M A G N E T I C
S H E E T
January 2021
Noise Suppression Sheets
Flexield
IFL series
(2/9)
MAGNETIC SHEET
Product compatible with RoHS directive
Halogen-free
Flexield
Overview of IFL series
FEATURES
Multiple high permeability materials to choose from based on application
Multiple thickness to meet performance requirements
High flexibility which allows sheets to easily be formed to desired shape
Non conductive film which can be attached directly to circuit components
Provide attenuation up to the 1-3 GHz range
Available on a roll or in sheet form
APPLICATION
General EMI attenuation on various types of electronic equipment
LED/LCD display address and data lined/traces/cables
Stylus pens for improved sensitivity
Sensors shielding and immunity
Digital audio and video lines
STANDARD SHAPE LIST
Material
name
IFL10M
IFL12
IFL16
Magnetic layer
thickness
(mm)
0.025
0.050
0.100
0.200
0.050
0.100
0.200
0.030
0.050
0.100
Roll dimensions
Sheet
dimensions
(mm)
300X200
300X200
300X200
Width
(mm)
Length
(m)
300
100
Non-STD
Non-STD
300
100
300
100
Non-STD
Non-STD
Please contact us for details
RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html
Halogen-free: Indicates that Cl content is less than 900ppm, Br content is less than 900ppm, and that the total Cl and Br content is less than 1500ppm.
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
20210118 / emc_noise-sheet_ifl_en.fm
(3/9)
MAGNETIC SHEET
IFL series Sheet Type
PART NUMBER CONSTRUCTION
IFL
Series name
IFL
10M Material
symbol
10M
12
16
050
N
Magnetic layer
thickness
(mm)
Top surface layer
thickness
(mm)
025
030
050
100
200
0.025
0.030
0.050
0.100
0.200
B
300
Double-sided
adhesive tape
thickness
(mm)
N
No
B
0.010
D
0.030
N
No
P
0.016
R
0.038
R: Release type
Length
(mm)
300
200
Width
(mm)
300
200
200
Top surface layer
Magnetic layer
Double-sided adhesive tape
Release liner
Length
Width
STANDARD PART NUMBER LIST
Material
name
Sheet
dimensions
(mm)
IFL10M
300X200
IFL12
300X200
IFL16
300X200
Magnetic layer
thickness
(mm)
0.025
0.050
0.100
0.200
0.050
0.100
0.200
0.030
0.050
0.100
Total
thickness
(mm)typ.
0.035
0.060
0.110
0.240
0.060
0.110
0.240
0.040
0.060
0.110
Part number
IFL10M-025NB300X200
IFL10M-050NB300X200
IFL10M-100NB300X200
IFL10M-200ND300X200
IFL12-050NB300X200
IFL12-100NB300X200
IFL12-200ND300X200
IFL16-030NB300X200
IFL16-050NB300X200
IFL16-100NB300X200
(4/9)
MAGNETIC SHEET
IFL series Roll Type
IFL
10M Material
Series name
symbol
IFL
10M
12
16
025
N
Magnetic layer
thickness
(mm)
Top surface layer
thickness
(mm)
025
030
050
100
200
0.025
0.030
0.050
0.100
0.200
B
N
No
P
0.016
R
0.038
R: Release type
1HR
Double-sided
adhesive tape
thickness
(mm)
N
No
B
0.010
D
0.030
Length
(m)
1HR
300
Width
(mm)
100
300
300
Top surface layer
Magnetic layer
Release liner
Length
Width
Material
name
Roll dimensions
Width
Length
(mm)
(m)
IFL10M
300
100
IFL12
300
100
IFL16
300
100
Magnetic layer
thickness
(mm)
0.025
0.050
0.100
0.025
0.050
0.100
0.050
0.100
0.050
0.100
0.030
0.050
0.100
0.030
0.050
Total
thickness
(mm)typ.
