ICS-52000
ICS-52000
    TDK(东电化)
    MICMEMSDIGITALOMNI-26DB
ICS-52000 数据手册
ICS-52000 Low-Noise Microphone with TDM Digital Output GENERAL DESCRIPTION APPLICATIONS The ICS-52000 is a digital TDM output bottom port microphone. The complete ICS-52000 solution consists of a MEMS sensor, signal conditioning, an analog-to-digital converter, decimation and antialiasing filters, power management, and an industry standard 24bit TDM interface. The TDM interface allows an array of up to 16 of the ICS-52000 microphones to connect directly to digital processors, such as DSPs and microcontrollers, without the need for an audio codec in the system. All microphones in an array sample their acoustic signals synchronously, enabling precise array processing. The ICS-52000 has a high SNR of 65 dBA and a wideband frequency response. The sensitivity tolerance of the ICS‐52000 is ±1 dB, which enables high-performance microphone arrays without the need for system calibration. The ICS-52000 is available in a small 4 mm × 3 mm × 1 mm surface-mount package. FUNCTIONAL BLOCK DIAGRAM FILTER HARDWARE CONTROL FEATURES • • • • • • • • • • • • Digital TDM Interface with High Precision 24-bit Data Supports TDM arrays of up to 16 synchronouslysampled channels High 65 dBA SNR −26 dB FS Sensitivity ±1 dB Sensitivity Tolerance Wide Frequency Response from 50 Hz to 20 kHz Low Current Consumption: 1.0 mA High Power Supply Rejection: −89 dB FS 117 dB SPL Acoustic Overload Point Small 4 mm × 3 mm × 1 mm Surface-Mount Package Compatible with Sn/Pb and Pb-Free Solder Processes RoHS/WEEE Compliant TDM SERIAL PORT SCK PART ICS-52000 EV_ICS-52000-FX TEMP RANGE −40°C to +85°C — SD WS WSO CONFIG GND VDD POWER MANAGEMENT Speech Recognition Arrays Smart Televisions Teleconferencing Systems Gaming Consoles Security Systems Microphone Arrays ORDERING INFORMATION ICS-52000 ADC • • • • • • InvenSense reserves the right to change the detail specifications as may be required to permit improvements in the design of its products. InvenSense Inc. 1745 Technology Drive, San Jose, CA 95110 U.S.A +1(408) 988–7339 www.invensense.com Document Number: DS-000121 Revision: 1.3 Release Date: 4/14/2017 PACKAGING 13” Tape & Reel ICS-52000 TABLE OF CONTENTS General Description ..................................................................................................................................................................... 1 Applications ................................................................................................................................................................................. 1 Features ....................................................................................................................................................................................... 1 Functional Block Diagram ............................................................................................................................................................ 1 Ordering Information ................................................................................................................................................................... 1 Table of Contents .................................................................................................................................................................................... 2 Specifications .......................................................................................................................................................................................... 4 Table 1. Electrical Characteristics ................................................................................................................................................ 4 Table 2. TDM Digital INPUT/Output ............................................................................................................................................ 5 Table 3. Serial Data Port Timing Specification ............................................................................................................................. 5 Timing Diagram ............................................................................................................................................................................ 5 Absolute Maximum Ratings .................................................................................................................................................................... 