INMP522ACEZ-R7
INMP522ACEZ-R7
    TDK(东电化)
    75Hz ~ 20kHz Digital, PDM Microphone MEMS (Silicon) Omnidirectional (-26dB ±1dB @ 94dB SPL) Solder ...
INMP522ACEZ-R7 数据手册
INMP522 Ultra-Low Noise, Low Sensitivity Tolerance, PDM Digital Microphone APPLICATIONS GENERAL DESCRIPTION The INMP522* is an omnidirectional, bottom-ported, digital output MEMS microphone with high performance, ultra-low noise, and low power. The INMP522 has a sensitivity tolerance of ±1 dB from part to part, making it ideal for microphone array and beamforming applications. The INMP522 consists of a MEMS microphone element and an impedance converter amplifier followed by a fourth-order Σ-Δ modulator. The digital interface enables the pulse density modulated (PDM) output of two microphones to be timemultiplexed on a single data line using a single clock. The INMP522 is function- and pin-compatible with the INMP521 and INMP421 microphones, providing an easy upgrade path. The INMP522 has a very high signal-to-noise ratio (SNR) of 65 dBA and sensitivity of −26 dBFS, making it an excellent choice for near- and far-field applications. The INMP522 has an extended wideband frequency response, resulting in natural sound with high intelligibility. Low current consumption and a sleep mode with less than 2 µA current consumption enables long battery life for portable applications. The INMP522 is available in a thin 4 × 3 × 1 mm surfacemount package. It is reflow solder compatible with no sensitivity degradation. • • • • • • • • Smartphones and Feature Phones Microphone Arrays Tablet Computers Teleconferencing Systems Digital Still and Video Cameras Bluetooth Headsets Notebook PCs Security and Surveillance FEATURES • • • • • • • • • • • • • • Sensitivity Tolerance of ±1 dB Small, Thin 4 × 3 × 1 mm Surface-Mount Package Omnidirectional Response Very High SNR of 65 dBA Sensitivity of −26 dBFS Wide Frequency Response from 75 Hz to >20 kHz Low Current Consumption of 800 µA Sleep Mode for Extended Battery Life, 20 0.5 Hz kHz % dBFS 116 dB SPL 120 dB SPL Output DC Offset Latency Noise Floor 3.63 V 1.2 mA 2 1.4 µA 3 0.65 x ILOAD = 0.5 mA Percent of full scale 20 Hz to 20 kHz, A-weighted 0.7 x VDD NOTES 1 2 3 mA µA 3 V VDD 0.35 x VDD Input Voltage Low (VIL) Output Voltage Low (VOL) 1.5 −83 1.0 ILOAD = 0.5 mA dBFS dBA dBA SPL dB 0.8 Input Voltage High (VIH) Output Voltage High (VOH) −25 UNITS 91 1.62 Normal Mode Sleep Mode Normal Mode Sleep Mode MAX V VDD 0 5 1 kHz), power on 10 INPUT tCLKIN Input clock period 270 Clock Frequency (CLK) 0.9 Clock Duty Cycle 40 2.4 ms 1111 ns 3.6 MHz % 60 1 1 OUTPUT DATA1 (right) driven after falling clock edge DATA1 (right) disabled after rising clock edge DATA2 (left) driven after rising clock edge DATA2 (left) disabled after falling clock edge T1OUTEN T1OUTDIS T2OUTEN T2OUTDIS ns 54 15 54 ns 54 15 ns 54 ns Note 1: The microphone operates at any clock frequency between 0.9 MHz and 3.6 MHz. Some specifications may not be guaranteed at frequencies other than 2.4 MHz. TIMING DIAGRAM tCLKIN CLK t1OUTEN t1OUTDIS DATA1 t2OUTDIS DATA2 t2OUTEN Figure 1. Pulse Density Modulated Output Timing Document Number: DS-INMP522-00 Revision: 1.1 Rev Date: 02/06/2014 Page 5 of 21 INMP522 ABSOLUTE MAXIMUM RATINGS Stress above those listed as Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these conditions is not implied. Exposure to the absolute maximum ratings conditions for extended periods may affect device reliability. TABLE 3. ABSOLUTE MAXIMUM RATINGS PARAMETER Supply Voltage (VDD) Digital Pin Input Voltage Sound Pressure Level Mechanical Shock Vibration Temperature Range Biased Storage RATING −0.3 