IIM-42652 Datasheet
High-performance 6-Axis SmartIndustrial™ MotionTracking
MEMS Device for Industrial Applications
GENERAL DESCRIPTION
APPLICATIONS
The IIM-42652 is a 6-axis SmartIndustrial™
MotionTracking device that supports an extended
operating temperature range.
The IIM-42652 combines a 3-axis gyroscope, and a
3-axis accelerometer in a small
2.5 mm x 3 mm x 0.91 mm (14-pin LGA) package. It
also features a 2 KB FIFO that can lower the traffic
on the serial bus interface and reduce power
consumption by allowing the system processor to
burst read sensor data and then go into a low-power
mode.
IIM-42652 supports highly accurate external clock
input to reduce system level sensitivity error, improve
orientation measurement from gyroscope data and
to reduce ODR sensitivity to temperature and device
to device variation.
The host interface can be configured to support I3CSM
slave, I2C slave, or SPI slave modes. The I3CSM
interface supports speeds up to 12.5 MHz (data rates
up to 12.5 Mbps in SDR mode, 25 Mbps in DDR
mode), the I2C interface supports speeds up to 1 MHz,
and the SPI interface supports speeds up to 24 MHz.
The device features an operating voltage range from
3.6V down to 1.71V.
ORDERING INFORMATION
PART NUMBER
IIM-42652†
TEMPERATURE
PACKAGE
−40°C to +105°C
14-pin LGA
Navigation
Orientation measurement
Tilt sensing
Platform stabilization
Robotics
FEATURES
Digital-output X-, Y-, and Z-axis angular rate
sensors (gyroscopes) with programmable
full-scale range of ±15.625, ±31.25, ±62.5,
±125, ±250, ±500, ±1000, and ±2000
degrees/sec
accelerometer with programmable fullscale range of ±2g, ±4g, ±8g and ±16g
User-programmable interrupts
I3CSM / I2C / SPI slave host interface
Digital-output temperature sensor
Small and thin package:
20,000 g shock tolerant
MEMS structure hermetically sealed and
bonded at wafer level
RoHS and Green compliant
TYPICAL OPERATING CIRCUIT
AP_SDO
RESV
RESV
INT1 / INT
14
AP_CS
AP_SCLK
AP_SDIO /
AP_SDI
†Denotes RoHS and Green-compliant package
13
12
11
1
2
10
ICM-42605
IIM-42652
3
4
9
8
5
6
RESV
RESV
INT2 / FSYNC / CLKIN
VDD
7
RESV
GND
VDDIO
C1, 0.1 µF
1.71 – 3.6VDC
C3, 10 nF
Application Schematic (SPI Interface to Host)
InvenSense, Inc. reserves the right to change
specifications and information herein without
notice unless the product is in mass
production and the datasheet has been
designated by InvenSense in writing as subject
to a specified Product / Process Change
Notification Method regulation.
InvenSense, a TDK Group Company
1745 Technology Drive, San Jose, CA 95110 U.S.A
+1(408) 988–7339
invensense.tdk.com
Document Number: DS-000401
Revision: 1.2
Release Date: 10/01/2021
1.71 – 3.6VDC
C2, 2.2 µF
IIM-42652
TABLE OF CONTENTS
General Description ............................................................................................................................................. 1
Ordering Information .......................................................................................................................................... 1
Applications ......................................................................................................................................................... 1
Features ............................................................................................................................................................... 1
Typical Operating Circuit ..................................................................................................................................... 1
1
Introduction .......................................................................................................................................................... 9
Purpose and Scope ................................................................................................................................... 9
Product Overview ..................................................................................................................................... 9
Applications .............................................................................................................................................. 9
2
Features .............................................................................................................................................................. 10
Gyroscope Features ................................................................................................................................ 10
Accelerometer Features ......................................................................................................................... 10
Motion Features ..................................................................................................................................... 10
Additional Features................................................................................................................................. 10
3
Electrical Characteristics..................................................................................................................................... 11
Gyroscope Specifications ........................................................................................................................ 11
Accelerometer Specifications ................................................................................................................. 12
Electrical Specifications .......................................................................................................................... 13
I2C Timing Characterization .................................................................................................................... 15
SPI Timing Characterization – 4-Wire SPI Mode ..................................................................................... 16
SPI Timing Characterization – 3-Wire SPI Mode ..................................................................................... 17
RTC (CLKIN) Timing Characterization ...................................................................................................... 18
Absolute Maximum Ratings .................................................................................................................... 19
4
Applications Information .................................................................................................................................... 20
Pin Out Diagram and Signal Description ................................................................................................. 20
Typical Operating Circuit......................................................................................................................... 21
Bill of Materials for External Components .............................................................................................. 22
System Block Diagram ............................................................................................................................ 22
Overview ................................................................................................................................................. 23
Three-Axis MEMS Gyroscope with 16-bit ADCs and Signal Conditioning ............................................... 23
Three-Axis MEMS Accelerometer with 16-bit ADCs and Signal Conditioning ........................................ 23
I3CSM, I2C, and SPI Host Interface ............................................................................................................ 23
Self-Test .................................................................................................................................................. 23
Clocking .............................................................................................................................................. 24
Sensor Data Registers ......................................................................................................................... 24
Interrupts............................................................................................................................................ 24
Revision: 1.2
Page 2 of 119
IIM-42652
Digital-Output Temperature Sensor ................................................................................................... 24
Bias and LDOs ..................................................................................................................................... 25
Charge Pump ...................................................................................................................................... 25
Standard Power Modes ...................................................................................................................... 25
5
Signal Path .......................................................................................................................................................... 26
Summary of Parameters Used to Configure the Signal Path .................................................................. 26
Notch Filter ............................................................................................................................................. 26
Anti-Alias Filter ....................................................................................................................................... 28
User Programmable Offset ..................................................................................................................... 30
UI Filter Block .......................................................................................................................................... 30
ODR And FSR Selection ........................................................................................................................... 36
6
FIFO..................................................................................................................................................................... 38
Packet Structure ..................................................................................................................................... 38
FIFO Header ............................................................................................................................................ 40
Maximum FIFO Storage .......................................................................................................................... 41
FIFO Configuration Registers .................................................................................................................. 41
7
Programmable Interrupts ................................................................................................................................... 43
8
APEX Motion Functions ...................................................................................................................................... 44
APEX ODR Support .................................................................................................................................. 44
DMP Power Save Mode .......................................................................................................................... 45
Pedometer Programming ....................................................................................................................... 45
Tilt Detection Programming.................................................................................................................... 46
Freefall Detection Programming............................................................................................................. 47
Tap Detection Programming ................................................................................................................... 48
Wake on Motion Programming .............................................................................................................. 48
Significant Motion Detection Programming ........................................................................................... 49
9
Digital Interface .................................................................................................................................................. 51
I3CSM, I2C, and SPI Serial Interfaces ......................................................................................................... 51
I3CSM Interface ........................................................................................................................................ 51
I2C Interface ............................................................................................................................................ 51
I2C Communications Protocol ................................................................................................................. 51
I2C Terms ................................................................................................................................................. 54
SPI Interface ............................................................................................................................................ 54
10
Assembly ............................................................................................................................................................ 56
Orientation of Axes ............................................................................................................................ 56
Package Dimensions ........................................................................................................................... 57
11
Part Number Package Marking ........................................................................................................................... 59
Revision: 1.2
Page 3 of 119
IIM-42652
12
Use Notes ........................................................................................................................................................... 60
Accelerometer Mode Transitions ....................................................................................................... 60
Accelerometer Low Power (LP) Mode Averaging Filter Setting ......................................................... 60
Settings for I2C, I3CSM, and SPI Operation........................................................................................... 60
Notch Filter and Anti-Alias Filter Operation ....................................................................................... 60
external clock input effect on odr ...................................................................................................... 60
INT_ASYNC_RESET Configuration ....................................................................................................... 61
FIFO Timestamp Interval Scaling ........................................................................................................ 61
Supplementary Information for FIFO_HOLD_LAST_DATA_EN ........................................................... 61
Register Values Modification.............................................................................................................. 63
13
Register Map ...................................................................................................................................................... 64
User Bank 0 Register Map .................................................................................................................. 64
User Bank 1 Register Map .................................................................................................................. 65
User Bank 2 Register Map .................................................................................................................. 66
User Bank 3 Register Map .................................................................................................................. 66
User Bank 4 Register Map .................................................................................................................. 66
Register Values Modification.............................................................................................................. 67
14
User Bank 0 Register Map – Descriptions........................................................................................................... 68
DEVICE_CONFIG ................................................................................................................................. 68
DRIVE_CONFIG ................................................................................................................................... 68
INT_CONFIG........................................................................................................................................ 69
FIFO_CONFIG ...................................................................................................................................... 69
TEMP_DATA1 ..................................................................................................................................... 69
TEMP_DATA0 ..................................................................................................................................... 70
ACCEL_DATA_X1................................................................................................................................. 70
ACCEL_DATA_X0................................................................................................................................. 70
ACCEL_DATA_Y1 ................................................................................................................................. 70
ACCEL_DATA_Y0 ................................................................................................................................. 71
ACCEL_DATA_Z1 ................................................................................................................................. 71
ACCEL_DATA_Z0 ................................................................................................................................. 71
GYRO_DATA_X1.................................................................................................................................. 71
GYRO_DATA_X0.................................................................................................................................. 71
GYRO_DATA_Y1 .................................................................................................................................. 72
GYRO_DATA_Y0 .................................................................................................................................. 72
GYRO_DATA_Z1 .................................................................................................................................. 72
GYRO_DATA_Z0 .................................................................................................................................. 72
TMST_FSYNCH .................................................................................................................................... 72
Revision: 1.2
Page 4 of 119
IIM-42652
TMST_FSYNCL ..................................................................................................................................... 73
INT_STATUS ........................................................................................................................................ 73
FIFO_COUNTH .................................................................................................................................... 73
FIFO_COUNTL ..................................................................................................................................... 74
FIFO_DATA.......................................................................................................................................... 74
APEX_DATA0 ...................................................................................................................................... 74
APEX_DATA1 ...................................................................................................................................... 74
APEX_DATA2 ...................................................................................................................................... 75
APEX_DATA3 ...................................................................................................................................... 75
APEX_DATA4 ...................................................................................................................................... 76
APEX_DATA5 ...................................................................................................................................... 76
INT_STATUS2 ...................................................................................................................................... 77
INT_STATUS3 ...................................................................................................................................... 77
SIGNAL_PATH_RESET ......................................................................................................................... 77
INTF_CONFIG0 .................................................................................................................................... 78
INTF_CONFIG1 .................................................................................................................................... 79
PWR_MGMT0 ..................................................................................................................................... 80
GYRO_CONFIG0 .................................................................................................................................. 81
ACCEL_CONFIG0 ................................................................................................................................. 82
GYRO_CONFIG1 .................................................................................................................................. 83
GYRO_ACCEL_CONFIG0 ...................................................................................................................... 84
ACCEL_CONFIG1 ................................................................................................................................. 85
TMST_CONFIG .................................................................................................................................... 85
APEX_CONFIG0 ................................................................................................................................... 86
SMD_CONFIG ..................................................................................................................................... 86
FIFO_CONFIG1 .................................................................................................................................... 87
FIFO_CONFIG2 .................................................................................................................................... 87
FIFO_CONFIG3 .................................................................................................................................... 87
FSYNC_CONFIG ................................................................................................................................... 88
INT_CONFIG0...................................................................................................................................... 88
INT_CONFIG1...................................................................................................................................... 89
INT_SOURCE0 ..................................................................................................................................... 89
INT_SOURCE1 ..................................................................................................................................... 90
INT_SOURCE3 ..................................................................................................................................... 90
INT_SOURCE4 ..................................................................................................................................... 91
FIFO_LOST_PKT0 ................................................................................................................................ 91
FIFO_LOST_PKT1 ................................................................................................................................ 91
Revision: 1.2
Page 5 of 119
IIM-42652
SELF_TEST_CONFIG ............................................................................................................................ 92
WHO_AM_I ........................................................................................................................................ 92
REG_BANK_SEL ................................................................................................................................... 92
15
User Bank 1 Register Map – Descriptions........................................................................................................... 93
SENSOR_CONFIG0 .............................................................................................................................. 93
GYRO_CONFIG_STATIC2 ..................................................................................................................... 93
GYRO_CONFIG_STATIC3 ..................................................................................................................... 93
GYRO_CONFIG_STATIC4 ..................................................................................................................... 94
GYRO_CONFIG_STATIC5 ..................................................................................................................... 94
GYRO_CONFIG_STATIC6 ..................................................................................................................... 94
GYRO_CONFIG_STATIC7 ..................................................................................................................... 94
GYRO_CONFIG_STATIC8 ..................................................................................................................... 95
GYRO_CONFIG_STATIC9 ..................................................................................................................... 95
GYRO_CONFIG_STATIC10 ................................................................................................................... 95
XG_ST_DATA....................................................................................................................................... 96
YG_ST_DATA....................................................................................................................................... 96
ZG_ST_DATA ....................................................................................................................................... 96
TMSTVAL0 .......................................................................................................................................... 96
TMSTVAL1 .......................................................................................................................................... 97
TMSTVAL2 .......................................................................................................................................... 97
INTF_CONFIG4 .................................................................................................................................... 97
INTF_CONFIG5 .................................................................................................................................... 98
INTF_CONFIG6 .................................................................................................................................... 98
16
User Bank 2 Register Map – Descriptions........................................................................................................... 99
ACCEL_CONFIG_STATIC2 .................................................................................................................... 99
ACCEL_CONFIG_STATIC3 .................................................................................................................... 99
ACCEL_CONFIG_STATIC4 .................................................................................................................... 99
XA_ST_DATA ....................................................................................................................................... 99
YA_ST_DATA ..................................................................................................................................... 100
ZA_ST_DATA ..................................................................................................................................... 100
17
User Bank 3 Register Map – Descriptions......................................................................................................... 101
PU_PD_CONFIG1 .............................................................................................................................. 101
PU_PD_CONFIG2 .............................................................................................................................. 102
18
User Bank 4 Register Map – Descriptions......................................................................................................... 103
FDR_CONFIG ..................................................................................................................................... 103
APEX_CONFIG1 ................................................................................................................................. 103
APEX_CONFIG2 ................................................................................................................................. 104
Revision: 1.2
Page 6 of 119
IIM-42652
APEX_CONFIG3 ................................................................................................................................. 105
APEX_CONFIG4 ................................................................................................................................. 106
APEX_CONFIG5 ................................................................................................................................. 107
APEX_CONFIG6 ................................................................................................................................. 108
APEX_CONFIG7 ................................................................................................................................. 109
APEX_CONFIG8 ................................................................................................................................. 109
APEX_CONFIG9 ................................................................................................................................. 109
APEX_CONFIG10 ............................................................................................................................... 110
ACCEL_WOM_X_THR........................................................................................................................ 110
ACCEL_WOM_Y_THR ........................................................................................................................ 111
ACCEL_WOM_Z_THR ........................................................................................................................ 111
INT_SOURCE6 ................................................................................................................................... 111
INT_SOURCE7 ................................................................................................................................... 112
INT_SOURCE8 ................................................................................................................................... 112
INT_SOURCE9 ................................................................................................................................... 113
INT_SOURCE10 ................................................................................................................................. 113
OFFSET_USER0 ................................................................................................................................. 114
OFFSET_USER1 ................................................................................................................................. 114
OFFSET_USER2 ................................................................................................................................. 114
OFFSET_USER3 ................................................................................................................................. 114
OFFSET_USER4 ................................................................................................................................. 115
OFFSET_USER5 ................................................................................................................................. 115
OFFSET_USER6 ................................................................................................................................. 115
OFFSET_USER7 ................................................................................................................................. 115
OFFSET_USER8 ................................................................................................................................. 116
19
Reference ......................................................................................................................................................... 117
Revision History ................................................................................................................................................ 118
Revision: 1.2
Page 7 of 119
IIM-42652
Table of Figures
Figure 1. I2C Bus Timing Diagram ...................................................................................................................................... 15
Figure 2. 4-Wire SPI Bus Timing Diagram ......................................................................................................................... 16
Figure 3. 3-Wire SPI Bus Timing Diagram ......................................................................................................................... 17
Figure 4. RTC Timing Diagram........................................................................................................................................... 18
Figure 5. Pin Out Diagram for IIM-42652 2.5 mm x 3.0 mm x 0.91 mm LGA ................................................................... 21
Figure 6. IIM-42652 Application Schematic (I3CSM / I2C Interface to Host) ...................................................................... 21
Figure 7. IIM-42652 Application Schematic (SPI Interface to Host).................................................................................. 22
Figure 8. IIM-42652 System Block Diagram ...................................................................................................................... 22
Figure 9. IIM-42652 Signal Path ........................................................................................................................................ 26
Figure 10. FIFO Packet Structure ...................................................................................................................................... 38
Figure 11. Maximum FIFO Storage ................................................................................................................................... 41
Figure 12. START and STOP Conditions ............................................................................................................................ 52
Figure 13. Acknowledge on the I2C Bus ............................................................................................................................ 52
Figure 14. Complete I2C Data Transfer ............................................................................................................................. 53
Figure 15. Typical SPI Master/Slave Configuration ........................................................................................................... 55
Figure 16. Orientation of Axes of Sensitivity and Polarity of Rotation ............................................................................. 56
Figure 17. Package Dimensions ........................................................................................................................................ 57
Figure 18. Part Number Package Marking ........................................................................................................................ 59
Table of Tables
Table 1. Gyroscope Specifications .................................................................................................................................... 11
Table 2. Accelerometer Specifications............................................................................................................................. 12
Table 3. D.C. Electrical Characteristics .............................................................................................................................. 13
Table 4. A.C. Electrical Characteristics .............................................................................................................................. 14
Table 5. I2C Timing Characteristics.................................................................................................................................... 15
Table 6. 4-Wire SPI Timing Characteristics (24-MHz Operation) ...................................................................................... 16
Table 7. 3-Wire SPI Timing Characteristics (24-MHz Operation) ...................................................................................... 17
Table 8. RTC Timing Characteristics .................................................................................................................................. 18
Table 9. Absolute Maximum Ratings ................................................................................................................................ 19
Table 10. Signal Descriptions ............................................................................................................................................ 20
Table 11. Bill of Materials ................................................................................................................................................. 22
Table 12. Standard Power Modes for IIM-42652 ............................................................................................................. 25
Table 13. Signal path parameters ..................................................................................................................................... 26
Table 14. I2C Terms ........................................................................................................................................................... 54
Revision: 1.2
Page 8 of 119
IIM-42652
1 INTRODUCTION
PURPOSE AND SCOPE
This document is a product specification, providing a description, specifications, and design related information on the
IIM-42652 SmartIndustrial™ device. The device is housed in a small 2.5 mm x 3 mm x 0.91 mm 14-pin LGA package.
PRODUCT OVERVIEW
The IIM-42652 is a 6-axis MotionTracking device that combines a 3-axis gyroscope, and a 3-axis accelerometer in a
small 2.5 mm x 3 mm x 0.91 mm (14-pin LGA) package. It also features a 2 KB FIFO that can lower the traffic on the
serial bus interface and reduce power consumption by allowing the system processor to burst read sensor data and
then go into a low-power mode. IIM-42652, with its 6-axis integration, enables manufacturers to eliminate the costly
and complex selection, qualification, and system level integration of discrete devices, guaranteeing optimal motion
performance for customers.
The gyroscope supports eight programmable full-scale range settings from ±15.625 dps to ±2000 dps, and the
accelerometer supports four programmable full-scale range settings from ±2g to ±16g. IIM-42652 also supports
external clock input for highly accurate 31 kHz to 50 kHz clocks to reduce system level sensitivity error and reduce
ODR sensitivity to temperature and device to device variation.
Other industry-leading features include on-chip 16-bit ADCs, programmable digital filters, an embedded temperature
sensor, and programmable interrupts. The device features I3CSM, I2C, and SPI serial interfaces; a VDD operating range
of 1.71V to 3.6V; and a separate VDDIO operating range of 1.71V to 3.6V.
The host interface can be configured to support I3CSM slave, I2C slave, or SPI slave modes. The I3CSM interface supports
speeds up to 12.5 MHz (data rates up to 12.5 Mbps in SDR mode, 25 Mbps in DDR mode), the I2C interface supports
speeds up to 1 MHz, and the SPI interface supports speeds up to 24 MHz.
IIM-42652 also supports external clock input for highly accurate 31 kHz to 50 kHz clocks to reduce system level
sensitivity error, improve orientation measurement from gyroscope data, and reduce ODR sensitivity to temperature
By leveraging its patented and volume-proven CMOS-MEMS fabrication platform, which integrates MEMS wafers with
companion CMOS electronics through wafer-level bonding, InvenSense has driven the package size down to a
footprint and thickness of 2.5 mm x 3 mm x 0.91 mm (14-pin LGA), to provide a very small yet high performance low
cost package. The device provides high robustness by supporting 20,000g shock reliability.
APPLICATIONS
Navigation
Tilt sensing
Robotics
Revision: 1.2
Page 9 of 119
IIM-42652
2 FEATURES
GYROSCOPE FEATURES
The triple-axis MEMS gyroscope in the IIM-42652 includes a wide range of features:
Digital-output X-, Y-, and Z-axis angular rate sensors (gyroscopes) with programmable full-scale range of
±15.625, ±31.25, ±62.5, ±125, ±250, ±500, ±1000, and ±2000 degrees/sec
Low Noise (LN) power mode support
Digitally-programmable low-pass filters
Factory calibrated sensitivity scale factor
Self-test
ACCELEROMETER FEATURES
The triple-axis MEMS accelerometer in IIM-42652 includes a wide range of features:
Digital-output X-, Y-, and Z-axis accelerometer with programmable full-scale range of ±2g, ±4g, ±8g and ±16g
Low Noise (LN) and Low Power (LP) power modes support
Wake-on-motion interrupt for low power operation of applications processor
Self-test
MOTION FEATURES
IIM-42652 includes the following motion features, also known as APEX (Advanced Pedometer and Event Detection –
neXt gen)
Pedometer: tracks step count, also issues step detect interrupt
Tilt Detection: issues an interrupt when the tilt angle exceeds 35° for more than a programmable time
Tap Detection: issues an interrupt when a tap is detected, along with the tap count
Freefall Detection: triggers an interrupt when device freefall is detected and outputs freefall duration
Wake on Motion: detects motion when accelerometer data exceeds a programmable threshold
Significant Motion Detection: detects significant motion if wake on motion events are detected during a
programmable time window
ADDITIONAL FEATURES
IIM-42652 includes the following additional features:
External clock input supports highly accurate clock input from 31 kHz to 50 kHz, helps to reduce system level
sensitivity error
2 KB FIFO buffer enables the applications processor to read the data in bursts
User-programmable digital filters for gyroscope, accelerometer, and temperature sensor
User configurable internal pull-up/pull-downs included on I/O interfaces to reduce system costs associated
with external pull-ups/pull-downs
12.5 MHz I3CSM (data rates up to 12.5 Mbps in SDR mode, 25Mbps in DDR mode) / 1 MHz I2C / 24 MHz SPI slave
host interface
Smallest and thinnest LGA package for Industrial IoT applications: 2.5 mm x 3 mm x 0.91 mm (14-pin LGA)
20,000g shock tolerant
MEMS structure hermetically sealed and bonded at wafer level
Revision: 1.2
Page 10 of 119
IIM-42652
3 ELECTRICAL CHARACTERISTICS
GYROSCOPE SPECIFICATIONS
Typical Operating Circuit of section 4.2, VDD = 1.8V, VDDIO = 1.8V, TA=25°C, unless otherwise noted.
PARAMETER
CONDITIONS
MIN
TYP
MAX
UNITS
NOTES
±2000
º/s
±1000
º/s
2
2
GYROSCOPE SENSITIVITY
GYRO_FS_SEL=0
GYRO_FS_SEL =1
Full-Scale Range
GYRO_FS_SEL =2
±500
º/s
2
GYRO_FS_SEL =3
±250
º/s
2
GYRO_FS_SEL =4
±125
º/s
2
GYRO_FS_SEL =5
±62.5
º/s
2
GYRO_FS_SEL =6
±31.25
º/s
2
GYRO_FS_SEL =7
±15.625
º/s
2
16
bits
2,6
GYRO_FS_SEL=0
GYRO_FS_SEL =1
16.4
LSB/(º/s)
2
32.8
LSB/(º/s)
2
GYRO_FS_SEL =2
65.5
LSB/(º/s)
2
GYRO_FS_SEL =3
131
LSB/(º/s)
2
GYRO_FS_SEL =4
262
LSB/(º/s)
2
GYRO_FS_SEL =5
524.3
LSB/(º/s)
2
GYRO_FS_SEL =6
1048.6
LSB/(º/s)
2
GYRO_FS_SEL =7
2097.2
LSB/(º/s)
2
Gyroscope ADC Word Length
Sensitivity Scale Factor
Sensitivity Scale Factor Initial Tolerance
25°C
-1
±0.5
+1
1, 5
Sensitivity Scale Factor Variation Over
Temperature
-40°C to +105°C
-0.02
±0.005
+0.02
%/ºC
3, 5
Nonlinearity
Best fit straight line; 25°C
-0.2
±0.1
+0.2
3, 5
-3.0
±1.25
+3.0
3, 5
Cross-Axis Sensitivity
ZERO-RATE OUTPUT (ZRO)
Initial ZRO Tolerance
Board-level, 25°C
ZRO Variation vs. Temperature
-40°C to +105°C
-3
±0.5
+3
º/s
3, 5
-0.025
±0.02
+0.025
º/s/ºC
3, 5
Rate Noise Spectral Density
@ 10 Hz
Total RMS Noise
0.0038
0.0052
º/s /√Hz
1, 5
Bandwidth = 100 Hz
0.038
0.052
º/s-rms
4, 5
27
29
KHz
1
500
Hz
2
3979
45
32000
Hz
ms
Hz
2
3, 5
2
OTHER PARAMETERS
Gyroscope Mechanical Frequencies
Low Pass Filter Response
Gyroscope Start-Up Time
Output Data Rate
25
ODR < 1 kHz
5
ODR ≥ 1 kHz
Time from gyro enable to gyro drive ready
42
Notes:
1.