6 Table 4. Absolute Maximum Ratings ........................................................................................................................................... 6 ESD Caution ................................................................................................................................................................................. 6 Soldering Profile........................................................................................................................................................................... 7 Table 5. Recommended Soldering Profile.................................................................................................................................... 7 Pin Configurations And Function Descriptions ....................................................................................................................................... 8 Table 6. Pin Function Descriptions............................................................................................................................................... 8 Typical Performance Characteristics....................................................................................................................................................... 9 Theory of Operation ............................................................................................................................................................................. 10 Startup and Power Management .............................................................................................................................................. 10 Startup ............................................................................................................................................................................ 10 Table 7. Startup time ...................................................................................................................................................... 10 Standby Mode ................................................................................................................................................................ 10 Soft Unmute ................................................................................................................................................................... 10 Synchronizing Microphones ...................................................................................................................................................... 11 TDM Data Interface ................................................................................................................................................................... 11 Data Output Format ....................................................................................................................................................... 11 Digital Microphone Sensitivity ................................................................................................................................................... 13 Digital Filter Characteristics ....................................................................................................................................................... 13 High-Pass Filter ............................................................................................................................................................... 13 Low-Pass Decimation Filter ............................................................................................................................................ 13 Applications Information ...................................................................................................................................................................... 14 SD Output Drive Strength .......................................................................................................................................................... 14 Design Recommendations .............................................................................................................................................. 14 Power Supply Decoupling .......................................................................................................................................................... 14 Supporting Documents ......................................................................................................................................................................... 