ICS-51360
ICS-51360
    TDK(东电化)
    BOTTOM PORT PDM DIGITAL OUTPUT M
ICS-51360 数据手册
ICS-51360 Bottom Port PDM Digital Output Multi-Mode Microphone APPLICATIONS GENERAL DESCRIPTION The ICS-51360 is a multi-mode, low noise digital MEMS microphone in a small package. The ICS-51360 consists of a MEMS microphone element and an impedance converter amplifier followed by a fourth-order Σ-Δ modulator. The digital interface allows the pulse density modulated (PDM) output of two microphones to be time multiplexed on a single data line using a single clock. The ICS-51360 has multiple modes of operation: Low-Power (AlwaysOn), Standard and Sleep. The ICS-51360 has high SNR in all operational modes. It has 130 dB SPL AOP in Standard Mode and 120 dB SPL AOP in Low-Power mode. The ICS-51360 is available in a standard 3.5 × 2.65 × 0.98 mm surface-mount package. It is reflow solder compatible with no sensitivity degradation. FUNCTIONAL BLOCK DIAGRAM FEATURES SPEC Sensitivity SNR Current AOP Clock         −36 dB FS ±1 dB 62 dBA 590 µA 130 dB SPL 2.4 MHz −36 dB FS ±1 dB 61 dBA 510 µA 130 dB SPL 1.536 MHz CLK ICS-51360 −26 dB FS ±1 dB 65 dBA 230 µA 120 dB SPL 768 kHz TEMP RANGE PACKAGING −40°C to +85°C 13” Tape and Reel DATA CHANNEL SELECT InvenSense reserves the right to change the detail specifications as may be required to permit improvements in the design of its products. LOW-POWER MODE 3.5 × 2.65 × 0.98 mm surface-mount package Extended frequency response from 50 Hz to >20 kHz Sleep Mode: 12 µA High power supply rejection (PSR): −98 dB FS Fourth-order Σ-Δ modulator Digital pulse density modulation (PDM) output Compatible with Sn/Pb and Pb-free solder processes RoHS/WEEE compliant PART PDM MODULATOR STANDARD MODE SELECT VDD GND POWER MANAGEMENT Smartphones Microphone Arrays Tablet Computers Cameras ORDERING INFORMATION ICS-51360 ADC     InvenSense Inc. 1745 Technology Drive, San Jose, CA 95110 U.S.A +1(408) 988–7339 www.invensense.com Document Number: DS-000094 Revision: 1.0 Release Date: 9/23/2016 ICS-51360 TABLE OF CONTENTS General Description ..................................................................................................................................................................... 1 Applications ................................................................................................................................................................................. 1 Features ....................................................................................................................................................................................... 1 Functional Block Diagram ............................................................................................................................................................ 1 Ordering Information ................................................................................................................................................................... 1 Table of Contents .................................................................................................................................................................................... 2 Specifications .......................................................................................................................................................................................... 4 Table 1. Acoustical/Electrical Characteristics – General .............................................................................................................. 4 Table 2. Acoustical/Electrical Characteristics – Standard Mode (2.4 MHz) ................................................................................. 4 Table 3. Acoustical/Electrical Characteristics – Standard Mode (1.536 MHz) ............................................................................. 5 Table 4. Acoustical/Electrical Characteristics – Low-Power Mode .............................................................................................. 6 Table 5. Digital Input/Output Characteristics .............................................................................................................................. 6 Table 6. PDM Digital Input/Output .............................................................................................................................................. 