ICM-20789
ICM-20789
    TDK(东电化)
    LGA24_4X4MM
    ICM-20789
ICM-20789 数据手册
ICM-20789 7-Axis, High Performance Integrated 6-Axis Inertial and Barometric Pressure Sensor GENERAL DESCRIPTION APPLICATIONS The 7-Axis ICM-20789 is an integrated 6-axis inertial device that combines a 3-axis gyroscope, 3-axis accelerometer, and an ultra-low noise MEMS capacitive pressure sensor in a 24pin LGA package. This unique 7-Axis device offers performance of discrete components in a single small footprint for tracking rotational and linear motion as well as pressure differences with an accuracy of ±1 Pa, an accuracy enabling altitude measurement differentials as small as 8.5 cm. The pressure sensor’s MEMS capacitive architecture provides the industry’s lowest noise at the lowest power, high sensor throughput, and temperature coefficient offset of ±0.5 Pa/°C. The pressure sensor’s combination of high accuracy elevation measurements, low power, and temperature stability complemented by the motion tracking 6-axis inertial sensor in a small footprint, make it ideal for a wide range of motion tracking applications. The embedded 6-axis MotionTracking device combines a 3axis gyroscope, 3-axis accelerometer, and a Digital Motion Processor™ (DMP). An available large 4 kB FIFO reduces traffic on the serial bus interface, and power consumption through burst sensor data transmission. The Gyroscope has programmable FSR of ±250 dps, ±500 dps, ±1000 dps and ±2000 dps. The Accelerometer FSR is programmable to ±2g, ±4g, ±8g and ±16g ICM-20789 has 16-bit ADC for the 6-axis inertial sensor and 24-bit ADC for the pressure Sensor, programmable digital filters, two temperature sensors – one each in 6-axis Inertial and Pressure sensor. The device features an operating voltage of 1.8V. Communication port includes I2C at 400 kHz (6-axis and Pressure) and 8 MHz SPI (6-axis only). The package is 4x4x1.365 mm 24-pin to minimize board area requirements. AP/HUB FEATURES • • • • • • • • • • • • • • • Pressure operating range: 30 to 110 kPa Noise and current consumption o 3.2 Pa @ 1.3 µA (LP mode) o 0.8 Pa @ 5.2 µA (LN mode) o 0.4 Pa @ 10.4 µA (ULN mode) Pressure Sensor Relative Accuracy: ±1 Pa for any 10 hPa change over 950 hPa-1050 hPa at 25°C Pressure Sensor Absolute Accuracy: ±1 hPa over 950 hPa-1050 hPa, 0°C to 65°C Pressure Sensor Temperature Coefficient Offset: ±0.5 Pa/°C over 25°C to 45°C at 100 kPa Gyroscope programmable FSR of ±250 dps, ±500 dps, ±1000 dps, and ±2000 dps Accelerometer with Programmable FSR of ±2g, ±4g, ±8g, and ±16g Large 4 kB FIFO reduces traffic on the serial bus interface EIS FSYNC support User-programmable interrupts Wake-on-motion interrupt for low power operation of applications processor Host interface: 400 kHz Fast Mode I2C & 8 MHz SPI (see datasheet for ICM-20689) Digital-output temperature sensor (x2) Nominal VDD operation at 1.8V RoHS and Green compliant I2C PART TEMP RANGE PACKAGE ICM-20789† −40°C to +85°C 24-Pin LGA †Denotes RoHS and Green-Compliant Package SPI (6-Axis only) 6-Axis Motion Drones and Flying Toys Motion-based gaming controllers Virtual Reality headsets and controllers Indoor/Outdoor Navigation (dead-reckoning, floor/elevator/step detection) ORDERING INFORMATION BLOCK DIAGRAM I2C • • • • I2C Pressure Sensor ICM-20789 InvenSense reserves the right to change the detail specifications as may be required to permit improvements in the design of its products. TDK Corporation 1745 Technology Drive, San Jose, CA 95110 U.S.A +1(408) 988–7339 www.invensense.com Document Number: DS-000169 Revision: 1.3 Revision Date: 10/31/2017 ICM-20789 TABLE OF CONTENTS General Description ............................................................................................................................................. 1 Block Diagram ...................................................................................................................................................... 1 Applications ......................................................................................................................................................... 1 Features ............................................................................................................................................................... 1 Ordering Information ........................................................................................................................................... 1 1 2 3 4 Introduction ......................................................................................................................................................... 7 1.1 Purpose and Scope .................................................................................................................................... 7 1.2 Product Overview...................................................................................................................................... 7 1.3 Applications............................................................................................................................................... 7 Features ............................................................................................................................................................... 8 2.1 Gyroscope Features .................................................................................................................................. 8 2.2 Accelerometer Features ............................................................................................................................ 8 2.3 Pressure sensor Features .......................................................................................................................... 8 2.4 Additional Features ................................................................................................................................... 8 2.5 Motion Processing .................................................................................................................................... 8 Electrical Characteristics ...................................................................................................................................... 9 3.1 Gyroscope Specifications .......................................................................................................................... 9 3.2 Accelerometer Specifications.................................................................................................................. 10 3.3 Pressure Sensor Specifications................................................................................................................ 11 3.4 Electrical Specifications ........................................................................................................................... 12 3.5 I2C Timing Characterization ..................................................................................................................... 14 3.6 Absolute Maximum Ratings .................................................................................................................... 16 Applications Information ................................................................................................................................... 17 4.1 Pin Out Diagram and Signal Description ................................................................................................. 17 4.2 Typical Operating Circuit ......................................................................................................................... 18 4.3 Bill of Materials for External Components .............................................................................................. 21 4.4 Block Diagram ......................................................................................................................................... 22 4.5 Overview ................................................................................................................................................. 23 4.6 Three-Axis MEMS Gyroscope with 16-bit ADCs and Signal Conditioning ............................................... 24 4.7 Three-Axis MEMS Accelerometer with 16-bit ADCs and Signal Conditioning......................................... 24 4.8 Digital Motion Processor ......................................................................................................................... 24 4.9 Pressure Sensor ....................................................................................................................................... 24 4.10 I2C Serial Communications Interface .................................................................................................. 24 4.11 Self-Test .............................................................................................................................................. 25 4.12 Clocking............................................................................................................................................... 26 4.13 Sensor Data Registers ......................................................................................................................... 26 4.14 FIFO ..................................................................................................................................................... 26 4.15 Interrupts ............................................................................................................................................ 26 4.16 Digital-Output Temperature Sensor ................................................................................................... 26 Document Number: DS-000169 Revision: 1.3 Page 2 of 62 ICM-20789 5 4.17 Bias and LDOs ..................................................................................................................................... 26 4.18 Charge Pump ...................................................................................................................................... 26 4.19 Standard Power Modes – Update the power modes ......................................................................... 27 Programmable Interrupts .................................................................................................................................. 28 5.1 6 7 Per Axis Wake-on-Motion Interrupt ....................................................................................................... 28 Digital Interface ................................................................................................................................................. 29 6.1 I2C Serial Interface ................................................................................................................................... 29 6.2 I2C Interface............................................................................................................................................. 29 6.3 I2C Communications Protocol (6-Axis only. For pressure please see chapter 10) ................................... 29 6.4 I2C Terms ................................................................................................................................................. 31 Serial Interface Considerations .......................................................................................................................... 33 7.1 ICM-20789 Supported Interfaces ............................................................................................................ 33 8 Register Map ...................................................................................................................................................... 34 9 Register Descriptions ......................................................................................................................................... 36 9.1 Registers Descriptions ............................................................................................................................. 36 9.2 Registers 0 to 2 – Self-Test Registers ...................................................................................................... 36 9.3 Registers 13 to 15.................................................................................................................................... 36 9.4 Register 19 – Gyro Offset Adjustment Register ...................................................................................... 36 9.5 Register 20 – Gyro Offset Adjustment Register ...................................................................................... 36 9.6 Register 21 – Gyro Offset Adjustment Register ...................................................................................... 37 9.7 Register 22 – Gyro Offset Adjustment Register ...................................................................................... 37 9.8 Register 23 – Gyro Offset Adjustment Register ...................................................................................... 37 9.9 Register 24 – Gyro Offset Adjustment Register ...................................................................................... 37 9.10 Register 25 – Sample Rate Divider. ..................................................................................................... 37 9.11 Register 26 – Configuration ................................................................................................................ 38 9.12 Register 27 – Gyroscope Configuration .............................................................................................. 38 9.13 Register 28 – Accelerometer Configuration ....................................................................................... 39 9.14 Register 29 – Accelerometer Configuration 2..................................................................................... 39 9.15 Register 30 – Low Power Mode Configuration ................................................................................... 40 9.16 Register 32 – Wake on Motion Threshold .......................................................................................... 41 9.17 Register 33 – Wake on Motion Threshold .......................................................................................... 