15 Document Number: DS-000121 Revision: 1.3 Page 2 of 20 ICS-52000 Evaluation Board User Guide ..................................................................................................................................................... 15 Application Notes ...................................................................................................................................................................... 15 PCB Design And Land Pattern Layout ................................................................................................................................................... 16 PCB Material And Thickness ...................................................................................................................................................... 16 Handling Instructions ............................................................................................................................................................................ 17 Pick And Place Equipment ......................................................................................................................................................... 17 Reflow Solder ............................................................................................................................................................................. 17 Board Wash................................................................................................................................................................................ 17 Outline Dimensions ............................................................................................................................................................................... 18 Ordering Guide .......................................................................................................................................................................... 18 Revision History ......................................................................................................................................................................... 19 Compliance Declaration Disclaimer ...................................................................................................................................................... 20 Document Number: DS-000121 Revision: 1.3 Page 3 of 20 ICS-52000 SPECIFICATIONS TABLE 1. ELECTRICAL CHARACTERISTICS TA = +25°C, VDD = 1.8 to 3.3V, fSCK = 3.072 MHz, CLOAD = 30 pF unless otherwise noted. Typical specifications are not guaranteed. PARAMETER PERFORMANCE Directionality Sensitivity Signal-to-Noise Ratio (SNR) Equivalent Input Noise (EIN) Dynamic Range Total Harmonic Distortion (THD) Power-Supply Rejection (PSR) CONDITIONS 1 kHz, 94 dB SPL MIN −27 Derived from EIN and acoustic overload point 105 dB SPL 217 Hz, 100 mVp-p square wave superimposed on VDD = 1.8 V (Aweighted) TYP Omni −26 65 29 MAX UNITS −25 dB FS dBA dBA SPL 88 0.3 dB 1 % −89 dB FS Power-Supply Rejection – Swept Sine 1 kHz sine wave −98 dB FS Acoustic Overload Point Noise Floor POWER SUPPLY Supply Voltage (VDD) 10% THD 20 Hz to 20 kHz, A-weighted, rms 117 −91 dB SPL dB FS Supply Current (IS) 1.62 VDD = 1.8V VDD = 3.3V DIGITAL FILTER Group Delay Normal Mode Standby Normal Mode Standby 1.0 5 1.1 7 Acoustic input to digital output – includes filter and TDM serial output 2/fS Pass Band Ripple Stop Band Attenuation Pass Band Document Number: DS-000121 Revision: 1.3 3.63 1.4 20 1.5 24 sec ±0.3 fs = 48 kHz Page 4 of 20 V mA µA mA µA 58 dB dB 20 kHz NOTES ICS-52000 TABLE 2. TDM DIGITAL INPUT/OUTPUT –40°C < TA < +85°C, 1.8 V < VDD < 3.3 V, unless otherwise noted. MIN MAX UNITS Voltage Input Low (VIL) 0 0.25 × VDD V Voltage Input High (VIH) 0.7 × VDD VDD V Voltage Output Low (VOL) 0 0.25 × VDD V Voltage Output High (VOH) 0.7 × VDD VDD V 150 pF DIGITAL INPUT PARAMETER CONDITIONS NOTES SD DIGITAL OUTPUT Maximum Load CLK = 24.576 MHz TABLE 3. SERIAL DATA PORT TIMING SPECIFICATION –40°C < TA < +85°C, 1.8 V < VDD < 3.3 V, unless otherwise noted. PARAMETER SCK duty cycle CONDITIONS MIN 48 SCK period (tSCP) MAX 52 UNITS % 37 SCK frequency (fSCK) 0.460 ns 27.034 MHz WS setup (tWSS) 0 ns WS hold (tWSH) 10 ns WS frequency (fS) 7.19 52.8 kHz SD data valid (tSDV) From SCK rising to valid SD data 18 ns SD data disable (tSDD) From SCK rising to SD output tristated 18 ns WSO valid (tWSOV) 15 pF trace load 18 ns WSO disable (tWSOD) 15 pF trace load 18 ns TIMING DIAGRAM tSCP SCK tWSH tWSS tWSOV WS WSO tSDV tSDD