2.
3.
4.
5.
6.
Tested in production.
Guaranteed by design.
Derived from validation or characterization of parts, not tested in production.
Calculated from Rate Noise Spectral Density.
MIN/MAX or MAX specs are derived from characterization data based 3σ calculation.
20-bits data format supported in FIFO, see section 6.1.
Revision: 1.2
Page 11 of 119
12.5
30
IIM-42652
ACCELEROMETER SPECIFICATIONS
PARAMETER
CONDITIONS
MIN
TYP
MAX
UNITS
NOTES
ACCELEROMETER SENSITIVITY
Full-Scale Range
ADC Word Length
ACCEL_FS_SEL =0
±16
g
ACCEL_FS_SEL =1
±8
g
2
2
ACCEL_FS_SEL =2
±4
g
2
ACCEL_FS_SEL =3
±2
g
2
Output in two’s complement format
16
bits
2, 6
ACCEL_FS_SEL =0
2,048
LSB/g
2
ACCEL_FS_SEL =1
4,096
LSB/g
2
ACCEL_FS_SEL =2
8,192
LSB/g
2
ACCEL_FS_SEL =3
Component-level
16,384
LSB/g
2
Sensitivity Change vs. Temperature
-40°C to +105°C
Nonlinearity
Best Fit Straight Line, ±2g
-1
±0.5
+1
1, 5
-0.025
±0.005
+0.025
%/ºC
3, 5
-0.2
±0.1
+0.2
3, 5
-2.0
±1
+2.0
3, 5
ZERO-G OUTPUT
Initial Tolerance
Board-level, all axes
Zero-G Level Change vs. Temperature
-40°C to +105°C
-30
±20
+30
mg
3, 5
-0.40
±0.15
+0.40
mg/ºC
3, 5
70
100
µg/√Hz
1, 5
0.70
1.00
mg-rms
4, 5
10
OTHER PARAMETERS
Power Spectral Density
@ 10 Hz
RMS Noise
Bandwidth = 100 Hz
Low-Pass Filter Response
Accelerometer Startup Time
Output Data Rate
ODR < 1 kHz
5
500
Hz
2
ODR ≥ 1 kHz
From sleep mode to valid data
42
3979
Hz
ms
Hz
2
3, 5
2
12.5
Notes:
1.
2.
3.
4.
5.
6.
Calculated from Power Spectral Density.
Revision: 1.2
Page 12 of 119
IIM-42652
ELECTRICAL SPECIFICATIONS
PARAMETER
CONDITIONS
MIN
TYP
MAX
UNITS
NOTES
VDD
1.71
1.8
3.6
V
1
VDDIO
1.71
1.8
3.6
V
1
6-Axis Gyroscope + Accelerometer
0.88
0.95
mA
2, 3
3-Axis Accelerometer
0.28
0.35
mA
2, 3
3-Axis Gyroscope
0.73
0.85
mA
2, 3
Full-Chip Sleep Mode
At 25ºC
7.5
10
µA
2, 3
Specified Temperature Range
TEMPERATURE RANGE
Performance parameters are not applicable
beyond Specified Temperature Range
+105
°C
2
SUPPLY VOLTAGES
SUPPLY CURRENTS
Low-Noise Mode
-40
Notes:
1.
2.
3.
Revision: 1.2
Page 13 of 119
IIM-42652
PARAMETER
CONDITIONS
MIN
SUPPLIES
Monotonic ramp. Ramp rate is 10% to 90% of
the final value
Supply Ramp Time
Power Supply Noise
Up to 10 kHz
Operating Range
25°C Output
ADC Resolution
ODR
Room Temperature Offset
Stabilization Time
Sensitivity
Sensitivity for FIFO data
Ambient
Start-up time for register read/write
From power-up
0.01
10
TEMPERATURE SENSOR
With Filter
25°C
-40
25
-5
Untrimmed
132.48
2.07
POWER-ON RESET
I2C ADDRESS
AP_AD0 = 0
AP_AD0 = 1
I2C ADDRESS
TYP
MAX
UNITS
3
ms
50
mV
peak-peak
105
2
3
2
2
3
2
1
1
1
ms
1
0.3*VDDIO
V
8000
5
14000
V
CI, Input Capacitance
< 10
pF
Input Leakage Current
100
nA
DIGITAL OUTPUT (SDO, INT1, INT2)
0.9*VDDIO
RLOAD=1 MΩ;
VOL1, LOW-Level Output Voltage
RLOAD=1 MΩ;
VOL.INT, INT Low-Level Output Voltage
Output Leakage Current
OPEN=1, 0.3 mA sink
Current
OPEN=1
tINT, INT Pulse Width
int_tpulse_duration= 0, 1 (100us, 8us ) ;
V
100
µs
-0.5 V
0.3*VDDIO
V
0.7*VDDIO
VDDIO +
0.5V
V
0.1*VDDIO
3 mA sink current
VOL=0.4V
VOL=0.6V
Frequency Variation over Temperature
20+0.1Cb
INTERNAL CLOCK SOURCE
CLKSEL=`2b00 or gyro inactive; 25°C
-3
CLK_SEL=`2b01 and gyro active; 25°C
-1.5
V
1
mA
mA
100
Cb bus capacitance in pf
nA
300
ns
+3
1
+1.5
1
CLK_SEL=`2b00 or gyro inactive; -40°C to +85°C
±3
1
CLK_SEL=`2b01 and gyro active; -40oC to +85oC
±2
1
Expected results based on design, will be updated after characterization. Not tested in production.
Production tested.
Revision: 1.2
V
0.4
3
6
Clock Frequency Initial Tolerance
1
nA
8
Vhys, Hysteresis
Notes:
1.
2.
3.
V
0.1
I2C I/O (SCL, SDA)
VIH, HIGH-Level Input Voltage
tof, Output Fall Time from VIHmax to VILmax
1
V
0.1*VDDIO
100
VIL, LOW-Level Input Voltage
VOL, LOW-Level Output Voltage
IOL, LOW-Level Output Current
1
1101000
1101001
VIL, Low Level Input Voltage
VOH, High Level Output Voltage
1
°C
LSB
bits
Hz
°C
µs
LSB/°C
LSB/°C
DIGITAL INPUTS (FSYNC, SCLK, SDI, CS)
0.7*VDDIO
VIH, High Level Input Voltage
NOTES
Page 14 of 119
IIM-42652
I2C TIMING CHARACTERIZATION
Parameters
Conditions
I2C TIMING
I2C FAST-MODE PLUS
Min
Typical
fSCL, SCL Clock Frequency
Max
Units
Notes
1
MHz
1
0.26
µs
1
tLOW, SCL Low Period
0.5
µs
1
tHIGH, SCL High Period
0.26
µs
1
tSU.STA, Repeated START Condition Setup Time
tHD.STA, (Repeated) START Condition Hold Time
0.26
µs
1
tHD.DAT, SDA Data Hold Time
µs
1
tSU.DAT, SDA Data Setup Time
50
ns
1
tr, SDA and SCL Rise Time
Cb bus cap. from 10 to 400 pF
120
ns
1
tf, SDA and SCL Fall Time
120
ns
1
tSU.STO, STOP Condition Setup Time
0.5
µs
1
tBUF, Bus Free Time Between STOP and START
Condition
0.5
µs
1
Cb, Capacitive Load for each Bus Line
pF
1
tVD.DAT, Data Valid Time
< 400
0.45
µs
1
tVD.ACK, Data Valid Acknowledge Time
0.45
µs
1
Notes:
1.
Based on characterization of 5 parts over temperature and voltage as mounted on evaluation board or in sockets
tf
SDA
tSU.DAT
tr
70%
30%
70%
30%
tf
SCL
S
SDA
SCL
tHD.STA
tr
70%
30%
tHD.DAT
1/fSCL
tLOW
1st clock cycle
tBUF
tHD.STA
tSU.STA
Sr
70%
30%
tSU.STO
tVD.ACK
9th clock cycle
Revision: 1.2
9th clock cycle
tHIGH
70%
30%
A
continued below at
tVD.DAT
70%
30%
Page 15 of 119
P
S
A
IIM-42652
SPI TIMING CHARACTERIZATION – 4-WIRE SPI MODE
PARAMETERS
CONDITIONS
MIN
TYP
MAX
UNITS
NOTES
24
SPI TIMING
fSPC, SCLK Clock Frequency
MHz
1
tLOW, SCLK Low Period
Default
17
ns
1
tHIGH, SCLK High Period
17
ns
1
tSU.CS, CS Setup Time
39
ns
1
tHD.CS, CS Hold Time
18
ns
1
tSU.SDI, SDI Setup Time
13
ns
1
tHD.SDI, SDI Hold Time
8
ns
1
tVD.SDO, SDO Valid Time
Cload = 20 pF
tHD.SDO, SDO Hold Time
Cload = 20 pF
21.5
3.5
28
tDIS.SDO, SDO Output Disable Time
ns
1
ns
1
ns
1
Notes:
1.
CS
SCLK
70%
30%
tSU;CS
SDI
70%
30%
70%
30%
tHIGH
tSU;SDI
1/fCLK
tRise
LSB IN
MSB IN
MSB OUT
70%
30%
Page 16 of 119
tDIS;SDO
tHD;SDO
Revision: 1.2
tHD;CS
tLOW
tHD;SDI
tVD;SDO
SDO
tFall
LSB OUT
IIM-42652
SPI TIMING CHARACTERIZATION – 3-WIRE SPI MODE
Typical Operating Circuit of section 4.2, VDD = 1.8 V, VDDIO = 1.8V, TA=25°C, unless otherwise noted.
PARAMETERS
CONDITIONS
MIN
TYP
MAX
UNITS
NOTES
24
SPI TIMING
MHz
1
Default
17
ns
1
17
ns
1
39
ns
1
5
ns
1
tSU.SDIO, SDIO Input Setup Time
13
ns
1
tHD.SDIO, SDIO Input Hold Time
8
ns
1
tVD.SDIO, SDIO Output Valid Time
Cload = 20 pF
tHD.SDIO, SDIO Output Hold Time
Cload = 20 pF
18.5
3.5
28
tDIS.SDIO, SDIO Output Disable Time
ns
1
ns
1
ns
1
Notes:
1.
CS
SCLK
70%
30%
tSU;CS
SDIO
I
O
70%
30%
70%
30%
tHIGH
tSU;SDIO
1/fCLK
tFall
tRise
tLOW
tHD;SDIO
LSB IN
MSB IN
tVD;SDIO
MSB OUT
70%
30%
Page 17 of 119
tDIS;SDIO
tHD;SDIO
Revision: 1.2
tHD;CS
LSB OUT
IIM-42652
RTC (CLKIN) TIMING CHARACTERIZATION
PARAMETERS
CONDITIONS
MIN
TYP
MAX
UNITS
NOTES
31
32
50
kHz
1
µs
1
RTC (CLKIN) TIMING
FRTC, RTC Clock Frequency
Default
tHIGHRTC, RTC Clock High Period
1
tRISERTC, RTC Clock Rise Time
5
500
ns
1
tFALLRTC, RTC Clock Fall Time
5
500
ns
1
Notes:
1.
Based on characterization. Not tested in production.
Revision: 1.2
Page 18 of 119
IIM-42652
ABSOLUTE MAXIMUM RATINGS
Stress above those listed as “Absolute Maximum Ratings” may cause permanent damage to the device. These are
stress ratings only and functional operation of the device at these conditions is not implied. Exposure to the absolute
maximum ratings conditions for extended periods may affect device reliability. Prolonged exposure to acceleration
ranges beyond ±60g may affect device reliability.
PARAMETER
RATING
Supply Voltage, VDD
-0.5V to +4V
Supply Voltage, VDDIO
-0.5V to +4V
Input Voltage Level (FSYNC, SCL, SDA)
-0.5V to VDDIO + 0.5V
Acceleration (Any Axis, unpowered)
20,000g for 0.2 ms
Operating Temperature Range
-40°C to +105°C
Storage Temperature Range
-40°C to +125°C
2 kV (HBM);
Electrostatic Discharge (ESD) Protection
500V (CDM)
JEDEC Class II (2),125°C
Latch-up
±100 mA
Revision: 1.2
Page 19 of 119
IIM-42652
4 APPLICATIONS INFORMATION
PIN OUT DIAGRAM AND SIGNAL DESCRIPTION
PIN NUMBER
PIN NAME
PIN DESCRIPTION
AP_SDO: AP SPI serial data output (4-wire mode);
AP_AD0: AP I3CSM / I2C slave address LSB
1
AP_SDO / AP_AD0
2
RESV
No Connect or Connect to GND
3
RESV
4
INT1 / INT
5
VDDIO
6
GND
Power supply ground
7
RESV
Connect to GND
8
VDD
Power supply voltage
9
10
RESV
11
RESV
INT1: Interrupt 1 (Note: INT1 can be push-pull or open drain)
INT: All interrupts mapped to pin 4
IO power supply voltage
By default, pull-up is disabled. Pull-up can be enabled by
setting PIN7_PU_EN = 1 (register 0x06h in Bank 3) and it
can be disabled by setting PIN7_PU_EN = 0.
INT2: Interrupt 2 (Note: INT2 can be push-pull or open drain)
FSYNC: Frame sync input; Connect to GND if FSYNC not used
CLKIN: External Clock Input
AP_CS
AP SPI Chip select (AP SPI interface); Connect to VDDIO if
using AP I3CSM / I2C interface
13
AP_SCL / AP_SCLK
AP_SCL: AP I3CSM / I2C serial clock; AP_SCLK: AP SPI serial
clock
AP_SDA / AP_SDIO /
AP_SDI
AP_SDA: AP I3C / I C serial data; AP_SDIO: AP SPI serial
data I/O (3-wire mode); AP_SDI: AP SPI serial data input (4wire mode)
SM
2
Revision: 1.2
By default, pull-down is disabled.
Pull-down can be enabled by setting PIN9_PD_EN = 1
(register 0x06h in Bank 3).
By default, pull-up is enabled.
Pull-up can be disabled by setting PIN10_PU_EN = 0 and
it can be enabled by setting PIN10_PU_EN = 1 (register
0x06h in Bank 3).
Pull-up can be disabled by setting PIN11_PU_EN = 0 and
it can be enabled by setting PIN11_PU_EN = 1 (register
0x06h in Bank 3).
12
14
PIN STATUS
By default, pull-up/pull-down is disabled. Pull-up can be
enabled by setting PIN1_PU_EN = 1 (register 0x0Eh in
Bank 3). Pull-down can be enabled by setting
PIN1_PD_EN = 1 (register 0x0Eh in Bank 3). Note that
both pull-up and pull-down must not be simultaneously
enabled for the same pin.
setting PIN2_PU_EN = 1 (register 0x06h in Bank 3).
setting PIN3_PU_EN = 1 (register 0x06h in Bank 3).
By default, pull-down is disabled. Pull-down can be
enabled by setting PIN4_PD_EN = 1 (register 0x06h in
Bank 3).
Page 20 of 119
By default, pull-up is enabled. Pull-up can be disabled by
setting PIN12_PU_EN = 0 (register 0x0Eh in Bank 3).
Pull-down can be enabled by setting PIN12_PD_EN = 1
(register 0x0Eh in Bank 3). Note that both pull-up and
pull-down must not be simultaneously enabled for the
same pin.
enabled by setting PIN13_PU_EN = 1 (register 0x0Eh in
PIN13_PD_EN = 1 (register 0x0Eh in Bank 3). Note that
enabled by setting PIN14_PU_EN = 1 (register 0x0Eh in
PIN14_PD_EN = 1 (register 0x0Eh in Bank 3). Note that
IIM-42652
+Z
IIM-42652
+Y
14
13
12
1
RESV
2
RESV
3
INT1 / INT
AP_SCL
AP_SDA
AP_AD0
VDDIO
ICM-42688-G
IIM-42652
4
11
RESV
10
RESV
9
8
5
6
7
VDD
RESV
GND
VDDIO
C1, 0.1 µF
1.71 – 3.6VDC
C2, 2.2 µF
1.71 – 3.6VDC
C3, 10 nF
Note: I2C lines are open drain and pull-up resistors (e.g. 10 kΩ) are required.
Revision: 1.2
Page 21 of 119
+X
IIM-42652
AP_SDO
14
13
12
1
RESV
2
RESV
3
INT1 / INT
AP_SCLK
AP_SDIO /
AP_SDI
AP_CS
IIM-42652
ICM-42688-G
4
11
RESV
10
RESV
9
8
5
6
7
1.71 – 3.6VDC
VDD
RESV
GND
VDDIO
C1, 0.1 µF
C2, 2.2 µF
1.71 – 3.6VDC
C3, 10 nF
BILL OF MATERIALS FOR EXTERNAL COMPONENTS
COMPONENT
LABEL
SPECIFICATION
QUANTITY
VDD Bypass Capacitors
C1
C2
X7R, 0.1µF ±10%
X7R, 2.2µF ±10%
1
1
VDDIO Bypass Capacitor
C3
X7R, 10nF ±10%
1
SYSTEM BLOCK DIAGRAM
IIM-42652
Note: The above block diagram is an example. Please refer to the pin-out (section 4.1) for other configuration options.
Revision: 1.2
Page 22 of 119
IIM-42652
OVERVIEW
The IIM-42652 is comprised of the following key blocks and functions:
Three-axis MEMS rate gyroscope sensor with 16-bit ADCs and signal conditioning
o 20-bits data format support in FIFO for high-data resolution (see section 6 for details)
Three-axis MEMS accelerometer sensor with 16-bit ADCs and signal conditioning
I3CSM, I2C, and SPI serial communications interfaces to Host
Self-Test
Clocking
FIFO
Interrupts
Bias and LDOs
Charge Pump
THREE-AXIS MEMS GYROSCOPE WITH 16-BIT ADCS AND SIGNAL CONDITIONING
The IIM-42652 includes a vibratory MEMS rate gyroscope, which detects rotation about the X-, Y-, and Z- Axes. When
the gyroscope is rotated about any of the sense axes, the Coriolis Effect causes a vibration that is detected by a
capacitive pickoff. The resulting signal is amplified, demodulated, and filtered to produce a voltage that is proportional
to the angular rate. This voltage is digitized using on-chip Analog-to-Digital Converters (ADCs) to sample each axis. The
full-scale range of the gyro sensors may be digitally programmed to ±15.625, ±31.25, ±62.5, ±125, ±250, ±500, ±1000,
and ±2000 degrees per second (dps).
THREE-AXIS MEMS ACCELEROMETER WITH 16-BIT ADCS AND SIGNAL CONDITIONING
The IIM-42652 includes a 3-Axis MEMS accelerometer. Acceleration along a particular axis induces displacement of a
proof mass in the MEMS structure, and capacitive sensors detect the displacement. The IIM-42652 architecture
reduces the accelerometers’ susceptibility to fabrication variations as well as to thermal drift. When the device is
placed on a flat surface, it will measure 0g on the X- and Y-axes and +1g on the Z-axis. The accelerometers’ scale
factor is calibrated at the factory and is nominally independent of supply voltage. The full-scale range of the digital
output can be adjusted to ±2g, ±4g, ±8g and ±16g.
I3CSM, I2C, AND SPI HOST INTERFACE
The IIM-42652 communicates to the application processor using an I3CSM, I2C, or SPI serial interface. The IIM-42652
always acts as a slave when communicating to the application processor.
SELF-TEST
Self-test allows for the testing of the mechanical and electrical portions of the sensors. The self-test for each
measurement axis can be activated by means of the gyroscope and accelerometer self-test registers.
When the self-test is activated, the electronics cause the sensors to be actuated and produce an output signal. The
output signal is used to observe the self-test response.
The self-test response is defined as follows:
SELF-TEST RESPONSE = SENSOR OUTPUT WITH SELF-TEST ENABLED – SENSOR OUTPUT WITH SELF-TEST DISABLED
When the value of the self-test response is within the specified min/max limits of the product specification, the part
has passed self-test. When the self-test response exceeds the min/max values, the part is deemed to have failed selftest.
Revision: 1.2
Page 23 of 119
IIM-42652
CLOCKING
The IIM-42652 has a flexible clocking scheme, allowing the following internal clock sources to be used for the internal
synchronous circuitry. This synchronous circuitry includes signal conditioning, ADCs, and various control circuits and
registers.
The CLKIN pin on IIM-42652 provides the ability to input an external clock. A highly accurate external clock may be
used rather than the internal clock sources, if greater clock accuracy is desired. External clock input supports highly
accurate clock input from 31 kHz to 50 kHz, resulting in improvement of the following:
ODR uncertainty due to process, temperature, operating mode (PLL vs. RCOSC), and design limitations. This
uncertainty can be as high as ±8% in RCOSC mode and ±1% in PLL mode. The CLKIN, assuming a 50 ppm or
better 32.768 kHz source, will improve the ODR accuracy from ±80,000 ppm to ±50 ppm in RCOSC mode, or
from ±10,000 ppm to ±50 ppm in PLL mode.
System level sensitivity error. Any clock uncertainty directly impacts gyroscope sensitivity at the system level.
Sophisticated systems can estimate ODR inaccuracy to some extent, but not to the extent improved by using
CLKIN.
System-level clock/sensor synchronization. When using CLKIN, the accelerometer and gyroscope are on the
same clock as the host. There is no need to continually re-synchronize the sensor data as the sensor sample
points and period are in exact alignment with the common system clock.
Other applications that benefit from CLKIN include navigation, robotics.
Allowable internal sources for generating the internal clock are:
a) An internal relaxation oscillator
b) Auto-select between internal relaxation oscillator and gyroscope MEMS oscillator to use the best available
source
The only setting supporting specified performance in all modes is option b). Option b) is recommended when using
the internal clock source.
SENSOR DATA REGISTERS
The sensor data registers contain the latest gyroscope, accelerometer, and temperature measurement data. They are
read-only registers and are accessed via the serial interface. Data from these registers may be read anytime.
INTERRUPTS
Interrupt functionality is configured via the Interrupt Configuration register. Items that are configurable include the
interrupt pins configuration, the interrupt latching and clearing method, and triggers for the interrupt. Items that can
trigger an interrupt are (1) clock generator locked to new reference oscillator (used when switching clock sources); (2)
new data is available to be read (from the FIFO and Data registers); (3) accelerometer event interrupts; (4) FIFO
watermark; (5) FIFO overflow. The interrupt status can be read from the Interrupt Status register.
DIGITAL-OUTPUT TEMPERATURE SENSOR
An on-chip temperature sensor and ADC are used to measure the IIM-42652 die temperature. The readings from the
ADC can be read from the FIFO or the Sensor Data registers.
Temperature data value from the sensor data registers can be converted to degrees centigrade by using the following
formula:
Temperature in Degrees Centigrade = (TEMP_DATA / 132.48) + 25
FIFO_TEMP_DATA, temperature data stored in FIFO, can be 8-bit or 16-it quantity. The 8-bit of temperature data
stored in FIFO is limited to -40°C to 85°C range, while the 16-bit representation can support the full operating
temperature range. It can be converted to degrees centigrade by using the following formula:
Temperature in Degrees Centigrade = (FIFO_TEMP_DATA / 2.07) + 25
Document Number: DS-000401
Revision: 1.2
Page 24 of 119
IIM-42652
BIAS AND LDOS
The bias and LDO section generate the internal supply and the reference voltages and currents required by the IIM42652.
CHARGE PUMP
An on-chip charge pump generates the high voltage required for the MEMS oscillator.
STANDARD POWER MODES
Table 12 lists the user-accessible power modes for IIM-42652.
MODE
1
2
3
4
5
6
NAME
Sleep Mode
Standby Mode
Accelerometer Low-Power Mode
Accelerometer Low-Noise Mode
Gyroscope Low-Noise Mode
6-Axis Low-Noise Mode
GYRO
Off
Drive On
Off
Off
On
On
Revision: 1.2
Page 25 of 119
ACCEL
Off
Off
Duty-Cycled
On
Off
On
IIM-42652
5 SIGNAL PATH
The following figure shows a block diagram of the signal path for IIM-42652.
ADC
Decimation
Filter
(32kHz)
Gyro Only
Notch Filter
Anti-Alias
Filter (AAF)
1
User
Programmable
Offset
UI Filter Block
(order, BW, ODR)
Sensor
Registers
FSR Selection
GYRO_NF_DIS
AAF_DIS
The signal path starts with ADCs for the gyroscope and accelerometer. Other components of the signal path are
described in section 5.1 in further detail.
SUMMARY OF PARAMETERS USED TO CONFIGURE THE SIGNAL PATH
Table 13 shows the parameters that can control the signal path.
PARAMETER NAME
GYRO_AAF_DIS
GYRO_AAF_DELT
GYRO_AAF_DELTSQR
GYRO_AAF_BITSHIFT
ACCEL_AAF_DIS
ACCEL_AAF_DELT
ACCEL_AAF_DELTSQR
ACCEL_AAF_BITSHIFT
GYRO_NF_DIS
GYRO_X/Y/Z_NF_COSWZ
GYRO_X/Y/Z_NF_COSWZ_SEL
GYRO_NF_BW_SEL
DESCRIPTION
Disables the Gyroscope Anti Alias Filter (AAF)
Three parameters required to program the gyroscope AAF. This is a 2nd order filter with
programmable low pass filter. This is a user programmable filter which can be used to select
the desired BW. This filter allows trading off RMS noise vs. latency for a given ODR.
