IFL10M-025NB1HRX300
IFL10M-025NB1HRX300
    TDK(东电化)
    RF ABSORBING SHEET IFL FLEXIELD
IFL10M-025NB1HRX300 数据手册
M A G N E T I C S H E E T January 2021 Noise Suppression Sheets Flexield IFL series (2/9) MAGNETIC SHEET Product compatible with RoHS directive Halogen-free Noise Suppression Sheets Flexield Overview of IFL series FEATURES Multiple high permeability materials to choose from based on application Multiple thickness to meet performance requirements High flexibility which allows sheets to easily be formed to desired shape Non conductive film which can be attached directly to circuit components Provide attenuation up to the 1-3 GHz range Available on a roll or in sheet form APPLICATION General EMI attenuation on various types of electronic equipment LED/LCD display address and data lined/traces/cables Stylus pens for improved sensitivity Sensors shielding and immunity Digital audio and video lines STANDARD SHAPE LIST Material name IFL10M IFL12 IFL16 Magnetic layer thickness (mm) 0.025 0.050 0.100 0.200 0.050 0.100 0.200 0.030 0.050 0.100 Roll dimensions Sheet dimensions (mm) 300X200 300X200 300X200  Width (mm) Length (m) 300 100 Non-STD Non-STD 300 100 300 100 Non-STD Non-STD Please contact us for details RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html Halogen-free: Indicates that Cl content is less than 900ppm, Br content is less than 900ppm, and that the total Cl and Br content is less than 1500ppm. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210118 / emc_noise-sheet_ifl_en.fm (3/9) MAGNETIC SHEET IFL series Sheet Type PART NUMBER CONSTRUCTION IFL Series name IFL 10M Material symbol 10M 12 16 050 N Magnetic layer thickness (mm) Top surface layer thickness (mm) 025 030 050 100 200 0.025 0.030 0.050 0.100 0.200 B 300 Double-sided adhesive tape thickness (mm) N No B 0.010 D 0.030 N No P 0.016 R 0.038 R: Release type × Length (mm) 300 200 Width (mm) 300 200 200 Top surface layer Magnetic layer Double-sided adhesive tape Release liner Length Width STANDARD PART NUMBER LIST Material name Sheet dimensions (mm) IFL10M 300X200 IFL12 300X200 IFL16 300X200 Magnetic layer thickness (mm) 0.025 0.050 0.100 0.200 0.050 0.100 0.200 0.030 0.050 0.100 Total thickness (mm)typ. 0.035 0.060 0.110 0.240 0.060 0.110 0.240 0.040 0.060 0.110 Part number IFL10M-025NB300X200 IFL10M-050NB300X200 IFL10M-100NB300X200 IFL10M-200ND300X200 IFL12-050NB300X200 IFL12-100NB300X200 IFL12-200ND300X200 IFL16-030NB300X200 IFL16-050NB300X200 IFL16-100NB300X200 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210118 / emc_noise-sheet_ifl_en.fm (4/9) MAGNETIC SHEET IFL series Roll Type PART NUMBER CONSTRUCTION IFL 10M Material Series name symbol IFL 10M 12 16 025 N Magnetic layer thickness (mm) Top surface layer thickness (mm) 025 030 050 100 200 0.025 0.030 0.050 0.100 0.200 B N No P 0.016 R 0.038 R: Release type 1HR Double-sided adhesive tape thickness (mm) N No B 0.010 D 0.030 × Length (m) 1HR 300 Width (mm) 100 300 300 Top surface layer Magnetic layer Double-sided adhesive tape Release liner Length Width STANDARD PART NUMBER LIST Material name Roll dimensions Width Length (mm) (m) IFL10M 300 100 IFL12 300 100 IFL16 300 100  Magnetic layer thickness (mm) 0.025 0.050 0.100 0.025 0.050 0.100 0.050 0.100 0.050 0.100 0.030 0.050 0.100 0.030 0.050 Total thickness (mm)typ. 0.063 0.088 0.138 0.035 0.060 0.110 0.088 0.138 0.060 0.110 0.068 0.088 0.138 0.040 0.060 Part number IFL10M-025RN1HRX300 IFL10M-050RN1HRX300 IFL10M-100RN1HRX300 IFL10M-025NB1HRX300 IFL10M-050NB1HRX300 IFL10M-100NB1HRX300 