -40 115* ˚C Notes & Conditions Measured at the location specified in the thermal measurement figure; maximum temperature varies with output current – see curve in the thermal performance section of the data sheet. * Engineering estimate Input Characteristics: Unless otherwise specified, specifications apply over all rated Input Voltage, Resistive Load, and Temperature conditions. Characteristic Min Typ Max Unit Operating Input Voltage 4.5 Maximum Input Current --- Startup Delay Time from application of input voltage Notes & Conditions --- 14 Vdc --- 6.5 A Vin=2.4 to Vin,max; Io=Io,max --- 5 --- mS Vo=0 to 0.1*Vo,set; on/off=on, Io=Io,max, Tc=25˚C Startup Delay Time from on/off --- 5 --- mS Vo=0 to 0.1*Vo,set; Vin=Vi,nom, Io=Io,max,Tc=25˚C Output Voltage Rise Time --- 4 --- mS Io=Io,max,Tc=25˚C, Vo=0.1 to 0.9*Vo,set Input Reflected Ripple --- 30* --- mApp Input Ripple Rejection --- 40* --- dB Turn on input voltage --- 4.2 --- V Turn off input voltage *Engineering Estimate --- 3.5 --- V See input/output ripple measurement figure; BW=20 MHz @ 120 Hz Caution: The power modules are not internally fused. An external input line normal blow fuse with a maximum value of 10A is required, see the Safety Considerations section of the data sheet. ℡ 1-800-526-2324 ©2015 TDK - Lambda Americas Inc. iCG12_Full_Datasheet_100312_rev 1.2.doc rev. 1.2 1/18/2017 5/16 Advance Data Sheet: iCG Series – Non-isolated SMT Power Module Electrical Data: Characteristic Unit Notes & Conditions Output Voltage Initial Setpoint -2 - +2 % Vo=3.3Vsetting, Vin=Vin,nom; Io=Io,max; Tc = 25˚C Output Voltage Tolerance -3 - +3 % Over all rated input voltage, load, and temperature conditions to end of life ----------- 84 86 88 92 94 ----------- % % % % % Vin=5V; Io=Io,max; Tc=25˚C Line Regulation --- 3 --- mV Vin=Vin,min to Vin,max Load Regulation --- 6 --- mV Io=Io,min to Io,max Output Current 0 --- 6 A Output Current Limiting Threshold --- 10 --- A Vo = 0.9*Vo,nom, Tc
ICG05006A006V-007-R 价格&库存
很抱歉,暂时无法提供与“ICG05006A006V-007-R”相匹配的价格&库存,您可以联系我们找货