Disables the Accelerometer Anti Alias Filter
Three parameters required to program the accelerometer AAF. This is a 2nd order filter with
Disables the gyro Notch Filter
Factory trimmed parameters, designed to position a Notch at or near the sense peak
frequency of Gyro. This allows the user to suppress only sense peak contribution to noise,
while still maintaining a low latency high BW/ODR interface from the Sensor. This filter is
available only in gyro, and the parameters for X, Y, and Z are chosen independently.
Factory trimmed parameter to cancel noise created by sense peak from gyro. This parameter
is common to all three axes
NOTCH FILTER
The Notch Filter is only supported for the gyroscope signal path. The following steps can be used to program the notch
filter. Note that the notch filter is specific to each axis in the gyroscope, so the X-, Y-, and Z-axis can be programmed
independently.
Frequency of Notch Filter (each axis)
To operate the Notch filter, two parameters NF_COSWZ, and NF_COSWZ_SEL must be programmed for each
gyroscope axis.
Parameters NF_COSWZ are defined for each axis of the gyroscope as GYRO_X_NF_COSWZ (register bank 1, register
0x0Fh & register 0x12h), GYRO_Y_NF_COSWZ (register bank 1, register 0x10h & register 0x12h), GYRO_Z_NF_COSWZ
(register bank 1, register 0x11h & register 0x12h). Note that the parameters have 9-bit values across two different
registers.
Revision: 1.2
Page 26 of 119
UI Interface
IIM-42652
Parameters NF_COSWZ_SEL are defined for each axis of the gyroscope as GYRO_X_NF_COSWZ_SEL (register bank 1,
register 0x12h, bit 3), GYRO_Y_NF_COSWZ_SEL (register bank 1, register 0x12h, bit 4), GYRO_Z_NF_COSWZ_SEL
(register bank 1, register 0x12h, bit 5).
Each value must be calculated using the steps described below and programmed into the corresponding register
locations mentioned above.
fdesired is the desired frequency of the Notch Filter in kHz. The lower bound for fdesired is 1 kHz, and the upper
bound is 3 kHz. Operating the notch filter outside this range is not supported.
Step1: COSWZ = cos(2*pi*fdesired/8)
Step2:
If abs(COSWZ)≤0.875
NF_COSWZ = round[COSWZ*256]
NF_COSWZ_SEL = 0
else
NF_COSWZ_SEL = 1
if COSWZ > 0.875
NF_COSWZ = round [8*(1-COSWZ)*256]
else if COSWZ < -0.875
NF_COSWZ = round [-8*(1+COSWZ)*256]
end
End
Bandwidth of Notch Filter (common to all axes)
The notch filter allows the user to control the width of the notch from eight possible values using a 3-bit parameter
GYRO_NF_BW_SEL in register bank 1, register 0x13h, bits 6:4. This parameter is common to all three axes.
GYRO_NF_BW_SEL
NOTCH FILTER BANDWIDTH (HZ)
1
680
2
329
3
162
4
80
5
40
6
10
The notch filter can be selected or bypassed by using the parameter GYRO_NF_DIS in register bank 1, register 0x0Bh,
bit 0 as shown below.
Revision: 1.2
GYRO_NF_DIS
FUNCTION
Enable notch filter
1
Disable notch filter
Page 27 of 119
IIM-42652
ANTI-ALIAS FILTER
To program the anti-alias filter for a required bandwidth, use the table below to map the bandwidth to register values
as shown:
Register bank 2, register 0x03h, bits 6:1, ACCEL_AAF_DELT: Code from 1 to 63 that allows
programming the bandwidth for accelerometer anti-alias filter
Register bank 2, register 0x04h, bits 7:0 and Bank 2, register 0x05h, bits 3:0, ACCEL_AAF_DELTSQR:
Square of the delt value for accelerometer
Register bank 2, register 0x05h, bits 7:4, ACCEL_AAF_BITSHIFT: Bitshift value for accelerometer used
in hardware implementation
Register bank 1, register 0x0Ch, bits 5:0, GYRO_AAF_DELT: Code from 1 to 63 that allows
programming the bandwidth for gyroscope anti-alias filter
Register bank 1, register 0x0Dh, bits 7:0 and Bank 1, register 0x0Eh, bits 3:0, GYRO_AAF_DELTSQR:
Square of the delt value for gyroscope
Register bank 1, register 0x0Eh, bits 7:4, GYRO_AAF_BITSHIFT: Bitshift value for gyroscope used in
42
ACCEL_AAF_DELT;
GYRO_AAF_DELT
1
ACCEL_AAF_DELTSQR;
GYRO_AAF_DELTSQR
1
ACCEL_AAF_BITSHIFT;
GYRO_AAF_BITSHIFT
15
84
2
4
13
126
3
9
12
170
4
16
11
213
5
25
10
258
6
36
10
303
7
49
9
348
8
64
9
394
9
81
9
441
10
100
8
488
11
122
8
536
12
144
8
585
13
170
8
634
14
196
7
684
15
224
7
734
16
256
7
785
17
288
7
837
18
324
7
890
19
360
6
943
6
997
21
440
6
1051
22
488
6
1107
23
528
6
1163
24
576
6
1220
25
624
6
1277
26
680
6
1336
27
736
5
3DB BANDWIDTH (HZ)
Revision: 1.2
Page 28 of 119
IIM-42652
1395
ACCEL_AAF_DELT;
GYRO_AAF_DELT
28
ACCEL_AAF_DELTSQR;
GYRO_AAF_DELTSQR
784
ACCEL_AAF_BITSHIFT;
GYRO_AAF_BITSHIFT
5
1454
29
848
5
1515
30
896
5
1577
31
960
5
1639
32
1024
5
1702
33
1088
5
1766
34
1152
5
1830
35
1232
5
1896
36
1296
5
1962
37
1376
4
2029
38
1440
4
2097
39
1536
4
2166
40
1600
4
2235
41
1696
4
2306
42
1760
4
2377
43
1856
4
2449
44
1952
4
2522
45
2016
4
2596
46
2112
4
2671
47
2208
4
2746
48
2304
4
2823
49
2400
4
2900
50
2496
4
2978
51
2592
4
3057
52
2720
4
3137
53
2816
3
3217
54
2944
3
3299
55
3008
3
3381
56
3136
3
3464
57
3264
3
3548
58
3392
3
3633
59
3456
3
3718
60
3584
3
3805
61
3712
3
3892
62
3840
3
3979
63
3968
3
3DB BANDWIDTH (HZ)
The anti-alias filter can be selected or bypassed for the gyroscope by using the parameter GYRO_AAF_DIS in register
bank 1, register 0x0Bh, bit 1 as shown below.
Revision: 1.2
Page 29 of 119
IIM-42652
GYRO_AAF_DIS
FUNCTION
Enable gyroscope anti-aliasing filter
1
Disable gyroscope anti-aliasing filter
The anti-alias filter can be selected or bypassed for the accelerometer by using the parameter ACCEL_AAF_DIS in
register bank 2, register 0x03h, bit 0 as shown below.
ACCEL_AAF_DIS
FUNCTION
Enable accelerometer anti-aliasing filter
1
Disable accelerometer anti-aliasing filter
USER PROGRAMMABLE OFFSET
Gyroscope and accelerometer offsets can be programmed by the user by using registers OFFSET_USER0, through
OFFSET_USER8, in bank 0, registers 0x77h through 0x7Fh (bank 4) as shown below.
REGISTER ADDRESS
REGISTER NAME
BITS
0x77h
OFFSET_USER0
7:0
0x78h
OFFSET_USER1
0x79h
OFFSET_USER2
7:0
0x7Ah
OFFSET_USER3
7:0
0x7Bh
OFFSET_USER4
0x7Ch
OFFSET_USER5
7:0
0x7Dh
OFFSET_USER6
7:0
0x7Eh
OFFSET_USER7
0x7Fh
OFFSET_USER8
3:0
7:4
3:0
7:4
3:0
7:4
7:0
FUNCTION
Lower bits of X-gyro offset programmed by user. Max
value is ±64 dps, resolution is 1/32 dps.
Upper bits of X-gyro offset programmed by user. Max
Upper bits of Y-gyro offset programmed by user. Max
Lower bits of Y-gyro offset programmed by user. Max
Lower bits of Z-gyro offset programmed by user. Max
Upper bits of Z-gyro offset programmed by user. Max
Upper bits of X-accel offset programmed by user. Max
value is ±1 g, resolution is 0.5 mg.
Lower bits of X-accel offset programmed by user. Max
Lower bits of Y-accel offset programmed by user. Max
Upper bits of Y-accel offset programmed by user. Max
Upper bits of Z-accel offset programmed by user. Max
Lower bits of Z-accel offset programmed by user. Max
UI FILTER BLOCK
The UI filter block can be programmed to select filter order and bandwidth independently for gyroscope and
accelerometer.
Gyroscope filter order can be selected by programming the parameter GYRO_UI_FILT_ORD in register bank 0, register
0x51h, bits 3:2, as shown below.
Revision: 1.2
Page 30 of 119
IIM-42652
GYRO_UI_FILT_ORD
FILTER ORDER
00
1st order
01
2nd order
10
3rd order
11
Reserved
Accelerometer filter order can be selected by programming the parameter ACCEL_UI_FILT_ORD in register bank 0,
register 0x53h, bits 4:3, as shown below.
ACCEL_UI_FILT_ORD
FILTER ORDER
00
1st order
01
2nd order
10
3rd order
11
Reserved
Gyroscope and accelerometer filter 3dB bandwidth can be selected by programming the parameter
GYRO_UI_FILT_BW in register bank 0, register 0x52h, bits 3:0, and the parameter ACCEL_UI_FILT_BW in register bank
0, register 0x52h, bits 7:4, as shown below. The values shown in bold correspond to low noise and the values shown
in italics correspond to low latency. User can select the appropriate setting based on the application requirements for
power and latency. Corresponding Noise Bandwidth (NBW) and Group Delay values are also shown.
1st Order Filter 3dB Bandwidth, Noise Bandwidth (NBW), Group Delay
3dB Bandwidth (Hz) for GYRO/ACCEL_UI_FILT_ORD=0 (1st order filter)
GYRO/ACCEL_UI_FILT_BW
GYRO/ACCEL_ODR
ODR(Hz)
1
32000
2
16000
4194.1
3
8000
2096.30
4
4000
1048.10
5
6
2000
524.00
1000
498.30
227.20
188.90
111.00
15
500
249.10
113.60
94.40
55.50
7
200
99.60
90.90
75.50
8
100
49.80
90.90
9
50
24.90
10
25
12.50
11
12.5
12.50
Revision: 1.2
2
3
4
5
6
7
14
15
92.40
59.60
48.80
23.90
262.00
2096.30
46.20
29.80
24.40
11.90
131.00
1048.10
44.40
37.00
23.80
19.50
9.60
104.80
419.20
75.50
44.40
37.00
23.80
19.50
9.60
104.80
209.60
90.90
75.50
44.40
37.00
23.80
19.50
9.60
104.80
104.80
90.90
75.50
44.40
37.00
23.80
19.50
9.60
104.80
52.40
90.90
75.50
44.40
37.00
23.80
19.50
9.60
104.80
52.40
8400.0
Page 31 of 119
IIM-42652
NBW Bandwidth (Hz) for GYRO/ACCEL_UI_FILT_ORD=0 (1st order filter)
GYRO/ACCEL_ODR
ODR(Hz)
2
3
4
5
6
7
14
15
1
32000
8831.7
2
16000
4410.6
3
8000
2204.6
4
4000
1102.2
5
6
2000
1000
551.1
230.8
196.3
126.5
108.9
75.8
64.1
34.1
275.6
2204.6
15
500
280.5
115.4
98.2
7
63.3
54.5
37.9
32.1
17.1
137.8
1102.2
200
112.2
92.4
8
78.5
50.6
43.6
30.3
25.7
13.7
110.3
440.9
100
56.1
9
50
28.1
92.4
78.5
50.6
43.6
30.3
25.7
13.7
110.3
220.5
92.4
78.5
50.6
43.6
30.3
25.7
13.7
110.3
110.3
10
25
11
14.1
92.4
78.5
50.6
43.6
30.3
25.7
13.7
110.3
55.2
12.5
14.1
92.4
78.5
50.6
43.6
30.3
25.7
13.7
110.3
55.2
551.1
Group Delay @DC (ms) for GYRO/ACCEL_UI_FILT_ORD=0 (1st order filter)
GYRO/ACCEL_ODR
ODR(Hz)
1
32000
0.1
2
16000
0.1
3
8000
0.2
4
4000
0.4
5
6
2000
0.8
1000
0.6
1.8
2.0
2.8
15
500
1.1
3.6
4.0
5.5
7
200
2.7
4.4
5.0
8
100
5.3
4.4
9
50
10.5
10
25
21.0
11
12.5
21.0
Revision: 1.2
2
3
5
6
3.1
4.1
4.7
8.1
1.5
0.2
6.1
8.1
9.3
16.2
3.0
0.4
6.8
7.6
10.2
11.7
20.3
3.8
1.0
5.0
6.8
7.6
10.2
11.7
20.3
3.8
1.9
4.4
5.0
6.8
7.6
10.2
11.7
20.3
3.8
3.8
4.4
5.0
6.8
7.6
10.2
11.7
20.3
3.8
7.5
4.4
5.0
6.8
7.6
10.2
11.7
20.3
3.8
7.5
Page 32 of 119
4
7
14
15
IIM-42652
2nd Order Filter 3dB Bandwidth, Noise Bandwidth (NBW), Group Delay
3dB Bandwidth (Hz) for GYRO/ACCEL_UI_FILT_ORD=1 (2nd order filter)
GYRO/ACCEL_ODR
ODR(Hz)
1
32000
2
3
4
8400.0
5
6
7
14
15
2
16000
4194.1
3
8000
2096.3
4
4000
1048.1
5
6
2000
524.0
1000
493.3
230.7
191.6
117.5
15
97.1
59.6
48.0
21.3
262.0
2096.3
500
246.7
115.3
95.8
7
200
98.7
92.3
76.6
58.8
48.5
29.8
24.0
10.6
131.0
1048.1
47.0
38.8
23.8
19.2
8.5
104.8
419.2
8
100
49.3
92.3
9
76.6
47.0
38.8
23.8
19.2
8.5
104.8
209.6
50
24.7
92.3
76.6
47.0
38.8
23.8
19.2
8.5
104.8
104.8
10
25
12.3
92.3
76.6
47.0
38.8
23.8
19.2
8.5
104.8
52.4
11
12.5
12.3
92.3
76.6
47.0
38.8
23.8
19.2
8.5
104.8
52.4
NBW Bandwidth (Hz) for GYRO/ACCEL_UI_FILT_ORD=1 (2nd order filter)
GYRO/ACCEL_ODR
ODR(Hz)
1
32000
8831.7
2
16000
4410.6
3
8000
2204.6
4
4000
1102.2
5
6
2000
1000
551.1
223.7
189.9
122.7
15
500
259.6
111.9
95.0
7
200
103.9
89.5
8
100
52.0
9
50
26.0
10
25
11
12.5
Revision: 1.2
2
3
4
5
6
7
14
15
102.8
64.7
52.5
23.7
275.6
2204.6
61.4
51.4
32.4
26.3
11.9
137.8
1102.2
76.0
49.1
41.2
25.9
21.0
9.5
110.3
440.9
89.5
76.0
49.1
41.2
25.9
21.0
9.5
110.3
220.5
89.5
76.0
49.1
41.2
25.9
21.0
9.5
110.3
110.3
13.0
89.5
76.0
49.1
41.2
25.9
21.0
9.5
110.3
55.2
13.0
89.5
76.0
49.1
41.2
25.9
21.0
9.5
110.3
55.2
551.1
Page 33 of 119
IIM-42652
Group Delay @DC (ms) for GYRO/ACCEL_UI_FILT_ORD=1 (2nd order filter)
GYRO/ACCEL_ODR
ODR(Hz)
2
3
4
5
6
1
32000
0.1
2
16000
0.1
3
8000
0.2
4
4000
0.4
5
6
2000
1000
0.7
2.1
2.4
3.2
15
500
1.3
4.1
4.7
7
200
3.3
5.1
8
100
6.5
9
50
12.9
10
25
11
12.5
7
14
15
3.7
5.2
6.1
12.0
1.5
0.2
6.4
7.3
10.4
12.2
24.0
3.0
0.4
5.8
8.0
9.1
12.9
15.3
30.0
3.8
1.0
5.1
5.8
8.0
9.1
12.9
15.3
30.0
3.8
1.9
5.1
5.8
8.0
9.1
12.9
15.3
30.0
3.8
3.8
25.7
5.1
5.8
8.0
9.1
12.9
15.3
30.0
3.8
7.5
25.7
5.1
5.8
8.0
9.1
12.9
15.3
30.0
3.8
7.5
0.8
3rd Order Filter 3dB Bandwidth, Noise Bandwidth (NBW), Group Delay
3dB Bandwidth (Hz) for GYRO/ACCEL_UI_FILT_ORD=2 (3rd order filter)
GYRO/ACCEL_ODR
ODR(Hz)
1
32000
8400.0
2
16000
4194.1
3
8000
2096.3
4
4000
1048.1
5
6
2000
524.0
1000
492.9
234.7
195.8
118.9
15
500
246.4
117.4
97.9
59.5
7
200
98.6
93.9
78.3
8
100
49.3
93.9
9
50
24.6
93.9
10
25
12.3
11
12.5
12.3
Revision: 1.2
2
3
5
6
7
14
15
97.9
60.8
46.8
25.2
262.0
2096.3
48.9
30.4
23.4
12.6
131.0
1048.1
47.6
39.2
24.3
18.7
10.1
104.8
419.2
78.3
47.6
39.2
24.3
18.7
10.1
104.8
209.6
78.3
47.6
39.2
24.3
18.7
10.1
104.8
104.8
93.9
78.3
47.6
39.2
24.3
18.7
10.1
104.8
52.4
93.9
78.3
47.6
39.2
24.3
18.7
10.1
104.8
52.4
Page 34 of 119
4
IIM-42652
NBW Bandwidth (Hz) for GYRO/ACCEL_UI_FILT_ORD=2 (3rd order filter)
GYRO/ACCEL_ODR
ODR(Hz)
2
3
4
5
6
7
14
15
1
32000
8831.7
2
16000
4410.6
3
8000
2204.6
4
4000
1102.2
5
6
2000
1000
551.1
221.3
188.5
120.1
100.0
62.9
48.6
26.4
275.6
2204.6
15
500
252.0
110.7
94.3
7
60.1
50.0
31.5
24.3
13.2
137.8
1102.2
200
100.8
88.6
8
75.4
48.1
40.0
25.2
19.5
10.6
110.3
440.9
100
50.4
9
50
25.2
88.6
75.4
48.1
40.0
25.2
19.5
10.6
110.3
220.5
88.6
75.4
48.1
40.0
25.2
19.5
10.6
110.3
110.3
10
25
11
12.6
88.6
75.4
48.1
40.0
25.2
19.5
10.6
110.3
55.2
12.5
12.6
88.6
75.4
48.1
40.0
25.2
19.5
10.6
110.3
55.2
551.1
Group Delay @DC (ms) for GYRO/ACCEL_UI_FILT_ORD=2 (3rd order filter)
GYRO/ACCEL_ODR
ODR(Hz)
1
32000
0.1
2
16000
0.1
3
8000
0.2
4
4000
0.4
5
6
2000
0.8
1000
0.8
2.3
2.7
4.0
4.6
6.6
8.2
14.1
1.5
0.2
15
500
1.6
4.6
5.4
7.9
9.2
13.2
16.3
28.1
3.0
0.4
7
200
4.0
5.8
6.8
9.8
11.4
16.5
20.4
35.2
3.8
1.0
8
100
8.0
5.8
6.8
9.8
11.4
16.5
20.4
35.2
3.8
1.9
9
50
15.9
5.8
6.8
9.8
11.4
16.5
20.4
35.2
3.8
3.8
10
25
31.8
5.8
6.8
9.8
11.4
16.5
20.4
35.2
3.8
7.5
11
12.5
31.8
5.8
6.8
9.8
11.4
16.5
20.4
35.2
3.8
7.5
Revision: 1.2
2
Page 35 of 119
3
4
5
6
7
14
15
IIM-42652
ODR AND FSR SELECTION
Gyroscope ODR can be selected by programming the parameter GYRO_ODR in register bank 0, register 0x4Fh, bits 3:0
as shown below.
GYRO_ODR
GYROSCOPE ODR VALUE
0000
Reserved
0001
32 kHz
0010
16 kHz
0011
8 kHz
0100
4 kHz
0101
2 kHz
0110
1 kHz (default)
0111
200 Hz
1000
100 Hz
1001
50 Hz
1010
25 Hz
1011
12.5 Hz
1100
Reserved
1101
Reserved
1110
Reserved
1111
500 Hz
Gyroscope FSR can be selected by programming the parameter GYRO_FS_SEL in register bank 0, register 0x4Fh, bits
7:5 as shown below.
GYRO_FS_SEL
GYROSCOPE FSR VALUE
000
2000 dps
001
1000 dps
010
500 dps
011
250 dps
100
125 dps
101
62.5 dps
110
31.25 dps
111
15.625 dps
Accelerometer ODR can be selected by programming the parameter ACCEL_ODR in register bank 0, register 0x50h,
bits 3:0 as shown below.
Revision: 1.2
Page 36 of 119
IIM-42652
ACCEL_ODR
ACCELEROMETER ODR VALUE
0000
Reserved
0001
32 kHz (LN mode)
0010
16 kHz (LN mode)
0011
8 kHz (LN mode)
0100
4 kHz (LN mode)
0101
2 kHz (LN mode)
0110
1 kHz (LN mode) (default)
0111
200 Hz (LP or LN mode)
1000
100 Hz (LP or LN mode)
1001
50 Hz (LP or LN mode)
1010
25 Hz (LP or LN mode)
1011
12.5 Hz (LP or LN mode)
1100
6.25 Hz (LP mode)
1101
3.125 Hz (LP mode)
1110
1.5625 Hz (LP mode)
1111
500 Hz (LP or LN mode)
Accelerometer FSR can be selected by programming the parameter ACCEL_FS_SEL in register bank 0, register 0x50h,
bits 7:5 as shown below.
Revision: 1.2
ACCEL_FS_SEL
ACCELEROMETER FSR VALUE
000
16g
001
8g
010
4g
011
2g
100
Reserved
101
Reserved
110
Reserved
111
Reserved
Page 37 of 119
IIM-42652
6 FIFO
The IIM-42652 contains a 2K-byte FIFO register that is accessible via the serial interface. The FIFO configuration
register determines which data is written into the FIFO. Possible choices include gyroscope data, accelerometer data,
temperature readings, and FSYNC input. A FIFO counter keeps track of how many bytes of valid data are contained in
the FIFO.
PACKET STRUCTURE
The following figure shows the FIFO packet structures supported in IIM-42652. Base data format for gyroscope and
accelerometer is 16-bits per element. 20-bits data format support is included in one of the packet structures. When
20-bits data format is used, gyroscope data consists of 19-bits of actual data and the LSB is always set to 0,
accelerometer data consists of 18-bits of actual data and the two lowest order bits are always set to 0. When 20-bits
data format is used, the only FSR settings that are operational are ±2000 dps for gyroscope and ±16g for
accelerometer, even if the FSR selection register settings are configured for other FSR values. The corresponding
sensitivity scale factor values are 131 LSB/dps for gyroscope and 8192 LSB/g for accelerometer.
Header
(1 byte)
Header
(1 byte)
Header
(1 byte)
Header
(1 byte)
Accelerometer Data
(6 bytes)
Gyroscope Data
(6 bytes)
Accelerometer Data
(6 bytes)
Accelerometer Data
(6 bytes)
Temperature Data
(1 byte)
Temperature Data
(1 byte)
Gyroscope Data
(6 bytes)
Gyroscope Data
(6 bytes)
Temperature Data
(1 byte)
Temperature Data
(2 bytes)
TimeStamp
(2 bytes)
TimeStamp
(2 bytes)
Packet 1
Packet 2
Packet 3
20-bit Extension
(3 bytes)
Packet 4
Due to limitations on the number of bits, 8-bit temperature data stored in FIFO is limited to a -40°C to 85°C range.
Either 16-bit temperature data format (FIFO packet 4) or the value from the sensor data registers (TEMP_DATA) must
be used to support a temperature measurements range of -40°C to 105°C.
The rest of this sub-section describes how individual data is packaged in the different FIFO packet structures.
Revision: 1.2
Page 38 of 119
IIM-42652
Packet 1: Individual data is packaged in Packet 1 as shown below.
BYTE
0x00
0x01
0x02
0x03
0x04
0x05
0x06
0x07
CONTENT
FIFO Header
Accel X [15:8]
Accel X [7:0]
Accel Y [15:8]
Accel Y [7:0]
Accel Z [15:8]
Accel Z [7:0]
Temperature[7:0]
Packet 2: Individual data is packaged in Packet 2 as shown below.
BYTE
0x00
0x01
0x02
0x03
0x04
0x05
0x06
0x07
CONTENT
FIFO Header
Gyro X [15:8]
Gyro X [7:0]
Gyro Y [15:8]
Gyro Y [7:0]
Gyro Z [15:8]
Gyro Z [7:0]
Temperature[7:0]
Packet 3: Individual data is packaged in Packet 3 as shown below.