41 9.18 Register 34 – Wake on Motion Threshold .......................................................................................... 41 9.19 Register 35 – FIFO Enable ................................................................................................................... 42 9.20 Register 55 – Interrupt/Bypass Pin Configuration .............................................................................. 42 9.21 Register 56 – Interrupt Enable ............................................................................................................ 43 9.22 Register 57 – DMP Interrupt Status .................................................................................................... 43 9.23 Register 58 – Interrupt Status ............................................................................................................. 43 9.24 Register 59 – Accelerometer Measurements ..................................................................................... 43 9.25 Register 60 – Accelerometer Measurements ..................................................................................... 43 9.26 Register 61 – Accelerometer Measurements ..................................................................................... 44 Document Number: DS-000169 Revision: 1.3 Page 3 of 62 ICM-20789 10 9.27 Register 62 – Accelerometer Measurements ..................................................................................... 44 9.28 Register 63 – Accelerometer Measurements ..................................................................................... 44 9.29 Register 64 – Accelerometer Measurements ..................................................................................... 44 9.30 Register 65 – Temperature Measurement ......................................................................................... 44 9.31 Register 66 – Temperature Measurement ......................................................................................... 44 9.32 Register 67 – Gyroscope Measurement ............................................................................................. 44 9.33 Register 68 – Gyroscope Measurement ............................................................................................. 45 9.34 Register 69 – Gyroscope Measurement ............................................................................................. 45 9.35 Register 70 – Gyroscope Measurement ............................................................................................. 45 9.36 Register 71 – Gyroscope Measurement ............................................................................................. 45 9.37 Register 72 – Gyroscope Measurement ............................................................................................. 45 9.38 Register 104 – Signal Path Reset......................................................................................................... 45 9.39 Register 105 – Accelerometer Intelligence Control ............................................................................ 46 9.40 Register 106 – User Control ................................................................................................................ 46 9.41 Register 107 – Power Management 1 ................................................................................................ 47 9.42 Register 108 – Power Management 2 ................................................................................................ 47 9.43 Register 114 – FIFO Count Registers ................................................................................................... 47 9.44 Register 115 – FIFO Count Registers ................................................................................................... 48 9.45 Register 116 – FIFO Read Write .......................................................................................................... 48 9.46 Register 117 – Who Am I .................................................................................................................... 48 9.47 Register 119 – Accelerometer Offset Register.................................................................................... 48 9.48 Register 120 – Accelerometer Offset Register.................................................................................... 49 9.49 Register 122 – Accelerometer Offset Register.................................................................................... 49 9.50 Register 123 – Accelerometer Offset Register.................................................................................... 49 9.51 Register 125 – Accelerometer Offset Register.................................................................................... 49 9.52 Register 126 – Accelerometer Offset Register.................................................................................... 49 Pressure sensor – How to Read ......................................................................................................................... 50 10.1 11 I2C Operation And Communication .................................................................................................... 50 Assembly ............................................................................................................................................................ 55 11.1 Orientation of Axes ............................................................................................................................. 55 11.2 Implementation and usage recommendations .................................................................................. 55 11.3 Package Dimensions ........................................................................................................................... 56 12 Part Number Package Marking .......................................................................................................................... 58 13 Ordering Guide .................................................................................................................................................. 59 14 Reference ........................................................................................................................................................... 60 15 Revision History ................................................................................................................................................. 61 Document Number: DS-000169 Revision: 1.3 Page 4 of 62 ICM-20789 LIST OF FIGURES Figure 1. I2C Bus Timing Diagram ............................................................................................................................................................. 15 Figure 2. Pin out Diagram for ICM-20789 ................................................................................................................................................ 17 Figure 3. I2C Communication – 1.8V Supply Schematic ........................................................................................................................... 18 Figure 4. I2C Communication MCU Interface at 3V or 1.8V Schematic .................................................................................................... 19 Figure 5. SPI Communication for Gyro/Accel; I2C for Pressure Schematic .............................................................................................. 20 Figure 6. SPI Communication for Gyro/Accel; I2C Pressure; MCU Digital Interface: 1.8V Schematic ...................................................... 20 Figure 7. SPI Communication for Gyro/Accel; I2C for Pressure; MCU Digital Interface: 3.0V Schematic................................................. 21 Figure 8. ICM-20789 Block Diagram (I2C interface).................................................................................................................................. 22 Figure 9. ICM-20789 Block Diagram (SPI/ I2C interface) .......................................................................................................................... 23 Figure 10. ICM-20789 Solution Using I2C Interface .................................................................................................................................. 25 Figure 11. START and STOP Conditions .................................................................................................................................................... 29 Figure 12. Acknowledge on the I2C Bus ................................................................................................................................................... 30 Figure 13. Complete I2C Data Transfer ..................................................................................................................................................... 30 Figure 14. I/O Levels and Connections..................................................................................................................................................... 33 Figure 15. Communication Sequence for starting a measurement and reading measurement results .................................................. 54 Figure 16. Orientation of Axes of Sensitivity and Polarity of Rotation .................................................................................................... 55 Figure 17. Package Dimensions................................................................................................................................................................ 56 Figure 18. ICM-20789 recommended PCB land pattern .......................................................................................................................... 57 Figure 19. Part Number Package Marking ............................................................................................................................................... 58 Document Number: DS-000169 Revision: 1.3 Page 5 of 62 ICM-20789 LIST OF TABLES Table 1. Gyroscope Specifications ............................................................................................................................................................. 9 Table 2. Accelerometer Specifications ..................................................................................................................................................... 10 Table 3. Operation Ranges ....................................................................................................................................................................... 11 Table 4. Operation Modes ....................................................................................................................................................................... 11 Table 5. Pressure Sensor Specifications ................................................................................................................................................... 11 Table 6. Temperature Sensor Specifications............................................................................................................................................ 12 Table 7. D.C. Electrical Characteristics ..................................................................................................................................................... 12 Table 8. A.C. Electrical Characteristics (6-Axis) ........................................................................................................................................ 13 Table 9. Electrical Characteristics (Pressure sensor) ................................................................................................................................ 14 Table 10. Other Electrical Specifications .................................................................................................................................................. 14 Table 11. I2C Timing Characteristics ......................................................................................................................................................... 15 Table 12. Absolute Maximum Ratings (6-Axis) ........................................................................................................................................ 16 Table 13. Absolute Maximum Ratings (pressure sensor)......................................................................................................................... 16 Table 14. Signal Descriptions ................................................................................................................................................................... 17 Table 15. Bill of Materials ........................................................................................................................................................................ 21 Table 16. Standard Power Modes for ICM-20789.................................................................................................................................... 27 Table 17. Table of Interrupt Sources........................................................................................................................................................ 28 Table 18. Serial Interface ......................................................................................................................................................................... 29 Table 19. I2C Term SPI Interface ............................................................................................................................................................... 31 Table 20. Register Map ............................................................................................................................................................................ 35 Table 21. Accelerometer Data Rates and Bandwidths (Low Noise Mode) .............................................................................................. 39 Table 22. Accelerometer Data Rates and Bandwidths (Low-Power Mode) ............................................................................................. 40 Table 23. ICM-20789 I2C Device Address ................................................................................................................................................. 