7 Timing Diagram ............................................................................................................................................................................ 7 Absolute Maximum Ratings .................................................................................................................................................................... 8 Table 7. Absolute Maximum Ratings ........................................................................................................................................... 8 ESD Caution ................................................................................................................................................................................. 8 Soldering Profile........................................................................................................................................................................... 9 Table 8. Recommended Soldering Profile* .................................................................................................................................. 9 Pin Configurations And Function Descriptions ..................................................................................................................................... 10 Table 9. Pin Function Descriptions............................................................................................................................................. 10 Typical Performance Characteristics ..................................................................................................................................................... 11 Theory Of Operation ............................................................................................................................................................................. 12 PDM Data Format ...................................................................................................................................................................... 12 Table 10. ICS-51360 Channel Setting ......................................................................................................................................... 12 PDM Microphone Sensitivity ..................................................................................................................................................... 12 Applications Information ...................................................................................................................................................................... 14 Low Power Mode ....................................................................................................................................................................... 14 Dynamic Range Considerations ................................................................................................................................................. 14 Connecting PDM Microphones .................................................................................................................................................. 14 Sleep Mode ................................................................................................................................................................................ 16 Start-Up Time ............................................................................................................................................................................. 16 Supporting Documents ......................................................................................................................................................................... 17 Application Notes – General ...................................................................................................................................................... 17 PCB Design And Land Pattern Layout ................................................................................................................................................... 18 PCB Material And Thickness ...................................................................................................................................................... 