Revision: 1.2
BYTE
CONTENT
0x00
0x01
0x02
0x03
0x04
0x05
0x06
0x07
0x08
0x09
0x0A
0x0B
0x0C
0x0D
0x0E
0x0F
FIFO Header
Accel X [15:8]
Accel X [7:0]
Accel Y [15:8]
Accel Y [7:0]
Accel Z [15:8]
Accel Z [7:0]
Gyro X [15:8]
Gyro X [7:0]
Gyro Y [15:8]
Gyro Y [7:0]
Gyro Z [15:8]
Gyro Z [7:0]
Temperature[7:0]
TimeStamp[15:8]
TimeStamp[7:0]
Page 39 of 119
IIM-42652
Packet 4: Individual data is packaged in Packet 4 as shown below.
BYTE
0x00
0x01
0x02
0x03
0x04
0x05
0x06
0x07
0x08
0x09
0x0A
0x0B
0x0C
0x0D
0x0E
0x0F
0x10
0x11
0x12
CONTENT
FIFO Header
Accel X [19:12]
Accel X [11:4]
Accel Y [19:12]
Accel Y [11:4]
Accel Z [19:12]
Accel Z [11:4]
Gyro X [19:12]
Gyro X [11:4]
Gyro Y [19:12]
Gyro Y [11:4]
Gyro Z [19:12]
Gyro Z [11:4]
Temperature[15:8]
Temperature[7:0]
TimeStamp[15:8]
TimeStamp[7:0]
Accel X [3:0]
Gyro X [3:0]
Accel Y [3:0]
Gyro Y [3:0]
0x13
Accel Z [3:0]
Gyro Z [3:0]
FIFO HEADER
The following table shows the structure of the 1-byte FIFO header.
BIT FIELD
ITEM
7
HEADER_MSG
6
HEADER_ACCEL
5
HEADER_GYRO
4
HEADER_20
3:2
HEADER_TIMESTAMP_FSYNC
1
HEADER_ODR_ACCEL
HEADER_ODR_GYRO
DESCRIPTION
1: FIFO is empty
0: Packet contains sensor data
1: Packet is sized so that accel data have location in the packet, FIFO_ACCEL_EN must be 1
0: Packet does not contain accel sample
1: Packet is sized so that gyro data have location in the packet, FIFO_GYRO_EN must be 1
0: Packet does not contain gyro sample
1: Packet has a new and valid sample of extended 20-bit data for gyro and/or accel
0: Packet does not contain a new and valid extended 20-bit data
00: Packet does not contain timestamp or FSYNC time data
01: Reserved
10: Packet contains ODR Timestamp
11: Packet contains FSYNC time, and this packet is flagged as first ODR after FSYNC (only if
FIFO_TMST_FSYNC_EN is 1)
1: The ODR for accel is different for this accel data packet compared to the previous accel
packet
0: The ODR for accel is the same as the previous packet with accel
1: The ODR for gyro is different for this gyro data packet compared to the previous gyro
packet
0: The ODR for gyro is the same as the previous packet with gyro
Note at least HEADER_ACCEL or HEADER_GYRO must be set for a sensor data packet to be set.
Revision: 1.2
Page 40 of 119
IIM-42652
MAXIMUM FIFO STORAGE
The maximum number of packets that can be stored in FIFO is a variable quantity depending on the use case. As
shown in Figure 12, the physical FIFO size is 2048 bytes. A number of bytes equal to the packet size selected (see
section 6.1) is reserved to prevent reading a packet during write operation. Additionally, a read cache 2 packets wide
is available.
When there is no serial interface operation, the read cache is not available for storing packets, being fed by the serial
interface clock.
When serial interface operation happens, depending on the operation length and the packet size chosen, either 1 or 2
of the packet entries in read cache may become available for storing packets. In that case the total storage available is
up to the maximum number of packets that can be accommodated in 2048 bytes + 1 packet size, depending on the
packet size used.
Due to the non-deterministic nature of system operation, driver memory allocation should always be the largest size
of 2080 bytes.
FIFO 2048 Bytes
2 Packet Size
Read Cache
2048 Bytes – 1 packet size
1 Packet Size
Reserved to prevent reading a
FIFO CONFIGURATION REGISTERS
The following control bits in bank 0, register 0x5Fh determine what data is placed into the FIFO. The values of these
bits may change while the FIFO is being filled without corruption of the FIFO.
BIT
NAME
4
FIFO_HIRES_EN
3
FIFO_TMST_FSYNC_EN
1
FIFO_GYRO_EN
FIFO_ACCEL_EN
Revision: 1.2
FUNCTION
0: Default setting; Sensor data have regular resolution
1: Sensor data in FIFO will have extended resolution enabling the 20 Bytes packet
with priority on other setting below
0: FIFO will only contain ODR timestamp information
1: FIFO can also contain FSYNC time and FSYNC tag for one ODR after an FSYNC
event
0: Default setting; Gyroscope data not placed into FIFO
1: Enables gyroscope data packets of 6-bytes to be placed in FIFO
0: Default setting; Accelerometer data not placed into FIFO
1: Enables accelerometer data packets of 6-bytes to be placed in FIFO
Page 41 of 119
IIM-42652
Configuration register settings above impact FIFO header and FIFO packet size as follows:
FIFO_HIRES_EN
FIFO_ACCEL_EN
FIFO_GYRO_EN
1
1
X
X
1
1
1
X
X
1
1
Revision: 1.2
Page 42 of 119
FIFO_TMST_
FSYNC_EN
X
X
X
HEADER
PACKET SIZE
8’b_0111_10xx
8’b_0111_11xx
8’b_0110_10xx
8’b_0110_11xx
8’b_0100_00xx
8’b_0010_00xx
No FIFO writes
20 Bytes
20 Bytes
16 Bytes
16 Bytes
8 Bytes
8 Bytes
No FIFO writes
IIM-42652
7 PROGRAMMABLE INTERRUPTS
The IIM-42652 has a programmable interrupt system that can generate an interrupt signal on the INT pins. Status flags
indicate the source of an interrupt. Interrupt sources may be enabled and disabled individually. There are two
interrupt outputs. Any interrupt may be mapped to either interrupt pin as explained in the register section. The
following configuration options are available for the interrupts:
INT1 and INT2 can be push-pull or open drain
Level or pulse mode
Active high or active low
Additionally, IIM-42652 includes In-band Interrupt (IBI) support for the I3CSM interface.
Revision: 1.2
Page 43 of 119
IIM-42652
8 APEX MOTION FUNCTIONS
The APEX (Advanced Pedometer and Event Detection – neXt gen) features of IIM-42652 consist of:
Pedometer: tracks step count and issues a step detect interrupt.
Tilt Detection: issues an interrupt when the tilt angle exceeds 35 degrees for more than a programmable
time.
Freefall Detection: triggers an interrupt when device freefall is detected and outputs freefall duration.
Tap Detection: issues an interrupt when tap is detected, along with a register containing the tap count.
Wake on Motion (WoM): detects motion when accelerometer samples exceed a programmable threshold.
This motion event can be used to enable chip operation from sleep mode.
Significant Motion Detector (SMD): detects motion if WoM events are detected during a programmable time
window (2s or 4s).
APEX ODR SUPPORT
APEX algorithms are designed to work with the accelerometer for a variety of ODR settings. However, there is a
minimum ODR required for each algorithm. The following table shows the relationship between the available
accelerometer ODRs and the operation of the APEX algorithms. In order to allow more flexible operation where we
can control the ODR of the APEX algorithms independent of the accelerometer ODR, we allow for an additional
selection determined by the field DMP_ODR (DMP stands for Digital Motion ProcessorTM, an architectural component
of APEX). The tables below show how DMP_ODR should be configured in relation to the accelerometer ODR and the
expected performance.
ACCEL ODR
DMP_ODR
PEDOMETER
TILT DETECTION
FREEFALL DETECTION
< 25 Hz
X
Disabled
Disabled
Disabled
≥ 25Hz
0 (25 Hz)
Low Power
Low Power
Low Power
≥ 50 Hz
2 (50 Hz)
Normal
Normal
Low Power
100 Hz
3 (100 Hz)
Normal (50 Hz)
High Performance (50 Hz)
Normal
500 Hz
1 (500 Hz)
Disabled
High Performance
Revision: 1.2
ACCEL ODR
TAP DETECTION
200 Hz
Low Power
500 Hz
Normal
1 kHz
High Performance
> 1 kHz
Disabled
Page 44 of 119
IIM-42652
If the accelerometer ODR is set below the minimum DMP ODR (25 Hz), the APEX features cannot be enabled.
When the accelerometer ODR needs to be set differently from the DMP ODR, only the integer multiple of DMP ODR
for accelerometer sensor ODR is suitable to use with DMP. For example, when the accelerometer ODR is set as 200
Hz, the APEX features can be enabled with choices of 25 Hz, or 50 Hz, depending on the DMP_ODR register setting.
DMP ODR should not be changed on the fly. The following sequence should be followed for changing the DMP ODR:
1.
2.
3.
4.
5.
Disable Pedometer and Tilt Detection if they are enabled
Change DMP ODR
Set DMP_INIT_EN for one cycle (Register 0x4Bh in Bank 0)
Unset DMP_INIT_EN (Register 0x4Bh in Bank 0)
Enable APEX features of interest
DMP POWER SAVE MODE
DMP Power Save Mode can be enabled or disabled by DMP_POWER_SAVE (Register 0x56h in Bank 0). When the DMP
Power Save Mode is enabled, APEX features are enabled only when WOM is detected. WOM must be explicitly
enabled for the DMP to work in this mode. When WOM is not detected the APEX features are on pause. If the user
does not want to use DMP Power Save Mode they may set DMP_POWER_SAVE = 0, and use APEX functions without
WOM detection.
PEDOMETER PROGRAMMING
Pedometer configuration parameters
1. LOW_ENERGY_AMP_TH_SEL (Register 0x40h in Bank 4)
2. PED_AMP_TH_SEL (Register 0x41h in Bank 4)
3. PED_STEP_CNT_TH_SEL (Register 0x41h in Bank 4)
4. PED_HI_EN_TH_SEL (Register 0x42h in Bank 4)
5. PED_SB_TIMER_TH_SEL (Register 0x42h in Bank 4)
6. PED_STEP_DET_TH_SEL (Register 0x42h in Bank 4)
7. SENSITIVITY_MODE (Register 0x48h in Bank 4)
8. There are 2 ODR and 2 sensitivity modes
ACCEL ODR (DMP_ODR)
NORMAL
SLOW WALK
25 Hz (0)
low power
low power and slow walk
50 Hz (2)
high performance
slow walk
Initialize Sensor in a typical configuration
1. Set accelerometer ODR to 50 Hz (Register 0x50h in Bank 0)
2. Set accelerometer to low power mode (Register 0x4Eh in Bank 0)
ACCEL_MODE = 2 and (Register 0x4Eh in Bank 0), ACCEL_LP_CLK_SEL = 0, for low power mode
3. Set DMP ODR = 50 Hz and turn on Pedometer feature (Register 0x56h in Bank 0)
4. Wait 1 millisecond
Initialize APEX hardware
1. Set DMP_MEM_RESET_EN to 1 (Register 0x4Bh in Bank 0)
2. Wait 1 millisecond
3. Set LOW_ENERGY_AMP_TH_SEL to 10 (Register 0x40h in Bank 4)
4. Set PED_AMP_TH_SEL to 8 (Register 0x41h in Bank 4)
5. Set PED_STEP_CNT_TH_SEL to 5 (Register 0x41h in Bank 4)
6. Set PED_HI_EN_TH_SEL to 1 (Register 0x42h in Bank 4)
7. Set PED_SB_TIMER_TH_SEL to 4 (Register 0x42h in Bank 4)
8. Set PED_STEP_DET_TH_SEL to 2 (Register 0x42h in Bank 4)
9. Set SENSITIVITY_MODE to 0 (Register 0x48h in Bank 4)
10. Set DMP_INIT_EN to 1 (Register 0x4Bh in Bank 0)
Revision: 1.2
Page 45 of 119
IIM-42652
11. Wait 50 milliseconds
12. Enable STEP detection, source for INT1 by setting bit 5 in register INT_SOURCE6 (Register 0x4Dh in
Bank 4) to 1. Or if INT2 is selected for STEP detection, enable STEP detection source by setting bit 5
in register INT_SOURCE7 (Register 0x4Eh in Bank 4) to 1.
13. As freefall and pedometer share the same output register, they cannot run concurrently. Disable
freefall by setting FF_ENABLE to 0 (Register 0x56h in Bank 0)
14. Turn on Pedometer feature by setting PED_ENABLE to 1 (Register 0x56h in Bank 0)
Output registers
1. Read interrupt register (Register 0x38h in Bank 0) for STEP_DET_INT
2. If the step count is equal to or greater than 65535 (uint16), the STEP_CNT_OVF_INT (Register 0x38h
in Bank 0) will be set to 1. Example:
Take 1 step =>output step count = 65533 (real step count is 65533)
Take 1 step => output step count = 65534 (real step count is 65534)
Take 1 step => output step count = 0 and interrupt is fired (real step count is 65535+0=
65535)
Take 1 step => output step count = 1 (real step count is 65535+1=65536)
3. Read the step count in STEP_CNT (Register 0x31h and 0x32h in Bank 0)
4. Read the step cadence in STEP_CADENCE (Register 0x33h in Bank 0)
5. Read the activity class in ACTIVITY_CLASS (Register 0x34h in Bank 0)
TILT DETECTION PROGRAMMING
Tilt Detection configuration parameters
1. TILT_WAIT_TIME (Register 0x43h in Bank 4)
This parameter configures how long of a delay after tilt is detected before interrupt is triggered
Default is 2 (4s).
Range is 0 = 0s, 1 = 2s, 2 = 4s, 3 = 6s
For example, setting TILT_WAIT_TIME = 2 is equivalent to 4 seconds for all ODRs
1. Set accelerometer ODR (Register 0x50h in Bank 0)
ACCEL_ODR = 9 for 50 Hz or 10 for 25 Hz
2. Set Accel to Low Power mode (Register 0x4Eh in Bank 0)
ACCEL_MODE = 2 and (Register 0x4Dh in Bank 0), ACCEL_LP_CLK_SEL = 0, for low power mode
3. Set DMP ODR (Register 0x56h in Bank 0)
DMP_ODR = 0 for 25 Hz, 2 for 50 Hz
3. Set TILT_WAIT_TIME (Register 0x43h in Bank 4) if default value does not meet needs
5. Set DMP_INIT_EN to 1 (Register 0x4Bh in Bank 0)
6. Enable Tilt Detection, source for INT1 by setting bit 3 in register INT_SOURCE6 (Register 0x4Dh in
Bank 4) to 1. Or if INT2 is selected for Tilt Detection, enable Tilt Detection source by setting bit 3 in
7. Wait 50 milliseconds
8. Turn on Tilt Detection feature by setting TILT_ENABLE to 1 (Register 0x56h in Bank 0)
Output registers
1. Read interrupt register (Register 0x38h in Bank 0) for TILT_DET_INT
Revision: 1.2
Page 46 of 119
IIM-42652
FREEFALL DETECTION PROGRAMMING
Freefall Detection detects device freefall. It uses a low-g and a high-g detector to detect freefall start and freefall end.
It provides a trigger indicating freefall event and the freefall duration. The duration is given in number of samples and
can be converted to freefall distance in meters by applying the following formula:
FF_DISTANCE = 0.5 * 9.81 * (FF_DUR * DMP_ODR_S)^2
Note: DMP_ODR_S is the duration of DMP_ODR expressed in seconds.
Freefall Detection configuration parameters
1. LOWG_PEAK_TH_SEL (Register 0x44h in Bank 4)
2. LOWG_TIME_TH_SEL (Register 0x44h in Bank 4)
3. LOWG_PEAK_TH_HYST_SEL (Register 0x43h in Bank 4)
4. HIGHG_PEAK_TH_SEL (Register 0x45h in Bank 4)
5. HIGHG_TIME_TH_SEL (Register 0x45h in Bank 4)
6. HIGHG_PEAK_TH_HYST_SEL (Register 0x43h in Bank 4)
7. FF_MIN_DURATION_CM (Register 0x49h in Bank 4)
8. FF_MAX_DURATION_CM (Register 0x49h in Bank 4)
9. FF_DEBOUNCE_DURATION (Register 0x49h in Bank 4)
1. Set Accel ODR to 500 Hz (Register 0x50h in Bank 0)
2. Set AVG filtering to 1 sample to minimize power consumption (Register 0x52h in Bank 0)
ACCEL_UI_FILT_BW = 1
3. Set Accel to Low Power mode (Register 0x4E in Bank 0)
ACCEL_MODE[1:0] = 2
4. Set DMP ODR = 500 Hz (Register 0x56 in Bank 0)
DMP_ODR[1:0] = 1
1. Set LOWG_PEAK_TH_SEL (Register 0x44h in Bank 4)
2. Set LOWG_TIME_TH_SEL (Register 0x44h in Bank 4)
3. Set LOWG_PEAK_TH_HYST_SEL (Register 0x43 in Bank4)
4. Set HIGHG_PEAK_TH_SEL (Register 0x45h in Bank 4)
5. Set HIGHG_TIME_TH_SEL (Register 0x45h in Bank 4)
6. Set HIGHG_PEAK_TH_HYST_SEL (Register 0x43h in Bank4)
7. Set FF_DEBOUNCE_DURATION (Register 0x49h in Bank 4)
8. Set FF_MIN_DURATION_CM (Register 0x49h in Bank 4)
9. Set FF_MAX_DURATION_CM (Register 0x49h in Bank 4)
10. Set DMP_MEM_RESET_EN to 1 if DMP is started for the first time after reset (Register 0x4Bh in Bank
0)
11. Wait 1 millisecond
12. Set DMP_INIT_EN to 1 (Register 0x4Bh in Bank 0)
13. Enable FREEFALL detection, source for INT1 by setting bit 1 in register INT_SOURCE6 (Register 0x4Dh
in Bank 4) to 1. Or if INT2 is selected for FREEFALL detection, enable FREEFALL detection source by
setting bit 1 in register INT_SOURCE7 (Register 0x4Eh in Bank 4) to 1.
14. Wait 50 milliseconds
15. As freefall and pedometer share the same output register, they cannot run concurrently. Disable
pedometer by setting PED_ENABLE to 0 (Register 0x56h in Bank 0)
16. Set FF_ENABLE to 1 (Register 0x56h in Bank 0)
Output registers
1. Read interrupt register (Register 0x38h in Bank 0) for FF_DET_INT
Revision: 1.2
Page 47 of 119
IIM-42652
2.
Read the freefall duration (Registers 0x31h and 0x32h in Bank 0)
Note: As freefall and pedometer share the same output register, they cannot be run concurrently.
TAP DETECTION PROGRAMMING
Tap Detection configuration parameters
1. TAP_TMAX (Register 0x47h in Bank 4)
2. TAP_TMIN (Register 0x47h in Bank 4)
3. TAP_TAVG (Register 0x47h in Bank 4)
4. TAP_MIN_JERK_THR (Register 0x46h in Bank 4)
5. TAP_MAX_PEAK_TOL (Register 0x46h in Bank 4)
6. TAP_ENABLE (Register 0x56h in Bank 0)
ACCEL_ODR = 15 for 500 Hz (ODR of 200Hz or 1kHz may also be used)
2. Set power modes and filter configurations as shown below
For ODR up to 500 Hz, set Accel to Low Power mode (Register 0x4Eh in Bank 0)
ACCEL_MODE = 2 and ACCEL_LP_CLK_SEL = 0, (Register 0x4Dh in Bank 0) for low power
mode
Set filter settings as follows: ACCEL_DEC2_M2_ORD = 2 (Register 0x53h in Bank 0);
ACCEL_UI_FILT_BW = 4 (Register 0x52h in Bank 0)
For ODR of 1 kHz, set Accel to Low Noise mode (Register 0x4Eh in Bank 0) ACCEL_MODE
=1
Set filter settings as follows: ACCEL_UI_FILT_ORD = 2 (Register 0x53h in Bank 0);
ACCEL_UI_FILT_BW = 0 (Register 0x52h in Bank 0)
3.
Wait 1 millisecond
1. Set TAP_TMAX to 2 (Register 0x47h in Bank 4)
2. Set TAP_TMIN to 3 (Register 0x47h in Bank 4)
3. Set TAP_TAVG to 3 (Register 0x47h in Bank 4)
4. Set TAP_MIN_JERK_THR to 17 (Register 0x46h in Bank 4)
5. Set TAP_MAX_PEAK_TOL to 2 (Register 0x46h in Bank 4)
6. Wait 1 millisecond
7. Enable TAP source for INT1 by setting bit 0 in register INT_SOURCE6 (Register 0x4Dh in Bank 4) to 1.
Or if INT2 is selected for TAP, enable TAP source by setting bit 0 in register INT_SOURCE7 (Register
8. Wait 50 milliseconds
9. Turn on TAP feature by setting TAP_ENABLE to 1 (Register 0x56h in Bank 0)
Output registers
1. Read interrupt register (Register 0x38h in Bank 0) for TAP_DET_INT
2. Read the tap count in TAP_NUM (Register 0x7Bh in Bank 0)
3. Read the tap axis in TAP_AXIS (Register 0x7Bh in Bank 0)
4. Read the polarity of tap pulse in TAP_DIR (Register 0x7Bh in Bank 0)
WAKE ON MOTION PROGRAMMING
Wake on Motion configuration parameters
1. WOM_X_TH (Register 0x4Ah in Bank 4)
Revision: 1.2
Page 48 of 119
IIM-42652
2.
3.
4.
5.
6.
WOM_Y_TH (Register 0x4Bh in Bank 4)
WOM_Z_TH (Register 0x4Ch in Bank 4)
WOM_INT_MODE (Register 0x57h in Bank 0)
WOM_MODE (Register 0x57h in Bank 0)
SMD_MODE (Register 0x57h in Bank 0)
3. Wait 1 millisecond
1. Set WOM_X_TH to 98 (Register 0x4Ah in Bank 4)
2. Set WOM_Y_TH to 98 (Register 0x4Bh in Bank 4)
3. Set WOM_Z_TH to 98 (Register 0x4Ch in Bank 4)
5. Enable all 3 axes as WOM sources for INT1 by setting bits 2:0 in register INT_SOURCE1 (Register
0x66h in Bank 0) to 1. Or if INT2 is selected for WOM, enable all 3 axes as WOM sources by setting
bits 2:0 in register INT_SOURCE4 (Register 0x69h in Bank 0) to 1.
6. Wait 50 milliseconds
7. Turn on WOM feature by setting WOM_INT_MODE to 0, WOM_MODE to 1, SMD_MODE to 1
Output registers
1. Read interrupt register (Register 0x37h in Bank 0) for WOM_X_INT
2. Read interrupt register (Register 0x37h in Bank 0) for WOM_Y_INT
3. Read interrupt register (Register 0x37h in Bank 0) for WOM_Z_INT
SIGNIFICANT MOTION DETECTION PROGRAMMING
Significant Motion Detection configuration parameters
2. WOM_Y_TH (Register 0x4Bh in Bank 4)
3. WOM_Z_TH (Register 0x4Ch in Bank 4)
4. WOM_INT_MODE (Register 0x57h in Bank 0)
5. WOM_MODE (Register 0x57h in Bank 0)
6. SMD_MODE (Register 0x57h in Bank 0)
Revision: 1.2
Page 49 of 119
IIM-42652
5. Enable SMD source for INT1 by setting bit 3 in register INT_SOURCE1 (Register 0x66h in Bank 0) to 1.
Or if INT2 is selected for SMD, enable SMD source by setting bit 3 in register INT_SOURCE4 (Register
7. Turn on SMD feature by setting WOM_INT_MODE to 0, WOM_MODE to 1, SMD_MODE to 3
Output registers
1. Read interrupt register (Register 0x37h in Bank 0) for SMD_INT
Revision: 1.2
Page 50 of 119
IIM-42652
9 DIGITAL INTERFACE
I3CSM, I2C, AND SPI SERIAL INTERFACES
The internal registers and memory of the IIM-42652 can be accessed using I3CSM at 12.5 MHz (data rates up to
12.5 Mbps in SDR mode, 25 Mbps in DDR mode), I2C at 1 MHz or SPI at 24 MHz. SPI operates in 3-wire or 4-wire mode.
Pin assignments for serial interfaces are described in Section 4.1.
I3CSM INTERFACE
I3CSM is a new 2-wire digital interface comprised of the signals serial data (SDA) and serial clock (SCLK). I3CSM is
intended to improve upon the I2C interface, while preserving backward compatibility.
I3CSM carries the advantages of I²C in simplicity, low pin count, easy board design, and multi-drop (vs. point to point),
but provides the higher data rates, simpler pads, and lower power of SPI. I3CSM adds higher throughput for a given
frequency, in-band interrupts (from slave to master), dynamic addressing.
IIM-42652 supports the following features of I3CSM:
SDR data rate up to 12.5 Mbps
DDR data rate up to 25 Mbps
Dynamic address allocation
Support for asynchronous timing control mode 0
Error detection (CRC and/or Parity)
Common Command Code (CCC)
The IIM-42652 always operates as an I3CSM slave device when communicating to the system processor, which thus
acts as the I3CSM master. I3CSM master controls an active pullup resistance on SDA, which it can enable and disable.
The pullup resistance may be a board level resistor controlled by a pin, or it may be internal to the I3CSM master.
I2C INTERFACE
I2C is a two-wire interface comprised of the signals serial data (SDA) and serial clock (SCL). In general, the lines are
open-drain and bi-directional. In a generalized I2C interface implementation, attached devices can be a master or a
slave. The master device puts the slave address on the bus, and the slave device with the matching address
acknowledges the master.
The IIM-42652 always operates as a slave device when communicating to the system processor, which thus acts as the
master. SDA and SCL lines typically need pull-up resistors to VDDIO. The maximum bus speed is 1 MHz.