50 Table 24. Measurement Commands ........................................................................................................................................................ 50 Table 25. Soft Reset Command ................................................................................................................................................................ 51 Table 26. Read-Out Command of ID Register .......................................................................................................................................... 51 Table 27. Structure of the 16-bit ID ......................................................................................................................................................... 51 Table 28. ICM-20789 I2C CRC Properties .................................................................................................................................................. 51 Table 29. Package Dimensions Table ....................................................................................................................................................... 56 Document Number: DS-000169 Revision: 1.3 Page 6 of 62 ICM-20789 1 INTRODUCTION 1.1 PURPOSE AND SCOPE This document is a product specification, providing a description, specifications, and design related information on the ICM-20789, a 6-axis inertial and pressure sensor device. The device is packaged in a 4 mm x 4 mm x 1.365 mm 24-pin LGA package. 1.2 PRODUCT OVERVIEW The ICM-20789 is a 6-axis inertial sensor, 3-axis gyroscope and a 3-axis accelerometer, ultra-low noise MEMS capacitive barometric pressure sensor in a 4 mm x 4 mm x 1.365 mm (24-pin LGA) package. It features a 4 KB FIFO that can lower the traffic on the serial bus interface. The digital output barometric pressure sensor is based on an ultra-low noise innovative MEMS capacitive technology that can measure pressure differences with an accuracy of ±1 Pa, an accuracy enabling altitude measurement differentials as small as 8.5 cm without the penalty of increased power consumption or reduced sensor throughput. The capacitive pressure sensor has a ±1 hPa absolute accuracy over its full range of 300 hPa -1100 hPa. The pressure sensor offers industry leading temperature stability of the pressure sensor with a temperature coefficient offset of ±0.5 Pa/°C, embedded temperature sensor and 400 kHz I2C bus for communication. The gyroscope has a programmable full-scale range of ±250 dps, ±500 dps, ±1000 dps, and ±2000 dps. The accelerometer has a userprogrammable full-scale range of ±2g, ±4g, ±8g, and ±16g. Factory-calibrated initial sensitivity of both sensors reduces productionline calibration requirements. Other features include on-chip 16-bit ADCs, programmable digital filters, another embedded temperature sensor, and programmable interrupts. The device features I2C serial interface to access its registers at 400 kHz as well as at 8 MHz SPI. By leveraging its patented and volume-proven CMOS-MEMS fabrication platform, which integrates MEMS wafers with companion CMOS electronics through wafer-level bonding, TDK has driven the package size down to a footprint and thickness of 4 mm x 4 mm x 1.365 mm (24-pin LGA), to provide an integrated high-performance package. The device provides high robustness by supporting 10,000g shock reliability. 1.3 APPLICATIONS • • • • Drones and Flying Toys Motion-based gaming controllers Virtual Reality Headsets & Controllers Indoor/Outdoor Navigation (dead-reckoning, floor/elevation/step detection) Document Number: DS-000169 Revision: 1.3 Page 7 of 62 ICM-20789 2 FEATURES 2.1 GYROSCOPE FEATURES • • • • • Digital-output X-, Y-, and Z-axis angular rate sensors (gyroscopes) with a user-programmable full-scale range of ±250 dps, ±500 dps, ±1000 dps, and ±2000 dps and integrated 16-bit ADCs Digitally-programmable low-pass filter Low-power gyroscope operation Factory calibrated sensitivity scale factor Self-test 2.2 ACCELEROMETER FEATURES • • • • Digital-output X-, Y-, and Z-axis accelerometer with a programmable full scale range of ±2g, ±4g, ±8g, and ±16g and integrated 16-bit ADCs User-programmable interrupts Wake-on-motion interrupt for low power operation of applications processor Self-test 2.3 PRESSURE SENSOR FEATURES • • • • • • • Pressure operating range: 30 kPa to 110 kPa 4 operating modes to optimize noise and power, 3 example modes: o 3.2 Pa @ 1.3 µA (LP mode) o 0.8 Pa @ 5.2 µA (LN mode) o 0.4 Pa @ 10.4 µA (ULN mode) Relative accuracy: ±1 Pa for any 10 hPa change over 950 hPa-1050 hPa at 25°C Absolute accuracy: ±1 hPa over 950 hPa-1050 hPa, 0°C to 65°C Temperature Coefficient Offset: ±0.5 Pa/°C over 25°C to 45°C at 100 kPa I2C at 400 kHz Temperature sensor accuracy: ±0.4°C 2.4 ADDITIONAL FEATURES • • • • • • • Minimal cross-axis sensitivity between the accelerometer and gyroscope axes 4 kB FIFO buffer enables the applications processor to read the data in bursts Digital-output temperature sensor User-programmable digital filters for gyroscope, accelerometer, and temp sensor 10,000g shock tolerant 400 kHz Fast Mode I2C for communicating with all registers RoHS and Green compliant 2.5 MOTION PROCESSING • • Internal Digital Motion Processing™ (DMP™) engine supports advanced MotionProcessing and low power functions DMP operation is possible in low-power gyroscope and low-power accelerometer modes Document Number: DS-000169 Revision: 1.3 Page 8 of 62 ICM-20789 3 ELECTRICAL CHARACTERISTICS 3.1 GYROSCOPE SPECIFICATIONS Typical Operating Circuit Figure 3, VDD = 1.8V, VDDIO = 1.8V, TA=25°C, unless otherwise noted. PARAMETER Full-Scale Range CONDITIONS MIN UNITS NOTES ±250 ±500 ±1000 dps dps dps 3 3 3 FS_SEL=0 ±2000 16 131 dps bits LSB/(dps) 3 3 3 FS_SEL=1 FS_SEL=2 65.5 32.8 LSB/(dps) LSB/(dps) 3 3 FS_SEL=3 Component-Level, 25°C -40°C to +85°C 16.4 ±2 ±1.5 LSB/(dps) % % 3 2 1 Best fit straight line; 25°C ±0.1 % 1 ±2 % 1 ±5 ±0.05 dps dps/°C 2 1 GYROSCOPE SENSITIVITY FS_SEL=0 FS_SEL=1 FS_SEL=2 FS_SEL=3 Gyroscope ADC Word Length Sensitivity Scale Factor Sensitivity Scale Factor Tolerance Sensitivity Scale Factor Variation Over Temperature Nonlinearity Cross-Axis Sensitivity Initial ZRO Tolerance ZRO Variation Over Temperature ZERO-RATE OUTPUT (ZRO) Component-Level, 25°C -40°C to +85°C TYP MAX GYROSCOPE NOISE PERFORMANCE (FS_SEL=0) Noise Spectral Density Gyroscope Mechanical Frequencies Low Pass Filter Response Gyroscope Start-Up Time Output Data Rate 0.006 Programmable Range From Sleep mode Standard (duty-cycled) mode Low-Noise (active) mode 25 5 27 29 250 35 3.91 4 500 8000 dps/√Hz 1 kHz Hz ms Hz Hz 2 3 1 1 1 Table 1. Gyroscope Specifications Notes: 1. 2. 3. Derived from validation or characterization of parts, not guaranteed in production. Tested in production. Guaranteed by design. Document Number: DS-000169 Revision: 1.3 Page 9 of 62 ICM-20789 3.2 ACCELEROMETER SPECIFICATIONS Typical Operating Circuit Figure 3, VDD = 1.8V, VDDIO = 1.8V, TA=25°C, unless otherwise noted. PARAMETER CONDITIONS MIN TYP MAX UNITS NOTES ACCELEROMETER SENSITIVITY AFS_SEL=0 AFS_SEL=1 ±2 ±4 g g 3 3 AFS_SEL=2 ±8 g 3 AFS_SEL=3 Output in two’s complement format ±16 16 g bits 3 3 AFS_SEL=0 AFS_SEL=1 16,384 8,192 LSB/g LSB/g 3 3 Sensitivity Initial Tolerance AFS_SEL=2 AFS_SEL=3 Component-Level, 25°C 4,096 2,048 ±2 LSB/g LSB/g % 3 3 2 Sensitivity Change vs. Temperature -40°C to +85°C ±1 % 1 Nonlinearity Cross-Axis Sensitivity Best Fit Straight Line ±0.5 ±2 % % 1 1 ±80 mg 2 ±0.75 mg/°C 1 150 µg/√Hz 1 Hz mg/LSB ms ms Hz Hz 3 3 1 1 Full-Scale Range ADC Word Length Sensitivity Scale Factor Offset Initial Tolerance ZERO-G OUTPUT Component-Level, 25°C Zero-G Level Change vs. Temperature -5°C to +85°C NOISE PERFORMANCE Noise Spectral Density Low Pass Filter Response Intelligence Function Increment Accelerometer Startup Time Output Data Rate Notes: 1. 2. 3. Programmable Range From Sleep mode From Cold Start, 1 ms VDD ramp Standard (duty-cycled) mode Low-Noise (active) mode 5 218 4 20 30 0.24 4 500 4000 Table 2. Accelerometer Specifications Derived from validation or characterization of parts, not guaranteed in production. Tested in production. Guaranteed by design. Document Number: DS-000169 Revision: 1.3 Page 10 of 62 1 ICM-20789 3.3 PRESSURE SENSOR SPECIFICATIONS Typical Operating Circuit Figure 3, VDD = 1.8V, VDDIO = 1.8V, TA=25°C, unless otherwise noted. OPERATION RANGE PRESSURE (kPa) TEMPERATURE (°C) Normal 70 to 110 0 to 65 Extended 30 to 110 0 to 65 Maximum 25 to 115 -40 to 85 Table 3. Operation Ranges PRESSURE PARAMETER Conversion Time Current Consumption Pressure RMS Noise CONDITIONS Sensor Mode TYP MAX Time between sending last bit of measurement command, and sensor data ready for measurement Low Power (LP) Normal (N) Low Noise (LN) Ultra Low Noise (ULN) Low Power (LP) Normal (N) Low Noise (LN) Ultra Low Noise (ULN) Low Power (LP) Normal Low Noise (LN) Ultra Low Noise (ULN) 1.6 5.6 20.8 1.8 6.3 23.8 83.2 94.5 1 Hz ODR Valid for P = 100 kPa, T = 25°C, and U = 1.8V 1.3 2.6 5.2 UNITS NOTES 1 1 1 ms 1 µA 10.4 3.2 1.6 0.8 Pa 0.4 Table 4. Operation Modes Notes: 1. Guaranteed by design. PARAMETER Absolute Accuracy Relative Accuracy Long-term drift During 1 year Solder drift Temperature coefficient offset Resolution CONDITIONS Normal range Extended range Any step ≤ 1 kPa, 25 °C Any step ≤ 10 kPa, 25 °C TYP ±1 ±1.5 ±1 ±3 UNITS hPa Extended range ±1 hPa/y 1.5 hPa ±0.5 Pa/°C 0.01 Pa P = 100 kPa 25°C … 45°C Maximum range NOTES 1 Pa 1, 2 Table 5. Pressure Sensor Specifications Notes: 1. 2. Absolute accuracy may be improved through One Point Calibration Sensor accuracy post Solder reflow may be improved through One Point Calibration Document Number: DS-000169 Revision: 1.3 Page 11 of 62 ICM-20789 Temperature PARAMETER Absolute Accuracy Repeatability Resolution Long-term drift CONDITIONS Extended range Extended range Maximum range Normal range TYP ±0.4 ±0.1 0.01 Vpor After soft reset AD0 = 0 AD0 = 1 VIH, High-Level Input Voltage Output Leakage Current tINT, INT Pulse Width TYP 0 0.4 3 6 100 20+0.1Cb V V V V mA mA nA 300 ns Table 8. A.C. Electrical Characteristics (6-Axis) Notes: 1. Guaranteed by design Document Number: DS-000169 Revision: 1.3 1 Page 13 of 62 1 ICM-20789 PARAMETER SYMBOL Supply voltage VDD Power-up/down level VPOR Supply current CONDITIONS MIN TYP MAX UNITS 1.71 1.8 1.89 V Static power supply 1.0 1.25 1.5 V Idle state - 1.0 2.5 µA Measurement - 210 300 µA Current consumption while sensor is measuring. - 1.3 - µA Current consumption in continuous operation @ 1 Hz ODR in LP Mode - 5.2 - µA Current consumption in continuous operation @1 Hz ODR in LN Mode IDD Average Low level input voltage VIL 0 - 0.3 VDD V High level input voltage VIH 0.7 VDD - VDD V Low level output voltage VOL 0 < IOL < 3 mA - - 0.2 VDD V Output Sink Current IOL VOL = 0.4V 3.1 4.1 - mA VOL = 0.6V 3.5 4.5 - mA COMMENTS Table 9. Electrical Characteristics (Pressure sensor) Other Electrical Specifications Typical Operating Circuit Figure 3, VDD = 1.8V, VDDIO = 1.8V, TA=25°C, unless otherwise noted. PARAMETER I2C Operating Frequency CONDITIONS MIN TYP SERIAL INTERFACE All registers, Fast-mode All registers, Standard-mode MAX UNITS NOTES 400 100 kHz kHz 1 1 MAX UNITS NOTES 400 1 1 Table 10. Other Electrical Specifications Notes: 1. Derived from validation or characterization of parts, not guaranteed in production. 3.5 I2C TIMING CHARACTERIZATION Typical Operating Circuit Figure 3, VDD = 1.8V, VDDIO = 1.8V, TA=25°C, unless otherwise noted. PARAMETERS I2C TIMING I2C CONDITIONS FAST-MODE MIN TYP fSCL, SCL Clock Frequency tHD.STA, (Repeated) START Condition Hold Time 0.6 kHz µs tLOW, SCL Low Period 1.3 µs 1 tHIGH, SCL High Period tSU.STA, Repeated START Condition Setup Time tHD.DAT, SDA Data Hold Time 0.6 0.6 0 µs µs µs 1 1 1 ns ns 1 1 ns µs 1 1 µs 1 pF 1 tSU.DAT, SDA Data Setup Time tr, SDA and SCL Rise Time tf, SDA and SCL Fall Time tSU.STO, STOP Condition Setup Time tBUF, Bus Free Time Between STOP and START Condition Cb, Capacitive Load for each Bus Line Document Number: DS-000169 Revision: 1.3 Cb bus cap. from 10 to 400 pF Cb bus cap. from 10 to 400 pF 100 20+0.1Cb 300 20+0.1Cb 0.6 300 1.3 < 400 Page 14 of 62 ICM-20789 PARAMETERS CONDITIONS I2C I2C TIMING tVD.DAT, Data Valid Time tVD.ACK, Data Valid Acknowledge Time MIN TYP MAX UNITS NOTES 0.9 0.9 µs µs 1 1 FAST-MODE Table 11. I2C Timing Characteristics Notes: 1. Based on characterization of 5 parts over temperature and voltage as mounted on evaluation board or in sockets tf SDA tSU.DAT tr 70% 30% 70% 30% continued below at tf SCL tr 70% 30% S tHD.STA tVD.DAT 70% 30% tHD.DAT 1/fSCL tLOW 1st clock cycle 9th clock cycle tHIGH tBUF SDA 70% 30% A tHD.STA tSU.STA SCL 70% 30% Sr tSU.STO tVD.ACK 9th clock cycle P S Figure 1. I2C Bus Timing Diagram Document Number: DS-000169 Revision: 1.3 Page 15 of 62 A ICM-20789 3.6 ABSOLUTE MAXIMUM RATINGS Stress above those listed as “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these conditions is not implied. Exposure to the absolute maximum ratings conditions for extended periods may affect device reliability. PARAMETER RATING Supply Voltage, VDD (for 6-axis MEMS) -0.5V to +4V Supply Voltage, VDDIO (for Pressure Sensor VDD and I/O) -0.5V to +2.16V REGOUT -0.5V to 2V Input Voltage Level (AD0, FSYNC, SCL, SDA) -0.5V to VDD + 0.5V Acceleration (Any Axis, unpowered) 10,000g for 0.2 ms Operating Temperature Range -40°C to +85°C Storage Temperature Range -40°C to +125°C 2 kV (HBM); Electrostatic Discharge (ESD) Protection 250V (MM) JEDEC Class II (2),125°C Latch-up ±100 mA Table 12. Absolute Maximum Ratings (6-Axis) PARAMETER Supply voltage, VDD RATING -0.3V to +2.16V Supply Voltage, SCL & SDA -0.3V to VDD +0.3V Operating temperature range -40°C to +85°C Storage temperature range -40°C to +125°C ESD HBM 1.0 kV ESD CDM 250V Latch up, JESD78 Class II, 85°C 100 mA Overpressure >600 kPa Table 13. Absolute Maximum Ratings (pressure sensor) Document Number: DS-000169 Revision: 1.3 Page 16 of 62 ICM-20789 4 APPLICATIONS INFORMATION 4.1 PIN OUT DIAGRAM AND SIGNAL DESCRIPTION PIN NUMBER PIN NAME PIN DESCRIPTION 6 PR_DA I2C interface data pin for Pressure Sensor access 7 PR_CL I2C interface clock pin for Pressure Sensor access 8 VDDIO 9 AD0/SDO I2C slave address LSB (AD0); SPI serial data output (SDO) Digital I/O supply voltage 10 REGOUT Regulator filter capacitor connection 11 FSYNC Frame synchronization digital input. Connect to GND if unused. 