18 Handling Instructions ............................................................................................................................................................................ 19 Page 2 of 22 Document Number: DS-000094 Revision: 1.0 ICS-51360 Pick And Place Equipment ......................................................................................................................................................... 19 Reflow Solder ............................................................................................................................................................................. 19 Board Wash................................................................................................................................................................................ 19 Outline Dimensions ............................................................................................................................................................................... 20 Ordering Guide .......................................................................................................................................................................... 20 Revision History ......................................................................................................................................................................... 21 Compliance Declaration Disclaimer ...................................................................................................................................................... 22 Page 3 of 22 Document Number: DS-000094 Revision: 1.0 ICS-51360 SPECIFICATIONS TABLE 1. ACOUSTICAL/ELECTRICAL CHARACTERISTICS – GENERAL TA = 25°C, VDD = 1.8 to 3.3 V, SCK = 1.536 MHz, 32× decimation, CLOAD = 30 pF unless otherwise noted. Typical specifications are not guaranteed. PARAMETER PERFORMANCE Directionality Output Polarity Supply Voltage (VDD) Sleep Mode Current (IS) CONDITIONS MIN TYP MAX UNITS NOTES Omni Input acoustic pressure vs. output data Non-Inverted 1.65 SCK < 200 kHz 3.63 12 V µA TABLE 2. ACOUSTICAL/ELECTRICAL CHARACTERISTICS – STANDARD MODE (2.4 MHZ) TA = 25°C, VDD = 1.8 to 3.3 V, SCK = 2.4 MHz, 50× decimation, CLOAD = 30 pF unless otherwise noted. Typical specifications are not guaranteed. PARAMETER Sensitivity Signal-to-Noise Ratio (SNR) Equivalent Input Noise (EIN) Acoustic Dynamic Range Total Harmonic Distortion (THD) Power Supply Rejection (PSR) Power Supply Rejection—Swept Sine Acoustic Overload Point Supply Current (IS) CONDITIONS 1 kHz, 94 dB SPL 20 kHz bandwidth, A-weighted 20 kHz bandwidth, A-weighted Derived from EIN and acoustic overload point 94 dB SPL 217 Hz, 100 mV p-p square wave superimposed on VDD = 1.8 V, Aweighted 1 kHz sine wave 10% THD VDD = 1.8 V, no load VDD = 1.8 V, 19 pF load MIN −37 TYP −36 62 32 MAX −35 98 0.2 UNITS dB FS dBA dBA SPL NOTES 1 dB 1 % −98 dB FS −110 130 590 670 dB FS dB SPL µA µA 650 730 Note 1: Sensitivity is relative to the RMS level of a sine wave with positive amplitude equal to 100% 1s density and negative amplitude equal to 0% 1s density. Note 2: The additional current in the loaded condition is independent of the microphone and can be calculated by ILOAD = CLOAD × VDD × fCLK. Page 4 of 22 Document Number: DS-000094 Revision: 1.0 ICS-51360 TABLE 3. ACOUSTICAL/ELECTRICAL CHARACTERISTICS – STANDARD MODE (1.536 MHZ) TA = 25°C, VDD = 1.8 to 3.3 V, SCK = 1.536 MHz, 32× decimation, CLOAD = 30 pF unless otherwise noted. Typical specifications are not guaranteed. PARAMETER Sensitivity Signal-to-Noise Ratio (SNR) Equivalent Input Noise (EIN) Acoustic Dynamic Range Total Harmonic Distortion (THD) Power Supply Rejection (PSR) Power Supply Rejection—Swept Sine Acoustic Overload Point Supply Current (IS) CONDITIONS 1 kHz, 94 dB SPL 20 kHz bandwidth, A-weighted 20 kHz bandwidth, A-weighted Derived from EIN and acoustic overload point 105 dBs SPL 217 Hz, 100 mV p-p square wave superimposed on VDD = 1.8 V, Aweighted 1 kHz sine wave 10% THD VDD = 1.8 V, no load VDD = 1.8 V, 19 pF load MIN −37 TYP −36 61 33 MAX −35 97 0.2 UNITS dB FS dBA dBA SPL NOTES 1 dB 1 % −94 dB FS −112 130 510 560 dB FS dB SPL µA µA 570 620 Note 1: Sensitivity is relative to the RMS level of a sine wave with positive amplitude equal to 100% 1s density and negative amplitude