IFL12-050RN1HRX300 IFL12-100RN1HRX300 IFL12-050NB1HRX300 IFL12-100NB1HRX300 IFL16-030RN1HRX300 IFL16-050RN1HRX300 IFL16-100RN1HRX300 IFL16-030NB1HRX300 IFL16-050NB1HRX300 Note : Including top surface layer Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210118 / emc_noise-sheet_ifl_en.fm (5/9) MAGNETIC SHEET IFL series MATERIAL CHARACTERISTIC MATERIAL CHARACTERISTIC SPECIFICATION TABLE Recommended specification frequency range Material name IFL10M IFL12 IFL16 10MHz to 3GHz 5MHz to 3GHz 0.5MHz to 1GHz Relative permeability [at 1MHz] [at 13.56MHz] u' u" u' u" 120 180 220 500 (at 1MHz)typ. 1600 1600 1700 (°C) –40 to +85 –40 to +85 –40 to +85 RELATIVE PERMEABILITY 250 IFL16 µ’ 200 Relative permeability IFL12 µ’ 150 IFL10M µ’ 100 IFL16 µ’’ 50 IFL12 µ’’ IFL10M µ’’ 0 1 10 100 Frequency (MHz) 1000 10000 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210118 / emc_noise-sheet_ifl_en.fm (6/9) MAGNETIC SHEET IFL series MATERIAL CHARACTERISTIC SHIELDING EFFECTIVENESS (Up to 100MHz) IFL10M IFL12 0 0 5 Shielding effectiveness (dB) Shielding effectiveness (dB) IFL10M-025 IFL10M-050 IFL10M-100 10 IFL10M-200 15 5 IFL12-050 10 IFL12-100 15 IFL12-200 20 1 10 Frequency (MHz) 100 10 Frequency (MHz) 100 20 1 10 Frequency (MHz) 100 IFL16 Shielding effectiveness (dB) 0 5 IFL16-030 IFL16-050 10 IFL16-100 15 20 1 MEASUREMENT SETUP (Up to 100MHz) 10 0 Noise suppression sheet Coil 2 150 ø10 Network Analyzer Coil 1 2 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210118 / emc_noise-sheet_ifl_en.fm (7/9) MAGNETIC SHEET IFL series MATERIAL CHARACTERISTIC SHIELDING EFFECTIVENESS (100MHz to 6GHz) * Note that there is no continuity with data below 100 MHz. Since the gap between the coils is shortened, the gain is a little increased. IFL10M IFL12  5 10 0 Shielding effectiveness (dB) Shielding effectiveness (dB) 0 IFL10M-025 IFL10M-050 IFL10M-100 15 20 IFL10M-200 25 0.1 1.0 Frequency (GHz) 10.0 1.0 Frequency (GHz) 10.0 5 IFL12-050 10 15 IFL12-100 IFL12-200 20 25 0.1 1.0 Frequency (GHz) 10.0 IFL16 Shielding effectiveness (dB) 0 5 IFL16-030 10 IFL16-050 15 IFL16-100 20 25 0.1 MEASUREMENT SETUP (100MHz to 6GHz) 10 0 Noise suppression sheet Coil 2 150 ø1 Network Analyzer Coil 1 1 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210118 / emc_noise-sheet_ifl_en.fm (8/9) MAGNETIC SHEET IFL series MATERIAL CHARACTERISTIC IFL12 0 Transmission Noise Attenuation (dB) Transmission Noise Attenuation (dB) TRANSMISSION NOISE ATTENUATION IFL10M 10 IFL10M-025 20 IFL10M-050 IFL10M-100 30 IFL10M-200 40 50 0 1 2 3 4 Frequency (GHz) 5 6 5 6 0 IFL12-050 10 20 IFL12-100 30 IFL12-200 40 50 0 1 2 3 4 Frequency (GHz) 5 6 Transmission Noise Attenuation (dB) IFL16 0 10 IFL16-030 20 IFL16-050 30 IFL16-100 40 50 0 1 2 3 4 Frequency (GHz) MEASUREMENT SETUP NOTE : Refers to IEC62333-1,2 (Transmission Attenuation power ratio) Noise suppression sheet Network Analyzer Micro Strip Line (50Ω) Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210118 / emc_noise-sheet_ifl_en.fm (9/9) MAGNETIC SHEET REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (excepting Pharmaceutical Affairs Law classification Class1,2) (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) (9) (10) (11) (12) (13) Public information-processing equipment Military equipment Electric heating apparatus, burning equipment Disaster prevention/crime prevention equipment Safety equipment Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210118 / emc_noise-sheet_ifl_en.fm
IFL10M-025NB1HRX300 价格&库存
很抱歉,暂时无法提供与“IFL10M-025NB1HRX300”相匹配的价格&库存,您可以联系我们找货