12 INT Interrupt digital output (totem pole or open-drain) 13 VDD Power supply voltage 18 GND Power supply ground 22 nCS SPI chip select 23 SCL/SCLK I2C serial clock (SCL); SPI serial clock (SCLK) 24 SDA/SDI I2C serial data (SDA); SPI serial data input (SDI) 1, 19, 20, 21 NC 2, 3, 4, 5, 14, 15, 16, 17 GND/VDD/NC No Connect Connect to: GND or VDD or No Connection Table 14. Signal Descriptions Note: 1. 2. VDD and VDDIO cannot be shorted if VDD > 1.98V VDD & VDDIO should not violate operating range specifications as mentioned in Section 3.4 SDA/SDI SCL/SCLK nCS NC NC NC 24 23 22 21 20 19 +Z NC 1 18 GND GND/VDD/NC 2 17 GND/VDD/NC GND/VDD/NC 3 16 GND/VDD/NC ICM-20789 GND/VDD/NC 4 15 GND/VDD/NC GND/VDD/NC 5 14 GND/VDD/NC PR_DA 6 13 VDD IC +Y M- 20 78 9 +X 7 8 9 10 11 12 PR_CL VDDIO AD0/SDO REGOUT FSYNC INT Top View – LGA Package 24-pin, 4mm x 4mm x 1.365mm +Y +Z +X Orientation of Axes of Sensitivity and Polarity of Rotation Figure 2. Pin out Diagram for ICM-20789 Document Number: DS-000169 Revision: 1.3 Page 17 of 62 ICM-20789 4.2 TYPICAL OPERATING CIRCUIT I2C Communication – 1.8V Supply Schematic Figure 3. I2C Communication – 1.8V Supply Schematic Document Number: DS-000169 Revision: 1.3 Page 18 of 62 ICM-20789 I2C Communication MCU Interface at 3V or 1.8V Schematic Figure 4. I2C Communication MCU Interface at 3V or 1.8V Schematic Document Number: DS-000169 Revision: 1.3 Page 19 of 62 ICM-20789 SPI Communication for Gyro/Accel; I2C for Pressure Schematic Figure 5. SPI Communication for Gyro/Accel; I2C for Pressure Schematic SPI Communication for Gyro/Accel; I2C Pressure; MCU Digital Interface: 1.8V Schematic Figure 6. SPI Communication for Gyro/Accel; I2C Pressure; MCU Digital Interface: 1.8V Schematic Document Number: DS-000169 Revision: 1.3 Page 20 of 62 ICM-20789 SPI Communication for Gyro/Accel; I2C for Pressure; MCU Digital Interface: 3.0V Schematic Figure 7. SPI Communication for Gyro/Accel; I2C for Pressure; MCU Digital Interface: 3.0V Schematic Note: I2C lines are open drain and pullup resistors (e.g. 10 kΩ) are required. 4.3 BILL OF MATERIALS FOR EXTERNAL COMPONENTS COMPONENT LABEL SPECIFICATION QUANTITY REGOUT Capacitor C1 X7R, 0.1 µF ±10% 1 C2 X7R, 0.1 µF ±10% 1 C4 X7R, 2.2 µF ±10% 1 C3 X7R, 10 nF ±10% 1 VDD Bypass Capacitors VDDIO Bypass Capacitor Table 15. Bill of Materials Document Number: DS-000169 Revision: 1.3 Page 21 of 62 ICM-20789 4.4 BLOCK DIAGRAM ICM-20789 Self test X Accel ADC Self test Y Accel ADC INT1 Interrupt Status Register nCS Slave I2C and SPI Serial Interface FIFO AD0 / SDO SCL / SCLK SDA / SDI Z Accel ADC Self test X Gyro ADC Self test Y Gyro Self test Z Gyro Signal Conditioning Self test User & Config Registers Serial Interface Bypass Mux Master I2C Serial Interface Sensor Registers PR_CL PR_DA FSYNC ADC Digital Motion Processor (DMP) ADC Signal Conditioning Temp Sensor ADC ADC Pressure Sensor Bias & LDOs Charge Pump VDD GND REGOUT Figure 8. ICM-20789 Block Diagram (I2C interface) Document Number: DS-000169 Revision: 1.3 Page 22 of 62 ICM-20789 ICM-20789 INT1 Interrupt Status Register nCS Slave I2C and SPI Serial Interface FIFO SDO SCLK SDI Signal Conditioning User & Config Registers Serial Interface Bypass Mux Master I2C Serial Interface Sensor Registers nCS SDO Host Processor SCLK SDI PR_CL PR_DA SCL SDA FSYNC Digital Motion Processor (DMP) Signal Conditioning ADC Pressure Sensor Bias & LDOs VDD GND REGOUT Figure 9. ICM-20789 Block Diagram (SPI/ I2C interface) 4.5 OVERVIEW The ICM-20789 is comprised of the following key blocks and functions: • • • • • • • • • • • • • • Three-axis MEMS rate gyroscope sensor with 16-bit ADCs and signal conditioning Three-axis MEMS accelerometer sensor with 16-bit ADCs and signal conditioning Digital Motion Processor (DMP) engine I2C serial communications interfaces Self-Test Clocking Sensor Data Registers FIFO Interrupts Digital-Output Temperature Sensor Bias and LDOs Charge Pump Standard Power Modes Pressure Sensor Document Number: DS-000169 Revision: 1.3 Page 23 of 62 ICM-20789 4.6 THREE-AXIS MEMS GYROSCOPE WITH 16-BIT ADCS AND SIGNAL CONDITIONING The ICM-20789 consists of three independent vibratory MEMS rate gyroscopes, which detect rotation about the X-, Y-, and Z- Axes. When the gyros are rotated about any of the sense axes, the Coriolis Effect causes a vibration that is detected by a capacitive pickoff. The resulting signal is amplified, demodulated, and filtered to produce a voltage that is proportional to the angular rate. This voltage is digitized using individual on-chip 16-bit Analog-to-Digital Converters (ADCs) to sample each axis. The full-scale range of the gyro sensors may be digitally programmed to ±250, ±500, ±1000, or ±2000 degrees/sec (dps). The ADC sample rate is programmable from 8,000 samples/sec, to 3.9 samples/sec, and user-selectable low-pass filters enable a wide range of cut-off frequencies. 4.7 THREE-AXIS MEMS ACCELEROMETER WITH 16-BIT ADCS AND SIGNAL CONDITIONING The ICM-20789’s 3-Axis accelerometer uses separate proof masses for each axis. Acceleration along a particular axis induces displacement on the corresponding proof mass, and capacitive sensors detect the displacement differentially. The ICM-20789’s architecture reduces the accelerometers’ susceptibility to fabrication variations as well as to thermal drift. When the device is placed on a flat surface, it will measure 0g on the X- and Y-axes and +1g on the Z-axis. The accelerometers’ scale factor is calibrated at the factory and is nominally independent of supply voltage. Each sensor has a dedicated sigma-delta ADC for providing digital outputs. The full-scale range of the digital output can be adjusted to ±2g, ±4g, ±8g, or ±16g. 4.8 DIGITAL MOTION PROCESSOR The embedded Digital Motion Processor (DMP) offloads computation of motion processing algorithms from the host processor. The DMP acquires data from the accelerometer and gyroscope, processes the data, and the results can be read from the FIFO. The DMP has access to one of the external pins, which can be used for generating interrupts. The purpose of the DMP is to offload both timing requirements and processing power from the host processor. Typically, motion processing algorithms should be run at a high rate, often around 200 Hz, in order to provide accurate results with low latency. This is required even if the application updates at a much lower rate; for example, a low power user interface may update as slowly as 5 Hz, but the motion processing should still run at 200 Hz. The DMP can be used to minimize power, simplify timing, simplify the software architecture, and save valuable MIPS on the host processor for use in applications. DMP operation is possible in low-power gyroscope and low-power accelerometer modes. 4.9 PRESSURE SENSOR The pressure sensor is a capacitive pressure sensor, and has a membrane over a sealed cavity at a reference pressure. External pressure changes relative to the sealed cavity pressure cause the membrane to deflect. The membrane and the floor of the cavity form a capacitor where the capacitance changes in response to changes in external pressure. The capacitance measurement is converted to a voltage proportional to the external pressure by the on-chip electronics. An external algorithm is used to compensate for temperature effects on the pressure accuracy. 4.10 I2C SERIAL COMMUNICATIONS INTERFACE The ICM-20789 communicates to a system processor using a I2C serial interface. The ICM-20789 always acts as a slave when communicating to the system processor. The LSB of the I2C slave address is set by pin 9 (AD0). Document Number: DS-000169 Revision: 1.3 Page 24 of 62 ICM-20789 ICM-20789 Solution Using I2C Interface Recommended operation mode is described in Figure 5, with the system processor being an I2C master to the ICM-20789. -20948 INT Slave I2C Interface SCL System Processor SCL SDA SDA Serial Interface Bypass Mux Master I2C Serial Interface FSYNC Digital Motion Processor (DMP) Signal Conditioning ADC Pressure Sensor Bias & LDOs VDD GND REGOUT Figure 10. ICM-20789 Solution Using I2C Interface Note: I2C lines are open drain and pullup resistors (e.g. 10 kΩ) are required. Accessing Pressure Sensor Data Pressure sensor data can be accessed in the following mode: • Bypass Mode: Set register INT_PIN_CFG (Address: 55 (Decimal); 37 (Hex)) bit 1 to value 1 and I2C_MST_EN bit is ‘0’ (Address: 106 (Decimal); 6A (Hex). Pressure sensor data can then be accessed using the procedure described in Section 10. 4.11 SELF-TEST Self-test allows for the testing of the mechanical and electrical portions of the sensors. The self-test for each measurement axis can be activated by means of the gyroscope and accelerometer self-test registers (registers 27 and 28). When the self-test is activated, the electronics cause the sensors to be actuated and produce an output signal. The output signal is used to observe the self-test response. The self-test response is defined as follows: SELF-TEST RESPONSE = SENSOR OUTPUT WITH SELF-TEST ENABLED – SENSOR OUTPUT WITH SELF-TEST DISABLED When the value of the self-test response is within the specified min/max limits of the product specification, the part has passed selftest. When the self-test response exceeds the min/max values, the part is deemed to have failed self-test. It is recommended to use TDK-InvenSense MotionApps software for executing self-test. Document Number: DS-000169 Revision: 1.3 Page 25 of 62 ICM-20789 4.12 CLOCKING The ICM-20789 has a flexible clocking scheme, allowing a variety of internal clock sources to be used for the internal synchronous circuitry. This synchronous circuitry includes the signal conditioning and ADCs, the DMP, and various control circuits and registers. An on-chip PLL provides flexibility in the allowable inputs for generating this clock. Allowable internal sources for generating the internal clock are: a) An internal relaxation oscillator b) Auto-select between internal relaxation oscillator and gyroscope MEMS oscillator to use the best available source The only setting supporting specified performance in all modes is option b). It is recommended that option b) be used. 4.13 SENSOR DATA REGISTERS The sensor data registers contain the latest gyroscope, accelerometer, and temperature measurement data. They are read-only registers, and are accessed via the serial interface. Data from these registers may be read anytime. 4.14 FIFO The ICM-20789 contains a 4 kB FIFO register that is accessible via the Serial Interface. The FIFO configuration register determines which data is written into the FIFO. Possible choices include gyro data, accelerometer data, temperature readings, and FSYNC input. A FIFO counter keeps track of how many bytes of valid data are contained in the FIFO. The FIFO register supports burst reads. The interrupt function may be used to determine when new data is available. The ICM-20789 allows FIFO read in low-power accelerometer mode. 4.15 INTERRUPTS Interrupt functionality is configured via the Interrupt Configuration register. Items that are configurable include the INT pin configuration, the interrupt latching and clearing method, and triggers for the interrupt. Items that can trigger an interrupt are (1) Clock generator locked to new reference oscillator (used when switching clock sources); (2) new data is available to be read (from the FIFO and Data registers); (3) accelerometer event interrupts; (4) DMP; (5) FIFO overflow. The interrupt status can be read from the Interrupt Status register. 4.16 DIGITAL-OUTPUT TEMPERATURE SENSOR An on-chip temperature sensor and ADC are used to measure the 6-axis motion die temperature. Another on-chip temperature sensor is present in the pressure sensor die. The readings from the ADC can be read from the FIFO or the Sensor Data registers. 4.17 BIAS AND LDOS The bias and LDO section generates the internal supply and the reference voltages and currents required by the ICM-20789. Its two inputs are an unregulated VDD and a VDDIO logic reference supply voltage. The LDO output is bypassed by a capacitor at REGOUT. For further details on the capacitor, please refer to the Bill of Materials for External Components. 4.18 CHARGE PUMP An on-chip charge pump generates the high voltage required for the MEMS oscillator. Document Number: DS-000169 Revision: 1.3 Page 26 of 62 ICM-20789 4.19 STANDARD POWER MODES – UPDATE THE POWER MODES The following table lists the user-accessible power modes for ICM-20789. MODE 1 2 3 4 5 6 7 8 9 10 NAME Sleep Mode Standby Mode Accelerometer Low-Power Mode Accelerometer Low-Noise Mode Gyroscope Low-Power Mode Gyroscope Low-Noise Mode 6-Axis Low-Noise Mode 6-Axis Low-Power Mode Pressure sensor Low Noise Mode Pressure Sensor Low Power Mode GYRO Off Drive On Off Off Duty-Cycled On On Duty-Cycled On Duty-Cycled ACCEL Off Off Duty-Cycled On Off Off On On On On DMP Off Off On or Off On or Off On or Off On or Off On or Off On or Off On or Off On or Off PRESSURE Off Off On or Off On or Off On or Off On or Off On or Off On or Off On On Table 16. Standard Power Modes for ICM-20789 Document Number: DS-000169 Revision: 1.3 Page 27 of 62 ICM-20789 5 PROGRAMMABLE INTERRUPTS The ICM-20789 has a programmable interrupt system which can generate an interrupt signal on the INT pin. Status flags indicate the source of an interrupt. Interrupt sources may be enabled and disabled individually. INTERRUPT NAME MODULE Motion Detection Motion FIFO Overflow FIFO Data Ready Sensor Registers DMP DMP Table 17. Table of Interrupt Sources 5.1 PER AXIS WAKE-ON-MOTION INTERRUPT The ICM-20789 provides motion detection capability. A qualifying motion sample is one where the high passed sample from any axis has an absolute value exceeding a user-programmable threshold. The following steps explain how to configure the Wake-on-Motion Interrupt. Step 1: Ensure that Accelerometer is running • • In PWR_MGMT_1 register (0x6B) set CYCLE = 0, SLEEP = 0, and GYRO_STANDBY = 0 In PWR_MGMT_2 register (0x6C) set DISABLE_XA = DISABLE_YA = DISABLE_ZA = 0, and DISABLE_XG = DISABLE_YG = DISABLE_ZG = 1 Step 2: Accelerometer Configuration 1. In ACCEL_CONFIG2 register (0x1D) set ACCEL_FCHOICE_B = 0 and A_DLPF_CFG [2:0] = 1 (b001) Step 3: Enable Motion Interrupt 2. In INT_ENABLE register (0x38) set WOM_X_INT_EN = WOM_Y_INT_EN = WOM_Z_INT_EN = 1 to enable motion interrupt per axis. Step 4: Set Motion Threshold 3. Set the motion threshold in ACCEL_WOM_X_THR (0x20), ACCEL_WOM_Y_THR (0x21), ACCEL_WOM_Z_THR (0x22) Step 5: Enable Accelerometer Hardware Intelligence 4. In ACCEL_INTEL_CTRL register (0x69) set ACCEL_INTEL_EN = ACCEL_INTEL_MODE = 1; Ensure that bit 0 is set to 0. Step 6: Set Frequency of Wake-Up 5. In SMPLRT_DIV register (0x19) set SMPLRT_DIV [7:0] = 3.9 Hz – 500 Hz Step 7: Enable Cycle Mode (Accelerometer Low-Power Mode) 6. In PWR_MGMT_1 register (0x6B) set CYCLE = 1 Document Number: DS-000169 Revision: 1.3 Page 28 of 62 ICM-20789 6 DIGITAL INTERFACE 6.1 I2C SERIAL INTERFACE The internal registers and memory of the ICM-20789 can be accessed using either I2C at 400 kHz. PIN NUMBER PIN NAME PIN DESCRIPTION 9 AD0 I2C Slave Address LSB (AD0) 23 SCL I2C serial clock (SCL) 24 SDA I2C serial data (SDA) Table 18. Serial Interface 6.2 I2C INTERFACE I2C is a two-wire interface comprised of the signals serial data (SDA) and serial clock (SCL). In general, the lines are open-drain and bidirectional. In a generalized I2C interface implementation, attached devices can be a master or a slave. The master device puts the slave address on the bus, and the slave device with the matching address acknowledges the master. The ICM-20789 always operates as a slave device when communicating to the system processor, which thus acts as the master. SDA and SCL lines typically need pull-up resistors to VDDIO. The maximum bus speed is 400 kHz. The slave address of the ICM-20789 is b110100X which is 7 bits long. The LSB bit of the 7-bit address is determined by the logic level on pin AD0. This allows two ICM-20789s to be connected to the same I2C bus. When used in this configuration, the address of one of the devices should be b1101000 (pin AD0 is logic low) and the address of the other should be b1101001 (pin AD0 is logic high). 