equal to 0% 1s density. Note 2: The additional current in the loaded condition is independent of the microphone and can be calculated by ILOAD = CLOAD × VDD × fCLK. Page 5 of 22 Document Number: DS-000094 Revision: 1.0 2 ICS-51360 TABLE 4. ACOUSTICAL/ELECTRICAL CHARACTERISTICS – LOW-POWER MODE TA = 25°C, VDD = 1.8 to 3.3 V, SCK = 768 kHz, 48× decimation, CLOAD = 30 pF unless otherwise noted. Typical specifications are not guaranteed. PARAMETER Sensitivity Signal-to-Noise Ratio (SNR) Equivalent Input Noise (EIN) Acoustic Dynamic Range Total Harmonic Distortion (THD) Power Supply Rejection (PSR) Power Supply Rejection—Swept Sine Acoustic Overload Point Supply Current (IS) CONDITIONS 1 kHz, 94 dB SPL 8 kHz bandwidth, A-weighted 8 kHz bandwidth, A-weighted Derived from EIN and acoustic overload point 105 dB SPL 217 Hz, 100 mV p-p square wave superimposed on VDD = 1.8 V, Aweighted 1 kHz sine wave 10% THD VDD = 1.8 V, no load VDD = 1.8 V, 19 pF load MIN −27 TYP −26 65 29 MAX −25 91 UNITS dB FS dBA dBA SPL NOTES 1 dB 0.2 1 % −91 dB FS −102 120 230 255 dB FS dB SPL µA µA 255 280 2 Note 1: Sensitivity is relative to the RMS level of a sine wave with positive amplitude equal to 100% 1s density and negative amplitude equal to 0% 1s density. Note 2: The additional current in the loaded condition is independent of the microphone and can be calculated by ILOAD = CLOAD × VDD × fCLK. TABLE 5. DIGITAL INPUT/OUTPUT CHARACTERISTICS TA = 25°C, 1.8 V < VDD < 3.3 V, unless otherwise noted. PARAMETER CONDITIONS MIN Input Voltage High (VIH) TYP 0.65 × VDD 0.35 × VDD Output Voltage High (VOH) ILOAD = 0.5 mA Output Voltage Low (VOL) ILOAD = 0.5 mA Output DC Offset Latency Percent of full scale 0.7 × VDD 3 400 kHz, output within 1 dB of final sensitivity, power on Between Low-Power and Standard Modes Wake-Up Time Switching time INPUT tCLKIN 592 Input clock period Sleep Mode Clock Frequency (CLK) 690 Low-Power Mode 1.00 Standard Mode Clock Duty Cycle tRISE tFALL OUTPUT t1OUTEN t1OUTDIS t2OUTEN t2OUTDIS fCLK < 2.65 MHz fCLK > 2.65 MHz CLK rise time (10% to 90% level) CLK fall time (90% to 10% level) 40 48 DATA1 (right) driven after falling clock edge DATA1 (right) disabled after rising clock edge DATA2 (left) driven after rising clock edge DATA2 (left) disabled after falling clock edge 40 10 23 40 10 23 ns ns Note 1: Guaranteed by design TIMING DIAGRAM tCLKIN CLK tFALL tRISE t1OUTEN t1OUTDIS DATA1 t2OUTDIS DATA2 t2OUTEN Figure 1. Pulse Density Modulated Output Timing Page 7 of 22 Document Number: DS-000094 Revision: 1.0 ns ns 1 1 ICS-51360 ABSOLUTE MAXIMUM RATINGS Stress above those listed as Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these conditions is not implied. Exposure to the absolute maximum ratings conditions for extended periods may affect device reliability. TABLE 7. ABSOLUTE MAXIMUM RATINGS PARAMETER RATING −0.3 V to +3.63 V Supply Voltage (VDD) Digital Pin Input Voltage Sound Pressure Level −0.3 V to VDD + 0.3 V or 3.63 V, whichever is less 160 dB Mechanical Shock 10,000 g Vibration Per MIL-STD-883 Method 2007, Test Condition B Temperature Range Biased Storage −40°C to +85°C −55°C to +150°C ESD CAUTION ESD (electrostatic discharge) sensitive device. Charged devices and circuit boards can discharge without detection. Although this product features patented or proprietary protection circuitry, damage may occur on devices subjected to high energy ESD. Therefore proper ESD precautions should be taken to avoid performance degradation or loss of functionality. Page 8 of 22 Document Number: DS-000094 Revision: 1.0 ICS-51360 SOLDERING PROFILE CRITICAL ZONE TL TO TP tP TP TEMPERATURE RAMP-UP TL tL TSMAX TSMIN tS RAMP-DOWN PREHEAT t25°C TO PEAK TEMPERATURE TIME Figure 2. Recommended Soldering Profile Limits TABLE 8. RECOMMENDED SOLDERING PROFILE* PROFILE FEATURE Average Ramp Rate (TL to TP) Sn63/Pb37 1.25°C/sec max Pb-Free 1.25°C/sec max 100°C 100°C 150°C 200°C 60 sec to 75 sec 60 sec to 75 sec Ramp-Up Rate (TSMAX to TL) 1.25°C/sec 1.25°C/sec Time Maintained Above Liquidous (tL) 45 sec to 75 sec ~50 sec Liquidous Temperature (TL) Peak Temperature (TP) 183°C 217°C 215°C +3°C/−3°C 260°C +0°C/−5°C Time Within +5°C of Actual Peak Temperature (tP) 20 sec to 30 sec 20 sec to 30 sec Ramp-Down Rate 3°C/sec max 3°C/sec max Time +25°C (t25°C) to Peak Temperature 5 min max 5 min