INMP401ACEZ-R0
INMP401ACEZ-R0
    TDK(东电化)
    MICMEMSANLGOMNI-42DB
INMP401ACEZ-R0 数据手册
INMP401 Omnidirectional Microphone with Bottom Port and Analog Output APPLICATIONS GENERAL DESCRIPTION * The INMP401 is a high-quality, high-performance, lowpower, analog-output bottom-ported omnidirectional MEMS microphone. The INMP401 consists of a MEMS microphone element, an impedance converter, and an output amplifier. The INMP401 sensitivity specification makes it an excellent choice for near-field applications. The INMP401 has a wideband frequency response, resulting in natural sound with high intelligibility. The specially designed low frequency cutoff reduces wind noise. Its low current consumption enables long battery life for portable applications. The INMP401 complies with the TIA-920 Telecommunications Telephone Terminal Equipment Transmission Requirements for Wideband Digital Wireline Telephones standard. The INMP401 is available in a 4.72 × 3.76 × 1.00 mm surfacemount package. It is reflow solder compatible with no sensitivity degradation. The INMP401 is halide free. • • • • • Mobile Devices Teleconferencing Systems Headsets Security Panels Intercom Devices FEATURES • • • • • • • • • 4.72 × 3.76 × 1.00 mm Surface-Mount Package SNR of 62 dBA Sensitivity of −42 dBV Flat Frequency Response from 60 Hz to 15 kHz Low Current Consumption:
INMP401ACEZ-R0
物料型号:INMP401
器件简介: - INMP401是一款高性能、低功耗、模拟输出的全方位MEMS麦克风。 - 包含MEMS麦克风元件、阻抗转换器和输出放大器。 - 适用于近场应用,具有宽带频率响应和高语音清晰度。 - 设计有低频截止以降低风噪声。 - 低电流消耗,适合便携式应用。
引脚分配: - 引脚1:模拟输出信号(OUTPUT) - 引脚2、3、4、6:地(GND) - 引脚5:电源供应(VDD)
参数特性: - 尺寸:4.72 × 3.76 × 1.00 mm - 信噪比(SNR):62 dBA - 灵敏度:-42 dBV - 频率响应:60 Hz至15 kHz - 电流消耗:<250 µA - 兼容Sn/Pb和无铅焊接工艺
功能详解: - 符合TIA-920宽带数字有线电话传输要求标准。 - 具有高PSR(70 dB)和单端模拟输出。
应用信息: - 移动设备、电话会议系统、耳机、安全面板、对讲设备等。
封装信息: - 提供6-Terminal LGA_CAV封装。 - 回流焊接兼容,无灵敏度降低。 - 无卤素。
INMP401ACEZ-R0 价格&库存
很抱歉,暂时无法提供与“INMP401ACEZ-R0”相匹配的价格&库存,您可以联系我们找货