6.3 I2C COMMUNICATIONS PROTOCOL (6-AXIS ONLY. FOR PRESSURE PLEASE SEE CHAPTER 10) START (S) and STOP (P) Conditions Communication on the I2C bus starts when the master puts the START condition (S) on the bus, which is defined as a HIGH-to-LOW transition of the SDA line while SCL line is HIGH (see figure below). The bus is considered to be busy until the master puts a STOP condition (P) on the bus, which is defined as a LOW to HIGH transition on the SDA line while SCL is HIGH (see figure below). Additionally, the bus remains busy if a repeated START (Sr) is generated instead of a STOP condition. SDA SCL S P START condition STOP condition Figure 11. START and STOP Conditions Document Number: DS-000169 Revision: 1.3 Page 29 of 62 ICM-20789 Data Format / Acknowledge I2C data bytes are defined to be 8 bits long. There is no restriction to the number of bytes transmitted per data transfer. Each byte transferred must be followed by an acknowledge (ACK) signal. The clock for the acknowledge signal is generated by the master, while the receiver generates the actual acknowledge signal by pulling down SDA and holding it low during the HIGH portion of the acknowledge clock pulse. If a slave is busy and cannot transmit or receive another byte of data until some other task has been performed, it can hold SCL LOW, thus forcing the master into a wait state. Normal data transfer resumes when the slave is ready, and releases the clock line (refer to the following figure). DATA OUTPUT BY TRANSMITTER (SDA) not acknowledge DATA OUTPUT BY RECEIVER (SDA) acknowledge SCL FROM MASTER 1 2 8 9 clock pulse for acknowledgement START condition Figure 12. Acknowledge on the I2C Bus Communications After beginning communications with the START condition (S), the master sends a 7-bit slave address followed by an 8th bit, the read/write bit. The read/write bit indicates whether the master is receiving data from or is writing to the slave device. Then, the master releases the SDA line and waits for the acknowledge signal (ACK) from the slave device. Each byte transferred must be followed by an acknowledge bit. To acknowledge, the slave device pulls the SDA line LOW and keeps it LOW for the high period of the SCL line. Data transmission is always terminated by the master with a STOP condition (P), thus freeing the communications line. However, the master can generate a repeated START condition (Sr), and address another slave without first generating a STOP condition (P). A LOW to HIGH transition on the SDA line while SCL is HIGH defines the stop condition. All SDA changes should take place when SCL is low, with the exception of start and stop conditions. SDA SCL 1–7 8 9 1–7 8 9 1–7 8 9 S START ADDRESS condition P R/W ACK DATA ACK DATA ACK STOP condition Figure 13. Complete I2C Data Transfer Document Number: DS-000169 Revision: 1.3 Page 30 of 62 ICM-20789 To write the internal ICM-20789 registers, the master transmits the start condition (S), followed by the I2C address and the write bit (0). At the 9th clock cycle (when the clock is high), the ICM-20789 acknowledges the transfer. Then the master puts the register address (RA) on the bus. After the ICM-20789 acknowledges the reception of the register address, the master puts the register data onto the bus. This is followed by the ACK signal, and data transfer may be concluded by the stop condition (P). To write multiple bytes after the last ACK signal, the master can continue outputting data rather than transmitting a stop signal. In this case, the ICM20789 automatically increments the register address and loads the data to the appropriate register. The following figures show single and two-byte write sequences. Single-Byte Write Sequence Master S AD+W RA Slave ACK DATA ACK P ACK Burst Write Sequence Master S AD+W RA Slave ACK DATA ACK DATA ACK P ACK To read the internal ICM-20789 registers, the master sends a start condition, followed by the I2C address and a write bit, and then the register address that is going to be read. Upon receiving the ACK signal from the ICM-20789, the master transmits a start signal followed by the slave address and read bit. As a result, the ICM-20789 sends an ACK signal and the data. The communication ends with a not acknowledge (NACK) signal and a stop bit from master. The NACK condition is defined such that the SDA line remains high at the 9th clock cycle. The following figures show single and two-byte read sequences. Single-Byte Read Sequence Master S AD+W Slave RA ACK S AD+R ACK NACK ACK P DATA Burst Read Sequence Master S AD+W Slave RA ACK S ACK AD+R ACK ACK DATA NACK P DATA 6.4 I2C TERMS SIGNAL DESCRIPTION S AD W Start Condition: SDA goes from high to low while SCL is high Slave I2C address Write bit (0) R ACK Read bit (1) Acknowledge: SDA line is low while the SCL line is high at the 9th clock cycle NACK RA DATA Not-Acknowledge: SDA line stays high at the 9th clock cycle ICM-20789 internal register address Transmit or received data P Stop condition: SDA going from low to high while SCL is high Table 19. I2C Term SPI Interface SPI is a 4-wire synchronous serial interface that uses two control lines and two data lines. The ICM-20789 always operates as a Slave device during standard Master-Slave SPI operation (6-Axis only). With respect to the Master, the Serial Clock output (SPC), the Serial Data Output (SDO) and the Serial Data Input (SDI) are shared among the Slave devices. Each SPI slave device requires its own Chip Select (CS) line from the master. CS goes low (active) at the start of transmission and goes back high (inactive) at the end. Only one CS line is active at a time, ensuring that only one slave is selected at any given time. The CS lines of the non-selected slave devices are held high, causing their SDO lines to remain in a high-impedance (high-z) state so that they do not interfere with any active devices. Document Number: DS-000169 Revision: 1.3 Page 31 of 62 ICM-20789 SPI Operational Features 1. Data is delivered MSB first and LSB last 2. Data is latched on the rising edge of SPC 3. Data should be transitioned on the falling edge of SPC 4. The maximum frequency of SPC is 8 MHz 5. SPI read and write operations are completed in 16 or more clock cycles (two or more bytes). The first byte contains the SPI Address, and the following byte(s) contain(s) the SPI data. The first bit of the first byte contains the Read/Write bit and indicates the Read (1) or Write (0) operation. The following 7 bits contain the Register Address. In cases of multiplebyte Read/Writes, data is two or more bytes: SPI Address format MSB R/W A6 A5 A4 A3 A2 A1 LSB A0 D6 D5 D4 D3 D2 D1 LSB D0 SPI Data format MSB D7 6. Supports Single or Burst Read/Writes. Document Number: DS-000169 Revision: 1.3 Page 32 of 62 ICM-20789 7 SERIAL INTERFACE CONSIDERATIONS 7.1 ICM-20789 SUPPORTED INTERFACES The ICM-20789 supports I2C communications on its serial interface. The ICM-20789’s I/O logic levels are set to be VDDIO. The figure below depicts a sample circuit of ICM-20789. It shows the relevant logic levels and voltage connections. VDDIO (0V - VDDIO) VDD VDDIO VDD INT SDA (0V - VDDIO) SYNC VDDIO SCL SYSTEM BUS VDD_IO System Processor IO (0V - VDDIO) (0V - VDDIO) (0V - VDDIO) ICM-20789 VDDIO (0V, VDDIO) AD0 Figure 14. I/O Levels and Connections Document Number: DS-000169 Revision: 1.3 Page 33 of 62 ICM-20789 8 REGISTER MAP Addr. (Dec) Addr (Hex) Register Names 0 00 SELF_TEST X GYRO XG_ST_DATA[7:0] 1 01 SELF_TEST Y GYRO YG_ST_DATA[7:0] 2 02 SELF_TEST Z GYRO ZG_ST_DATA[7:0] 13 0D 14 0E Bit7 Bit6 Bit5 Bit4 SELF_TEST4(X ACCEL) SELF_TEST5(Y ACCEL) SELF_TEST6(Z ACCEL) Bit3 0F 13 XG_OFFS_USRH X_OFFS_USR[15:8] 20 14 XG_OFFS_USRL X_OFFS_USR[7:0] 21 15 YG_OFFS_USRH Y_OFFS_USR[15:8] 22 16 YG_OFFS_USRL Y_OFFS_USR[7:0] 23 17 ZG_OFFS_USRH Z_OFFS_USR[15:8] 24 18 ZG_OFFS_USRL Z_OFFS_USR[7:0] 25 19 SMPLRT_DIV 26 1A CONFIG 27 1B GYRO CONFIG 28 1C ACCEL_CONFIG 1D ACCEL_CONFIG2 1E LP_MODE_CTRL 32 20 33 21 34 22 35 23 55 37 ZA_ST_DATA[7:0] SMPLRT_DIV[7:0] FIFO_COUN T_REC XGYRO_STE N AX_ST_EN FIFO_MODE EXT_SYNC_SET[2:0] ZGYRO_STEN GYRO_FS_SEL[1:0] - AY_ST_EN AZ_ST_EN ACCEL_FS_SEL[4:3] - FIFO_SIZE[1:0] FCHOICE_B[1:0] - ACCEL_FCHOICE _B DEC2_CFG[5:4] GYRO_CYCL E - A_DLPF_CFG[2:0] GYRO_AVGCFG[2:0] LPOSC_CLKSEL2[3:0] WOM_X_THRESHOLD[7:0] WOM_Y_THRESHOLD[7:0] WOM_Z_THRESHOLD[7:0] TEMP_OUT GYRO_XOUT GYRO_YOUT INT_PIN_CFG ACTL OPEN LATCH_INT_EN WOM_X_IN T_EN WOM_Y_INT_EN WOM_Z_INT_EN FIFO_WM_INT 56 38 INT_ENABLE 57 39 DMP_INT_STATUS WOM_X_IN T WOM_Y_INT GYRO_ZOUT INT_ANYRD_2CLE AR FIFO_OVERFLOW _EN ACCEL_XYZ_OU T - - - ACTL_FSYNC FSYNC_INT_MOD E_EN BYPASS_EN - - GDRIVE_RDY_EN DMP_INT_EN RAW_RDY_EN DMP_INT [5:0] WOM_Z_INT FIFO_OVERFLOW _INT 58 3A INT_STATUS 59 3B ACCEL_XOUT_H ACCEL_XOUT_H [15:8] 60 3C ACCEL_XOUT_L ACCEL_XOUT_L[7:0] 61 3D ACCEL_YOUT_H ACCEL_YOUT_H[15:8] 62 3E ACCEL_YOUT_L ACCEL_YOUT_L[7:0] 63 3F ACCEL_ZOUT_H ACCEL_ZOUT_H[15:8] 64 40 ACCEL_ZOUT_L ACCEL_ZOUT_L[7:0] 65 41 TEMP_OUT_H TEMP_OUT_H[15:8] 66 42 TEMP_OUT_L TEMP_OUT_L[7:0] 67 43 GYRO_XOUT_H GYRO_XOUT_H[15:8] 68 44 GYRO_XOUT_L GYRO_XOUT_L[7:0] 69 45 GYRO_YOUT_H GYRO_YOUT_H[15:8] 70 46 GYRO_YOUT_L GYRO_YOUT_L[7:0] 71 47 GYRO_ZOUT_H GYRO_ZOUT_H[15:8] 72 48 GYRO_ZOUT_L GYRO_ZOUT_L[7:0] 104 68 SIGNAL_PATH_RES ET - - - 105 69 ACCEL_INTEL_CTRL ACCEL_INTE L_EN ACCEL_INTEL_MO DE - Document Number: DS-000169 Revision: 1.3 DLPF_CFG[2:0] YGYRO_STEN ACCEL_WOM_X_T HR ACCEL_WOM_Y_T HR ACCEL_WOM_Z_T HR FIFO_EN Bit0 YA_ST_DATA[7:0] 19 30 Bit1 XA_ST_DATA[7:0] 15 29 Bit2 - GDRIVE_RDY_INT DMP_INT RAW_DATA_RDY _INT - - GYRO_RST ACCEL_RST TEMP_RST - - - - - Page 34 of 62 ICM-20789 Addr. (Dec) Addr (Hex) Register Names 106 6A Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 USER_CTRL DMP_EN FIFO_EN - I2C_IF_DIS DMP_RST FIFO_RST - SIG_COND_RST SLEEP ACCEL_CYCLE GYRO_STANDBY TEMP_DIS DMP_LP_DIS DISABLE_XA DISABLE_YA DISABLE_ZA 107 6B PWR_MGMT_1 DEVICE_RES ET 108 6C PWR_MGMT_2 LP_DIS 114 72 FIFO_COUNTH FIFO_COUNTH[12:8] 115 73 FIFO_COUNTL FIFO_COUNTL[7:0] 116 74 FIFO_R_W FIFO_R_W[7:0] 117 75 WHO_AM_I WHO_AM_I[7:0] 119 77 XA_OFFS_H XA_OFFSH[14:7] 120 78 XA_OFFS_L 122 7A YA_OFFS_H 123 7B YA_OFFS_L 125 7D ZA_OFFS_H 126 7E ZA_OFFS_L CLKSEL[2:0] DISABLE_XG DISABLE_YG XA_OFFSL[6:0] DISABLE_ZG - YA_OFFSH[14:7] YA_OFFSL[6:0] - ZA_OFFSH[14:7] ZA_OFFSL[6:0] - Table 20. Register Map Note: Register Names ending in _H and _L contain the high and low bytes, respectively, of an internal register value. In the detailed register tables that follow, register names are in capital letters, while register values are in capital letters and italicized. For example, the ACCEL_XOUT_H register (Register 59) contains the 8 most significant bits, ACCEL_XOUT[15:8], of the 16bit X-Axis accelerometer measurement, ACCEL_XOUT. The reset value is 0x00 for all registers other than the registers below, also the self-test registers contain pre-programmed values and will not be 0x00 after reset. • • Register 107 (0x40) Power Management 1 Register 117 (0x03) WHO_AM_I for ICM-20789 Document Number: DS-000169 Revision: 1.3 Page 35 of 62 ICM-20789 9 REGISTER DESCRIPTIONS This section describes the function and contents of each register within the ICM-20789. Note: The device will come up in sleep mode upon power-up. 9.1 REGISTERS DESCRIPTIONS Reset values are “0” for all registers, unless otherwise specified 9.2 REGISTERS 0 TO 2 – SELF-TEST REGISTERS Register Name: SELF_TEST X GYRO, SELF_TEST Y GYRO, SELF_TEST Z GYRO Type: USR/CFG Register Address: 0, 1, 2 (Decimal); 00, 01, 02 (Hex) REGISTER BIT NAME SELF_TEST X GYRO [7:0] XG_ST_DATA SELF_TEST Y GYRO [7:0] YG_ST_DATA SELF_TEST Z GYRO [7:0] ZG_ST_DATA FUNCTION The value in this register indicates the self-test output generated during manufacturing tests. This value is to be used to check against subsequent self-test outputs performed by the end user. The value in this register indicates the self-test output generated during manufacturing tests. This value is to be used to check against subsequent self-test outputs performed by the end user. The value in this register indicates the self-test output generated during manufacturing tests. This value is to be used to check against subsequent self-test outputs performed by the end user. 9.3 REGISTERS 13 TO 15 Register Name: SELF_TEST4(X ACCEL), SELF_TEST5(Y ACCEL), SELF_TEST6(Z ACCEL) Register Type: USR/CFG Register Address: 13, 14, 15 (Decimal); 0D, 0E, 0F (Hex) REGISTER SELF_TEST4(X ACCEL) SELF_TEST5(Y ACCEL) SELF_TEST6(Z ACCEL) BIT [7:0] [7:0] [7:0] NAME XA_ST_DATA[7:0] YA_ST_DATA[7:0] ZA_ST_DATA[7:0] FUNCTION Contains self-test data for the X Accelerometer Contains self-test data for the Y Accelerometer Contains self-test data for the Z Accelerometer 9.4 REGISTER 19 – GYRO OFFSET ADJUSTMENT REGISTER Register Name: XG_OFFS_USRH Register Type: USR Register Address: 19 (Decimal); 13 (Hex) BIT [7:0] NAME X_OFFS_USR[15:8] FUNCTION Bits 15 to 8 of the 16-bit offset of X gyroscope (2’s complement). This register is used to remove DC bias from the sensor output. The value in this register is added to the gyroscope sensor value before going into the sensor register. 