max Preheat Minimum Temperature (TSMIN) Minimum Temperature (TSMIN) Time (TSMIN to TSMAX), tS *The reflow profile in Table 8 is recommended for board manufacturing with InvenSense MEMS microphones. All microphones are also compatible with the J-STD-020 profile Page 9 of 22 Document Number: DS-000094 Revision: 1.0 ICS-51360 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS Figure 3. Pin Configuration (Top View, Terminal Side Down) TABLE 9. PIN FUNCTION DESCRIPTIONS PIN NAME FUNCTION 1 DATA Digital Output Signal (DATA1 or DATA2) 2 SELECT 3 GND Left Channel or Right Channel Select: DATA 1 (right): SELECT tied to GND DATA 2 (left): SELECT tied to VDD. In this setting, SELECT should be tied to the same voltage source as the VDD pin. Ground 4 CLK Clock Input to Microphone 5 VDD Power Supply. For best performance and to avoid potential parasitic artifacts, place a 0.1 µF (100 nF) ceramic type X7R capacitor between Pin 5 (VDD) and ground. Place the capacitor as close to Pin 5 as possible. Page 10 of 22 Document Number: DS-000094 Revision: 1.0 ICS-51360 TYPICAL PERFORMANCE CHARACTERISTICS 30 Standard Mode 10 10 THD+N (%) NORMALIZED AMPLITUDE (dB) Low Power Mode 20 0 1 -10 -20 0.1 100 1000 10000 90 FREQUENCY (Hz) -20 PSR (dB FS) -40 -60 -80 -100 -120 10000 FREQUENCY (Hz) Figure 6. Power Supply Rejection (PSR) vs. Frequency, Standard Mode Page 11 of 22 Document Number: DS-000094 Revision: 1.0 120 130 Figure 5. THD + N vs. Input Level, Standard and Low-Power Modes 0 1000 110 INPUT AMPLITUDE (dB SPL) Figure 4. Typical Audio Frequency Response, Standard Mode 100 100 ICS-51360 THEORY OF OPERATION PDM DATA FORMAT The output from the DATA pin of the ICS-51360 is in pulse density modulated (PDM) format. This data is the 1-bit output of a fourthorder Σ-Δ modulator. The data is encoded so that the left channel is clocked on the falling edge of CLK, and the right channel is clocked on the rising edge of CLK. After driving the DATA signal high or low in the appropriate half frame of the CLK signal, the DATA driver of the microphone tristates. In this way, two microphones, one set to the left channel and the other to the right, can drive a single DATA line. See Figure 1 for a timing diagram of the PDM data format; the DATA1 and DATA2 lines shown in this figure are two halves of the single physical DATA signal. Figure 7 shows a diagram of the two stereo channels sharing a common DATA line. CLK DATA2 (L) DATA DATA1 (R) DATA2 (L) DATA1 (R) Figure 7. Stereo PDM Format If only one microphone is connected to the DATA signal, the output is only clocked on a single edge (Figure 8). For example, a left channel microphone is never clocked on the rising edge of CLK. In a single microphone application, each bit of the DATA signal is typically held for the full CLK period until the next transition because the leakage of the DATA line is not enough to discharge the line while the driver is tristated. CLK DATA DATA1 (R) DATA1 (R) DATA1 (R) Figure 8. Mono PDM Format See Table 10 for the channel assignments according to the logic level on the SELECT pin. The setting on the SELECT pin is sampled at power-up and should not be changed during operation. TABLE 10. ICS-51360 CHANNEL SETTING SELECT Pin Setting Low (tie to GND) High (tie to VDD) Channel Right (DATA1) Left (DATA2) For PDM data, the density of the pulses indicates the signal amplitude. A high density of high pulses indicates a signal near positive full scale, and a high density of low pulses indicates a signal near negative full scale. A perfect zero (dc) audio signal shows an alternating pattern of high and low pulses. The output PDM data signal has a small dc offset of about 3% of full scale. A high-pass filter in the codec that is connected to the digital microphone and does not affect the performance of the microphone typically removes this dc signal. PDM MICROPHONE SENSITIVITY The sensitivity of a PDM output microphone is specified with the unit dB FS (decibels relative to digital full scale). A 0 dB FS sine wave is defined as a signal whose peak just touches the full-scale code of the digital word (see Figure 9). This measurement convention also means that signals with a different crest factor may have an RMS level higher than 0 dB FS. For example, a full-scale square wave has an RMS level of 3 dB FS. Page 12 of 22 Document