The slave address of the IIM-42652 is b110100X, which is 7 bits long. The LSB bit of the 7-bit address is determined by
the logic level on pin AP_AD0. This allows two IIM-42652s to be connected to the same I2C bus. When used in this
configuration, the address of one of the devices should be b1101000 (pin AP_AD0 is logic low) and the address of the
other should be b1101001 (pin AP_AD0 is logic high).
I2C COMMUNICATIONS PROTOCOL
START (S) and STOP (P) Conditions
Communication on the I2C bus starts when the master puts the START condition (S) on the bus, which is defined as a
HIGH-to-LOW transition of the SDA line while SCL line is HIGH (see figure below). The bus is considered to be busy
until the master puts a STOP condition (P) on the bus, which is defined as a LOW to HIGH transition on the SDA line
while SCL is HIGH (see figure below).
Additionally, the bus remains busy if a repeated START (Sr) is generated instead of a STOP condition.
Revision: 1.2
Page 51 of 119
IIM-42652
SDA
SCL
S
P
START condition
STOP condition
Figure 12. START and STOP Conditions
Data Format / Acknowledge
I2C data bytes are defined to be 8-bits long. There is no restriction to the number of bytes transmitted per data
transfer. Each byte transferred must be followed by an acknowledge (ACK) signal. The clock for the acknowledge
signal is generated by the master, while the receiver generates the actual acknowledge signal by pulling down SDA
and holding it low during the HIGH portion of the acknowledge clock pulse.
If a slave is busy and cannot transmit or receive another byte of data until some other task has been performed, it can
hold SCL LOW, thus forcing the master into a wait state. Normal data transfer resumes when the slave is ready and
releases the clock line (refer to Figure 14).
DATA OUTPUT BY
TRANSMITTER (SDA)
not acknowledge
DATA OUTPUT BY
RECEIVER (SDA)
acknowledge
SCL FROM
MASTER
1
2
8
9
clock pulse for
acknowledgement
START
condition
Figure 13. Acknowledge on the I2C Bus
Communications
After beginning communications with the START condition (S), the master sends a 7-bit slave address followed by an
8th bit, the read/write bit. The read/write bit indicates whether the master is receiving data from or is writing to the
slave device. Then, the master releases the SDA line and waits for the acknowledge signal (ACK) from the slave device.
Each byte transferred must be followed by an acknowledge bit. To acknowledge, the slave device pulls the SDA line
LOW and keeps it LOW for the high period of the SCL line. Data transmission is always terminated by the master with a
STOP condition (P), thus freeing the communications line. However, the master can generate a repeated START
condition (Sr), and address another slave without first generating a STOP condition (P). A LOW to HIGH transition on
the SDA line while SCL is HIGH defines the stop condition. All SDA changes should take place when SCL is low, with the
exception of start and stop conditions.
Revision: 1.2
Page 52 of 119
IIM-42652
SDA
SCL
1–7
8
8
1–7
9
9
1–7
8
9
S
P
START ADDRESS
condition
R/W
DATA
ACK
DATA
ACK
ACK
STOP
condition
Figure 14. Complete I2C Data Transfer
To write the internal IIM-42652 registers, the master transmits the start condition (S), followed by the I2C address and
the write bit (0). At the 9th clock cycle (when the clock is high), the IIM-42652 acknowledges the transfer. Then the
master puts the register address (RA) on the bus. After the IIM-42652 acknowledges the reception of the register
address, the master puts the register data onto the bus. This is followed by the ACK signal, and data transfer may be
concluded by the stop condition (P). To write multiple bytes after the last ACK signal, the master can continue
outputting data rather than transmitting a stop signal. In this case, the IIM-42652 automatically increments the
register address and loads the data to the appropriate register. The following figures show single and two-byte write
sequences.
Single-Byte Write Sequence
Master
Slave
S
AD+W
RA
ACK
DATA
ACK
P
ACK
Burst Write Sequence
Master
Slave
S
AD+W
RA
ACK
DATA
ACK
DATA
ACK
P
ACK
To read the internal IIM-42652 registers, the master sends a start condition, followed by the I2C address and a write
bit, and then the register address that is going to be read. Upon receiving the ACK signal from the IIM-42652, the
master transmits a start signal followed by the slave address and read bit. As a result, the IIM-42652 sends an ACK
signal and the data. The communication ends with a not acknowledge (NACK) signal and a stop bit from master. The
NACK condition is defined such that the SDA line remains high at the 9th clock cycle. The following figures show single
and two-byte read sequences.
Single-Byte Read Sequence
Master
Slave
S
AD+W
RA
ACK
S
AD+R
ACK
NACK
ACK
P
DATA
Burst Read Sequence
Master
Slave
S
AD+W
Revision: 1.2
RA
ACK
S
ACK
AD+R
ACK
ACK
Page 53 of 119
DATA
NACK
DATA
P
IIM-42652
I2C TERMS
SIGNAL
S
AD
W
R
ACK
NACK
RA
DATA
P
DESCRIPTION
Start Condition: SDA goes from high to low while SCL is high
Slave I2C address
Write bit (0)
Read bit (1)
Acknowledge: SDA line is low while the SCL line is high at the 9th clock cycle
Not-Acknowledge: SDA line stays high at the 9th clock cycle
IIM-42652 internal register address
Transmit or received data
Stop condition: SDA going from low to high while SCL is high
Table 14. I2C Terms
SPI INTERFACE
The IIM-42652 supports 3-wire or 4-wire SPI for the host interface. The IIM-42652 always operates as a Slave device
during standard Master-Slave SPI operation.
With respect to the Master, the Serial Clock output (SCLK), the Serial Data Output (SDO), the Serial Data Input (SDI),
and the Serial Data IO (SDIO) are shared among the Slave devices. Each SPI slave device requires its own Chip Select
(CS) line from the master.
CS goes low (active) at the start of transmission and goes back high (inactive) at the end. Only one CS line is active at a
time, ensuring that only one slave is selected at any given time. The CS lines of the non-selected slave devices are held
high, causing their SDO lines to remain in a high-impedance (high-z) state so that they do not interfere with any active
devices.
SPI Operational Features
1. Data is delivered MSB first and LSB last
2. Data is latched on the rising edge of SCLK
3. Data should be transitioned on the falling edge of SCLK
4. The maximum frequency of SCLK is 24 MHz
5. SPI read operations are completed in 16 or more clock cycles (two or more bytes). The first byte contains
the SPI Address, and the following byte(s) contain(s) the SPI data. The first bit of the first byte contains the
Read/Write bit and indicates the Read (1) operation. The following 7 bits contain the Register Address. In
cases of multiple-byte Reads, data is two or more bytes:
SPI Address format
MSB
R/W
A6
A5
A4
A3
A2
A1
LSB
A0
D1
LSB
D0
SPI Data format
MSB
D7
D6
D5
D4
D3
D2
6.
SPI write operations are completed in 16 clock cycles (two bytes). The first byte contains the SPI Address,
and the second byte contains the SPI data. The first bit of the first byte contains the Read/Write bit and
indicates the Write (0) operation. The following 7 bits contain the Register Address.
7.
Supports Single or Burst Reads and Single Writes.
Revision: 1.2
Page 54 of 119
IIM-42652
SCLK
SPI Master
SDIO
CS1
nCS
SPI Slave 1
CS2
SCLK
SDIO
nCS
SPI Slave 2
Figure 15. Typical SPI Master/Slave Configuration
Revision: 1.2
Page 55 of 119
IIM-42652
10 ASSEMBLY
This section provides general guidelines for assembling InvenSense Micro Electro-Mechanical Systems (MEMS) devices
packaged in LGA package.
ORIENTATION OF AXES
Figure 16 shows the orientation of the axes of sensitivity and the polarity of rotation. Note the pin 1 identifier (•) in
the figure.
+Z
+Y
+Z
+Y
+X
+X
Figure 16. Orientation of Axes of Sensitivity and Polarity of Rotation
Revision: 1.2
Page 56 of 119
IIM-42652
PACKAGE DIMENSIONS
14 Lead LGA (2.5x3x0.91) mm NiAu pad finish
Figure 17. Package Dimensions
Revision: 1.2
Page 57 of 119
IIM-42652
DIMENSIONS IN MILLIMETERS
Total Thickness
Substrate Thickness
Mold Thickness
Body Size
Lead Width
Lead Length
Lead Pitch
Lead Count
Edge Pin Center to Center
Body Center to Contact Pin
Package Edge Tolerance
Mold Flatness
Coplanarity
Revision: 1.2
SYMBOLS
A
A1
A2
MIN
0.85
NOM
0.91
0.105
0.8
MAX
0.97
REF
REF
D
2.5
BSC
E
3
BSC
W
0.2
0.25
0.3
L
e
n
0.425
0.475
0.5
14
0.525
BSC
D1
1.5
BSC
E1
SD
aaa
bbb
ddd
1
0.25
0.1
0.2
0.08
BSC
BSC
Page 58 of 119
IIM-42652
11 PART NUMBER PACKAGE MARKING
The part number package marking for IIM-42652 devices is summarized below:
PART NUMBER
IIM-42652
I4652
TOP VIEW
Part Number
Lot Traceability Code
I4652
I4265
XXXXXX
YYWW
Y Y = Year Code
W W = Work Week
Figure 18. Part Number Package Marking
Revision: 1.2
Page 59 of 119
IIM-42652
12 USE NOTES
ACCELEROMETER MODE TRANSITIONS
When transitioning from accelerometer Low Power (LP) mode to accelerometer Low Noise (LN) mode, if ODR is
6.25 Hz or lower, software should change ODR to a value of 12.5 Hz or higher, because accelerometer LN mode does
not support ODR values below 12.5 Hz.
When transitioning from accelerometer LN mode to accelerometer LP mode, if ODR is greater than 500 Hz, software
should change ODR to a value of 500 Hz or lower, because accelerometer LP mode does not support ODR values
above 500 Hz.
ACCELEROMETER LOW POWER (LP) MODE AVERAGING FILTER SETTING
Software drivers provided with the device use Averaging Filter setting of 16x. This setting is recommended for meeting
Android noise requirements in LP mode, and to minimize accelerometer offset variation when transitioning from LP to
Low Noise (LN) mode. 1x averaging filter can be used by following the setting configuration shown in section 14.38.
SETTINGS FOR I2C, I3CSM, AND SPI OPERATION
Upon bootup the device comes up in SPI mode. The following settings should be used for I2C, I3CSM, and SPI operation.
Scenario 1: INT1/INT2 pins are used for interrupt assertion in I3CSM mode.
REGISTER FIELD
I2C Driver Setting
SPI Driver Setting
1
I3CSM Driver
Setting
1
1
I3C_EN (bit 4, register INTF_CONFIG6, address 0x7C, bank 1)
I3C_SDR_EN (bit 0, register INTF_CONFIG6, address 0x7C, bank 1)
I3C_DDR_EN (bit 1, register INTF_CONFIG6, address 0x7C, bank 1)
I3C_BUS_MODE (bit 6, register INTF_CONFIG4, address 0x7A,
bank 1)
I2C_SLEW_RATE (bits 5:3, register DRIVE_CONFIG, address 0x13,
bank 0)
SPI_SLEW_RATE (bits 2:0, register DRIVE_CONFIG, address 0x13,
bank 0)
3
5
REGISTER FIELD
I2C Driver Setting
SPI Driver Setting
bank 1)
bank 0)
bank 0)
1
I3CSM Driver
Setting
1
1
1
5
5
1
1
1
Scenario 2: IBI is used for interrupt assertion in I3CSM mode.
1
1
1
NOTCH FILTER AND ANTI-ALIAS FILTER OPERATION
Use of Notch Filter and Anti-Alias Filter is supported only for Low Noise (LN) mode operation. The host is responsible
for keeping the UI path in LN mode while Notch Filter and Anti-Alias Filter are turned on.
EXTERNAL CLOCK INPUT EFFECT ON ODR
ODR values supported by the device scale with external clock frequency, if external clock input is used. The ODR
values shown in the datasheet are supported with external clock input frequency of 32 kHz. For any other external
clock input frequency, these ODR values will scale by a factor of (External clock value in kHz / 32). For example, if an
external clock frequency of 32.768 kHz is used, instead of ODR value of 500 Hz, it will be 500 * (32.768 / 32) = 512 Hz.
Revision: 1.2
Page 60 of 119
IIM-42652
INT_ASYNC_RESET CONFIGURATION
For register INT_CONFIG1 (bank 0 register 0x64) bit 4 INT_ASYNC_RESET, user should change setting to 0 from default
setting of 1, for proper INT1 and INT2 pin operation.
FIFO TIMESTAMP INTERVAL SCALING
When RTC_MODE =1 (bank 0 register 0x4D bit2) and register INTF_CONFIG5 (bank 1 register 0x7B) bit 2:1
(PIN9_FUNCTION) is set to 10 for CLKIN input;
THEN
If TMST_RES = 0 (corresponding to timestamp resolution of 1 µs), timestamp interval reported in FIFO requires
scaling by a factor of 32.768/RTC Frequency.
For example, when ODR = 1 kHz, RTC Frequency 32 kHz, the true timestamp interval should be 1000 μs. But the
value in FIFO toggles between 976 and 977. After scaling 976.5 * 32.768/32 = 1000 μs.
ELSE
If TMST_RES = 1 (corresponding to timestamp resolution of 1 RTC clock period), timestamp interval reported in
FIFO requires scaling by a factor of RTC clock period.
value in FIFO is 32. After scaling 1/32kHz*32 = 1000 μs.
If TMST_RES = 0 (corresponding to timestamp resolution of 1µs), timestamp interval reported in FIFO requires
scaling by a factor of 32/30.
For example, when ODR = 1 kHz, the true timestamp interval should be 1000 μs. But the value in FIFO toggles
between 937 and 938. After scaling 937.5 * 32/30 = 1000 μs.
If TMST_RES = 1 (corresponding to timestamp resolution of 16 µs), timestamp interval reported in FIFO
requires scaling by a factor of 16*32/30.
between 58 and 59. After scaling 58.5 * 16* 32/30 = 1000 μs.
ELSE
Timestamp interval reported in FIFO requires scaling by a factor of 32/30. For example, when ODR = 1 kHz, the true
timestamp interval should be 1000 µs. But the value in FIFO toggles between 937 and 938 µs. After scaling 937.5 *
32/30 = 1000 µs.
SUPPLEMENTARY INFORMATION FOR FIFO_HOLD_LAST_DATA_EN
This section contains supplementary information for using register field FIFO_HOLD_LAST_DATA_EN (bit 7) of register
INTF_CONFIG0 (address 0x4C, bank 0).
Revision: 1.2
Page 61 of 119
IIM-42652
The following table shows the values in FIFO:
16-BIT
FIFO
PACKET
0 (Insert Invalid code)
1 (“copy last valid” mode: No
invalid code insertion)
Valid sample
All values
in:
{-32766 to
+32767}
Invalid
sample
-32768
Valid sample
All values
in:
{-32768 to
+32767}
Invalid
sample
20-BIT FIFO PACKET
Gyro: All Even numbers in {-524256 to +524286}
Example: {-524256, -524254, -524252, -524250 …..+524284,
+524286}
Accel: Every Other Even number in {-524256 to +524284}
Example: {-524256, -524252, -524248, -524244 …..+524280,
+524284}
-524288
Gyro: All Even numbers in {-524288 to +524286}
Example: {-524288, -524286, -524284, -524282 …..+524284,
+524286 }
Accel: Every Other Even number in {-524288 to +524284}
Example: {-524288, -524284, -524280 …..+524280,
+524284}
Copy last valid sample
The following table shows the values in sense registers on reset:
Power On Reset till
First Sample
FIFO_HOLD_LAST_DATA_EN = 0
FIFO_HOLD_LAST_DATA_EN = 1
Accel/Gyro/Temperature Sensor = -32768
Accel/Gyro/Temperature Sensor = 0
The following table shows the values in sense registers after first sample is received. As shown in the table, the
combination of FIFO_HOLD_LAST_DATA_EN and FSYNC Tag determine the range of values read for valid samples and
invalid samples.
0 (Insert Invalid
code)
1 (“copy last
valid” mode: No
invalid code
insertion)
Valid sample
Invalid
sample
Valid sample
Revision: 1.2
Invalid
sample
FSYNC Enabled on one Sensor
Other Sensor Not
Sensor selected for FSYNC Tag
selected for FSYNC
tagging
FSYNC tagged
FSYNC not tagged
All values in:
All ODD values in:
All EVEN values in: All values in:
{-32766 to +32767} {-32765 to +32767}
{-32766 to
{-32766 to +32767}
+32766}
Registers do not receive invalid samples. Registers hold last valid sample until new one
arrives
All values in:
All ODD values in:
All EVEN values in:
All values in:
{-32768 to +32767} {-32767 to +32767}
{-32768 to
{-32768 to +32767}
+32766}
arrives
FSYNC tag
disabled
Page 62 of 119
IIM-42652
REGISTER VALUES MODIFICATION
The only register settings that user can modify during sensor operation are for ODR selection, FSR selection, and
sensor mode changes (register parameters GYRO_ODR, ACCEL_ODR, GYRO_FS_SEL, ACCEL_FS_SEL, GYRO_MODE,
ACCEL_MODE). User must not modify any other register values during sensor operation. The following procedure
must be used for other register values modification.
Turn Accel and Gyro Off
Modify register values
Turn Accel and/or Gyro On
Revision: 1.2
Page 63 of 119
IIM-42652
13 REGISTER MAP
This section lists the register map for the IIM-42652, for user banks 0, 1, 2, 4.
USER BANK 0 REGISTER MAP
Addr
(Hex)
Addr
(Dec.)
Register Name
Serial
I/F
11
17
DEVICE_CONFIG
R/W
13
19
DRIVE_CONFIG
R/W
14
Bit7
Bit6
Bit5
INT_CONFIG
Bit4
Bit3
Bit2
SPI_MODE
I2C_SLEW_RATE
INT2_DRIVE_
CIRCUIT
INT2_MODE
Bit0
SOFT_RESET_
CONFIG
SPI_SLEW_RATE
INT2_POLARI
TY
16
22
FIFO_CONFIG
R/W
1D
29
TEMP_DATA1_UI
SYNCR
1E
30
TEMP_DATA0_UI
SYNCR
TEMP_DATA[7:0]
1F
31
ACCEL_DATA_X1_UI
SYNCR
ACCEL_DATA_XI[15:8]
ACCEL_DATA_X0_UI
SYNCR
ACCEL_DATA_X[7:0]
21
33
ACCEL_DATA_Y1_UI
SYNCR
ACCEL_DATA_Y[15:8]
22
34
ACCEL_DATA_Y0_UI
SYNCR
ACCEL_DATA_YI[7:0]
23
35
ACCEL_DATA_Z1_UI
SYNCR
ACCEL_DATA_Z[15:8]
24
36
ACCEL_DATA_Z0_UI
SYNCR
ACCEL_DATA_Z[7:0]
25
37
GYRO_DATA_X1_UI
SYNCR
GYRO _DATA_XI[15:8]
26
38
GYRO _DATA_X0_UI
SYNCR
GYRO _DATA_X[7:0]
27
39
GYRO _DATA_Y1_UI
SYNCR
GYRO _DATA_Y[15:8]
28
40
GYRO _DATA_Y0_UI
SYNCR
GYRO _DATA_YI[7:0]
29
41
GYRO _DATA_Z1_UI
SYNCR
GYRO_DATA_ZI[15:8]
2A
42
GYRO _DATA_Z0_UI
SYNCR
GYRO_DATA_ZI[7:0]
2B
43
TMST_FSYNCH
SYNCR
TMST_FSYNC_DATA[15:8]
2C
44
TMST_FSYNCL
SYNCR
TMST_FSYNC_DATA[7:0]
2D
45
INT_STATUS
R/C
2E
46
FIFO_COUNTH
R
FIFO_COUNT[15:8]
2F
47
FIFO_COUNTL
R
FIFO_COUNT[7:0]
30
48
FIFO_DATA
R
FIFO_DATA
31
49
APEX_DATA0
SYNCR
STEP_CNT[7:0] / FF_DUR[7:0]
32
50
APEX_DATA1
SYNCR
STEP_CNT[15:8] / FF_DUR[15:8]
33
51
APEX_DATA2
R
34
52
APEX_DATA3
R
35
53
APEX_DATA4
R
36
54
APEX_DATA5
R
37
55
INT_STATUS2
R/C
FIFO_MODE
INT1_MODE
INT1_DRIVE_
CIRCUIT
INT1_POLARI
TY
FIFO_THS_IN
T
FIFO_FULL_I
NT
AGC_RDY_IN
T
TEMP_DATA[15:8]
FSYNC_INT
PLL_RDY_INT
RESET_DONE
_INT
DATA_RDY_I
NT
STEP_CADENCE
DMP_IDLE
TAP_NUM
ACTIVITY_CLASS
TAP_AXIS
TAP_DIR
DOUBLE_TAP_TIMING
SMD_INT
WOM_Z_INT
WOM_Y_INT
WOM_X_INT
STEP_DET_IN
T
STEP_CNT_O
VF_INT
TILT_DET_IN
T
FF_DET_INT
TAP_DET_INT
ABORT_AND
_RESET
TMST_STROB
E
FIFO_FLUSH
38
56
INT_STATUS3
R/C
4B
75
SIGNAL_PATH_RESET
W/C
DMP_INIT_E
N
DMP_MEM_
RESET_EN
4C
76
INTF_CONFIG0
R/W
FIFO_HOLD_L
AST_DATA_E
N
FIFO_COUNT
_REC
FIFO_COUNT
_ENDIAN
SENSOR_DAT
A_ENDIAN
4D
77
INTF_CONFIG1
R/W
4E
78
PWR_MGMT0
R/W
4F
79
GYRO_CONFIG0
R/W
GYRO_UI_FS_SEL
50
80
ACCEL_CONFIG0
R/W
ACCEL_UI_FS_SEL
51
81
GYRO_CONFIG1
R/W
TEMP_FILT_BW
52
82
GYRO_ACCEL_CONFIG0
R/W
ACCEL_UI_FILT_BW
53
83
ACCEL_CONFIG1
R/W
Revision: 1.2
Bit1
ACCEL_LP_CL
K_SEL
TEMP_DIS
IDLE
RTC_MODE
CLKSEL
GYRO_MODE
ACCEL_MODE
GYRO_ODR
ACCEL_ODR
GYRO_UI_FILT_ORD
GYRO_DEC2_M2_ORD
GYRO_UI_FILT_BW
ACCEL_UI_FILT_ORD
Page 64 of 119
UI_SIFS_CFG
ACCEL_DEC2_M2_ORD
IIM-42652
Addr
(Hex)
Addr
(Dec.)
Register Name
Serial
I/F
Bit7
Bit6
Bit5
Bit4
Bit3
Bit2
Bit1
Bit0
TMST_TO_RE
GS_EN
TMST_RES
TMST_DELTA
_EN
TMST_FSYNC
_EN
TMST_EN
TILT_ENABLE
FF_ENABLE
DMP_ODR
WOM_INT_
MODE
WOM_MODE
SMD_MODE
FIFO_TMST_F
SYNC_EN
FIFO_TEMP_
EN
54
84
TMST_CONFIG
R/W
56
86
APEX_CONFIG0
R/W
57
87
SMD_CONFIG
R/W
5F
95
FIFO_CONFIG1
R/W
60
96
FIFO_CONFIG2
R/W
61
97
FIFO_CONFIG3
R/W
62
98
FSYNC_CONFIG
R/W
63
99
INT_CONFIG0
R/W
64
100
INT_CONFIG1
R/W
INT_TPULSE_
DURATION
INT_TDEASSE
RT_DISABLE
INT_ASYNC_
RESET
65
101
INT_SOURCE0
R/W
UI_FSYNC_IN
T1_EN
PLL_RDY_INT
1_EN
RESET_DONE
_INT1_EN
66
102
INT_SOURCE1
R/W
I3C_PROTOC
OL_ERROR_I
NT1_EN
68
104
INT_SOURCE3
R/W
UI_FSYNC_IN
T2_EN
69
105
INT_SOURCE4
R/W
I3C_PROTOC
OL_ERROR_I
NT2_EN
6C
108
FIFO_LOST_PKT0
R
6D
109
FIFO_LOST_PKT1
R
70
112
SELF_TEST_CONFIG
R/W
75
117
WHO_AM_I
R
76
118
REG_BANK_SEL
R/W
DMP_POWE
R_SAVE
TAP_ENABLE
PED_ENABLE
FIFO_RESUM
E_PARTIAL_R
D
FIFO_WM_G
T_TH
FIFO_HIRES_
EN
FIFO_GYRO_
EN
FIFO_ACCEL_
EN
FIFO_WM[7:0]
FIFO_WM[11:8]
FSYNC_UI_SEL
FSYNC_UI_FL
AG_CLEAR_S
EL
UI_DRDY_INT_CLEAR
FIFO_THS_INT_CLEAR
PLL_RDY_INT
2_EN
RESET_DONE
_INT2_EN
FSYNC_POLA
RITY
FIFO_FULL_INT_CLEAR
UI_DRDY_INT
1_EN
FIFO_THS_IN
T1_EN
FIFO_FULL_I
NT1_EN
UI_AGC_RDY
_INT1_EN
SMD_INT1_E
N
WOM_Z_INT
1_EN
WOM_Y_INT
1_EN
WOM_X_INT
1_EN
UI_DRDY_INT
2_EN
FIFO_THS_IN
T2_EN
FIFO_FULL_I
NT2_EN
UI_AGC_RDY
_INT2_EN
SMD_INT2_E
N
WOM_Z_INT
2_EN
WOM_Y_INT
2_EN
WOM_X_INT
2_EN
EN_GZ_ST
EN_GY_ST
EN_GX_ST
FIFO_LOST_PKT_CNT[15:8]
FIFO_LOST_PKT_CNT[7:0]
ACCEL_ST_P
OWER
EN_AZ_ST
EN_AY_ST
EN_AX_ST
WHOAMI
BANK_SEL
USER BANK 1 REGISTER MAP
Addr
(Hex)
Addr
(Dec.)