9.5 REGISTER 20 – GYRO OFFSET ADJUSTMENT REGISTER Register Name: XG_OFFS_USRL Register Type: USR Register Address: 20 (Decimal); 14 (Hex) BIT [7:0] NAME X_OFFS_USR[7:0] Document Number: DS-000169 Revision: 1.3 FUNCTION Bits 7 to 0 of the 16-bit offset of X gyroscope (2’s complement). This register is used to remove DC bias from the sensor output. The value in this register is added to the gyroscope sensor value before going into the sensor register. Page 36 of 62 ICM-20789 9.6 REGISTER 21 – GYRO OFFSET ADJUSTMENT REGISTER Register Name: YG_OFFS_USRH Register Type: USR Register Address: 21 (Decimal); 15 (Hex) INTBIT [7:0] NAME Y_OFFS_USR[15:8] FUNCTION Bits 15 to 8 of the 16-bit offset of Y gyroscope (2’s complement). This register is used to remove DC bias from the sensor output. The value in this register is added to the gyroscope sensor value before going into the sensor register. 9.7 REGISTER 22 – GYRO OFFSET ADJUSTMENT REGISTER Register Name: YG_OFFS_USRL Register Type: USR Register Address: 22 (Decimal); 16 (Hex) BIT [7:0] NAME Y_OFFS_USR[7:0] FUNCTION Bits 7 to 0 of the 16-bit offset of Y gyroscope (2’s complement). This register is used to remove DC bias from the sensor output. The value in this register is added to the gyroscope sensor value before going into the sensor register. 9.8 REGISTER 23 – GYRO OFFSET ADJUSTMENT REGISTER Register Name: ZG_OFFS_USRH Register Type: USR Register Address: 23 (Decimal); 17 (Hex) BIT [7:0] NAME Z_OFFS_USR[15:8] FUNCTION Bits 15 to 8 of the 16-bit offset of Z gyroscope (2’s complement). This register is used to remove DC bias from the sensor output. The value in this register is added to the gyroscope sensor value before going into the sensor register. 9.9 REGISTER 24 – GYRO OFFSET ADJUSTMENT REGISTER Register Name: ZG_OFFS_USRL Register Type: USR Register Address: 24 (Decimal); 18 (Hex) BIT NAME [7:0] Z_OFFS_USR[7:0] FUNCTION Bits 7 to 0 of the 16-bit offset of Z gyroscope (2’s complement). This register is used to remove DC bias from the sensor output. The value in this register is added to the gyroscope sensor value before going into the sensor register. 9.10 REGISTER 25 – SAMPLE RATE DIVIDER. Register Name: SMPLRT_DIV Register Type: USR Register Address: 25 (Decimal); 19 (Hex) BIT NAME [7:0] SMPLRT_DIV[7:0] Document Number: DS-000169 Revision: 1.3 FUNCTION Divides the internal sample rate (see register CONFIG (0x1A)) to generate the sample rate that controls sensor data output rate, FIFO sample rate. Note: This register is only effective when FCHOICE_B register bits are 2’b00, and (0 < DLPF_CFG < 7). This is the update rate of the sensor register: SAMPLE_RATE = INTERNAL_SAMPLE_RATE / (1 + SMPLRT_DIV) Where INTERNAL_SAMPLE_RATE = 1 kHz Page 37 of 62 ICM-20789 9.11 REGISTER 26 – CONFIGURATION Register Name: CONFIG Register Type: USR Register Address: 26 (Decimal); 1A (Hex) BIT [7] NAME FIFO_COUNT_REC [6] FIFO_MODE [5:3] EXT_SYNC_SET[2:0] [2:0] DLPF_CFG[2:0] FUNCTION Always set to 0. When set to ‘1’, when the fifo is full, additional writes will not be written to fifo. When set to ‘0’, when the fifo is full, additional writes will be written to the fifo, replacing the oldest data. Enables the FSYNC pin data to be sampled. EXT_SYNC_SET 0 1 2 3 4 5 6 7 FSYNC bit location function disabled TEMP_OUT_L[0] GYRO_XOUT_L[0] GYRO_YOUT_L[0] GYRO_ZOUT_L[0] ACCEL_XOUT_L[0] ACCEL_YOUT_L[0] ACCEL_ZOUT_L[0] For the DLPF to be used, FCHOICE_B[1:0] is 2’b00. See the table below. The DLPF is configured by DLPF_CFG, when FCHOICE_B [1:0] = 2b’00. The gyroscope and temperature sensor are filtered according to the value of DLPF_CFG and FCHOICE_B as shown in the table below. FCHOICE_B Gyroscope DLPF_CFG X 1 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 X X 0 1 2 3 4 5 6 7 3-dB BW (Hz) Noise BW (Hz) 8173 3281 250 176 92 41 20 10 5 3281 8595.1 3451.0 306.6 177.0 108.6 59.0 30.5 15.6 8.0 3451.0 Temperature Sensor 3-dB BW (Hz) 4000 4000 4000 188 98 42 20 10 5 4000 9.12 REGISTER 27 – GYROSCOPE CONFIGURATION Register Name: GYRO CONFIG Register Type: USR Register Address: 27 (Decimal); 1B (Hex) BIT [7] [6] [5] NAME XGYRO_STEN YGYRO_STEN ZGYRO_STEN [4:3] GYRO_FS_SEL[1:0] [2] [1:0] FCHOICE_B[1:0] Document Number: DS-000169 Revision: 1.3 FUNCTION X Gyro self-test. Y Gyro self-test. Z Gyro self-test. Gyro Full Scale Select: 00 = ±250 dps 01= ±500 dps 10 = ± 1000 dps 11 = ±2000 dps Reserved. NOTE: Register is Fchoice_b (inverted version of Fchoice) Page 38 of 62 ICM-20789 9.13 REGISTER 28 – ACCELEROMETER CONFIGURATION Register Name: ACCEL_CONFIG Register Type: USR Register Address: 28 (Decimal); 1C (Hex) BIT [7] [6] [5] AX_ST_EN AY_ST_EN AZ_ST_EN NAME [4:3] ACCEL_FS_SEL[1:0] [2:0] - FUNCTION X Accel self-test. Y Accel self-test. Z Accel self-test. Accel Full Scale Select: ±2g (00), ±4g (01), ±8g (10), ±16g (11) Reserved. 9.14 REGISTER 29 – ACCELEROMETER CONFIGURATION 2 Register Name: ACCEL_CONFIG2 Register Type: USR Register Address: 29 (Decimal); 1D (Hex) BIT [7:6] NAME FUNCTION Fifo size control: 0=512bytes, 1=1 KB, 2=2 KB, 3=4 KB FIFO_SIZE[1:0] NOTE: After the fifo size has been changed, the fifo should be reset. [5:4] DEC2_CFG [3] ACCEL_FCHOICE_B [2:0] A_DLPF_CFG Controls the number of samples averaged in the accel decimator 2: 0 = average 4 samples 1 = average 8 samples 2 = average 16 samples 3 = average 32 samples Used to bypass DLPF as shown in table 2 below. NOTE: This register contains accel_fchoice_b (the inverted version of accel_fchoice as described in the table below). Accelerometer low pass filter setting as shown in table below. Accelerometer ACCEL_FCHOICE_B A_DLPF_CFG 1 0 0 0 0 0 0 0 0 X 0 1 2 3 4 5 6 7 3-dB BW (Hz) 1046.0 218.1 218.1 99.0 44.8 21.2 10.2 5.1 420.0 Table 21. Accelerometer Data Rates and Bandwidths (Low Noise Mode) Notes: 1. 2. The data rate out of the DLPF filter block can be further reduced by a factor of 1/(1+SMPLRT_DIV), where SMPLRT_DIV is an 8-bit integer. Data should be sampled at or above sample rate; SMPLRT_DIV is only used for1 kHz internal sampling. Document Number: DS-000169 Revision: 1.3 Page 39 of 62 ICM-20789 In the low-power mode of operation, the accelerometer is duty-cycled. For each ODR, there are several bandwidth settings corresponding to different numbers of averages per measurement cycle of the Dec1 output. ACCEL_FCHOICE_B A_DLPF_CFG DEC2_CFG Averages Ton (ms) Noise BW (Hz) Noise (mg) TYP based on 150 µg/√Hz SMPLRT_DIV ODR (Hz) 255 3.9 127 7.8 63 15.6 31 31.3 15 62.5 7 125.0 3 250.0 1 500.0 1 x x 1x 1.084 1100.0 0 7 0 4x 1.84 441.6 0 7 1 8x 2.84 235.4 0 7 2 16x 4.84 121.3 0 7 3 32x 8.84 61.5 8.3 5.3 3.8 2.8 2.0 8.4 9.8 12.8 18.7 30.4 57.4 100.9 194.9 Current Consumption (µA) TYP 9.4 10.8 13.6 11.9 14.7 20.3 17.0 22.5 33.7 27.1 38.2 60.4 47.2 69.4 113.9 87.5 132.0 220.9 168.1 257.0 N/A 329.3 N/A 19.2 31.4 55.9 104.9 202.8 N/A Table 22. Accelerometer Data Rates and Bandwidths (Low-Power Mode) • • • Gyros ON: When at least one axis of the Gyro is ON, then the ODR is determined by the gyro_fchoice and dlpf_cfg. Gyro OFF and normal Accel mode: When all the axes of Gyro are turned off and in normal Accel mode, then the ODR is determined by accel_fchoice and dlpf_cfg. Low power Accel mode: In low power Accel mode, the ODR is determined by Accel_fchoice and dec2_cfg 9.15 REGISTER 30 – LOW POWER MODE CONFIGURATION Register Name: LP_MODE_CTRL Register Type: USR Register Address: 30 (Decimal); 1E (Hex) BIT [7] [6:4] [3:0] NAME GYRO_CYCLE GYRO_AVGCFG[2:0] LPOSC_CLKSEL[3:0] FUNCTION Enable gyro duty cycling. Averaging filter configuration for gyro duty cycling. Reserved. To operate in gyroscope low-power mode or 6-axis low-power mode, GYRO_CYCLE should be set to ‘1.’ Gyroscope filter configuration is determined by G_AVGCFG[2:0] that sets the averaging filter configuration. It is not dependent on DLPF_CFG[2:0]. The following table shows some example configurations for gyroscope low power mode. Document Number: DS-000169 Revision: 1.3 Page 40 of 62 ICM-20789 FCHOICE_B G_AVGCFG Averages Ton (ms) Noise BW (Hz) Noise (dps) TYP based on 0.006 dps/√Hz SMPLRT_DIV ODR (Hz) 255 3.9 99 10.0 64 15.4 32 30.3 19 50.0 9 100.0 7 125.0 4 200.0 3 250.0 2 333.3 1 500.0 0 0 1x 1.73 650.8 0 1 2x 2.23 407.1 0 2 4x 3.23 224.2 0 3 8x 5.23 117.4 0 4 16x 9.23 60.2 0 5 32x 17.23 30.6 0 6 64x 33.23 15.6 0 7 128x 65.23 8.0 0.15 0.12 0.09 0.07 0.05 0.03 0.02 0.02 1.3 1.3 1.4 1.4 1.5 1.6 1.7 1.9 2.1 2.3 2.9 1.3 1.3 1.4 1.4 1.5 1.7 1.8 2.1 2.3 2.6 1.3 1.4 1.4 1.5 1.6 1.9 2.0 2.5 2.7 1.4 1.6 1.8 2.2 2.8 1.5 1.9 2.2 1.8 2.5 N/A Current Consumption (mA) TYP 1.3 1.4 1.4 1.5 1.5 1.6 1.6 1.8 1.8 2.1 2.2 3.0 2.5 N/A N/A N/A N/A N/A N/A 9.16 REGISTER 32 – WAKE ON MOTION THRESHOLD Register Name: ACCEL_WOM_X_THR Register Type: USR Register Address: 32 (Decimal); 20 (Hex) BIT [7:0] NAME WOM_X_Threshold FUNCTION Accel WOM threshold for x-axis. 9.17 REGISTER 33 – WAKE ON MOTION THRESHOLD Register Name: ACCEL_WOM_Y_THR Register Type: USR Register Address: 33 (Decimal); 21 (Hex) BIT [7:0] NAME WOM_Y_Threshold FUNCTION Accel WOM threshold for y-axis. 9.18 REGISTER 34 – WAKE ON MOTION THRESHOLD Register Name: ACCEL_WOM_Z_THR Register Type: USR Register Address: 34 (Decimal); 22 (Hex) BIT [7:0] NAME WOM_Z_Threshold Document Number: DS-000169 Revision: 1.3 FUNCTION Accel WOM threshold for z-axis. Page 41 of 62 ICM-20789 9.19 REGISTER 35 – FIFO ENABLE FIFO enable takes effect during the idle state of the sequence controller. Register Name: FIFO_EN Register Type: USR Register Address: 35 (Decimal); 23 (Hex) BIT NAME [7] TEMP_OUT [6] GYRO_XOUT [5] GYRO_YOUT FUNCTION 1 – Write TEMP_OUT_H and TEMP_OUT_L to the FIFO at the sample rate; If enabled, buffering of data occurs even if data path is in standby. 0 – Function is disabled. 1 – Write GYRO_XOUT_H and GYRO_XOUT_L to the FIFO at the sample rate; If enabled, buffering of data occurs even if data path is in standby. 0 – Function is disabled. 1 – Write GYRO_YOUT_H and GYRO_YOUT_L to the FIFO at the sample rate; If enabled, buffering of data occurs even if data path is in standby. 0 – Function is disabled. NOTE: Enabling any one of the bits corresponding to the Gyros or Temp data paths, data is buffered into the FIFO even though that data path is not enabled. [4] GYRO_ZOUT [3] ACCEL_XYZ_OUT [2] [1] [0] - 1 – Write GYRO_ZOUT_H and GYRO_ZOUT_L to the FIFO at the sample rate; If enabled, buffering of data occurs even if data path is in standby. 0 – Function is disabled. 1 – Write ACCEL_XOUT_H, ACCEL_XOUT_L, ACCEL_YOUT_H, ACCEL_YOUT_L, ACCEL_ZOUT_H, and ACCEL_ZOUT_L to the FIFO at the sample rate; 0 – Function is disabled. Reserved. Reserved. Reserved. 9.20 REGISTER 55 – INTERRUPT/BYPASS PIN CONFIGURATION Register Name: INT_PIN_CFG Register Type: USR Register Address: 55 (Decimal); 37 (Hex) BIT NAME [7] ACTL [6] OPEN [5] LATCH_INT_EN [4] INT_ANYRD_2CLEAR [3] ACTL_FSYNC [2] FSYNC_INT_MODE_EN [1] [0] BYPASS_EN - Document Number: DS-000169 Revision: 1.3 FUNCTION 1 – The logic level for INT pin is active low. 0 – The logic level for INT pin is active high. 1 – INT pin is configured as open drain. 0 – INT pin is configured as push-pull. 1 – INT pin level held until interrupt status is cleared. 0 – INT pin indicates interrupt pulse’s is width 50 µs. 1 – Interrupt status is cleared if any read operation is performed. 0 – Interrupt status is cleared only by reading INT_STATUS register. 1 – The logic level for the FSYNC pin as an interrupt is active low. 0 – The logic level for the FSYNC pin as an interrupt is active high. 1 – This enables the FSYNC pin to be used as an interrupt. A transition to the active level described by the ACTL_FSYNC bit will cause an interrupt. The status of the interrupt is read in the I2C Master Status register PASS_THROUGH bit. 0 – This disables the FSYNC pin from causing an interrupt. When asserted, will go into ‘bypass mode’ where the I2C master interface is disabled. Reserved. Page 42 of 62 ICM-20789 9.21 REGISTER 56 – INTERRUPT ENABLE Register Name: INT_ENABLE Register Type: USR Register Address: 56 (Decimal); 38 (Hex) BIT [7] [6] [5] NAME WOM_X_INT_EN WOM_Y_INT_EN WOM_Z_INT_EN [4] FIFO_OVERFLOW_EN [3] - [2] GDRIVE_RDY_EN [1] DMP_INT_EN [0] RAW_RDY_EN FUNCTION 1 – Enable wake on motion interrupt on accel X-axis 1 – Enable wake on motion interrupt on accel Y-axis, 1 – Enable wake on motion interrupt on accel Z-axis 1 – Enable interrupt for FIFO overflow to propagate to interrupt pin. 0 – Function is disabled. Reserved 1 – Enable gyro drive rdy interrupt to propagate to interrupt pin. 0 – Function is disabled. 1 – Enable DMP interrupt to propagate to interrupt pin. 0 – Function is disabled. 1 – Enable Raw Sensor Data Ready interrupt to propagate to interrupt pin. 0 – Function is disabled. 9.22 REGISTER 57 – DMP INTERRUPT STATUS Register Name: DMP_INT_STATUS Register Type: USR Register Address: 57 (Decimal); 39 (Hex) BIT [6] [5:0] NAME FIFO_WM_INT DMP_INT FUNCTION Reserved. DMP Interrupt Status. 9.23 REGISTER 58 – INTERRUPT STATUS Register Name: INT_STATUS Register Type: USR Register Address: 58 (Decimal); 3A (Hex) BIT [7] [6] [5] NAME WOM_X_INT WOM_Y_INT WOM_Z_INT [4] FIFO_OVERFLOW_INT [3] [2] [1] [0] GDRIVE_RDY_INT DMP_INT RAW_DATA_RDY_INT FUNCTION Wake on motion interrupt triggered on x-axis. Wake on motion interrupt triggered on y-axis. Wake on motion interrupt triggered on z-axis. 1 – FIFO Overflow interrupt occurred. Note that the oldest data is has been dropped from the FIFO. Reserved. 1 – Indicates that the gyro drive has been enabled and is ready. 1 – The DMP has generated an Interrupt. 