Number: DS-000094 Revision: 1.0 ICS-51360 This definition of a 0 dB FS signal must be understood when measuring the sensitivity of the ICS-51360. A 1 kHz sine wave at a 94 dB SPL acoustic input to the ICS-51360 results in an output signal with a −26 dB FS level (low power mode). The output digital word peaks at −26 dB below the digital full-scale level. A common misunderstanding is that the output has an RMS level of −29 dB FS; however, this is not true because of the definition of the 0 dB FS sine wave. 1.0 0.8 DIGITAL AMPLITUDE (D) 0.6 0.4 0.2 0 –0.2 –0.4 –0.6 –0.8 –1.0 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 TIME (ms) Figure 9. 1 kHz, 0 dB FS Sine Wave There is not a commonly accepted unit of measurement to express the instantaneous level, as opposed to the RMS level of the signal, of a digital signal output from the microphone. Some measurement systems express the instantaneous level of an individual sample in units of D, where 1.0 D is digital full scale. In this case, a −26 dB FS sine wave has peaks at 0.05 D. Page 13 of 22 Document Number: DS-000094 Revision: 1.0 ICS-51360 APPLICATIONS INFORMATION LOW POWER MODE Low Power Mode (LPM) enables the ICS-51360 to be used in an AlwaysOn listening mode for keyword spotting and ambient sound analysis. The ICS-51360 will enter LPM when the frequency of SCK is 768 kHz. In this mode, the microphone consumes only 230 µA while retaining high electro-acoustic performance. When one microphone is in LPM for AlwaysOn listening, a second microphone sharing the same data line may be powered down. In this case, where one microphone is powered up and another is powered down by disabling the VDD supply or in sleep mode by reducing the frequency of a separate clock source, the disabled microphone does not present a load to the signal on the LPM microphone’s DATA pin. DYNAMIC RANGE CONSIDERATIONS The microphone clips (THD = 10%) at 120 dB SPL in Low Power Mode and at 130 dB SPL in Standard Mode (see Figure 5); however, it continues to output an increasingly distorted signal above that point. The peak output level, which is controlled by the modulator, limits at 0 dB FS. To fully use the 98 dB dynamic range of the output data of the ICS-51360 in a design, the digital signal processor (DSP), analog-to-digital converter (ADC), or codec circuit following it must be chosen carefully. The decimation filter that inputs the PDM signal from the ICS51360 must have a dynamic range sufficiently better than the dynamic range of the microphone so that the overall noise performance of the system is not degraded. If the decimation filter has a dynamic range of 10 dB better than the microphone, the overall system noise only degrades by 0.4 dB. This 108 dB filter dynamic range requires the filter to have at least 18 bit resolution. CONNECTING PDM MICROPHONES A PDM output microphone is typically connected to a codec with a dedicated PDM input. This codec separately decodes the left and right channels and filters the high sample rate modulated data back to the audio frequency band. This codec also generates the clock for the PDM microphones or is synchronous with the source that is generating the clock. Figure 10 and Figure 11 show mono and stereo connections of the ICS-51360 to a codec. The mono connection shows an ICS-51360 set to output data on the right channel. To output on the left channel, tie the SELECT pin to VDD instead of tying it to GND. 1.8V TO 3.3V 0.1µF VDD PDM MICROPHONE SELECT CODEC CLOCK OUTPUT CLK DATA DATA INPUT GND Figure 10. Mono PDM Microphone (Right Channel) Connection to Codec Page 14 of 22 Document Number: DS-000094 Revision: 1.0 ICS-51360 1.8V TO 3.3V 0.1µF VDD CODEC CLK PDM MICROPHONE SELECT CLOCK OUTPUT DATA DATA INPUT GND 1.8V TO 3.3V 0.1µF VDD PDM MICROPHONE SELECT CLK DATA GND Figure 11. Stereo PDM Microphone Connection to Codec Decouple the VDD pin of the ICS-51360 to GND with a 0.1 µF capacitor. Place this capacitor as close to VDD as the printed circuit board (PCB) layout allows. Do not use a pull-up or pull-down resistor on the PDM data signal line because it can pull the signal to an incorrect state during the period that the signal line is tristated. The DATA signal does not need to be buffered in normal use when the ICS-51360 microphone(s) is placed close to the codec on the PCB. If the