SD Figure 1. Serial Data Port Timing Document Number: DS-000121 Revision: 1.3 Page 5 of 20 tWSOD NOTES ICS-52000 ABSOLUTE MAXIMUM RATINGS Stress above those listed as Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these conditions is not implied. Exposure to the absolute maximum ratings conditions for extended periods may affect device reliability. TABLE 4. ABSOLUTE MAXIMUM RATINGS PARAMETER RATING Supply Voltage (VDD) −0.3V to +3.63V Digital Pin Input Voltage −0.3V to VDD + 0.3V or 3.63V, whichever is less Sound Pressure Level 160 dB Mechanical Shock 10,000 g Vibration Per MIL-STD-883 Method 2007, Test Condition B Temperature Range Biased −40°C to +85°C Storage −55°C to +150°C ESD CAUTION ESD (electrostatic discharge) sensitive device. Charged devices and circuit boards can discharge without detection. Although this product features patented or proprietary protection circuitry, damage may occur on devices subjected to high energy ESD. Therefore proper ESD precautions should be taken to avoid performance degradation or loss of functionality. Document Number: DS-000121 Revision: 1.3 Page 6 of 20 ICS-52000 SOLDERING PROFILE CRITICAL ZONE TL TO TP tP TP TEMPERATURE RAMP-UP TL tL TSMAX TSMIN tS RAMP-DOWN PREHEAT t25°C TO PEAK TEMPERATURE TIME Figure 2. Recommended Soldering Profile Limits TABLE 5. RECOMMENDED SOLDERING PROFILE PROFILE FEATURE Average Ramp Rate (TL to TP) Preheat Minimum Temperature (TSMIN) Minimum Temperature (TSMIN) Time (TSMIN to TSMAX), tS Ramp-Up Rate (TSMAX to TL) Time Maintained Above Liquidous (tL) Liquidous Temperature (TL) Peak Temperature (TP) Time Within +5°C of Actual Peak Temperature (tP) Ramp-Down Rate Time +25°C (t25°C) to Peak Temperature Sn63/Pb37 1.25°C/sec max Pb-Free 1.25°C/sec max 100°C 100°C 150°C 200°C 60 sec to 75 sec 60 sec to 75 sec 1.25°C/sec 1.25°C/sec 45 sec to 75 sec ~50 sec 183°C 217°C 215°C ±3°C/−3°C 260°C +0°C/−5°C 20 sec to 30 sec 20 sec to 30 sec 3°C/sec max 3°C/sec max 5 min max 5 min max *The reflow profile in Table 5 is recommended for board manufacturing with InvenSense MEMS microphones. All microphones are also compatible with the J-STD-020 profile. Document Number: DS-000121 Revision: 1.3 Page 7 of 20 ICS-52000 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS GND 4 WS 5 3 VDD SCK 6 2 CONFIG SD 7 1 WSO Figure 3. Pin Configuration (Top View, Terminal Side Down) TABLE 6. PIN FUNCTION DESCRIPTIONS PIN NAME TYPE 1 WSO Output 2 CONFIG Input Pull to VDD. The state of this pin is used at power-up. 3 VDD Power Power, 1.62V to 3.63V. This pin should be decoupled to GND with a 0.1 μF capacitor. 4 GND Ground Ground. Connect to ground on the PCB. 5 WS Input Serial Data-Word Select for TDM Interface 6 SCK Input Serial Data Clock for TDM Interface 7 SD Output Document Number: DS-000121 Revision: 1.3 FUNCTION WS output, connect to WS of the next ICS-52000 in the daisy-chain. Serial Data Output for TDM Interface. This pin tri-states when not actively driving the appropriate output channel. The SD trace should have a 100 kΩ pulldown resistor to discharge the line during the time that all microphones on the bus have tri-stated their outputs. Page 8 of 20 ICS-52000 TYPICAL PERFORMANCE CHARACTERISTICS 20 10 10 THD + N (%) NORMALIZED AMPLITUDE (dB) 30 0 -10 -20 -30 10 100 1k   FREQUENCY (Hz) 0.1 10k 90 95 100 105 110   (dB SPL) INPUT 115 120 125 Figure 5. Total Harmonic Distortion + Noise (THD+N) vs. Input SPL Figure 4. Typical Frequency Response (Measured) 0 0 -5 OUTPUT AMPLITUDE (dB FS) –20 -10 –40 PSR (dB FS) 1 -15 –60 -20 –80 -25 –100 –120 100 -30 1k FREQUENCY (Hz) -35 10k Figure 6. PSR vs. Frequency, 100 mV p-p Swept Sine Wave Document Number: DS-000121 Revision: 1.3 90 95 100 105 110 115   INPUT AMPLITUDE (dB SPL) Figure 7. Linearity Page 9 of 20 120 125 ICS-52000 THEORY OF OPERATION STARTUP AND POWER MANAGEMENT The ICS-52000 has two power states: normal operation, and standby mode. Startup At startup of the ICS-52000, the start of the frame sync (WS) signal should be delayed from the start of the serial clock (SCK) by at least 10 ms. This enables the microphone’s internal circuits to completely initialize before starting the synchronization sequence with other microphones in the TDM array. This delay can be implemented either by enabling the WS output on the clock master at least 10 ms after the SCK is enabled, or by externally controlling the signals given to the ICS-52000s. 1/fs >10 ms WS (MASTER) SCK Figure 8. Clock Startup Sequence The ICS-52000 will begin to output non-zero data 4462 SCK