ICS‐41350
Bottom Port PDM Low‐Power Multi‐Mode
Microphone With High AOP Mode
GENERAL DESCRIPTION
APPLICATIONS
The ICS‐41350 is a low‐power, low‐noise digital MEMS
microphone in a small package. The ICS‐41350 consists of a
MEMS microphone element and an impedance converter
amplifier followed by a fourth‐order Σ‐Δ modulator. The pulse
density modulated (PDM) interface allows two microphones
to be time multiplexed on a data line using a single clock.
The ICS‐41350 has multiple modes of operation: High
Performance, Low Power (AlwaysOn), Standard and Sleep.
The ICS‐41350 has low power and high SNR in all operational
modes. It has 126 dB SPL AOP in High Performance mode, and
120 dB SPL AOP in Standard and Low‐Power modes.
The ICS‐41350 supports ultrasound applications in High
Performance Mode. It has an extended ultrasonic response up to
40 kHz with high SNR.
The ICS‐41350 is available in a small 3.5 × 2.65 × 0.98 mm
surface‐mount package. It is reflow solder compatible with
no sensitivity degradation.
Smartphones
Microphone Arrays
Tablets
Cameras
Bluetooth Headsets
Notebook PCs
Security and Surveillance
FEATURES
SPEC
LOW‐POWER
MODE
STANDARD
MODE
HIGH
PERFORMANCE
MODE
Sensitivity
SNR
Current
AOP
Clock
−26 dB FS ±1 dB
63 dBA
185 µA
120 dB SPL
400 – 800 kHz
−26 dB FS ±1 dB
64 dBA
430 µA
120 dB SPL
1.0 – 3.3 MHz
−32 dB FS ±1 dB
64 dBA
650 µA
126 dB SPL
4.1 – 4.8 MHz
3.5 × 2.65 × 0.98 mm surface‐mount package
Low power: 185 µA in Low‐Power Mode
Extended frequency response from 50 Hz to >20 kHz
Ultrasound support up to 40 kHz
Sleep Mode: 12 µA
High power supply rejection (PSR): −97 dB FS
Fourth‐order Σ‐Δ modulator
Digital pulse density modulation (PDM) output
Compatible with Sn/Pb and Pb‐free solder processes
RoHS/WEEE compliant
FUNCTIONAL BLOCK DIAGRAM
ORDERING INFORMATION
PART
ICS‐41350
VDD
GND
POWER
MANAGEMENT
PDM
MODULATOR
InvenSense reserves the right to change the detail
specifications as may be required to permit improvements
in the design of its products.
CLK
DATA
TEMP RANGE
PACKAGING
−40°C to +85°C
13” Tape and Reel
CHANNEL
SELECT
SELECT
ADC
ICS‐41350
EV_ICS‐41350‐FX
InvenSense Inc.
1745 Technology Drive, San Jose, CA 95110 U.S.A
+1(408) 988–7339
www.invensense.com
Document Number: DS‐000047
Revision: 1.0
Release Date: Preliminary 2/4/2016
ICS‐41350
TABLE OF CONTENTS
General Description ..................................................................................................................................................................... 1
Applications ................................................................................................................................................................................. 1
Features ....................................................................................................................................................................................... 1
Functional Block Diagram ............................................................................................................................................................ 1
Ordering Information ................................................................................................................................................................... 1
Table of Contents .................................................................................................................................................................................... 2
Specifications .......................................................................................................................................................................................... 4
Table 1. Acoustical/Electrical Characteristics – General .............................................................................................................. 4
Table 2. Acoustical/Electrical Characteristics – High‐Performance Mode ................................................................................... 4
Table 3. Acoustical/Electrical Characteristics – Standard Mode .................................................................................................. 5
Table 4. Acoustical/Electrical Characteristics – Low‐Power Mode .............................................................................................. 5
Table 5. Digital Input/Output Characteristics .............................................................................................................................. 6
Table 6. PDM Digital Input/Output .............................................................................................................................................. 6
Timing Diagram ............................................................................................................................................................................ 7
Absolute Maximum Ratings .................................................................................................................................................................... 8
Table 7. Absolute Maximum Ratings ........................................................................................................................................... 8
ESD Caution ................................................................................................................................................................................. 8
Soldering Profile ........................................................................................................................................................................... 9
Table 8. Recommended Soldering Profile* .................................................................................................................................. 9
Pin Configurations And Function Descriptions ..................................................................................................................................... 10
Table 9. Pin Function Descriptions ............................................................................................................................................. 10
Typical Performance Characteristics ..................................................................................................................................................... 11
Theory Of Operation ............................................................................................................................................................................. 12
PDM Data Format ...................................................................................................................................................................... 12
Table 10. ICS‐41350 Channel Setting ......................................................................................................................................... 12
PDM Microphone Sensitivity ..................................................................................................................................................... 12
Applications Information ...................................................................................................................................................................... 14
Low Power Mode ....................................................................................................................................................................... 14
Dynamic Range Considerations ................................................................................................................................................. 14
Connecting PDM Microphones .................................................................................................................................................. 14
Ultrasound Applications ............................................................................................................................................................ 16
Sleep Mode ................................................................................................................................................................................ 16
Start‐Up Time ............................................................................................................................................................................. 16
Supporting Documents ......................................................................................................................................................................... 17
Application Notes ...................................................................................................................................................................... 17
PCB Design And Land Pattern Layout ................................................................................................................................................... 18
PCB Material And Thickness ...................................................................................................................................................... 18
Page 2 of 22
Revision: 1.0
ICS‐41350
Handling Instructions ............................................................................................................................................................................ 19
Pick And Place Equipment ......................................................................................................................................................... 19
Reflow Solder ............................................................................................................................................................................. 19
Board Wash ............................................................................................................................................................................... 19
Outline Dimensions ............................................................................................................................................................................... 20
Ordering Guide .......................................................................................................................................................................... 20
Revision History ......................................................................................................................................................................... 21
Compliance Declaration Disclaimer ...................................................................................................................................................... 22
Page 3 of 22
Revision: 1.0
ICS‐41350
SPECIFICATIONS
TABLE 1. ACOUSTICAL/ELECTRICAL CHARACTERISTICS – GENERAL
TA = 25°C, VDD = 1.8 to 3.3 V, SCK = 2.4 MHz, 50× decimation, CLOAD = 30 pF unless otherwise noted. Typical specifications are not
guaranteed.
PARAMETER
CONDITIONS
MIN
TYP
MAX
UNITS
NOTES
PERFORMANCE
Directionality
Omni
Output Polarity
Input acoustic pressure vs.
Non‐Inverted
output data
Supply Voltage (VDD)
1.65
3.63
V
Sleep Mode Current (IS)
SCK
很抱歉,暂时无法提供与“ICS-41350”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+17.361061+2.25612
- 10+13.1758610+1.71224
- 25+11.8592425+1.54114
- 50+10.9706250+1.42566
- 100+10.16342100+1.32077
- 250+9.20629250+1.19638
- 500+8.55554500+1.11182
- 1000+7.960911000+1.03454
- 5000+6.940435000+0.90193
- 国内价格 香港价格
- 10000+6.9293310000+0.90049
- 国内价格
- 30+5.56392
- 200+5.38629