DATA signal must be driven over a long cable (>15 cm) or other large capacitive load, a digital buffer may be required. Only use a signal buffer on the DATA line when one microphone is in use or after the point where two microphones are connected (see Figure 12). The DATA output of each microphone in a stereo configuration cannot be individually buffered because the two buffer outputs cannot drive a single signal line. If a buffer is used, take care to select one with low propagation delay so that the timing of the data connected to the codec is not corrupted. CODEC PDM MICROPHONE CLK CLOCK OUTPUT DATA DATA INPUT PDM MICROPHONE CLK DATA Figure 12. Buffered Connections Between Stereo ICS-51360s and a Codec Page 15 of 22 Document Number: DS-000094 Revision: 1.0 ICS-51360 When long wires are used to connect the codec to the ICS-51360, a source termination resistor can be used on the clock output of the codec instead of a buffer to minimize signal overshoot or ringing. Match the value of this resistor to the characteristic impedance of the CLK trace on the PCB. Depending on the drive capability of the codec clock output, a buffer may still be needed, as shown in Figure 12. SLEEP MODE The microphone enters sleep mode when the clock frequency falls below 200 kHz. In this mode, the microphone data output is in a high impedance state. The current consumption in sleep mode is 12 µA. The microphone wakes up from sleep mode and begins to output data within 10 ms after the clock becomes active. The wake-up time indicates the time from when the clock is enabled to when the ICS-51360 outputs data within 1 dB of its settled sensitivity. START-UP TIME The start-up time of the ICS-51360 is less than 20 ms, measured by the time from when power and clock are enabled until sensitivity of the output signal is within 1 dB of its settled sensitivity. Page 16 of 22 Document Number: DS-000094 Revision: 1.0 ICS-51360 SUPPORTING DOCUMENTS For additional information, see the following documents. APPLICATION NOTES – GENERAL AN-000048, PDM Digital Output MEMS Microphone Flex Evaluation Board User Guide AN-100, MEMS Microphone Handling and Assembly Guide AN-1003, Recommendations for Mounting and Connecting the Invensense, Bottom-Ported MEMS Microphones AN-1112, Microphone Specifications Explained AN-1124, Recommendations for Sealing InvenSense Bottom-Port MEMS Microphones from Dust and Liquid Ingress AN-1140, Microphone Array Beamforming Page 17 of 22 Document Number: DS-000094 Revision: 1.0 ICS-51360 PCB DESIGN AND LAND PATTERN LAYOUT The recommended PCB land pattern for the ICS-51360 is a 1:1 ratio of the solder pads on the microphone package, as shown in Figure 13. Avoid applying solder paste to the sound hole in the PCB. A suggested solder paste stencil pattern layout is shown in Figure 14. The response of the ICS-51360 is not affected by the PCB hole size as long as the hole is not smaller than the sound port of the microphone (0.375 mm in diameter). A 0.5 mm to 1 mm diameter for the hole is recommended. Take care to align the hole in the microphone package with the hole in the PCB. The exact degree of the alignment does not affect the microphone performance as long as the holes are not partially or completely blocked. 0.522x0.725(4X) Ø1.625 Ø1.025 1.675 0.838 0.822 1.252 Figure 13. Recommended PCB Land Pattern Layout 0.422x0.625(4X) Ø1.625 Ø1.125 1.675 0.1(4x) 0.822 1.252 Figure 14. Suggested Solder Paste Stencil Pattern Layout PCB MATERIAL AND THICKNESS The performance of the ICS-51360 is not affected by PCB thickness. The ICS-51360 can be mounted on either a rigid or flexible PCB. A flexible PCB with the microphone can be attached directly to the device housing with an adhesive layer. This mounting method offers a reliable seal around the sound port while providing the shortest acoustic path for good sound quality. Page 18 of 22 Document Number: DS-000094 Revision: 1.0 ICS-51360 HANDLING INSTRUCTIONS PICK AND PLACE EQUIPMENT The MEMS microphone can be handled using standard pick-and-place and chip shooting equipment. Take care to avoid damage to the MEMS microphone structure as follows:  Use a standard pickup tool to handle the microphone. Because the microphone hole is on the bottom of the package, the pickup tool can make contact with any part of the lid surface.  