Register Name
Serial
I/F
03
03
SENSOR_CONFIG0
R/W
0B
11
GYRO_CONFIG_STATIC2
R/W
Bit7
Bit6
Bit5
Bit4
Bit3
Bit2
ZG_DISABLE
YG_DISABLE
XG_DISABLE
ZA_DISABLE
0C
12
GYRO_CONFIG_STATIC3
R/W
0D
13
GYRO_CONFIG_STATIC4
R/W
0E
14
GYRO_CONFIG_STATIC5
R/W
0F
15
GYRO_CONFIG_STATIC6
R/W
GYRO_X_NF_COSWZ[7:0]
10
16
GYRO_CONFIG_STATIC7
R/W
GYRO_Y_NF_COSWZ[7:0]
11
17
GYRO_CONFIG_STATIC8
R/W
12
18
GYRO_CONFIG_STATIC9
R/W
13
19
GYRO_CONFIG_STATIC10
R/W
Bit0
YA_DISABLE
XA_DISABLE
GYRO_AAF_D
IS
GYRO_NF_DI
S
GYRO_AAF_DELT
GYRO_AAF_DELTSQR[7:0]
GYRO_AAF_BITSHIFT
GYRO_AAF_DELTSQR[11:8]
GYRO_Z_NF_COSWZ[7:0]
GYRO_Z_NF_
COSWZ_SEL[
0]
GYRO_Y_NF_
COSWZ_SEL[
0]
GYRO_X_NF_
COSWZ_SEL[
0]
GYRO_NF_BW_SEL
GYRO_Z_NF_
COSWZ[8]
GYRO_Y_NF_
COSWZ[8]
GYRO_HPF_BW_IND
5F
95
XG_ST_DATA
R/W
XG_ST_DATA
60
96
YG_ST_DATA
R/W
YG_ST_DATA
61
97
ZG_ST_DATA
R/W
ZG_ST_DATA
62
98
TMSTVAL0
R
TMST_VALUE[7:0]
63
99
TMSTVAL1
R
64
100
TMSTVAL2
R
Document Number: DS-000401
Revision: 1.2
Bit1
TMST_VALUE[15:8]
Page 65 of 119
TMST_VALUE[19:16]
GYRO_X_NF_
COSWZ[8]
GYRO_HPF_O
RD_IND
IIM-42652
Addr
(Hex)
Addr
(Dec.)
Register Name
Serial
I/F
7A
122
INTF_CONFIG4
R/W
7B
123
INTF_CONFIG5
R/W
7C
124
INTF_CONFIG6
R/W
Bit7
Bit6
I3C_BUS_MO
DE
Bit5
Bit4
Bit3
Bit2
ASYNCTIME0
_DIS
Bit1
Bit0
SPI_AP_4WIR
E
PIN9_FUNCTION
I3C_EN
I3C_IBI_BYTE
_EN
I3C_IBI_EN
I3C_DDR_EN
I3C_SDR_EN
Bit4
Bit3
Bit2
Bit1
Bit0
USER BANK 2 REGISTER MAP
Addr
(Hex)
Addr
(Dec.)
Register Name
Serial
I/F
Bit7
03
03
ACCEL_CONFIG_STATIC2
R/W
04
04
ACCEL_CONFIG_STATIC3
R/W
05
05
ACCEL_CONFIG_STATIC4
R/W
3B
59
XA_ST_DATA
R/W
XA_ST_DATA
3C
60
YA_ST_DATA
R/W
YA_ST_DATA
3D
61
ZA_ST_DATA
R/W
ZA_ST_DATA
Bit6
Bit5
ACCEL_AAF_
DIS
ACCEL_AAF_DELT
ACCEL_AAF_DELTSQR[7:0]
ACCEL_AAF_BITSHIFT
ACCEL_AAF_DELTSQR[11:8]
USER BANK 3 REGISTER MAP
Addr
(Hex)
Addr
(Dec.)
Register Name
Serial
I/F
Bit7
PIN7_PU_EN
Bit6
06
06
PU_PD_CONFIG1
R/W
PIN11_PU_E
N
0E
14
PU_PD_CONFIG2
R/W
PIN1_PU_EN
Bit5
Bit4
Bit3
Bit2
Bit1
Bit0
PIN9_PD_EN
PIN10_PU_E
N
PIN3_PU_EN
PIN2_PU_EN
PIN4_PD_EN
PIN1_PD_EN
PIN12_PU_E
N
PIN12_PD_E
N
PIN14_PU_E
N
PIN14_PD_E
N
PIN13_PU_E
N
PIN13_PD_E
N
Bit6
Bit5
Bit4
Bit3
Bit2
Bit1
Bit0
USER BANK 4 REGISTER MAP
Addr
(Hex)
Addr
(Dec.)
Register Name
Serial
I/F
Bit7
09
40
09
FDR_CONFIG
R/W
64
APEX_CONFIG1
R/W
41
65
APEX_CONFIG2
R/W
PED_AMP_TH_SEL
42
66
APEX_CONFIG3
R/W
43
67
APEX_CONFIG4
R/W
44
68
APEX_CONFIG5
R/W
LOWG_PEAK_TH_SEL
LOWG_TIME_TH_SEL
45
69
APEX_CONFIG6
R/W
HIGHG_PEAK_TH_SEL
HIGHG_TIME_TH_SEL
46
70
APEX_CONFIG7
R/W
47
71
APEX_CONFIG8
R/W
48
72
APEX_CONFIG9
R/W
FDR_SEL
DMP_POWER_SAVE_TIME_SEL
PED_STEP_CNT_TH_SEL
PED_STEP_DET_TH_SEL
PED_SB_TIMER_TH_SEL
TILT_WAIT_TIME_SEL
PED_HI_EN_TH_SEL
TAP_MIN_JERK_THR
TAP_TMAX
TAP_MAX_PEAK_TOL
TAP_TAVG
TAP_TMIN
SENSITIVITY_
MODE
49
73
APEX_CONFIG10
R/W
4A
74
ACCEL_WOM_X_THR
R/W
FF_MIN_DURATION_CM
WOM_X_TH
FF_MAX_DURATION_CM
4B
75
ACCEL_WOM_Y_THR
R/W
WOM_Y_TH
4C
76
ACCEL_WOM_Z_THR
R/W
WOM_Z_TH
4D
77
INT_SOURCE6
R/W
STEP_DET_IN
T1_EN
4E
78
INT_SOURCE7
R/W
STEP_DET_IN
T2_EN
STEP_CNT_O
FL_INT2_EN
TILT_DET_IN
T2_EN
FREEFALL_DE
T_INT2_EN
TAP_DET_INT
2_EN
4F
79
INT_SOURCE8
R/W
FSYNC_IBI_E
N
PLL_RDY_IBI_
EN
UI_DRDY_IBI
_EN
FIFO_THS_IBI
_EN
FIFO_FULL_IB
I_EN
AGC_RDY_IBI
_EN
50
80
INT_SOURCE9
R/W
SMD_IBI_EN
WOM_Z_IBI_
EN
WOM_Y_IBI_
EN
WOM_X_IBI_
EN
51
81
INT_SOURCE10
R/W
STEP_CNT_O
FL_IBI_EN
TILT_DET_IBI
_EN
FREEFALL_DE
T_IBI_EN
TAP_DET_IBI
_EN
77
119
OFFSET_USER0
R/W
Revision: 1.2
I3C_PROTOC
OL_ERROR_I
BI_EN
STEP_DET_IB
I_EN
STEP_CNT_O
FL_INT1_EN
TILT_DET_IN
T1_EN
FREEFALL_DE
T_INT1_EN
TAP_DET_INT
1_EN
GYRO_X_OFFUSER[7:0]
Page 66 of 119
IIM-42652
Addr
(Hex)
Addr
(Dec.)
Register Name
Serial
I/F
78
120
OFFSET_USER1
R/W
79
121
OFFSET_USER2
R/W
7A
122
OFFSET_USER3
R/W
7B
123
OFFSET_USER4
R/W
7C
124
OFFSET_USER5
R/W
7D
125
OFFSET_USER6
R/W
7E
126
OFFSET_USER7
R/W
7F
127
OFFSET_USER8
R/W
Bit7
Bit6
Bit5
Bit4
Bit3
GYRO_Y_OFFUSER[11:8]
Bit2
Bit1
GYRO_X_OFFUSER[11:8]
GYRO_Y_OFFUSER[7:0]
GYRO_Z_OFFUSER[7:0]
ACCEL_X_OFFUSER[11:8]
GYRO_Z_OFFUSER[11:8]
ACCEL_X_OFFUSER[7:0]
ACCEL_Y_OFFUSER[7:0]
ACCEL_Z_OFFUSER[11:8]
ACCEL_Y_OFFUSER[11:8]
ACCEL_Z_OFFUSER[7:0]
Detailed register descriptions are provided in the sections that follow. Please note the following regarding Clock
Domain for each register:
Clock Domain: SCLK_UI means that the register is controlled from the UI interface
Register fields marked as Reserved must not be modified by the user. The Reset Value of the register can be used to
determine the default value of reserved register fields, and unless otherwise noted this default value must be
maintained even if the values of other register fields are modified by the user.
must be used for register values modification:
• Turn Accel and Gyro Off
• Modify register values
• Turn Accel and/or Gyro On
Revision: 1.2
Page 67 of 119
Bit0
IIM-42652
14 USER BANK 0 REGISTER MAP – DESCRIPTIONS
This section describes the function and contents of each register within USR Bank 0.
Note: The device powers up in sleep mode.
DEVICE_CONFIG
Address: 17 (11h)
Serial IF: R/W
Reset value: 0x00
BIT NAME
7:5 4
SPI_MODE
3:1
SOFT_RESET_CONFIG
FUNCTION
Reserved
SPI mode selection
0: Mode 0 and Mode 3 (default)
1: Mode 1 and Mode 2
Reserved
Software reset configuration
0: Normal (default)
1: Enable reset
After writing 1 to this bitfield, wait 1ms for soft reset to be effective, before
attempting any other register access
DRIVE_CONFIG
Address: 19 (13h)
Serial IF: R/W
Reset value: 0x05
BIT NAME
7:6 -
5:3
I2C_SLEW_RATE
2:0
SPI_SLEW_RATE
Revision: 1.2
FUNCTION
Reserved
Controls slew rate for output pin 14 in I2C mode only
000: 20ns-60ns
001: 12ns-36ns
010: 6ns-18ns
011: 4ns-12ns
100: 2ns-6ns
101: < 2ns
110: Reserved
111: Reserved
Controls slew rate for output pin 14 in SPI or I3CSM mode, and for all other
output pins
000: 20ns-60ns
001: 12ns-36ns
010: 6ns-18ns
011: 4ns-12ns
100: 2ns-6ns
101: < 2ns
110: Reserved
111: Reserved
Page 68 of 119
IIM-42652
INT_CONFIG
Address: 20 (14h)
Serial IF: R/W
Reset value: 0x00
BIT NAME
7:6 5
INT2_MODE
4
INT2_DRIVE_CIRCUIT
3
INT2_POLARITY
2
INT1_MODE
1
INT1_DRIVE_CIRCUIT
INT1_POLARITY
FUNCTION
Reserved
INT2 interrupt mode
0: Pulsed mode
1: Latched mode
INT2 drive circuit
0: Open drain
1: Push pull
INT2 interrupt polarity
0: Active low (default)
1: Active high
INT1 interrupt mode
0: Pulsed mode
1: Latched mode
INT1 drive circuit
0: Open drain
1: Push pull
INT1 interrupt polarity
1: Active high
FIFO_CONFIG
Address: 22 (16h)
Serial IF: R/W
Reset value: 0x00
BIT NAME
7:6 FIFO_MODE
5:0
FUNCTION
00: Bypass Mode (default)
01: Stream-to-FIFO Mode
10: STOP-on-FULL Mode
11: STOP-on-FULL Mode
Reserved
TEMP_DATA1
Address: 29 (1Dh)
Serial IF: SYNCR
Reset value: 0x80
BIT NAME
7:0 TEMP_DATA[15:8]
Revision: 1.2
FUNCTION
Upper byte of temperature data
Page 69 of 119
IIM-42652
TEMP_DATA0
Address: 30 (1Eh)
Serial IF: SYNCR
Reset value: 0x00
BIT NAME
7:0 TEMP_DATA[7:0]
FUNCTION
Lower byte of temperature data
Temperature data value from the sensor data registers can be converted to degrees centigrade by using the following
formula:
Temperature in Degrees Centigrade = (TEMP_DATA / 132.48) + 25
FIFO_TEMP_DATA, temperature data stored in FIFO, can be 8-bit or 16-it quantity. The 8-bit of temperature data
stored in FIFO is limited to -40°C to 85°C range, while the 16-bit representation can support the full operating
temperature range. It can be converted to degrees centigrade by using the following formula:
Temperature in Degrees Centigrade = (FIFO_TEMP_DATA / 2.07) + 25
ACCEL_DATA_X1
Address: 31 (1Fh)
Serial IF: SYNCR
Reset value: 0x80
BIT NAME
7:0 ACCEL_DATA_X[15:8]
FUNCTION
Upper byte of Accel X-axis data
ACCEL_DATA_X0
Address: 32 (20h)
Serial IF: SYNCR
Reset value: 0x00
BIT NAME
7:0 ACCEL_DATA_X[7:0]
FUNCTION
Lower byte of Accel X-axis data
ACCEL_DATA_Y1
Address: 33 (21h)
Serial IF: SYNCR
Reset value: 0x80
BIT NAME
7:0 ACCEL_DATA_Y[15:8]
Revision: 1.2
FUNCTION
Upper byte of Accel Y-axis data
Page 70 of 119
IIM-42652
ACCEL_DATA_Y0
Address: 34 (22h)
Serial IF: SYNCR
Reset value: 0x00
BIT NAME
7:0 ACCEL_DATA_Y[7:0]
FUNCTION
Lower byte of Accel Y-axis data
ACCEL_DATA_Z1
Address: 35 (23h)
Serial IF: SYNCR
Reset value: 0x80
BIT NAME
7:0 ACCEL_DATA_Z[15:8]
FUNCTION
Upper byte of Accel Z-axis data
ACCEL_DATA_Z0
Address: 36 (24h)
Serial IF: SYNCR
Reset value: 0x00
BIT NAME
7:0 ACCEL_DATA_Z[7:0]
FUNCTION
Lower byte of Accel Z-axis data
GYRO_DATA_X1
Address: 37 (25h)
Serial IF: SYNCR
Reset value: 0x80
BIT NAME
7:0 GYRO_DATA_X[15:8]
FUNCTION
Upper byte of Gyro X-axis data
GYRO_DATA_X0
Address: 38 (26h)
Serial IF: SYNCR
Reset value: 0x00
BIT NAME
7:0 GYRO_DATA_X[7:0]
Revision: 1.2
FUNCTION
Lower byte of Gyro X-axis data
Page 71 of 119
IIM-42652
GYRO_DATA_Y1
Address: 39 (27h)
Serial IF: SYNCR
Reset value: 0x80
BIT NAME
7:0 GYRO_DATA_Y[15:8]
FUNCTION
Upper byte of Gyro Y-axis data
GYRO_DATA_Y0
Address: 40 (28h)
Serial IF: SYNCR
Reset value: 0x00
BIT NAME
7:0 GYRO_DATA_Y[7:0]
FUNCTION
Lower byte of Gyro Y-axis data
GYRO_DATA_Z1
Address: 41 (29h)
Serial IF: SYNCR
Reset value: 0x80
BIT NAME
7:0 GYRO_DATA_Z[15:8]
FUNCTION
Upper byte of Gyro Z-axis data
GYRO_DATA_Z0
Address: 42 (2Ah)
Serial IF: SYNCR
Reset value: 0x00
BIT NAME
7:0 GYRO_DATA_Z[7:0]
FUNCTION
Lower byte of Gyro Z-axis data
TMST_FSYNCH
Address: 43 (2Bh)
Serial IF: SYNCR
Reset value: 0x00
BIT NAME
7:0
Revision: 1.2
FUNCTION
Stores the upper byte of the time delta from the rising edge of FSYNC to
the latest ODR until the UI Interface reads the FSYNC tag in the status
register
Page 72 of 119
IIM-42652
TMST_FSYNCL
Address: 44 (2Ch)
Serial IF: SYNCR
Reset value: 0x00
BIT NAME
7:0
FUNCTION
Stores the lower byte of the time delta from the rising edge of FSYNC to
register
INT_STATUS
Address: 45 (2Dh)
Serial IF: R/C
Reset value: 0x10
BIT NAME
7
6
UI_FSYNC_INT
5
PLL_RDY_INT
4
RESET_DONE_INT
3
DATA_RDY_INT
2
FIFO_THS_INT
1
FIFO_FULL_INT
AGC_RDY_INT
FUNCTION
Reserved
This bit automatically sets to 1 when a UI FSYNC interrupt is generated. The
bit clears to 0 after the register has been read.
This bit automatically sets to 1 when a PLL Ready interrupt is generated. The
This bit automatically sets to 1 when software reset is complete. The bit
This bit automatically sets to 1 when a Data Ready interrupt is generated.
The bit clears to 0 after the register has been read.
This bit automatically sets to 1 when the FIFO buffer reaches the threshold
value. The bit clears to 0 after the register has been read.
This bit automatically sets to 1 when the FIFO buffer is full. The bit clears to
This bit automatically sets to 1 when an AGC Ready interrupt is generated.
FIFO_COUNTH
Address: 46 (2Eh)
Serial IF: R
Reset value: 0x00
BIT NAME
7:0
FIFO_COUNT[15:8]
Revision: 1.2
FUNCTION
High Bits, count indicates the number of records or bytes available in FIFO
according to FIFO_COUNT_REC setting.
Note: Must read FIFO_COUNTL to latch new data for both FIFO_COUNTH
and FIFO_COUNTL.
Page 73 of 119
IIM-42652
FIFO_COUNTL
Address: 47 (2Fh)
Serial IF: R
Reset value: 0x00
BIT NAME
7:0
FIFO_COUNT[7:0]
FUNCTION
Low Bits, count indicates the number of records or bytes available in FIFO
Reading this byte latches the data for both FIFO_COUNTH, and
FIFO_COUNTL.
FIFO_DATA
Address: 48 (30h)
Serial IF: R
Reset value: 0xFF
BIT NAME
7:0 FIFO_DATA
FUNCTION
FIFO data port
APEX_DATA0
Address: 49 (31h)
Serial IF: SYNCR
Reset value: 0x00
BIT NAME
STEP_CNT[7:0] (when
Pedometer is enabled)
7:0
FF_DUR[7:0] (when Freefall
Detection is enabled)
FUNCTION
Pedometer Output: Lower byte of Step Count measured by pedometer
Lower byte of Freefall Duration
APEX_DATA1
Address: 50 (32h)
Serial IF: SYNCR
Reset value: 0x00
BIT NAME
STEP_CNT[15:8] (when
7:0 FF_DUR[15:8] (when
Freefall Detection is
enabled)
Revision: 1.2
FUNCTION
Pedometer Output: Upper byte of Step Count measured by pedometer
Upper byte of Freefall Duration
Page 74 of 119
IIM-42652
APEX_DATA2
Address: 51 (33h)
Serial IF: R
Reset value: 0x00
BIT NAME
7:0
STEP_CADENCE
FUNCTION
Pedometer Output: Walk/run cadency in number of samples. Format is
u6.2. e.g. At 50Hz ODR and 2Hz walk frequency, the cadency is 25 samples.
The register will output 100.
APEX_DATA3
Address: 52 (34h)
Serial IF: R
Reset value: 0x04
BIT NAME
7:3 2
1:0
DMP_IDLE
ACTIVITY_CLASS
Revision: 1.2
FUNCTION
Reserved
0: Indicates DMP is running
1: Indicates DMP is idle
Pedometer Output: Detected activity
00: Unknown
01: Walk
10: Run
11: Reserved
Page 75 of 119
IIM-42652
APEX_DATA4
Address: 53 (35h)
Serial IF: R
Reset value: 0x00
BIT NAME
7:5 4:3
TAP_NUM
2:1
TAP_AXIS
TAP_DIR
FUNCTION
Reserved
Tap Detection Output: Number of taps in the current Tap event
00: No tap
01: Single tap
10: Double tap
11: Reserved
Tap Detection Output: Represents the accelerometer axis on which tap
energy is concentrated
00: X-axis
01: Y-axis
10: Z-axis
11: Reserved
Tap Detection Output: Polarity of tap pulse
0: Current accelerometer value – Previous accelerometer value is a positive
value
1: Current accelerometer value – Previous accelerometer value is a negative
value or zero
APEX_DATA5
Address: 54 (36h)
Serial IF: R
Reset value: 0x00
BIT NAME
7:6 -
5:0
DOUBLE_TAP_TIMING
Revision: 1.2
FUNCTION
Reserved
DOUBLE_TAP_TIMING measures the time interval between the two taps
when double tap is detected. It counts every 16 accelerometer samples as
one unit between the 2 tap pulses. Therefore, the value is related to the
accelerometer ODR.
Time in seconds = DOUBLE_TAP_TIMING * 16 / ODR
For example, if the accelerometer ODR is 500 Hz, and the
DOUBLE_TAP_TIMING register reading is 6, the time interval value is
6*16/500 = 0.192 seconds.
Page 76 of 119
IIM-42652
INT_STATUS2
Address: 55 (37h)
Serial IF: R/C
Reset value: 0x00
BIT NAME
7:4 3
SMD_INT
2
WOM_Z_INT
1
WOM_Y_INT
WOM_X_INT
FUNCTION
Reserved
Significant Motion Detection Interrupt, clears on read
Wake on Motion Interrupt on Z-axis, clears on read
Wake on Motion Interrupt on Y-axis, clears on read
Wake on Motion Interrupt on X-axis, clears on read
INT_STATUS3
Address: 56 (38h)
Serial IF: R/C
Reset value: 0x00
BIT NAME
7:6 5
STEP_DET_INT
4
STEP_CNT_OVF_INT
3
TILT_DET_INT
2
1
FF_DET_INT
TAP_DET_INT
FUNCTION
Reserved
Step Detection Interrupt, clears on read
Step Count Overflow Interrupt, clears on read
Tilt Detection Interrupt, clears on read
Reserved
Freefall Interrupt, clears on read
Tap Detection Interrupt, clears on read
SIGNAL_PATH_RESET
Address: 75 (4Bh)
Serial IF: W/C
Reset value: 0x00
BIT NAME
7
6
DMP_INIT_EN
5
DMP_MEM_RESET_EN
4
3
ABORT_AND_RESET
2
TMST_STROBE
1
FIFO_FLUSH
Revision: 1.2
FUNCTION
Reserved
When this bit is set to 1, the DMP is enabled
When this bit is set to 1, the DMP memory is reset
Reserved
When this bit is set to 1, the signal path is reset by restarting the ODR
counter and signal path controls
When this bit is set to 1, the time stamp counter is latched into the time
stamp register. This is a write on clear bit.
When set to 1, FIFO will get flushed.
Reserved
Page 77 of 119
IIM-42652
INTF_CONFIG0
Address: 76 (4Ch)
Serial IF: R/W
Reset value: 0x30
BIT NAME
FUNCTION
Setting this bit to 0:
In order to signal an invalid sample, and to differentiate it from a valid
sample based on values only:
Sense Registers:
• Do not receive invalid samples. They hold the last valid
sample. Repeated reading before new sample received will yield
copies of the last valid sample.
• Valid samples of values -32768, -32767 are replaced with -32766
• FSYNC Tagging can modify the least significant bit and further limit
values (see section 12.8).
7
FIFO:
• 16-bit FIFO packet: Same as Sense Registers, except:
o FSYNC tagging is not applied to data in FIFO.
• 20-bit FIFO packet:
o Invalid samples are indicated with the value -524288
o Valid samples in {-524288 to -524258} are replaced by 524256
o Valid Gyro samples: All Even numbers in { -524256 to
+524286}
o Valid Accel samples: All numbers divisible by 4 in {-524256 to
+524284}
Setting this bit to 1:
Sense registers:
FIFO:
• Invalid sample will get copy of last valid sample
o Valid Gyro samples: All Even numbers in {-524288 to
+524286}
o - Valid Accel samples: All numbers divisible by 4 in {-524288 to
+524284}
Revision: 1.2
Page 78 of 119
IIM-42652
Address: 76 (4Ch)
Serial IF: R/W
Reset value: 0x30
BIT NAME
6
FIFO_COUNT_REC
5
FIFO_COUNT_ENDIAN
4
SENSOR_DATA_ENDIAN
3:2
1:0
UI_SIFS_CFG
FUNCTION
0: FIFO count is reported in bytes
1: FIFO count is reported in records (1 record = 16 bytes for header + gyro +
accel + temp sensor data + time stamp, or 8 bytes for header + gyro/accel +
temp sensor data)
0: FIFO count is reported in Little Endian format
1: FIFO count is reported in Big Endian format (default)
0: Sensor data is reported in Little Endian format
1: Sensor data is reported in Big Endian format (default)
Reserved
0x: Reserved
10: Disable SPI
11: Disable I2C
Invalid Data Generation: FIFO/Sense Registers may contain invalid data under the following conditions:
a) From power on reset to first ODR sample of any sensor (accel, gyro, temp sensor)
b) When any sensor is disabled (accel, gyro, temp sensor)
c) When accel and gyro are enabled with different ODRs. In this case, the sensor with lower ODR will generate
invalid samples when it has no new data.