0.063
0.088
0.138
0.035
0.060
0.110
0.088
0.138
0.060
0.110
0.068
0.088
0.138
0.040
0.060
Part number
IFL10M-025RN1HRX300
IFL10M-050RN1HRX300
IFL10M-100RN1HRX300
IFL10M-025NB1HRX300
IFL10M-050NB1HRX300
IFL10M-100NB1HRX300
IFL12-050RN1HRX300
IFL12-100RN1HRX300
IFL12-050NB1HRX300
IFL12-100NB1HRX300
IFL16-030RN1HRX300
IFL16-050RN1HRX300
IFL16-100RN1HRX300
IFL16-030NB1HRX300
IFL16-050NB1HRX300
Note : Including top surface layer
(5/9)
MAGNETIC SHEET
IFL series
MATERIAL CHARACTERISTIC
MATERIAL CHARACTERISTIC SPECIFICATION TABLE
Recommended
specification
frequency range
Material
name
IFL10M
IFL12
IFL16
10MHz to 3GHz
5MHz to 3GHz
0.5MHz to 1GHz
Relative permeability
[at 1MHz]
[at 13.56MHz]
u'
u"
u'
u"
120
180
220
500
(at 1MHz)typ.
1600
1600
1700
(°C)
–40 to +85
–40 to +85
–40 to +85
RELATIVE PERMEABILITY
250
IFL16 µ’
200
IFL12 µ’
150
IFL10M µ’
100
IFL16 µ’’
50
IFL12 µ’’
IFL10M µ’’
10
100
Frequency (MHz)
1000
10000
(6/9)
MAGNETIC SHEET
IFL series
SHIELDING EFFECTIVENESS (Up to 100MHz)
IFL10M
IFL12
Shielding effectiveness (dB)
IFL10M-025
IFL10M-050
IFL10M-100
10
IFL10M-200
15
5
IFL12-050
10
IFL12-100
15
IFL12-200
10
Frequency (MHz)
100
10
Frequency (MHz)
100
10
Frequency (MHz)
100
IFL16
IFL16-030
IFL16-050
10
IFL16-100
15
MEASUREMENT SETUP (Up to 100MHz)
10
Noise suppression sheet
Coil 2
150
ø10
Network Analyzer
Coil 1
2
(7/9)
MAGNETIC SHEET
IFL series
SHIELDING EFFECTIVENESS (100MHz to 6GHz) *
Note that there is no continuity with data below 100 MHz. Since the gap between the coils is shortened, the gain is a little increased.
IFL10M
IFL12
5
10
IFL10M-025
IFL10M-050
IFL10M-100
15
IFL10M-200
25
0.1
1.0
Frequency (GHz)
10.0
1.0
Frequency (GHz)
10.0
5
IFL12-050
10
15
IFL12-100
IFL12-200
0.1
1.0
Frequency (GHz)
10.0
IFL16
IFL16-030
10
IFL16-050
15
IFL16-100
0.1
MEASUREMENT SETUP (100MHz to 6GHz)
10
Coil 2
150
ø1
Network Analyzer
Coil 1
1
(8/9)
MAGNETIC SHEET
IFL series
IFL12
Transmission Noise Attenuation (dB)
TRANSMISSION NOISE ATTENUATION
IFL10M
10
IFL10M-025
IFL10M-050
IFL10M-100
30
IFL10M-200
40
50
2
3
4
Frequency (GHz)
5
6
5
6
IFL12-050
10
IFL12-100
30
IFL12-200
40
50
2
3
4
Frequency (GHz)
5
6
IFL16
IFL16-030
IFL16-050
30
IFL16-100
40
50
2
3
4
Frequency (GHz)
MEASUREMENT SETUP
NOTE : Refers to IEC62333-1,2 (Transmission Attenuation power ratio)
Network Analyzer
Micro Strip Line (50Ω)
(9/9)
MAGNETIC SHEET
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment,
home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality
require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person
or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set
forth in the each catalog, please contact us.
(1) Aerospace/aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment (excepting Pharmaceutical Affairs Law
classification Class1,2)
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8)
(9)
(10)
(11)
(12)
(13)
Public information-processing equipment
Military equipment
Electric heating apparatus, burning equipment
Disaster prevention/crime prevention equipment
Safety equipment
Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing
protection circuit/device or providing backup circuits in your equipment.
很抱歉,暂时无法提供与“IFL12-050NB300X200”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+81.40000
- 5+64.90000
- 10+54.01000
- 国内价格
- 15+61.26511
- 40+58.78646
- 200+56.47708
- 450+54.25233
- 1300+52.03968
- 国内价格
- 1+74.35800
- 10+67.56480
- 40+63.42840
- 100+59.95080