Do not pick up the microphone with a vacuum tool that makes contact with the bottom side of the microphone. Do not pull air out of or blow air into the microphone port.  Do not use excessive force to place the microphone on the PCB. REFLOW SOLDER For best results, the soldering profile must be in accordance with the recommendations of the manufacturer of the solder paste used to attach the MEMS microphone to the PCB. It is recommended that the solder reflow profile not exceed the limit conditions specified in Figure 2 and Table 8. BOARD WASH When washing the PCB, ensure that water does not make contact with the microphone port. Do not use blow-off procedures or ultrasonic cleaning. Page 19 of 22 Document Number: DS-000094 Revision: 1.0 ICS-51360 OUTLINE DIMENSIONS d 0.10 (4X) 3.50 0.522X0.725 (4x) j 0.10m C A B A PIN1 CORNER PIN1 CORNER 0.82 ø 1.625 ø 1.025 (2.45) 2.65 1 2 5 4 ø 0.325 1.68 3 B (3.30) (0.125) 0.300 (0.125) 1.51 BOTTOM VIEW TOP VIEW f 0.10 C 0.98±0.10 (0.254) C SIDE VIEW Figure 15. 5-Terminal Chip Array Small Outline No Lead Cavity [LGA_CAV] 3.5 mm × 2.65 mm × 0.98 mm Body Dimensions shown in millimeters Dimension tolerance is ±0.15 mm unless otherwise specified PART NUMBER PIN 1 INDICATION 1360 YYXXX DATE CODE LOT TRACEABILITY CODE Figure 16. Package Marking Specification (Top View) ORDERING GUIDE PART TEMP RANGE PACKAGE QUANTITY PACKAGING ICS-51360 −40°C to +85°C 5-Terminal LGA_CAV 10,000 13” Tape and Reel Page 20 of 22 Document Number: DS-000094 Revision: 1.0 1.04 1.33 ICS-51360 REVISION HISTORY REVISION DATE REVISION DESCRIPTION 9/23/2016 1.0 Initial version Page 21 of 22 Document Number: DS-000094 Revision: 1.0 ICS-51360 COMPLIANCE DECLARATION DISCLAIMER InvenSense believes the environmental and other compliance information given in this document to be correct but cannot guarantee accuracy or completeness. Conformity documents substantiating the specifications and component characteristics are on file. InvenSense subcontracts manufacturing, and the information contained herein is based on data received from vendors and suppliers, which has not been validated by InvenSense. This information furnished by InvenSense is believed to be accurate and reliable. However, no responsibility is assumed by InvenSense for its use, or for any infringements of patents or other rights of third parties that may result from its use. Specifications are subject to change without notice. InvenSense reserves the right to make changes to this product, including its circuits and software, in order to improve its design and/or performance, without prior notice. InvenSense makes no warranties, neither expressed nor implied, regarding the information and specifications contained in this document. InvenSense assumes no responsibility for any claims or damages arising from information contained in this document, or from the use of products and services detailed therein. This includes, but is not limited to, claims or damages based on the infringement of patents, copyrights, mask work and/or other intellectual property rights. Certain intellectual property owned by InvenSense and described in this document is patent protected. No license is granted by implication or otherwise under any patent or patent rights of InvenSense. This publication supersedes and replaces all information previously supplied. Trademarks that are registered trademarks are the property of their respective companies. InvenSense sensors should not be used or sold in the development, storage, production or utilization of any conventional or mass-destructive weapons or for any other weapons or life threatening applications, as well as in any other life critical applications such as medical equipment, transportation, aerospace and nuclear instruments, undersea equipment, power plant equipment, disaster prevention and crime prevention equipment. ©2016 InvenSense, Inc. All rights reserved. InvenSense, MotionTracking, MotionProcessing, MotionProcessor, MotionFusion, MotionApps, DMP, AAR and the InvenSense logo are trademarks of InvenSense, Inc. Other company and product names may be trademarks of the respective companies with which they are associated. ©2016 InvenSense, Inc. All rights reserved. Page 22 of 22 Document Number: DS-000094 Revision: 1.0
ICS-51360 价格&库存
很抱歉,暂时无法提供与“ICS-51360”相匹配的价格&库存,您可以联系我们找货