Invalid data can take special values or can hold last valid sample received. For -32768 to be used as a flag for invalid
accel/gyro samples, the valid accel/gyro sample range is limited in such case as well. Bit 7 of INTF_CONFIG0 controls
what values invalid (and valid) samples can take as shown above.
INTF_CONFIG1
Address: 77 (4Dh)
Serial IF: R/W
Reset value: 0x91
BIT NAME
7:4 3
ACCEL_LP_CLK_SEL
2
RTC_MODE
1:0
CLKSEL
Revision: 1.2
FUNCTION
Reserved
0: Accelerometer LP mode uses Wake Up oscillator clock
1: Accelerometer LP mode uses RC oscillator clock
0: No input RTC clock is required
1: RTC clock input is required
00: Always select internal RC oscillator
01: Select PLL when available, else select RC oscillator (default)
10: Reserved
11: Disable all clocks
Page 79 of 119
IIM-42652
PWR_MGMT0
Address: 78 (4Eh)
Serial IF: R/W
Reset value: 0x00
BIT NAME
7:6 5
TEMP_DIS
4
IDLE
3:2
1:0
GYRO_MODE
ACCEL_MODE
FUNCTION
Reserved
0: Temperature sensor is enabled (default)
1: Temperature sensor is disabled
If this bit is set to 1, the RC oscillator is powered on even if Accel and Gyro
are powered off.
Nominally this bit is set to 0, so when Accel and Gyro are powered off,
the chip will go to OFF state, since the RC oscillator will also be powered off
00: Turns gyroscope off (default)
01: Places gyroscope in Standby Mode
10: Reserved
11: Places gyroscope in Low Noise (LN) Mode
Gyroscope needs to be kept ON for a minimum of 45ms. When transitioning
from OFF to any of the other modes, do not issue any register writes for
200µs.
00: Turns accelerometer off (default)
01: Turns accelerometer off
10: Places accelerometer in Low Power (LP) Mode
11: Places accelerometer in Low Noise (LN) Mode
When transitioning from OFF to any of the other modes, do not issue any
register writes for 200µs.
Revision: 1.2
Page 80 of 119
IIM-42652
GYRO_CONFIG0
Address: 79 (4Fh)
Serial IF: R/W
Reset value: 0x06
BIT NAME
7:5
4
3:0
GYRO_FS_SEL
GYRO_ODR
Revision: 1.2
FUNCTION
Full scale select for gyroscope UI interface output
000: ±2000dps (default)
001: ±1000dps
010: ±500dps
011: ±250dps
100: ±125dps
101: ±62.5dps
110: ±31.25dps
111: ±15.625dps
Reserved
Gyroscope ODR selection for UI interface output
0000: Reserved
0001: 32kHz
0010: 16kHz
0011: 8kHz
0100: 4kHz
0101: 2kHz
0110: 1kHz (default)
0111: 200Hz
1000: 100Hz
1001: 50Hz
1010: 25Hz
1011: 12.5Hz
1100: Reserved
1101: Reserved
1110: Reserved
1111: 500Hz
Page 81 of 119
IIM-42652
ACCEL_CONFIG0
Address: 80 (50h)
Serial IF: R/W
Reset value: 0x06
BIT NAME
7:5
4
3:0
ACCEL_FS_SEL
ACCEL_ODR
Revision: 1.2
FUNCTION
Full scale select for accelerometer UI interface output
000: ±16g (default)
001: ±8g
010: ±4g
011: ±2g
100: Reserved
101: Reserved
110: Reserved
111: Reserved
Reserved
Accelerometer ODR selection for UI interface output
0000: Reserved
0001: 32kHz
0010: 16kHz
0011: 8kHz (LN mode)
0100: 4kHz (LN mode)
0101: 2kHz (LN mode)
0110: 1kHz (LN mode) (default)
0111: 200Hz (LP or LN mode)
1000: 100Hz (LP or LN mode)
1001: 50Hz (LP or LN mode)
1010: 25Hz (LP or LN mode)
1011: 12.5Hz (LP or LN mode)
1100: 6.25Hz (LP mode)
1101: 3.125Hz (LP mode)
1110: 1.5625Hz (LP mode)
1111: 500Hz (LP or LN mode)
Page 82 of 119
IIM-42652
GYRO_CONFIG1
Address: 81 (51h)
Serial IF: R/W
Reset value: 0x16
BIT NAME
7:5
4
TEMP_FILT_BW
3:2
GYRO_UI_FILT_ORD
1:0
GYRO_DEC2_M2_ORD
Revision: 1.2
FUNCTION
Sets the bandwidth of the temperature signal DLPF
000: DLPF BW = 4000Hz; DLPF Latency = 0.125ms (default)
001: DLPF BW = 170Hz; DLPF Latency = 1ms
010: DLPF BW = 82Hz; DLPF Latency = 2ms
011: DLPF BW = 40Hz; DLPF Latency = 4ms
100: DLPF BW = 20Hz; DLPF Latency = 8ms
101: DLPF BW = 10Hz; DLPF Latency = 16ms
110: DLPF BW = 5Hz; DLPF Latency = 32ms
111: DLPF BW = 5Hz; DLPF Latency = 32ms
Reserved
Selects order of GYRO UI filter
00: 1st Order
01: 2nd Order
10: 3rd Order
11: Reserved
Selects order of GYRO DEC2_M2 Filter
00: Reserved
01: Reserved
10: 3rd Order
11: Reserved
Page 83 of 119
IIM-42652
GYRO_ACCEL_CONFIG0
Address: 82 (52h)
Serial IF: R/W
Reset value: 0x11
BIT NAME
7:4
3:0
ACCEL_UI_FILT_BW
GYRO_UI_FILT_BW
Revision: 1.2
FUNCTION
LN Mode:
Bandwidth for Accel LPF
0 BW=ODR/2
1 BW=max(400Hz, ODR)/4 (default)
2 BW=max(400Hz, ODR)/5
3 BW=max(400Hz, ODR)/8
4 BW=max(400Hz, ODR)/10
5 BW=max(400Hz, ODR)/16
6 BW=max(400Hz, ODR)/20
7 BW=max(400Hz, ODR)/40
8 to 13: Reserved
14 Low Latency option: Trivial decimation @ ODR of Dec2 filter output. Dec2
runs at max(400Hz, ODR)
15 Low Latency option: Trivial decimation @ ODR of Dec2 filter output. Dec2
runs at max(200Hz, 8*ODR)
LP Mode:
0 Reserved
1 1x AVG filter (default)
2 to 5 Reserved
6 16x AVG filter
7 to 15 Reserved
LN Mode:
Bandwidth for Gyro LPF
0 BW=ODR/2
8 to 13: Reserved
Page 84 of 119
IIM-42652
ACCEL_CONFIG1
Address: 83 (53h)
Serial IF: R/W
Reset value: 0x0D
BIT NAME
7:5 4:3
ACCEL_UI_FILT_ORD
2:1
ACCEL_DEC2_M2_ORD
FUNCTION
Reserved
Selects order of ACCEL UI filter
00: 1st Order
01: 2nd Order
10: 3rd Order
11: Reserved
Order of Accelerometer DEC2_M2 filter
00: Reserved
01: Reserved
10: 3rd order
11: Reserved
Reserved
TMST_CONFIG
Address: 84 (54h)
Serial IF: R/W
Reset value: 0x23
BIT NAME
7:5 4
TMST_TO_REGS_EN
3
TMST_RES
2
TMST_DELTA_EN
1
TMST_FSYNC_EN
TMST_EN
Revision: 1.2
FUNCTION
Reserved
0: TMST_VALUE[19:0] read always returns 0s
1: TMST_VALUE[19:0] read returns timestamp value
Time Stamp resolution:
When set to 0 (default), time stamp resolution is 1 µs.
When set to 1: If RTC is disabled, resolution is 16 µs. If RTC is enabled,
resolution is 1 RTC clock period
Time Stamp delta enable: When set to 1, the time stamp field contains the
measurement of time since the last occurrence of ODR.
Time Stamp register FSYNC enable (default). When set to 1, the contents of
the Timestamp feature of FSYNC is enabled. The user also needs to select
FIFO_TMST_FSYNC_EN in order to propagate the timestamp value to the
FIFO.
0: Time Stamp register disable
1: Time Stamp register enable (default)
Page 85 of 119
IIM-42652
APEX_CONFIG0
Address: 86 (56h)
Serial IF: R/W
Reset value: 0x82
BIT NAME
7
DMP_POWER_SAVE
6
TAP_ENABLE
5
PED_ENABLE
4
TILT_ENABLE
3
2
FF_ENABLE
1:0
DMP_ODR
FUNCTION
0: DMP power save mode not active
1: DMP power save mode active (default)
0: Tap Detection not enabled
1: Tap Detection enabled when accelerometer ODR is set to one of the ODR
values supported by Tap Detection (200Hz, 500Hz, 1kHz)
0: Pedometer not enabled
1: Pedometer enabled
0: Tilt Detection not enabled
1: Tilt Detection enabled
Reserved
0: Freefall Detection not enabled
1: Freefall Detection enabled
00: 25Hz
01: 500 Hz
10: 50Hz
11: 100 Hz
SMD_CONFIG
Address: 87 (57h)
Serial IF: R/W
Reset value: 0x00
BIT NAME
7:4 3
WOM_INT_MODE
2
WOM_MODE
1:0
SMD_MODE
Revision: 1.2
FUNCTION
Reserved
0: Set WoM interrupt on the OR of all enabled accelerometer thresholds
1: Set WoM interrupt on the AND of all enabled accelerometer threshold
0: Initial sample is stored. Future samples are compared to initial sample
1: Compare current sample to previous sample
00: SMD disabled
01: WOM mode
10: SMD short (1 sec wait) An SMD event is detected when two WOM are
detected 1 sec apart
11: SMD long (3 sec wait) An SMD event is detected when two WOM are
detected 3 sec apart
Page 86 of 119
IIM-42652
FIFO_CONFIG1
Address: 95 (5Fh)
Serial IF: R/W
Reset value: 0x00
BIT NAME
7
6
FIFO_RESUME_PARTIAL_RD
5
FIFO_WM_GT_TH
4
FIFO_HIRES_EN
3
2
1
FIFO_TMST_FSYNC_EN
FIFO_TEMP_EN
FIFO_GYRO_EN
FIFO_ACCEL_EN
FUNCTION
Reserved
0: Partial FIFO read disabled, requires re-reading of the entire FIFO
1: FIFO read can be partial, and resume from last read point
Trigger FIFO watermark interrupt on every ODR (DMA write) if
FIFO_COUNT ≥ FIFO_WM_TH
0: Default setting; Sensor data have regular resolution
1: Sensor data in FIFO will have extended resolution enabling the 20 Bytes
packet
Must be set to 1 for all FIFO use cases when FSYNC is used
Enable temperature sensor packets to go to FIFO
Enable gyroscope packets to go to FIFO
Enable accelerometer packets to go to FIFO
FIFO_CONFIG2
Address: 96 (60h)
Serial IF: R/W
Reset value: 0x00
BIT NAME
7:0
FIFO_WM[7:0]
FUNCTION
Lower bits of FIFO watermark. Generate interrupt when the FIFO reaches
or exceeds FIFO_WM size in bytes or records according to
FIFO_COUNT_REC setting. Interrupt only fires once. This register should
be set to non-zero value, before choosing this interrupt source.
FIFO_CONFIG3
Address: 97 (61h)
Serial IF: R/W
Reset value: 0x00
BIT NAME
7:4 3:0
FIFO_WM[11:8]
Note: Do not set FIFO_WM to value 0.
Revision: 1.2
FUNCTION
Reserved
Upper bits of FIFO watermark. Generate interrupt when the FIFO reaches
Page 87 of 119
IIM-42652
FSYNC_CONFIG
Address: 98 (62h)
Serial IF: R/W
Reset value: 0x10
BIT NAME
7
6:4
FSYNC_UI_SEL
3:2
1
FSYNC_UI_FLAG_CLEAR_SE
L
FSYNC_POLARITY
FUNCTION
Reserved
000: Do not tag FSYNC flag
001: Tag FSYNC flag to TEMP_OUT LSB
010: Tag FSYNC flag to GYRO_XOUT LSB
011: Tag FSYNC flag to GYRO_YOUT LSB
100: Tag FSYNC flag to GYRO_ZOUT LSB
101: Tag FSYNC flag to ACCEL_XOUT LSB
110: Tag FSYNC flag to ACCEL_YOUT LSB
111: Tag FSYNC flag to ACCEL_ZOUT LSB
Reserved
0: FSYNC flag is cleared when UI sensor register is updated
1: FSYNC flag is cleared when UI interface reads the sensor register LSB of
FSYNC tagged axis
0: Start from Rising edge of FSYNC pulse to measure FSYNC interval
1: Start from Falling edge of FSYNC pulse to measure FSYNC interval
INT_CONFIG0
Address: 99 (63h)
Serial IF: R/W
Reset value: 0x00
BIT NAME
7:6 5:4
UI_DRDY_INT_CLEAR
3:2
FIFO_THS_INT_CLEAR
1:0
FIFO_FULL_INT_CLEAR
Revision: 1.2
FUNCTION
Reserved
Data Ready Interrupt Clear Option (latched mode)
00: Clear on Status Bit Read (default)
01: Clear on Status Bit Read
10: Clear on Sensor Register Read
11: Clear on Status Bit Read AND on Sensor Register read
FIFO Threshold Interrupt Clear Option (latched mode)
10: Clear on FIFO data 1Byte Read
11: Clear on Status Bit Read AND on FIFO data 1 byte read
FIFO Full Interrupt Clear Option (latched mode)
Page 88 of 119
IIM-42652
INT_CONFIG1
Address: 100 (64h)
Serial IF: R/W
Reset value: 0x10
BIT NAME
7
6
INT_TPULSE_DURATION
5
INT_TDEASSERT_DISABLE
4
INT_ASYNC_RESET
3:0
FUNCTION
Reserved
Interrupt pulse duration
0: Interrupt pulse duration is 100µs. Use only if ODR < 4kHz. (Default)
1: Interrupt pulse duration is 8 µs. Required if ODR ≥ 4kHz, optional for ODR
< 4kHz.
Interrupt de-assertion duration
0: The interrupt de-assertion duration is set to a minimum of 100µs. Use
1: Disables de-assert duration. Required if ODR ≥ 4kHz, optional for ODR <
4kHz.
User should change setting to 0 from default setting of 1, for proper INT1
Reserved
INT_SOURCE0
Address: 101 (65h)
Serial IF: R/W
Reset value: 0x10
BIT NAME
7
6
UI_FSYNC_INT1_EN
5
PLL_RDY_INT1_EN
4
RESET_DONE_INT1_EN
3
UI_DRDY_INT1_EN
2
FIFO_THS_INT1_EN
1
FIFO_FULL_INT1_EN
UI_AGC_RDY_INT1_EN
Revision: 1.2
FUNCTION
Reserved
0: UI FSYNC interrupt not routed to INT1
1: UI FSYNC interrupt routed to INT1
0: PLL ready interrupt not routed to INT1
1: PLL ready interrupt routed to INT1
0: Reset done interrupt not routed to INT1
1: Reset done interrupt routed to INT1
0: UI data ready interrupt not routed to INT1
1: UI data ready interrupt routed to INT1
0: FIFO threshold interrupt not routed to INT1
1: FIFO threshold interrupt routed to INT1
0: FIFO full interrupt not routed to INT1
1: FIFO full interrupt routed to INT1
0: UI AGC ready interrupt not routed to INT1
1: UI AGC ready interrupt routed to INT1
Page 89 of 119
IIM-42652
INT_SOURCE1
Address: 102 (66h)
Serial IF: R/W
Reset value: 0x00
BIT NAME
7
I3C_PROTOCOL_ERROR_IN
6
T1_EN
5:4 3
SMD_INT1_EN
2
WOM_Z_INT1_EN
1
WOM_Y_INT1_EN
WOM_X_INT1_EN
FUNCTION
Reserved
0: I3CSM protocol error interrupt not routed to INT1
1: I3CSM protocol error interrupt routed to INT1
Reserved
0: SMD interrupt not routed to INT1
1: SMD interrupt routed to INT1
0: Z-axis WOM interrupt not routed to INT1
1: Z-axis WOM interrupt routed to INT1
0: Y-axis WOM interrupt not routed to INT1
1: Y-axis WOM interrupt routed to INT1
0: X-axis WOM interrupt not routed to INT1
1: X-axis WOM interrupt routed to INT1
INT_SOURCE3
Address: 104 (68h)
Serial IF: R/W
Reset value: 0x00
BIT NAME
7
6
UI_FSYNC_INT2_EN
5
PLL_RDY_INT2_EN
4
RESET_DONE_INT2_EN
3
UI_DRDY_INT2_EN
2
FIFO_THS_INT2_EN
1
FIFO_FULL_INT2_EN
UI_AGC_RDY_INT2_EN
Revision: 1.2
FUNCTION
Reserved
0: UI FSYNC interrupt not routed to INT2
1: UI FSYNC interrupt routed to INT2
0: PLL ready interrupt not routed to INT2
1: PLL ready interrupt routed to INT2
0: Reset done interrupt not routed to INT2
1: Reset done interrupt routed to INT2
0: UI data ready interrupt not routed to INT2
1: UI data ready interrupt routed to INT2
0: FIFO threshold interrupt not routed to INT2
1: FIFO threshold interrupt routed to INT2
0: FIFO full interrupt not routed to INT2
1: FIFO full interrupt routed to INT2
0: UI AGC ready interrupt not routed to INT2
1: UI AGC ready interrupt routed to INT2
Page 90 of 119
IIM-42652
INT_SOURCE4
Address: 105 (69h)
Serial IF: R/W
Reset value: 0x00
BIT NAME
7
6
T2_EN
5:4 3
SMD_INT2_EN
2
WOM_Z_INT2_EN
1
WOM_Y_INT2_EN
WOM_X_INT2_EN
FUNCTION
Reserved
0: I3CSM protocol error interrupt not routed to INT2
1: I3CSM protocol error interrupt routed to INT2
Reserved
0: SMD interrupt not routed to INT2
1: SMD interrupt routed to INT2
0: Z-axis WOM interrupt not routed to INT2
1: Z-axis WOM interrupt routed to INT2
0: Y-axis WOM interrupt not routed to INT2
1: Y-axis WOM interrupt routed to INT2
0: X-axis WOM interrupt not routed to INT2
1: X-axis WOM interrupt routed to INT2
FIFO_LOST_PKT0
Address: 108 (6Ch)
Serial IF: R
Reset value: 0x00
BIT NAME
7:0 FIFO_LOST_PKT_CNT[7:0]
FUNCTION
Low byte, number of packets lost in the FIFO
FIFO_LOST_PKT1
Address: 109 (6Dh)
Serial IF: R
Reset value: 0x00
BIT NAME
7:0 FIFO_LOST_PKT_CNT[15:8]
Revision: 1.2
FUNCTION
High byte, number of packets lost in the FIFO
Page 91 of 119
IIM-42652
SELF_TEST_CONFIG
Address: 112 (70h)
Serial IF: R/W
Reset value: 0x00
BIT NAME
7
6
ACCEL_ST_POWER
5
4
3
2
1
EN_AZ_ST
EN_AY_ST
EN_AX_ST
EN_GZ_ST
EN_GY_ST
EN_GX_ST
FUNCTION
Reserved
Set to 1 for accel self-test
Otherwise set to 0; Set to 0 after self-test is completed
Enable Z-accel self-test
Enable Y-accel self-test
Enable X-accel self-test
Enable Z-gyro self-test
Enable Y-gyro self-test
Enable X-gyro self-test
WHO_AM_I
Address: 117 (75h)
Serial IF: R
Reset value: 0x6F
BIT NAME
7:0 WHOAMI
FUNCTION
Register to indicate to user which device is being accessed
Description:
This register is used to verify the identity of the device. The contents of WHOAMI is an 8-bit device ID. The default
value of the register is 0x6F. This is different from the I2C address of the device as seen on the slave I2C controller by
the applications processor.
REG_BANK_SEL
Note: This register is accessible from all register banks
Address: 118 (76h)
Serial IF: R/W
Reset value: 0x00
Clock Domain: ALL
BIT NAME
7:3 -
2:0
BANK_SEL
Revision: 1.2
FUNCTION
Reserved
Register bank selection
000: Bank 0 (default)
001: Bank 1
010: Bank 2
011: Bank 3
100: Bank 4
101: Reserved
110: Reserved
111: Reserved
Page 92 of 119
IIM-42652
15 USER BANK 1 REGISTER MAP – DESCRIPTIONS
This section describes the function and contents of each register within USR Bank 1.
SENSOR_CONFIG0
Address: 03 (03h)
Serial IF: R/W
Reset value: 0x80
BIT NAME
7:6 5
ZG_DISABLE
4
YG_DISABLE
3
XG_DISABLE
2
ZA_DISABLE
1
YA_DISABLE
XA_DISABLE
FUNCTION
Reserved
0: Z gyroscope is on
1: Z gyroscope is disabled
0: Y gyroscope is on
1: Y gyroscope is disabled
0: X gyroscope is on
1: X gyroscope is disabled
0: Z accelerometer is on
1: Z accelerometer is disabled
0: Y accelerometer is on
1: Y accelerometer is disabled
0: X accelerometer is on
1: X accelerometer is disabled
GYRO_CONFIG_STATIC2
Address: 11 (0Bh)
Serial IF: R/W
Reset value: 0xA0
BIT NAME
7:2 1
GYRO_AAF_DIS
GYRO_NF_DIS
FUNCTION
Reserved
0: Enable Anti-Aliasing/Low Pass Filter
1: Disable Anti-Aliasing/Low Pass Filter
0: Enable Notch Filter
1: Disable Notch Filter
GYRO_CONFIG_STATIC3
Address: 12 (0Ch)
Serial IF: R/W
Reset value: 0x0D
BIT NAME
7:6 5:0
GYRO_AAF_DELT
Revision: 1.2
FUNCTION
Reserved
Controls bandwidth of the gyroscope anti-alias filter
See section 5.3 for details
Page 93 of 119
IIM-42652
GYRO_CONFIG_STATIC4
Address: 13 (0Dh)
Serial IF: R/W
Reset value: 0xAA
BIT NAME
7:0
FUNCTION
GYRO_CONFIG_STATIC5
Address: 14 (0Eh)
Serial IF: R/W
Reset value: 0x80
BIT NAME
7:4
GYRO_AAF_BITSHIFT
3:0
FUNCTION
See section for details
GYRO_CONFIG_STATIC6
Address: 15 (0Fh)
Serial IF: R/W
Reset value: 0xXX (Factory trimmed on an individual device basis)
BIT NAME
FUNCTION
Used for gyroscope X-axis notch filter frequency selection
7:0 GYRO_X_NF_COSWZ[7:0]
See section 5.1 for details
GYRO_CONFIG_STATIC7
Address: 16 (10h)
Serial IF: R/W
BIT NAME
FUNCTION
Used for gyroscope Y-axis notch filter frequency selection
7:0 GYRO_Y_NF_COSWZ[7:0]
Revision: 1.2
Page 94 of 119
IIM-42652
GYRO_CONFIG_STATIC8
Address: 17 (11h)
Serial IF: R/W
BIT NAME
FUNCTION
Used for gyroscope Z-axis notch filter frequency selection
7:0 GYRO_Z_NF_COSWZ[7:0]
GYRO_CONFIG_STATIC9
Address: 18 (12h)
Serial IF: R/W
BIT NAME
FUNCTION
7:6 Reserved
5
GYRO_Z_NF_COSWZ_SEL[0]
4
GYRO_Y_NF_COSWZ_SEL[0]
3
GYRO_X_NF_COSWZ_SEL[0]
2
GYRO_Z_NF_COSWZ[8]
1
GYRO_Y_NF_COSWZ[8]
GYRO_X_NF_COSWZ[8]
Address: 19 (13h)
Serial IF: R/W
Reset value: 0x11
BIT NAME
7
6:4
GYRO_NF_BW_SEL
3:1
GYRO_HPF_BW_IND
GYRO_HPF_ORD_IND
Revision: 1.2
FUNCTION
Reserved
Selects bandwidth for gyroscope notch filter
Selects HPF 3dB cutoff frequency bandwidth
See section 5.6 for details
Selects HPF filter order (see section 5.6 for details)
0: 1st order HPF
1: 2nd order HPF
Page 95 of 119
IIM-42652
XG_ST_DATA
Address: 95 (5Fh)
Serial IF: R/W
Reset value: 0xXX (The value in this register indicates the self-test output generated during manufacturing tests)
BIT NAME
FUNCTION
7:0 XG_ST_DATA
X-gyro self-test data
YG_ST_DATA
Address: 96 (60h)
Serial IF: R/W
BIT NAME
FUNCTION
7:0 YG_ST_DATA
Y-gyro self-test data
ZG_ST_DATA
Address: 97 (61h)
Serial IF: R/W
BIT NAME
FUNCTION
7:0 ZG_ST_DATA
Z-gyro self-test data
TMSTVAL0
Address: 98 (62h)
Serial IF: R
Reset value: 0x00
BIT NAME
7:0
TMST_VALUE[7:0]
Revision: 1.2
FUNCTION
When TMST_STROBE is programmed, the current value of the internal
counter is latched to this register. Allows the full 20-bit precision of the time
stamp to be read back.