clock cycles (1.5 ms with fSCK = 3.072 MHz) after initial power-up. The data is valid to use after the initial 262,144 SCK cycles (85 ms with fSCK = 3.072 MHz). This startup time is applicable any time it is entering normal operation mode, coming either from power-down or out of standby. Table 7 shows the startup time for different sampling rates. Table 7. Startup time fS (WS frequency) Time to non-zero data output Startup time to valid data 48 kHz 1.5 ms 85 ms 24 kHz 3.0 ms 171 ms 16 kHz 4.5 ms 256 ms 8 kHz 9.0 ms 512 ms Normal Operation The part is in normal operation mode when SCK and WS are active. Clocks should not be supplied to the microphones until they are settled and stable. Standby Mode The microphone enters standby mode when the frequency of SCK falls below about 1 kHz. It is recommended to enter standby mode by stopping both the SCK and WS clock signals and pulling those signals to ground to avoid drawing current through the WS pin’s internal pull-down resistor. The timing for exiting standby mode is the same as normal startup. Do not supply active clocks (WS and SCK) to the ICS-52000 while there is no power supplied to VDD, doing this continuously turns on ESD protection diodes, which may affect long-term reliability of the microphone. Soft Unmute The ICS-52000 has a soft unmute feature to prevent pops on power-up. From the time that the ICS-52000 starts to output data, the volume will ramp up to the full-scale output level over 256 WS clock cycles. With a 48 kHz sampling rate, this unmute sequence will take about 5.3 ms. Document Number: DS-000121 Revision: 1.3 Page 10 of 20 ICS-52000 SYNCHRONIZING MICROPHONES ICS-52000 microphones are synchronized by the WS signal, so audio captured from multiple microphones sharing the same clock will be sampled synchronously. TDM DATA INTERFACE The slave serial data port’s format is TDM, 24-bit, twos complement and up to 16 ICS-52000 microphones can be daisy-chained together on a single data bus. There must be 64, 128, 256 or 512 SCK cycles in each WS frame. Each microphone will output 24-bit data in subsequent 32-bit slots. Tie the SD pins of all ICS-52000 microphones driving the data bus together as shown in Figure 9. The ICS-52000 will always be a slave on the TDM bus. The word select/word clock signals of the microphones in the system will be daisy-chained so that the clock master drives WS of the first ICS-52000, whose WSO will drive WS of the second ICS-52000, and so on; the last ICS-52000 in the chain can leave WSO disconnected. See Figure 9 for an illustration of these connections. The ICS-52000’s WS clock input is sampled on the rising edge of SCK and the falling edge of WS can come anywhere before the start of the next frame. The ICS-52000 connected directly to the system’s clock master will output its data in the first TDM slot, the next microphone in the chain will output its data in the second TDM slot, and so on. The frequency of SCK will depend on the number of microphones in the system. The SCK frequency should be n × 32 × fS, where n is a power of two (2, 4, 8, or 16) equal to or greater than the number of ICS-52000s on the bus. Table 8 shows the recommended SCK frequency for a chain of ICS-52000 microphones. Table 8. SCK Frequency Number of ICS-52000 Microphones SCK Frequency, based on WS frequency (fS) 1-2 64 × fS 3-4 128 × fS 5-8 256 × fS 9-16 512 × fS Figure 10 shows the format of an n-channel TDM data stream. Figure 11 zooms in on a single TDM data slot as output from a single ICS-52000 microphone. Data Output Format The output data word length is 24 bits/channel. The data word format is 2’s complement, MSB-first. The serial TDM data output bits are triggered on SCK’s rising edge. The receiver (DSP, codec, microcontroller) should sample that data bit on the next SCK rising edge. This is illustrated in Figure 11; SCK rising edge A triggers the SD output bit and the receiver should sample the data at its input on SCK rising edge B. The data is formatted in this way to support the internal propagation delay of the microphone data at high SCK frequencies. The output data pin (SD) is tri-stated when it is not actively driving TDM output data. SD will immediately tri-state after the LSB is output so that another microphone can drive the common data line. The SD trace should have a pull-down resistor to discharge the line during the time that all microphones on the bus have tri-stated their outputs. A 100 kΩ or smaller resistor is sufficient for this, as shown in Figure 