1 – Sensor Register Raw Data sensors are updated and Ready to be read. 9.24 REGISTER 59 – ACCELEROMETER MEASUREMENTS Register Name: ACCEL_XOUT_H Register Type: USR Register Address: 59 (Decimal); 3B (Hex) BIT [7:0] NAME ACCEL_XOUT_H [15:8] FUNCTION High byte of accelerometer x-axis data. 9.25 REGISTER 60 – ACCELEROMETER MEASUREMENTS Register Name: ACCEL_XOUT_L Register Type: USR Register Address: 60 (Decimal); 3C (Hex) BIT [7:0] NAME ACCEL_XOUT_L [7:0] Document Number: DS-000169 Revision: 1.3 FUNCTION Low byte of accelerometer x-axis data. Page 43 of 62 ICM-20789 9.26 REGISTER 61 – ACCELEROMETER MEASUREMENTS Register Name: ACCEL_YOUT_H Register Type: USR Register Address: 61 (Decimal); 3D (Hex) BIT [7:0] NAME ACCEL_YOUT_H [15:8] FUNCTION High byte of accelerometer y-axis data. 9.27 REGISTER 62 – ACCELEROMETER MEASUREMENTS Register Name: ACCEL_YOUT_L Register Type: USR Register Address: 62 (Decimal); 3E (Hex) BIT [7:0] NAME ACCEL_YOUT_L [7:0] FUNCTION Low byte of accelerometer y-axis data. 9.28 REGISTER 63 – ACCELEROMETER MEASUREMENTS Register Name: ACCEL_ZOUT_H Register Type: USR Register Address: 63 (Decimal); 3F (Hex) BIT [7:0] NAME ACCEL_ZOUT_H [15:8] FUNCTION High byte of accelerometer z-axis data. 9.29 REGISTER 64 – ACCELEROMETER MEASUREMENTS Register Name: ACCEL_ZOUT_L Register Type: USR Register Address: 64 (Decimal); 40 (Hex) BIT [7:0] NAME ACCEL_ZOUT_L [7:0] FUNCTION Low byte of accelerometer z-axis data. 9.30 REGISTER 65 – TEMPERATURE MEASUREMENT Register Name: TEMP_OUT_H Register Type: USR Register Address: 65 (Decimal); 41 (Hex) BIT [7:0] NAME TEMP_OUT_H[15:8] FUNCTION High byte of the temperature sensor output. 9.31 REGISTER 66 – TEMPERATURE MEASUREMENT Register Name: TEMP_OUT_L Register Type: USR Register Address: 66 (Decimal); 42 (Hex) BIT [7:0] NAME TEMP_OUT_L[7:0] FUNCTION Low byte of the temperature sensor output. 9.32 REGISTER 67 – GYROSCOPE MEASUREMENT Register Name: GYRO_XOUT_H Register Type: USR Register Address: 67 (Decimal); 43 (Hex) BIT [7:0] NAME GYRO_XOUT_H[15:8] Document Number: DS-000169 Revision: 1.3 FUNCTION High byte of the x-axis gyroscope output. Page 44 of 62 ICM-20789 9.33 REGISTER 68 – GYROSCOPE MEASUREMENT Register Name: GYRO_XOUT_L Register Type: USR Register Address: 68 (Decimal); 44 (Hex) BIT [7:0] NAME GYRO_XOUT_L[7:0] FUNCTION Low byte of the x-axis gyroscope output. 9.34 REGISTER 69 – GYROSCOPE MEASUREMENT Register Name: GYRO_YOUT_H Register Type: USR Register Address: 69 (Decimal); 45 (Hex) BIT [7:0] NAME GYRO_YOUT_H[15:8] FUNCTION High byte of the y-axis gyroscope output. 9.35 REGISTER 70 – GYROSCOPE MEASUREMENT Register Name: GYRO_YOUT_L Register Type: USR Register Address: 70 (Decimal); 46 (Hex) BIT [7:0] NAME GYRO_YOUT_L[7:0] FUNCTION Low byte of the y-axis gyroscope output. 9.36 REGISTER 71 – GYROSCOPE MEASUREMENT Register Name: GYRO_ZOUT_H Register Type: USR Register Address: 71 (Decimal); 47 (Hex) BIT [7:0] NAME GYRO_ZOUT_H[15:8] FUNCTION High byte of the z-axis gyroscope output. 9.37 REGISTER 72 – GYROSCOPE MEASUREMENT Register Name: GYRO_ZOUT_L Register Type: USR Register Address: 72 (Decimal); 48 (Hex) BIT [7:0] NAME GYRO_ZOUT_L[7:0] FUNCTION Low byte of the z-axis gyroscope output. 9.38 REGISTER 104 – SIGNAL PATH RESET Register Name: SIGNAL_PATH_RESET Register Type: USR/CFG Register Address: 104 (Decimal); 68 (Hex) BIT [7:3] NAME - [2] GYRO_RST [1] ACCEL_RST [0] TEMP_RST Document Number: DS-000169 Revision: 1.3 FUNCTION Reserved. Reset gyro digital signal path. Note: Sensor registers are not cleared. Use SIG_COND_RST to clear sensor registers. Reset accel digital signal path. Note: Sensor registers are not cleared. Use SIG_COND_RST to clear sensor registers. Reset temp digital signal path. Note: Sensor registers are not cleared. Use SIG_COND_RST to clear sensor registers. Page 45 of 62 ICM-20789 9.39 REGISTER 105 – ACCELEROMETER INTELLIGENCE CONTROL Register Name: ACCEL_INTEL_CTRL Register Type: USR/CFG Register Address: 105 (Decimal); 69 (Hex) BIT [7] NAME ACCEL_INTEL_EN [6] ACCEL_INTEL_MODE [5:4] [3:2] 1 0 - FUNCTION Enable the WOM logic. This bit defines 1 = compare the current sample with the previous sample. 0 = initial sample is stored; all future samples are compared to the initial sample. Reserved. Reserved. Reserved. Reserved. 9.40 REGISTER 106 – USER CONTROL Register Name: USER_CTRL Register Type: USR/CFG Register Address: 106 (Decimal); 6A (Hex) BIT NAME [7] DMP_EN [6] FIFO_EN [5] [4] [3] [2] [1] I2C_IF_DIS DMP_RST FIFO_RST - [0] SIG_COND_RST Document Number: DS-000169 Revision: 1.3 FUNCTION 1 – Enable DMP operation mode. 0 – Freeze DMP processing after DMP Done (finish) with current processing sample. NOTE: DMP will run when enabled, even if all sensors are disabled, except when the sample rate is set to 8 kHz. 1 – Enable FIFO operation mode. 0 – Disable FIFO access from serial interface. To disable FIFO writes by dma, use FIFO_EN register. To disable possible FIFO writes from dmp, disable the dmp. Reserved. 1 – Reset I2C Slave module. 1 – Reset DMP module. Reset is asynchronous. This bit auto clears after one clock cycle. 1 – Reset FIFO module. Reset is asynchronous. This bit auto clears after one clock cycle. Reserved. 1 – Reset all gyro digital signal path, accel digital signal path, and temp digital signal path. This bit also clears all the sensor registers. SIG_COND_RST is a pulse of one clk8M wide. Page 46 of 62 ICM-20789 9.41 REGISTER 107 – POWER MANAGEMENT 1 Register Name: PWR_MGMT_1 Register Type: USR/CFG Register Address: 107 (Decimal); 6B (Hex) BIT NAME [7] DEVICE_RESET [6] SLEEP [5] ACCEL_CYCLE [4] GYRO_STANDBY [3] TEMP_DIS [2:0] CLKSEL[2:0] FUNCTION 1 – Reset the internal registers and restores the default settings. The bit automatically clears to 0 once the reset is done. 1 – The chip is set to sleep mode. Note: The default value is 1; the chip comes up in Sleep mode When set to 1, and SLEEP and STANDBY are not set to 1, the chip will cycle between sleep and taking a single accelerometer sample at a rate determined by SMPLRT_DIV Note: When all accelerometer axes are disabled via PWR_MGMT_2 register bits and cycle is enabled, the chip will wake up at the rate determined by the respective registers above, but will not take any samples. When set, the gyro drive and pll circuitry are enabled, but the sense paths are disabled. This is a low power mode that allows quick enabling of the gyros. When set to 1, this bit disables the temperature sensor. Code 0 1 2 3 4 5 6 7 Clock Source Internal 20 MHz oscillator Auto selects the best available clock source – PLL if ready, else use the Internal oscillator Auto selects the best available clock source – PLL if ready, else use the Internal oscillator Auto selects the best available clock source – PLL if ready, else use the Internal oscillator Auto selects the best available clock source – PLL if ready, else use the Internal oscillator Auto selects the best available clock source – PLL if ready, else use the Internal oscillator Internal 20 MHz oscillator Stops the clock and keeps timing generator in reset 9.42 REGISTER 108 – POWER MANAGEMENT 2 Register Name: PWR_MGMT_2 Register Type: USR/CFG Register Address: 108 (Decimal); 6C (Hex) BIT NAME [7] LP_DIS [6] DMP_LP_DIS [5] DISABLE_XA [4] DISABLE_YA [3] DISABLE_ZA [2] DISABLE_XG [1] DISABLE_YG [0] DISABLE_ZG FUNCTION Low power disable bit. When cleared the system will enter sleep when gyro is disabled and accel is off while duty cycling. When cleared DMP will execute in low power accel mode. When set DMP will not execute in low power accel mode. 1 – X accelerometer is disabled. 0 – X accelerometer is on. 1 – Y accelerometer is disabled. 0 – Y accelerometer is on. 1 – Z accelerometer is disabled. 0 – Z accelerometer is on. 1 – X gyro is disabled. 0 – X gyro is on. 1 – Y gyro is disabled. 0 – Y gyro is on. 1 – Z gyro is disabled. 0 – Z gyro is on. 9.43 REGISTER 114 – FIFO COUNT REGISTERS Register Name: FIFO_COUNTH Register Type: USR/CFG Register Address: 114 (Decimal); 72 (Hex) BIT [7:5] NAME NOT IMPLEMENTED [4:0] FIFO_COUNTH[12:8] Document Number: DS-000169 Revision: 1.3 FUNCTION Hard coded to ‘000’. High Bits, count indicates the number of written bytes in the FIFO. Reading this byte latches the data for both FIFO_COUNTH, and FIFO_COUNTL. Page 47 of 62 ICM-20789 9.44 REGISTER 115 – FIFO COUNT REGISTERS Register Name: FIFO_COUNTL Register Type: USR/CFG Register Address: 115 (Decimal); 73 (Hex) BIT NAME [7:0] FIFO_COUNTL[7:0] FUNCTION Low Bits, count indicates the number of written bytes in the FIFO. NOTE: Must read FIFO_COUNTH to latch new data for both FIFO_COUNTH and FIFO_COUNTL. 9.45 REGISTER 116 – FIFO READ WRITE Register Name: FIFO_R_W Register Type: USR/CFG Register Address: 116 (Decimal); 74 (Hex) BIT [7:0] NAME FIFO_R_W[7:0] FUNCTION Read/Write command provides Read or Write operation for the FIFO. Description: This register is used to read and write data from the FIFO buffer. Data is written to the FIFO in order of register number (from lowest to highest). If all the FIFO enable flags (see below) are enabled, the contents of registers 59 through 72 will be written in order at the Sample Rate. The contents of the sensor data registers (Registers 59 to 72) are written into the FIFO buffer when their corresponding FIFO enable flags are set to 1 in FIFO_EN (Register 35). If the FIFO buffer has overflowed, the status bit FIFO_OFLOW_INT is automatically set to 1. This bit is located in INT_STATUS (Register 58). When the FIFO buffer has overflowed, the oldest data will be lost and new data will be written to the FIFO unless register 26 CONFIG, bit[6] FIFO_MODE = 1. If the FIFO buffer is empty, reading register FIFO_DATA will return a unique value of 0xFF until new data is available. Normal data is precluded from ever indicating 0xFF, so 0xFF gives a trustworthy indication of FIFO empty. 9.46 REGISTER 117 – WHO AM I Register Name: WHOAMI Register Type: USR/CFG Register Address: 117 (Decimal); 75 (Hex) BIT [7:0] NAME WHOAMI FUNCTION Register to indicate to user which device is being accessed. This register is used to verify the identity of the device. The contents of WHOAMI is an 8-bit device ID. 9.47 REGISTER 119 – ACCELEROMETER OFFSET REGISTER Register Name: XA_OFFS_H Register Type: CFG Register Address: 119 (Decimal); 77 (Hex) BIT NAME [7:0] XA_OFFSH[14:7] Document Number: DS-000169 Revision: 1.3 FUNCTION Upper bits of the X accelerometer offset cancellation. ±16g Offset cancellation in all FullScale modes, 15 bit 0.98-mg steps. Page 48 of 62 ICM-20789 9.48 REGISTER 120 – ACCELEROMETER OFFSET REGISTER Register Name: XA_OFFS_L Register Type: CFG Register Address: 120 (Decimal); 78 (Hex) BIT NAME [7:1] XA_OFFSL[6:0] [0] - FUNCTION Lower bits of the X accelerometer offset cancellation. ±16g Offset cancellation in all FullScale modes, 15 bit 0.98-mg steps Reserved. 9.49 REGISTER 122 – ACCELEROMETER OFFSET REGISTER Register Name: YA_OFFS_H Register Type: CFG Register Address: 122 (Decimal); 7A (Hex) BIT NAME [7:0] YA_OFFSH[14:7] FUNCTION Upper bits of the Y accelerometer offset cancellation. ±16g Offset cancellation in all FullScale modes, 15 bit 0.98-mg steps. 9.50 REGISTER 123 – ACCELEROMETER OFFSET REGISTER Register Name: YA_OFFS_L Register Type: CFG Register Address: 123 (Decimal); 7B (Hex) BIT NAME [7:1] YA_OFFSL[6:0] [0] - FUNCTION Lower bits of the Y accelerometer offset cancellation. ±16g Offset cancellation in all FullScale modes, 15 bit 0.98-mg steps. Reserved. 9.51 REGISTER 125 – ACCELEROMETER OFFSET REGISTER Register Name: ZA_OFFS_H Register Type: CFG Register Address: 125 (Decimal); 7D (Hex) BIT [7:0] NAME ZA_OFFSH[14:7] FUNCTION Upper bits of the Z accelerometer offset cancellation. ±16g Offset cancellation in all FullScale modes, 15 bit 0.98-mg steps. 9.52 REGISTER 126 – ACCELEROMETER OFFSET REGISTER Register Name: ZA_OFFS_L Register Type: CFG Register Address: 126 (Decimal); 7E (Hex) BIT NAME [7:1] ZA_OFFSL[6:0] [0] - Document Number: DS-000169 Revision: 1.3 FUNCTION Lower bits of the Z accelerometer offset cancellation. ±16g Offset cancellation in all FullScale modes, 15 bit 0.98-mg steps. Reserved. Page 49 of 62 ICM-20789 10 PRESSURE SENSOR – HOW TO READ 10.1 I2C OPERATION AND COMMUNICATION All commands and memory locations of the ICM-20789 are mapped to a 16-bit address space which can be accessed via the I2C protocol. ICM-20789 I2C Address Bin. 110’0011 Dec. 99 Hex. 0x63 Table 23. ICM-20789 I2C Device Address Power-Up and Communication Start Upon VDD reaching the power-up voltage level VPOR, the ICM-20789 enters idle state after a duration of tPU. In idle state, the ICM20789 is ready to receive commands from the master (microcontroller). Each transmission sequence begins with START condition (S) and ends with an (optional) STOP condition (P) as described in the I2Cbus specification. Whenever the sensor is powered up, but not performing a measurement or communicating, it automatically enters idle state for energy saving. Measurement Commands The ICM-20789 provides the possibility to define the sensor behavior during measurement as well as the transmission sequence of measurement results. These characteristics are defined by the appropriate measurement command (see Table 24). Each measurement command triggers both a temperature and a pressure measurement. OPERATION MODE Low Power (LP) Normal (N) Low Noise (LN) Ultra-Low Noise (ULN) TRANSMIT T FIRST 0x609C 0x6825 0x70DF 0x7866 TRANSMIT P FIRST 0x401A 0x48A3 0x5059 0x58E0 Table 24. Measurement Commands Starting a Measurement A measurement communication sequence consists of a START condition followed by the I2C header with the 7-bit I2C device address and a write bit (write W: ‘0’, 8-bit word including I2C header: 0xC6). The sensor indicates the proper reception of a byte by pulling the SDA pin low (ACK bit) after the falling edge of the 8th SCL clock. Then the sensor is ready to receive a 16-bit measurement command. Again, the ICM-20789 acknowledges the proper reception of each byte with ACK condition. With the acknowledgement of the measurement command, the ICM-20789 starts measuring pressure and temperature. Sensor Behavior during Measurement In general, the sensor does not respond to any I2C activity during measurement, i.e. I2C read and write headers are not acknowledged (NACK). Readout of Measurement Results After a measurement command has been issued and the sensor has completed the measurement, the master can read the measurement results by sending a START condition followed by an