Page 96 of 119
IIM-42652
TMSTVAL1
Address: 99 (63h)
Serial IF: R
Reset value: 0x00
BIT NAME
7:0
TMST_VALUE[15:8]
FUNCTION
TMSTVAL2
Address: 100 (64h)
Serial IF: R
Reset value: 0x00
BIT NAME
7:4 3:0
TMST_VALUE[19:16]
FUNCTION
Reserved
INTF_CONFIG4
Address: 122 (7Ah)
Serial IF: R/W
Reset value: 0x03
BIT NAME
7
6
5:2
I3C_BUS_MODE
1
SPI_AP_4WIRE
Revision: 1.2
FUNCTION
Reserved
0: Device is on a bus with I2C and I3CSM devices
1: Device is on a bus with I3CSM devices only
Reserved
0: AP interface uses 3-wire SPI mode
1: AP interface uses 4-wire SPI mode (default)
Reserved
Page 97 of 119
IIM-42652
INTF_CONFIG5
Address: 123 (7Bh)
Serial IF: R/W
Reset value: 0x20
BIT NAME
7:3 2:1
PIN9_FUNCTION
FUNCTION
Reserved
Selects among the following functionalities for pin 9
00: INT2
01: FSYNC
10: CLKIN
11: Reserved
Reserved
INTF_CONFIG6
Address: 124 (7Ch)
Serial IF: R/W
Reset value: 0x5F
BIT NAME
7
6:5
ASYNCTIME0_DIS
4
I3C_EN
3
I3C_IBI_BYTE_EN
2
I3C_IBI_EN
1
I3C_DDR_EN
I3C_SDR_EN
Revision: 1.2
FUNCTION
0: I3CSMAsynchronous Mode 0 timing control is enabled
1: I3CSM Asynchronous Mode 0 timing control is disabled
Reserved
0: I3CSM slave not enabled
1: I3CSM slave enabled
0: I3CSM IBI payload function not enabled
1: I3CSM IBI payload function enabled
0: I3CSM IBI function not enabled
1: I3CSM IBI function enabled
0: I3CSM DDR mode not enabled
1: I3CSM DDR mode enabled
0: I3CSM SDR mode not enabled
1: I3CSM SDR mode enabled
Page 98 of 119
IIM-42652
16 USER BANK 2 REGISTER MAP – DESCRIPTIONS
This section describes the function and contents of each register within USR Bank 2.
Address: 03 (03h)
Serial IF: R/W
Reset value: 0x30
BIT NAME
7
6:1
ACCEL_AAF_DELT
ACCEL_AAF_DIS
FUNCTION
Reserved
Controls bandwidth of the accelerometer anti-alias filter
See section 5.2 for details
0: Enable accelerometer anti-aliasing filter
1: Disable accelerometer anti-aliasing filter
Address: 04 (04h)
Serial IF: R/W
Reset value: 0x40
BIT NAME
7:0
FUNCTION
Address: 05 (05h)
Serial IF: R/W
Reset value: 0x62
BIT NAME
7:4
ACCEL_AAF_BITSHIFT
3:0
FUNCTION
XA_ST_DATA
Address: 59 (3Bh)
Serial IF: R/W
BIT NAME
FUNCTION
7:0 XA_ST_DATA
X-accel self-test data
Revision: 1.2
Page 99 of 119
IIM-42652
YA_ST_DATA
Address: 60 (3Ch)
Serial IF: R/W
BIT NAME
FUNCTION
7:0 YA_ST_DATA
Y-accel self-test data
ZA_ST_DATA
Address: 61 (3Dh)
Serial IF: R/W
BIT NAME
FUNCTION
7:0 ZA_ST_DATA
Z-accel self-test data
Revision: 1.2
Page 100 of 119
IIM-42652
17 USER BANK 3 REGISTER MAP – DESCRIPTIONS
This section describes the function and contents of each register within USR Bank 3.
PU_PD_CONFIG1
Address: 06 (06h)
Serial IF: R/W
Reset value: 0x80
BIT NAME
7
PIN11_PU_EN
6
PIN7_PU_EN
5
4
PIN9_PD_EN
3
PIN10_PU_EN
2
PIN3_PU_EN
1
PIN2_PU_EN
PIN4_PD_EN
Revision: 1.2
FUNCTION
Pull-up control for pin 11
0: Pull-up is disabled
1: Pull-up is enabled
Pull-up control for pin 7 if triple interface mode is used. Must be set to 0 if
single/dual interface mode is used.
Reserved
Pull-down control for pin 9 in single/dual interface mode. Must be set to 0 if
0: Pull-down is disabled
1: Pull-down is enabled
Pull-up control for pin 10
Pull-up control for pin 3
Pull-up control for pin 2
Pull-down control for pin 4
Page 101 of 119
IIM-42652
PU_PD_CONFIG2
Address: 14 (0Eh)
Serial IF: R/W
Reset value: 0x20
BIT NAME
7
PIN1_PU_EN
6
PIN1_PD_EN
5
PIN12_PU_EN
4
PIN12_PD_EN
3
PIN14_PU_EN
2
PIN14_PD_EN
1
PIN13_PU_EN
PIN13_PD_EN
Revision: 1.2
FUNCTION
Pull-up control for pin 1. See bit 6 description for pull-down control for pin
1. Note that both pull-up and pull-down must not be simultaneously
enabled for the same pin.
Pull-down control for pin 1. See bit 7 description for pull-up control for pin
Pull-up control for pin 12. See bit 4 description for pull-down control for pin
12. Note that both pull-up and pull-down must not be simultaneously
Pull-down control for pin 12. See bit 5 description for pull-up control for pin
Pull-up control for pin 14. See bit 2 description for pull-down control for pin
14. Note that both pull-up and pull-down must not be simultaneously
Pull-down control for pin 14. See bit 3 description for pull-up control for pin
Pull-up control for pin 13. See bit 0 description for pull-down control for pin
13. Note that both pull-up and pull-down must not be simultaneously
Pull-down control for pin 13. See bit 1 description for pull-up control for pin
Page 102 of 119
IIM-42652
18 USER BANK 4 REGISTER MAP – DESCRIPTIONS
This section describes the function and contents of each register within USR Bank 4.
FDR_CONFIG
Address: 09 (09h)
Serial IF: R/W
Reset value: 0x00
BIT NAME
7
6:0
FDR_SEL
FUNCTION
Reserved
FIFO packet rate decimation factor. Sets the number of discarded FIFO
packets. Valid range is 0 to 127. User must disable sensors when initializing
FDR_SEL value or making changes to it.
0000000: Decimation is disabled, all packets are sent to FIFO
0000001: 1 packet out of 2 is sent to FIFO
0000010: 1 packet out of 3 is sent to FIFO
0000011: 1 packet out of 4 is sent to FIFO
1111111: 1 packet out of 128 is sent to FIFO
APEX_CONFIG1
Address: 64 (40h)
Serial IF: R/W
Reset value: 0xA2
BIT NAME
7:4
LOW_ENERGY_AMP_TH_SEL
3:0
Revision: 1.2
FUNCTION
Pedometer Low Energy mode amplitude threshold selection
Use default value 1010b
When the DMP is in power save mode, it is awakened by the WOM and
will wait for a certain duration before going back to sleep. This bitfield
configures this duration.
0000: 0 seconds
0001: 4 seconds
0010: 8 seconds
0011: 12 seconds
0100: 16 seconds
0101: 20 seconds
0110: 24 seconds
0111: 28 seconds
1000: 32 seconds
1001: 36 seconds
1010: 40 seconds
1011: 44 seconds
1100: 48 seconds
1101: 52 seconds
1110: 56 seconds
1111: 60 seconds
Page 103 of 119
IIM-42652
APEX_CONFIG2
Address: 65 (41h)
Serial IF: R/W
Reset value: 0x85
BIT NAME
7:4
PED_AMP_TH_SEL
3:0
PED_STEP_CNT_TH_SEL
Revision: 1.2
FUNCTION
Pedometer amplitude threshold selection
Use default value 1000b
Pedometer step count detection window
Use default value 0101b
0000: 0 steps
0001: 1 step
0010: 2 steps
0011: 3 steps
0100: 4 steps
0101: 5 steps (default)
0110: 6 steps
0111: 7 steps
1000: 8 steps
1001: 9 steps
1010: 10 steps
1011: 11 steps
1100: 12 steps
1101: 13 steps
1110: 14 steps
1111: 15 steps
Page 104 of 119
IIM-42652
APEX_CONFIG3
Address: 66 (42h)
Serial IF: R/W
Reset value: 0x51
BIT NAME
7:5
PED_STEP_DET_TH_SEL
4:2
PED_SB_TIMER_TH_SEL
1:0
PED_HI_EN_TH_SEL
Revision: 1.2
FUNCTION
Pedometer step detection threshold selection
Use default value 010b
000: 0 steps
001: 1 step
010: 2 steps (default)
011: 3 steps
100: 4 steps
101: 5 steps
110: 6 steps
111: 7 steps
Pedometer step buffer timer threshold selection
Use default value 100b
000: 0 samples
001: 1 sample
010: 2 samples
011: 3 samples
100: 4 samples (default)
101: 5 samples
110: 6 samples
111: 7 samples
Pedometer high energy threshold selection
Use default value 01b
Page 105 of 119
IIM-42652
APEX_CONFIG4
Address: 67 (43h)
Serial IF: R/W
Reset value: 0xA4
BIT NAME
7:6
TILT_WAIT_TIME_SEL
5:3
LOWG_PEAK_TH_HYST_SEL
2:0
HIGHG_PEAK_TH_HYST_SEL
Revision: 1.2
FUNCTION
Configures duration of delay after tilt is detected before interrupt is
triggered
00: 0s
01: 2s
10: 4s (default)
11: 6s
This threshold is added to the LOWG peak threshold after the initial
threshold is met. The threshold values corresponding to parameter values
are shown below:
000: 31mgee
001: 63mgee
010: 94mgee
011: 125mgee
100: 156mgee (default)
101: 188mgee
110: 219mgee
111: 250mgee
This threshold is added to the HIGHG peak threshold after the initial
are shown below:
000: 31mgee
001: 63mgee
010: 94mgee
011: 125mgee
101: 188mgee
110: 219mgee
111: 250mgee
Page 106 of 119
IIM-42652
APEX_CONFIG5
Address: 68 (44h)
Serial IF: R/W
Reset value: 0x8C
BIT NAME
7:3
LOWG_PEAK_TH_SEL
2:0
LOWG_TIME_TH_SEL
FUNCTION
This parameter defines the threshold for accelerometer values below
which the algorithm considers it has entered low-g state. The threshold
values corresponding to parameter values are shown below:
00000: 31mgee
00001: 63mgee
00010: 94mgee
00011: 125mgee
00100: 156mgee
00101: 188mgee
00110: 219mgee
00111: 250mgee
01000: 281mgee
01001: 313mgee
01010: 344mgee
01011: 375mgee
01100: 406mgee
01101: 438mgee
01110: 469mgee
01111: 500mgee
10000: 531mgee
10001: 563mgee (default)
10010: 594mgee
10011: 625mgee
10100: 656mgee
10101: 688mgee
10110: 719mgee
10111: 750mgee
11000: 781mgee
11001: 813mgee
11010: 844mgee
11011: 875mgee
11100: 906mgee
11101: 938mgee
11110: 969mgee
11111: 1000mgee
This parameter defines the number of samples for which the device should
stay in low-g before triggering interrupt.
Number of samples = LOWG_TIME_TH_SEL + 1
Default value is 4 (i.e. 5 samples)
Revision: 1.2
Page 107 of 119
IIM-42652
APEX_CONFIG6
Address: 69 (45h)
Serial IF: R/W
Reset value: 0x5C
BIT NAME
7:3
HIGHG_PEAK_TH_SEL
2:0
HIGHG_TIME_TH_SEL
Revision: 1.2
FUNCTION
This parameter defines the threshold for accelerometer values above
which the algorithm considers it has entered high-g state. The threshold
00000: 250mgee
00001: 500mgee
00010: 750mgee
00011: 1000mgee
00100: 1250mgee
00101: 1500mgee
00110: 1750mgee
00111: 2000mgee
01000: 2250mgee
01001: 2500mgee
01010: 2750mgee
01011: 3000mgee
01100: 3250mgee
01101: 3500mgee
01110: 3750mgee
01111: 4000mgee
10000: 4250mgee
10001: 4500mgee
10010: 4750mgee
10011: 5000mgee
10100: 5250mgee
10101: 5500mgee
10110: 5750mgee
10111: 6000mgee
11000: 6250mgee
11001: 6500mgee
11010: 6750mgee
11011: 7000mgee
11100: 7250mgee
11101: 7500mgee
11110: 7750mgee
11111: 8000mgee
stay in high-g before triggering interrupt.
Number of samples = HIGHG_TIME_TH_SEL + 1
Page 108 of 119
IIM-42652
APEX_CONFIG7
Address: 70 (46h)
Serial IF: R/W
Reset value: 0x45
BIT NAME
7:2
TAP_MIN_JERK_THR
1:0
TAP_MAX_PEAK_TOL
FUNCTION
Tap Detection minimum jerk threshold
Use default value 010001b
Tap Detection maximum peak tolerance
APEX_CONFIG8
Address: 71 (47h)
Serial IF: R/W
Reset value: 0x5B
BIT NAME
7
6:5
TAP_TMAX
4:3
TAP_TAVG
2:0
TAP_TMIN
FUNCTION
Reserved
Tap measurement window (number of samples)
Use default value 10b
Tap energy measurement window (number of samples)
Use default value 11b
Single tap window (number of samples)
Use default value 011b
APEX_CONFIG9
Address: 72 (48h)
Serial IF: R/W
Reset value: 0x00
BIT NAME
7:1 0
SENSITIVITY_MODE
Revision: 1.2
FUNCTION
Reserved
0: Low power mode at accelerometer ODR 25 Hz; High performance mode
at accelerometer ODR ≥ 50 Hz
1: Low power and slow walk mode at accelerometer ODR 25 Hz; Slow walk
mode at accelerometer ODR ≥ 50 Hz
Page 109 of 119
IIM-42652
APEX_CONFIG10
Address: 73 (49h)
Serial IF: R/W
Reset value: 0x00
BIT NAME
7:5
FF_MIN_DURATION_CM
4:2
FF_MAX_DURATION_CM
1:0
FF_DEBOUNCE_DURATION
FUNCTION
This parameter defines the minimum freefall length that the algorithm
should report. Freefalls smaller than this value are ignored. Freefall lengths
000: 13cm (default)
001: 19cm
010: 28cm
011: 38cm
100: 50cm
101: 64cm
110: 78cm
111: 95cm
This parameter defines the maximum freefall length that the algorithm
should report. Freefalls longer than this value are ignored. Freefall lengths
000: 113cm (default)
001: 154cm
010: 201cm
011: 255cm
100: 314cm
101: 380cm
110: 452cm
111: 531cm
This parameter defines the time during which low-g and high-g events are
not taken into account after a high-g event. It helps to avoid detecting
bounces as free fall. Debounce durations corresponding to parameter
00: 0s
01: 1s
10: 2s
11: 3s
ACCEL_WOM_X_THR
Address: 74 (4Ah)
Serial IF: R/W
Reset value: 0x00
BIT NAME
7:0
WOM_X_TH
Revision: 1.2
FUNCTION
Threshold value for the Wake on Motion Interrupt for X-axis accelerometer
WoM thresholds are expressed in fixed “mg” independent of the selected
Range [0g : 1g]; Resolution 1g/256=~3.9mg
Page 110 of 119
IIM-42652
ACCEL_WOM_Y_THR
Address: 75 (4Bh)
Serial IF: R/W
Reset value: 0x00
BIT NAME
7:0
WOM_Y_TH
FUNCTION
Threshold value for the Wake on Motion Interrupt for Y-axis accelerometer
ACCEL_WOM_Z_THR
Address: 76 (4Ch)
Serial IF: R/W
Reset value: 0x00
BIT NAME
7:0
WOM_Z_TH
FUNCTION
Threshold value for the Wake on Motion Interrupt for Z-axis accelerometer
INT_SOURCE6
Address: 77 (4Dh)
Serial IF: R/W
Reset value: 0x00
BIT NAME
7:6 5
STEP_DET_INT1_EN
4
STEP_CNT_OFL_INT1_EN
3
TILT_DET_INT1_EN
2
1
FREEFALL_DET_INT1_EN
TAP_DET_INT1_EN
Revision: 1.2
FUNCTION
Reserved
0: Step detect interrupt not routed to INT1
1: Step detect interrupt routed to INT1
0: Step count overflow interrupt not routed to INT1
1: Step count overflow interrupt routed to INT1
0: Tilt detect interrupt not routed to INT1
1: Tile detect interrupt routed to INT1
Reserved
0: Freefall detect interrupt not routed to INT1
1: Freefall detect interrupt routed to INT1
0: Tap detect interrupt not routed to INT1
1: Tap detect interrupt routed to INT1
Page 111 of 119
IIM-42652
INT_SOURCE7
Address: 78 (4Eh)
Serial IF: R/W
Reset value: 0x00
BIT NAME
7:6 5
STEP_DET_INT2_EN
4
STEP_CNT_OFL_INT2_EN
3
TILT_DET_INT2_EN
2
1
FREEFALL_DET_INT2_EN
TAP_DET_INT2_EN
FUNCTION
Reserved
0: Step detect interrupt not routed to INT2
1: Step detect interrupt routed to INT2
0: Step count overflow interrupt not routed to INT2
1: Step count overflow interrupt routed to INT2
0: Tilt detect interrupt not routed to INT2
1: Tile detect interrupt routed to INT2
Reserved
0: Freefall detect interrupt not routed to INT2
1: Freefall detect interrupt routed to INT2
0: Tap detect interrupt not routed to INT2
1: Tap detect interrupt routed to INT2
INT_SOURCE8
Address: 79 (4Fh)
Serial IF: R/W
Reset value: 0x00
BIT NAME
7:6 5
FSYNC_IBI_EN
4
PLL_RDY_IBI_EN
3
UI_DRDY_IBI_EN
2
FIFO_THS_IBI_EN
1
FIFO_FULL_IBI_EN
AGC_RDY_IBI_EN
Revision: 1.2
FUNCTION
Reserved
0: FSYNC interrupt not routed to IBI
1: FSYNC interrupt routed to IBI
0: PLL ready interrupt not routed to IBI
1: PLL ready interrupt routed to IBI
0: UI data ready interrupt not routed to IBI
1: UI data ready interrupt routed to IBI
0: FIFO threshold interrupt not routed to IBI
1: FIFO threshold interrupt routed to IBI
0: FIFO full interrupt not routed to IBI
1: FIFO full interrupt routed to IBI
0: AGC ready interrupt not routed to IBI
1: AGC ready interrupt routed to IBI
Page 112 of 119
IIM-42652
INT_SOURCE9
Address: 80 (50h)
Serial IF: R/W
Reset value: 0x00
BIT NAME
I3C_PROTOCOL_ERROR_IBI
7
_EN
6:5 4
SMD_IBI_EN
3
WOM_Z_IBI_EN
2
WOM_Y_IBI_EN
1
WOM_X_IBI_EN
FUNCTION
0: I3CSM protocol error interrupt not routed to IBI
1: I3CSM protocol error interrupt routed to IBI
Reserved
0: SMD interrupt not routed to IBI
1: SMD interrupt routed to IBI
0: Z-axis WOM interrupt not routed to IBI
1: Z-axis WOM interrupt routed to IBI
0: Y-axis WOM interrupt not routed to IBI
1: Y-axis WOM interrupt routed to IBI
0: X-axis WOM interrupt not routed to IBI
1: X-axis WOM interrupt routed to IBI
Reserved
INT_SOURCE10
Address: 81 (51h)
Serial IF: R/W
Reset value: 0x00
BIT NAME
7:6 5
STEP_DET_IBI_EN
4
STEP_CNT_OFL_IBI_EN
3
TILT_DET_IBI_EN
2
1
FREEFALL_DET_IBI_EN
TAP_DET_IBI_EN
Revision: 1.2
FUNCTION
Reserved
0: Step detect interrupt not routed to IBI
1: Step detect interrupt routed to IBI
0: Step count overflow interrupt not routed to IBI
1: Step count overflow interrupt routed to IBI
0: Tilt detect interrupt not routed to IBI
1: Tile detect interrupt routed to IBI
Reserved
0: Freefall detect interrupt not routed to IBI
1: Freefall detect interrupt routed to IBI
0: Tap detect interrupt not routed to IBI
1: Tap detect interrupt routed to IBI
Page 113 of 119
IIM-42652
OFFSET_USER0
Address: 119 (77h)
Serial IF: R/W
Reset value: 0x00
BIT NAME
7:0
GYRO_X_OFFUSER[7:0]
FUNCTION
Lower bits of X-gyro offset programmed by user. Max value is ±64 dps,
resolution is 1/32 dps.
OFFSET_USER1
Address: 120 (78h)
Serial IF: R/W
Reset value: 0x00
BIT NAME
7:4
3:0
FUNCTION
Upper bits of Y-gyro offset programmed by user. Max value is ±64 dps,
Upper bits of X-gyro offset programmed by user. Max value is ±64 dps,
OFFSET_USER2
Address: 121 (79h)
Serial IF: R/W
Reset value: 0x00
BIT NAME
7:0
GYRO_Y_OFFUSER[7:0]
FUNCTION
Lower bits of Y-gyro offset programmed by user. Max value is ±64 dps,
OFFSET_USER3
Address: 122 (7Ah)
Serial IF: R/W
Reset value: 0x00
BIT NAME
7:0
GYRO_Z_OFFUSER[7:0]
Revision: 1.2
FUNCTION
Lower bits of Z-gyro offset programmed by user. Max value is ±64 dps,
Page 114 of 119
IIM-42652
OFFSET_USER4
Address: 123 (7Bh)
Serial IF: R/W
Reset value: 0x00
BIT NAME
7:4
3:0
FUNCTION
Upper bits of X-accel offset programmed by user. Max value is ±1g,
resolution is 0.5 mg.
Upper bits of Z-gyro offset programmed by user. Max value is ±64 dps,
OFFSET_USER5
Address: 124 (7Ch)
Serial IF: R/W
Reset value: 0x00
BIT NAME
7:0
FUNCTION
Lower bits of X-accel offset programmed by user. Max value is ±1g,
resolution is 0.5mg.
OFFSET_USER6
Address: 125 (7Dh)
Serial IF: R/W
Reset value: 0x00
BIT NAME
7:0
FUNCTION
Lower bits of Y-accel offset programmed by user. Max value is ±1g,
OFFSET_USER7
Address: 126 (7Eh)
Serial IF: R/W
Reset value: 0x00
BIT NAME
7:4
3:0
Revision: 1.2
FUNCTION
Upper bits of Z-accel offset programmed by user. Max value is ±1g,
Upper bits of Y-accel offset programmed by user. Max value is ±1g,
Page 115 of 119
IIM-42652
OFFSET_USER8
Address: 127 (7Fh)
Serial IF: R/W
Reset value: 0x00
BIT NAME
7:0
Revision: 1.2
FUNCTION
Lower bits of Z-accel offset programmed by user. Max value is ±1g,
Page 116 of 119
IIM-42652
19 REFERENCE
Please refer to “InvenSense MEMS Handling Application Note (AN-IVS-0002A-00)” for the following information:
• Manufacturing Recommendations
o Assembly Guidelines and Recommendations
o PCB Design Guidelines and Recommendations
o MEMS Handling Instructions
o ESD Considerations
o Reflow Specification
o Storage Specifications
o Package Marking Specification
o Tape & Reel Specification
o Reel & Pizza Box Label
o Packaging
o Representative Shipping Carton Label
• Compliance
o Environmental Compliance
o DRC Compliance
o Compliance Declaration Disclaimer
Revision: 1.2
Page 117 of 119
IIM-42652
20 REVISION HISTORY
REVISION DATE
REVISION
DESCRIPTION
01/07/2021
1.0
Initial release
Updated anti-aliasing filter reference in Chapter 15.3, 15.4 and 15.5 from Chapter
5.2 to Chapter 5.3.
Chapter 15.1 reset Value 0xB0 changed to 0x80
07/27/2021
1.1
Remove the FIFO_WM_EN reference on sections 14.46 & 14.47
Updated section 12.7 “FIFO Timestamp Interval Scaling”
Added section 12.9 on register value modification
Updated bit 3 description on Section 14.4
10/01/2021
1.2
Revision: 1.2
Updated Sections 14.43, 17.1, 17.2
Updated SmartIndustrial formatting
Page 118 of 119
IIM-42652
This information furnished by InvenSense or its affiliates (“TDK InvenSense”) is believed to be accurate and reliable. However, no responsibility is
assumed by TDK InvenSense for its use, or for any infringements of patents or other rights of third parties that may result from its use.
Specifications are subject to change without notice. TDK InvenSense reserves the right to make changes to this product, including its circuits and
software, in order to improve its design and/or performance, without prior notice. TDK InvenSense makes no warranties, neither expressed nor
implied, regarding the information and specifications contained in this document. TDK InvenSense assumes no responsibility for any claims or
damages arising from information contained in this document, or from the use of products and services detailed therein. This includes, but is not
limited to, claims or damages based on the infringement of patents, copyrights, mask work and/or other intellectual property rights.
Certain intellectual property owned by InvenSense and described in this document is patent protected. No license is granted by implication or
otherwise under any patent or patent rights of InvenSense. This publication supersedes and replaces all information previously supplied.
Trademarks that are registered trademarks are the property of their respective companies. TDK InvenSense sensors should not be used or sold in
the development, storage, production or utilization of any conventional or mass-destructive weapons or for any other weapons or life threatening
applications, as well as in any other life critical applications such as medical equipment, transportation, aerospace and nuclear instruments,
undersea equipment, power plant equipment, disaster prevention and crime prevention equipment.
©2021 InvenSense. All rights reserved. InvenSense, MotionTracking, MotionProcessing, MotionProcessor, MotionFusion, MotionApps, DMP, AAR,
and the InvenSense logo are trademarks of InvenSense, Inc. The TDK logo is a trademark of TDK Corporation. Other cocmpany and product names
may be trademarks of the respective companies with which they are associated.
Revision: 1.2
Page 119 of 119