9. Document Number: DS-000121 Revision: 1.3 Page 11 of 20 ICS-52000 From Voltage Regulator (1.8-3.3V) 0.1 uF 0.1 uF 0.1 uF SEE THE STARTUP SECTION AND FIGURE 8 FOR DETAILS ON CONNECTING THE SYSTEM MASTER TO THE MICROPHONE ARRAY. CONFIG WS SYSTEM MASTER (MICROCONTROLLER, DSP, CODEC) SCK WS VDD CONFIG ICS-52000 #1 WS WSO SD SCK VDD ICS-52000 #2 WSO WSI SD SCK GND CONFIG VDD ICS-52000 #n WSO SD SCK GND GND SD 100 kΩ Figure 9. System Block Diagram WS(MASTER) WSO(1), WS(2) WSO(2), WS(3) WSO(n-1), WS(n) SCK SD SLOT 1 SLOT 2 SLOT 1 SLOT n SLOT 3 Figure 10. n-Channel Output TDM Timing Diagram WS 1 2 3 23 24 25 31 32 33 WSO A B SCK (n x 32 x fs) SD Output Data High-Z High-Z MSB LSB Figure 11. Single TDM Slot Timing Diagram Document Number: DS-000121 Revision: 1.3 Page 12 of 20 34 ICS-52000 DIGITAL MICROPHONE SENSITIVITY The sensitivity of a digital output microphone is specified in units of dB FS (decibels relative to a full-scale digital output). A 0 dB FS sine wave is defined as a signal whose peak just touches the full-scale code of the digital word (see Figure 5). This measurement convention means that signals with a different crest factor may have an RMS level higher than 0 dB FS. For example, a full-scale square wave has an RMS level of 3 dB FS. 1.0 0.8 DIGITAL AMPLITUDE (D) 0.6 0.4 0.2 0 –0.2 –0.4 –0.6 –0.8 –1.0 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 TIME (ms) Figure 12. 1 kHz, 0 dB FS Sine Wave The definition of a 0 dB FS signal must be understood when measuring the sensitivity of the ICS-52000. An acoustic input signal of a 1 kHz sine wave at 94 dB SPL applied to the ICS-52000 results in an output signal with a −26 dB FS level. This means that the output digital word peaks at −26 dB below the digital full-scale level. A common misunderstanding is that the output has an RMS level of −29 dB FS; however, this is not the case because of the definition of a 0 dB FS sine wave. There is no commonly accepted unit of measurement to express the instantaneous level of a digital signal output from the microphone, as opposed to the RMS level of the signal. Some measurement systems express the instantaneous level of an individual sample in units of D, where 1.0 D is digital full scale (see Figure 12). In this case, a −26 dB FS sine wave has peaks at 0.05 D. For more information about digital microphone sensitivity, see the AN-1112 Application Note, Microphone Specifications Explained. DIGITAL FILTER CHARACTERISTICS The ICS-52000 has an internal digital bandpass filter. A high-pass filter eliminates unwanted low frequency signals. A low-pass decimation filter scales the pass band with the sampling frequency and performs required out-of-band noise reduction. High-Pass Filter The ICS-52000 incorporates a high-pass filter to remove unwanted dc and very low frequency components. With fS = 48 kHz, this high pass filter has a −3 dB corner frequency of 3.7 Hz. The cutoff frequency scales with changes in sampling rate. This digital filter response is in addition to the acoustic high-pass response of the ICS-52000 that has a −3 dB corner of 50 Hz. Low-Pass Decimation Filter The analog-to-digital converter in the ICS-52000 is a single-bit, high order, sigma-delta (Σ-Δ) running at a high oversampling ratio. The noise shaping of the converter pushes the majority of the noise well above the audio band and gives the microphone a wide dynamic range. However, it does require a good quality low-pass decimation filter to eliminate the high frequency noise. The pass band of the filter extends to 0.417 × fS and, in that band, has only 0.04 dB of ripple. The high frequency cutoff of −3 dB occurs at 0.5 × fS. A 48 kHz sampling rate results in a pass band of 20.3 kHz and a half amplitude corner at 24 kHz; the stop-band attenuation of the filter is 58 dB. Note that these filter specifications scale with sampling frequency. Document Number: DS-000121 Revision: 1.3 Page 13 of 20 ICS-52000 APPLICATIONS INFORMATION SD OUTPUT DRIVE STRENGTH The SD data output pin must drive a load that includes the PCB trace and the tri-stated inputs of the other ICS-52000 SD pins connected to that same trace. The tri-stated load capacitance of the ICS-52000 SD pin is about 6 pF. The ICS-52000 is designed to drive a load of 150 pF. If 16 ICS-52000 microphones are connected to a common 30” SD trace on a typical PCB, the driver will meet the timing specs with a 24.576 MHz SCK and 2 ns propagation delay. Design Recommendations The SD output driver has an output impedance of about 25-35Ω. A