I2C read header (8-bit word including I2C header: 0xC7). The sensor will acknowledge the reception of the read header and send the measured data in the specified order to the master. The MSB of the corresponding data is always transmitted first. Temperature data is transmitted in two 8-bit words and pressure data is transmitted in four 8-bit words. Regarding the pressure data, only the first three words MMSB, MLSB and LMSB contain information about the ADC pressure value. Therefore, for retrieving the ADC pressure value, LLSB must be disregarded: pdout = MMSB ≪ 16 | MLSB ≪ 8| LMSB. Two bytes of data are always followed by one byte CRC checksum, for calculation see the Checksum Calculation section. Each byte must be acknowledged by the microcontroller with an ACK condition for the sensor to continue sending data. If the ICM-20789 does not receive an ACK from the master after any byte of data, it will not continue sending data. Document Number: DS-000169 Revision: 1.3 Page 50 of 62 ICM-20789 Whether the sensor sends out pressure or temperature data first depends on the measurement command that was sent to the sensor to initiate the measurement. The I2C master can abort the read transfer with a NACK condition after any data byte if it is not interested in subsequent data, e.g. the CRC byte or the second measurement result, in order to save time. Soft Reset The ICM-20789 provides a soft reset mechanism that forces the system into a well-defined state without removing the power supply. If the system is in idle state (i.e. if no measurement is in progress) the soft reset command will be accepted by ICM-20789. This triggers the sensor to reset all internal state machines and reload calibration data from the memory. Command Soft reset Hex Code 0x805D Binary Code 1000’0000’0101’1101 Table 25. Soft Reset Command Read-out of ID Register The ICM-20789 has an ID register which contains a specific product code. The read-out of the ID register can be used to verify the presence of the sensor and proper communication. The command to read the ID register is shown in Table 21. Command Read ID Register Hex Code 0xEFC8 Binary Code 1110’1111’1100’1000 Table 26. Read-Out Command of ID Register It needs to be sent to the ICM-20789 after an I2C write header. After the ICM-20789 has acknowledged the proper reception of the command, the master can send an I2C read header and the ICM-20789 will submit the 16-bit ID followed by 8 bits of CRC. The structure of the ID is described in Table 22. Table 27. Structure of the 16-bit ID Bits 15:6 of the ID contain unspecified information (marked as “x”), which may vary from sensor to sensor, while bits 5:0 contain the ICM-20789-specific product code. Checksum Calculation The 8-bit CRC checksum transmitted after each data word is generated by a CRC algorithm with the properties displayed in Table 23. The CRC covers the contents of the two previously transmitted data bytes. Property Name Width Polynomial Initialization Reflect input Reflect output Final XOR Examples Value CRC-8 8 bits 0x31 (x8 + x5 + x4 + 1) 0xFF false false 0x00 CRC(0x00) = 0xAC CRC(0xBEEF) = 0x92 Table 28. ICM-20789 I2C CRC Properties Conversion of Signal Output Pressure measurement data is always transferred as 4 8-bit words; temperature measurement data is always transferred as two 8bit words. Please see Readout of Measurement Results (Page 44) for more details. Document Number: DS-000169 Revision: 1.3 Page 51 of 62 ICM-20789 Temperature measurement values t_dout are linearized by the ICM-20789 and must be calculated to °C by the user via the following formula: T = - 45°C + (175°C / 216) x t_dout For retrieving physical pressure values in Pa the following conversion formula has to be used: P = A + B / (C + pdout) where pdout is the sensor’s raw pressure output. The converted output is compensated for temperature effects via the temperature dependent functions A, B and C. Besides the raw temperature output t_dout, the calculation of A, B and C requires to access calibration parameters OTP0, OTP1, OTP2, OTP3 stored in the OTP of the sensor. Full sample code for calculating physical pressure values is given in the Sample Code section. The general workflow of the conversion is done by: 1) Import class Invensense_pressure_conversion 2) Read out values OTP0, …, OTP3 and save to c1, …, c4 3) Create object name for an individual sensor with parameter values c1, …, c4 name = Invensense_pressure_conversion ([c1,c2,c3,c4]) 4) Get raw pressure p_dout and temperature t_dout data from the sensor as described in chapter Readout of Measurement Results. 5) Call function get_pressure: name.get_pressure(p_dout, t_dout) The Sample Code section gives an example of this workflow. Read-out of calibration parameters For converting raw pressure data to physical values, four calibration parameters have to be retrieved from the OTP of the sensor. Set up of OTP read: 1) Send I2C write header 0xC6 2) Send command 0xC595 (move pointer in address register) 3) Send address parameter together with its CRC 0x00669C Steps 1) – 3) can be done on many platforms by a single I2C write of the value 0xC59500669C. Read out parameters: Repeat the following procedure 4 times: a. Send I2C write header 0xC6 b. Send command 0xC7F7 (incremental read-out of OTP) c. Send I2C read header 0xC7 d. Read 3Byte (2Byte of data and 1Byte of CRC) e. Decode data as 16-bit big endian signed integer and store result into n-th calibration parameter cn. Steps a) to d) can be done on many platforms by a single write 0xC7F7 to the chip address followed by a single read of 3 Byte from the chip slave device address. Sample Pseudo Code: conversion formula (exemplary python syntax) class Invensense_pressur_Conversion: """ Class for conversion of the pressure and temperature output of the Invensense sensor""" def __init__(self, sensor_constants): """ Initialize customer formula Arguments: sensor_constants -- list of 4 integers: [c1, c2, c3, c4] """ self.sensor_constants = sensor_constants # configuration for Pressure Samples self.p_Pa_calib = [45000.0, 80000.0, 105000.0] self.LUT_lower = 3.5 * (2**20) self.LUT_upper = 11.5 * (2**20) self.quadr_factor = 1 / 16777216.0 self.offst_factor = 2048.0 Document Number: DS-000169 Revision: 1.3 Page 52 of 62 ICM-20789 def calculate_conversion_constants(self, p_Pa, p_LUT): """ calculate temperature dependent constants Arguments: p_Pa -- List of 3 values corresponding to applied pressure in Pa p_LUT -- List of 3 values corresponding to the measured p_LUT values at the applied pressures. """ C = (p_LUT[0] * p_LUT[1] * (p_Pa[0] - p_Pa[1]) + p_LUT[1] * p_LUT[2] * (p_Pa[1] - p_Pa[2]) + p_LUT[2] * p_LUT[0] * (p_Pa[2] - p_Pa[0])) / \ (p_LUT[2] * (p_Pa[0] - p_Pa[1]) + p_LUT[0] * (p_Pa[1] - p_Pa[2]) + p_LUT[1] * (p_Pa[2] - p_Pa[0])) A = (p_Pa[0] * p_LUT[0] - p_Pa[1] * p_LUT[1] - (p_Pa[1] - p_Pa[0]) * C) / (p_LUT[0] - p_LUT[1]) B = (p_Pa[0] - A) * (p_LUT[0] + C) return [A, B, C] def get_pressure(self, p_LSB, T_LSB): """ Convert an output from a calibrated sensor to a pressure in Pa. Arguments: p_LSB -- Raw pressure data from sensor T_LSB -- Raw temperature data from sensor """ t = T_LSB - 32768.0 s1 = self.LUT_lower + float(self.sensor_constants[0] * t * t) * self.quadr_factor s2 = self.offst_factor * self.sensor_constants[3] + float(self.sensor_constants[1] * t * t) * self.quadr_factor s3 = self.LUT_upper + float(self.sensor_constants[2] * t * t) * self.quadr_factor A, B, C = self.calculate_conversion_constants(self.p_Pa_calib, [s1, s2, s3]) return A + B / (C + p_LSB) [end of the pseudocode] Document Number: DS-000169 Revision: 1.3 Page 53 of 62 ICM-20789 Sample code: using conversion formula (exemplary python syntax) def read_otp_from_i2c(): # TODO: implement read from I2C # refer to data sheet for I2C commands to read OTP return 1000, 2000, 3000, 4000 def read_raw_pressure_temp_from_i2c(): # TODO: implement read from I2C # refer to data sheet for I2C commands to read pressure and temperature return 8000000, 32000 # Sample code to read from Invensense_pressure_conversion import Invensense_pressure_conversion # -- initialization c1, c2, c3, c4 = read_otp_from_i2c() conversion = Invensense_pressure_conversion([c1, c2, c3, c4]) # -- read raw pressure and temp data, calculate pressure p, T = read_raw_pressure_temp_from_i2c() pressure = conversion.get_pressure(p, T) print 'Pressure: %f' % pressure [end of the pseudocode] Communication Data Sequences Figure 15. Communication Sequence for starting a measurement and reading measurement results Document Number: DS-000169 Revision: 1.3 Page 54 of 62 ICM-20789 11 ASSEMBLY This section provides general guidelines for assembling TDK-InvenSense Micro Electro-Mechanical Systems (MEMS) gyros packaged in LGA package. 11.1 ORIENTATION OF AXES The diagram below shows the orientation of the axes of sensitivity and the polarity of rotation. Note the pin 1 identifier (•) in the figure. +Z +Y +Z +Y IC M- 20 78 9 +X +X Figure 16. Orientation of Axes of Sensitivity and Polarity of Rotation 11.2 IMPLEMENTATION AND USAGE RECOMMENDATIONS Soldering When soldering, use the standard soldering profile IPC/JEDEC J-STD-020 with peak temperatures of 260°C. ICM-20789 may exhibit a pressure offset after soldering, some settling time may be required depending on soldering properties, PCB properties, and ambient conditions. The ICM-20789 is an open cavity package, it is mandatory to use no-clean solder paste and no board wash should be applied. The ICM-20789 should be limited to a single reflow and no rework is recommended. Chemical Exposure and Sensor Protection The ICM-20789 is an open cavity package and therefore should not be exposed to particulates or liquids. If any type of protective coating must be applied to the circuit board, the sensor must be protected during the coating process. Document Number: DS-000169 Revision: 1.3 Page 55 of 62 ICM-20789 11.3 PACKAGE DIMENSIONS 24 Lead LGA (4 mm x 4 mm x 1.365 mm) NiPdAu Lead-frame finish Figure 17. Package Dimensions DIMENSIONS IN MILLIMETERS SYMBOLS A A3 b c D E e L L1 L3 MIN 1.265 --0.20 --3.90 3.90 --0.35 0.025 0.325 NOM 1.365 1.185 REF. 0.25 0.18 REF. 4.00 4.00 0.50 0.45 0.075 0.375 MAX 1.465 --0.30 --4.10 4.10 --0.55 0.125 0.425 Table 29. Package Dimensions Table Figure 18 shows the recommended PCB land pattern for ICM-20789. Document Number: DS-000169 Revision: 1.3 Page 56 of 62 ICM-20789 Figure 18. ICM-20789 recommended PCB land pattern Document Number: DS-000169 Revision: 1.3 Page 57 of 62 ICM-20789 12 PART NUMBER PACKAGE MARKING The part number package marking for ICM-20789 devices is summarized below: PART NUMBER ICM-20789 PART NUMBER PACKAGE MARKING IC2789 TOP VIEW Part Number Lot Traceability Code IC2789 X X X X X XXX YYWW Y Y = Year Code W W = Work Week Figure 19. Part Number Package Marking Document Number: DS-000169 Revision: 1.3 Page 58 of 62 ICM-20789 13 ORDERING GUIDE PART TEMP RANGE PACKAGE QUANTITY PACKAGING ICM-20789† −40°C to +85°C 24-Pin LGA 3,000 13” Tape and Reel †Denotes RoHS and Green-Compliant Package Document Number: DS-000169 Revision: 1.3 Page 59 of 62 ICM-20789 14 REFERENCE Please refer to “InvenSense MEMS Handling Application Note (AN-IVS-0002A-00)” for the following information: • Manufacturing Recommendations o Assembly Guidelines and Recommendations o PCB Design Guidelines and Recommendations o MEMS Handling Instructions o ESD Considerations o Reflow Specification o Storage Specifications o Package Marking Specification o Tape & Reel Specification o Reel & Pizza Box Label o Packaging o Representative Shipping Carton Label • Compliance o Environmental Compliance o DRC Compliance o Compliance Declaration Disclaimer Document Number: DS-000169 Revision: 1.3 Page 60 of 62 ICM-20789 15 REVISION HISTORY REVISION DATE REVISION DESCRIPTION 06/05/17 1.0 Initial Release 08/28/2017 1.1 Updated part marking 10/04/17 1.2 Updated performance specifications, added handling instructions 10/31/17 1.3 Updated Ordering Guide, Clarified Pin Connections as NC, GND, or VDD Document Number: DS-000169 Revision: 1.3 Page 61 of 62 ICM-20789 This information furnished by InvenSense, Inc. (“InvenSense”) is believed to be accurate and reliable. However, no responsibility is assumed by InvenSense for its use, or for any infringements of patents or other rights of third parties that may result from its use. Specifications are subject to change without notice. InvenSense reserves the right to make changes to this product, including its circuits and software, in order to improve its design and/or performance, without prior notice. InvenSense makes no warranties, neither expressed nor implied, regarding the information and specifications contained in this document. InvenSense assumes no responsibility for any claims or damages arising from information contained in this document, or from the use of products and services detailed therein. This includes, but is not limited to, claims or damages based on the infringement of patents, copyrights, mask work and/or other intellectual property rights. Certain intellectual property owned by InvenSense and described in this document is patent protected. No license is granted by implication or otherwise under any patent or patent rights of InvenSense. This publication supersedes and replaces all information previously supplied. Trademarks that are registered trademarks are the property of their respective companies. InvenSense sensors should not be used or sold in the development, storage, production or utilization of any conventional or mass-destructive weapons or for any other weapons or life threatening applications, as well as in any other life critical applications such as medical equipment, transportation, aerospace and nuclear instruments, undersea equipment, power plant equipment, disaster prevention and crime prevention equipment. ©2017 InvenSense. All rights reserved. InvenSense, MotionTracking, MotionProcessing, MotionProcessor, MotionFusion, MotionApps, DMP, AAR, and the InvenSense logo are trademarks of InvenSense, Inc. The TDK logo is a trademark of TDK Corporation. Other company and product names may be trademarks of the respective companies with which they are associated. ©2017 InvenSense. All rights reserved. Document Number: DS-000169 Revision: 1.3 Page 62 of 62
ICM-20789 价格&库存
很抱歉,暂时无法提供与“ICM-20789”相匹配的价格&库存,您可以联系我们找货