source termination resistor placed close to each microphone’s SD pin may help to reduce ringing and overshoot on the output signal. A 15-25Ω resistor will help to match the source impedance to a typical 50Ω transmission line. The SD signal’s propagation delay is a function of the PCB material and length of the trace. Arrays with a larger number of microphones will usually have a longer SD trace on the PCB. The worst-case timing conditions specified above (24.576 MHz SCK, 2 ns propagation delay) were calculated for a 16 microphone array with 2” spacing between each microphone and fS = 48 kHz. The propagation delay is minimized by reducing the distance between the SD source and the device receiving the data. This is done by placing the receiver in the layout in the middle of the SD trace, rather than at one of the extremes. That will cut the worst-case propagation delay in half, compared to if the receiver is placed at one end of a long SD trace. If the distance between the microphone array and the receiver cannot be minimized, it may be useful to have a buffer between the two. Place the buffer at the point that minimizes the distance between it and the furthest microphones on the PCB trace. This single buffer could drive the remaining distance between it and the data receiver. The buffer’s propagation delay may be a critical spec, especially with higher clock rates. POWER SUPPLY DECOUPLING For best performance and to avoid potential parasitic artifacts, placing a 0.1 µF ceramic type X7R or better capacitor between Pin 3 (VDD) and ground is strongly recommended. The capacitor should be placed as close to Pin 3 as possible. The connections to each side of the capacitor should be as short as possible, and the trace should stay on a single layer with no vias. For maximum effectiveness, locate the capacitor equidistant from the power and ground pins or, when equidistant placement is not possible, slightly closer to the power pin. Thermal connections to the ground planes should be made on the far side of the capacitor, as shown in Figure 13. VDD GND CAPACITOR TO V DD TO GND Figure 13. Recommended Power Supply Bypass Capacitor Layout Document Number: DS-000121 Revision: 1.3 Page 14 of 20 ICS-52000 SUPPORTING DOCUMENTS For additional information, see the following documents. EVALUATION BOARD USER GUIDE AN-000001, Bottom-Port I2S/TDM Output MEMS Microphone Evaluation Board AN-000099, Synchronous Sampling with an Array of ICS-52000 TDM Microphones APPLICATION NOTES AN-100, MEMS Microphone Handling and Assembly Guide AN-1003, Recommendations for Mounting and Connecting the InvenSense Bottom-Ported MEMS Microphones AN-1112, Microphone Specifications Explained AN-1124, Recommendations for Sealing InvenSense Bottom-Port MEMS Microphones from Dust and Liquid Ingress AN-1140, Microphone Array Beamforming Document Number: DS-000121 Revision: 1.3 Page 15 of 20 ICS-52000 PCB DESIGN AND LAND PATTERN LAYOUT The recommended PCB land pattern for the ICS-52000 should be laid out to a 1:1 ratio to the solder pads on the microphone package, as shown in Figure 14. Take care to avoid applying solder paste to the sound hole in the PCB. A suggested solder paste stencil pattern layout is shown in Figure 15. The diameter of the sound hole in the PCB should be larger than the diameter of the sound port of the microphone. A minimum diameter of 0.5 mm is recommended. 6X 0.40X0.60 0.65 0.65 1.275 Ø1.65 1.075 2.15 Ø1.05 Figure 14. PCB Land Pattern Layout Dimensions shown in millimeters 6X 0.30X0.50 Ø1.65 Ø1.15 2.15 0.1(4x) 0.65 0.65 1.275 Figure 15. Suggested Solder Paste Stencil Pattern Layout Dimensions shown in millimeters PCB MATERIAL AND THICKNESS The performance of the ICS-52000 is not affected by PCB thickness. The ICS-52000 can be mounted on either a rigid or flexible PCB. A flexible PCB with the microphone can be attached directly to the device housing with an adhesive layer. This mounting method offers a reliable seal around the sound port while providing the shortest acoustic path for good sound quality. Document Number: DS-000121 Revision: 1.3 Page 16 of 20 ICS-52000 HANDLING INSTRUCTIONS PICK AND PLACE EQUIPMENT The MEMS microphone can be handled using standard pick-and-place and chip shooting equipment. Take care to avoid damage to the MEMS microphone structure as follows: • Use a standard pickup tool to handle the microphone. Because the microphone hole is on the bottom of the package, the pickup tool can make contact with any part of the lid surface. • Do not pick up the microphone with a vacuum tool that makes contact with the bottom side of the microphone. Do not pull air out of or blow air into the microphone port. • Do not use excessive force to place the microphone on the PCB. REFLOW SOLDER For best results, the soldering profile must be in accordance with the recommendations of the manufacturer of the solder paste used to attach the MEMS microphone to the PCB. It is recommended that the solder reflow profile not exceed the limit conditions specified in Figure 2 and Table 5. BOARD WASH When washing the PCB, ensure that water does not make contact with the microphone port. Do not use blow-off procedures or ultrasonic cleaning. Document Number: DS-000121 Revision: 1.3 Page 17 of 20 ICS-52000 OUTLINE DIMENSIONS d 0.10 (4X) f 0.10 C C A (0.266) 4.00±0.10 REFERENCE CORNER 0.07 (0.72) 0.25 0.125±0.05 1.075 0.40X0.60 (6x) j 0.10 m C A B Ø1.65 3.00 2.15 (2.80) 3.00±0.10 Ø1.05 0.125±0.05 Ø0.35 B (3.86) 0.25 0.125±0.05 1.0±0.10 TOP VIEW SIDE VIEW 1.10 4.00 BOTTOM VIEW Figure 16. 7-Terminal Chip Array Small Outline No Lead Cavity 4.00 × 3.00 × 1.00 mm Body Dimensions shown in millimeters PIN 1 INDIC ATION PART NUMBE R 520 YYXXXX DATE COD E LOT TR ACEABILIT Y Figure 17. Package Marking Specification (Top View) ORDERING GUIDE PART ICS-52000 EV_ICS-52000-FX Document Number: DS-000121 Revision: 1.3 TEMP RANGE −40°C to +85°C 1.50 0.125±0.05 PACKAGE 7-Terminal LGA_CAV Flex Evaluation Board Page 18 of 20 QUANTITY 5,000 PACKAGING 13” Tape and Reel ICS-52000 REVISION HISTORY REVISION DATE REVISION DESCRIPTION 8/26/2016 1.0 Initial Version 9/14/2016 1.1 Fixed typo on Table 8 1/4/2017 1.2 Updated boilerplate text to reflect Production status. 4/14/2017 1.3 Updated Table 3, Figure 1, Startup and TDM Data Interface Sections Document Number: DS-000121 Revision: 1.3 Page 19 of 20 ICS-52000 COMPLIANCE DECLARATION DISCLAIMER InvenSense believes the environmental and other compliance information given in this document to be correct but cannot guarantee accuracy or completeness. Conformity documents substantiating the specifications and component characteristics are on file. InvenSense subcontracts manufacturing, and the information contained herein is based on data received from vendors and suppliers, which has not been validated by InvenSense. This information furnished by InvenSense is believed to be accurate and reliable. However, no responsibility is assumed by InvenSense for its use, or for any infringements of patents or other rights of third parties that may result from its use. Specifications are subject to change without notice. InvenSense reserves the right to make changes to this product, including its circuits and software, in order to improve its design and/or performance, without prior notice. InvenSense makes no warranties, neither expressed nor implied, regarding the information and specifications contained in this document. InvenSense assumes no responsibility for any claims or damages arising from information contained in this document, or from the use of products and services detailed therein. This includes, but is not limited to, claims or damages based on the infringement of patents, copyrights, mask work and/or other intellectual property rights. Certain intellectual property owned by InvenSense and described in this document is patent protected. No license is granted by implication or otherwise under any patent or patent rights of InvenSense. This publication supersedes and replaces all information previously supplied. Trademarks that are registered trademarks are the property of their respective companies. InvenSense sensors should not be used or sold in the development, storage, production or utilization of any conventional or mass-destructive weapons or for any other weapons or life threatening applications, as well as in any other life critical applications such as medical equipment, transportation, aerospace and nuclear instruments, undersea equipment, power plant equipment, disaster prevention and crime prevention equipment. ©2016-2017 InvenSense, Inc. All rights reserved. InvenSense, MotionTracking, MotionProcessing, MotionProcessor, MotionFusion, MotionApps, DMP, AAR and the InvenSense logo are trademarks of InvenSense, Inc. Other company and product names may be trademarks of the respective companies with which they are associated. ©2016-2017 InvenSense, Inc. All rights reserved. Document Number: DS-000121 Revision: 1.3 Page 20 of 20
ICS-52000 价格&库存
很抱歉,暂时无法提供与“ICS-52000”相匹配的价格&库存,您可以联系我们找货