V to +3.63 V −0.3 V to VDD + 0.3 V or 3.63 V, whichever is less 160 dB 10,000 g Per MIL-STD-883 Method 2007, Test Condition B −40°C to +85°C −55°C to +150°C ESD CAUTION ESD (electrostatic discharge) sensitive device. Charged devices and circuit boards can discharge without detection. Although this product features patented or proprietary protection circuitry, damage may occur on devices subjected to high energy ESD. Therefore proper ESD precautions should be taken to avoid performance degradation or loss of functionality. Document Number: DS-INMP522-00 Revision: 1.1 Rev Date: 02/06/2014 Page 6 of 21 INMP522 SOLDERING PROFILE CRITICAL ZONE TL TO TP tP TP TEMPERATURE RAMP-UP TL tL TSMAX TSMIN tS RAMP-DOWN PREHEAT t25°C TO PEAK TEMPERATURE TIME Figure 2. Recommended Soldering Profile Limits TABLE 4. RECOMMENDED SOLDERING PROFILE PROFILE FEATURE Average Ramp Rate (TL to TP) Sn63/Pb37 1.25°C/sec max Pb-Free 1.25°C/sec max 100°C 100°C 150°C 200°C 60 sec to 75 sec 1.25°C/sec 60 sec to 75 sec 1.25°C/sec 45 sec to 75 sec 183°C ~50 sec 217°C 215°C +3°C/−3°C 260°C +0°C/−5°C Time Within +5°C of Actual Peak Temperature (tP) 20 sec to 30 sec 20 sec to 30 sec Ramp-Down Rate 3°C/sec max 3°C/sec max Time +25°C (t25°C) to Peak Temperature 5 min max 5 min max Minimum Temperature (TSMIN) Minimum Temperature Preheat (TSMIN) Time (TSMIN to TSMAX), tS Ramp-Up Rate (TSMAX to TL) Time Maintained Above Liquidous (tL) Liquidous Temperature (TL) Peak Temperature (TP) *The reflow profile in Table4 is recommended for board manufacturing with InvenSense MEMS microphones. All microphones are also compatible with the J-STD-020 profile. Document Number: DS-INMP522-00 Revision: 1.1 Rev Date: 02/06/2014 Page 7 of 21 INMP522 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS DATA VDD 5 1 CLK 4 2 L/R SELECT 3 GND Figure 3. Pin Configuration TABLE 5. PIN FUNCTION DESCRIPTIONS PIN NAME FUNCTION 1 CLK Clock Input to Microphone 2 L/R SELECT Left Channel or Right Channel Select: DATA 1 (right): L/R SELECT tied to GND DATA 2 (left): L/R SELECT tied to VDD 3 GND Ground 4 VDD Power Supply. For best performance and to avoid potential parasitic artifacts, place a 0.1 µF (100 nF) ceramic type X7R capacitor between Pin 4 (VDD) and ground. Place the capacitor as close to Pin 4 as possible. 5 DATA Digital Output Signal (DATA1 or DATA2) Document Number: DS-INMP522-00 Revision: 1.1 Rev Date: 02/06/2014 Page 8 of 21 INMP522 TYPICAL PERFORMANCE CHARACTERISTICS 15 10 NORMALIZED AMPLITUDE (dB) NORMALIZED AMPLITUDE (dB) 8 10 5 0 –5 –10 6 4 2 0 –2 –4 –6 –8 –15 –10 10 1k 100 10k 10 100 FREQUENCY (Hz) 1k 10k FREQUENCY (Hz) Figure 4. Frequency Response Mask Figure 5. Typical Frequency Response (Measured) 0 10 –10 –20 THD + N (%) PSR (dBFS) –30 –40 –50 1 –60 –70 –80 –90 100 1k 0.1 95 10k 105 110 Figure 7. THD+N vs. Input SPL Figure 6. Power Supply Rejection (PSR) vs. Frequency Document Number: DS-INMP522-00 Revision: 1.1 Rev Date: 02/06/2014 100 INPUT LEVEL (dB SPL) FREQUENCY (Hz) Page 9 of 21 115 120 INMP522 THEORY OF OPERATION PDM DATA FORMAT The output from the DATA pin of the INMP522 is in PDM format. This data is the 1-bit output of a fourth-order Σ-Δ modulator. The data is encoded so that the left channel is clocked on the falling edge of CLK and the right channel is clocked on the rising edge of CLK. After driving the DATA signal high or low in the appropriate half frame of the CLK signal, the DATA driver of the microphone is tristated. In this way, two microphones—one set to the left channel and the other to the right channel—can drive a single DATA line. Figure 1 shows a timing diagram of the PDM data format; the DATA1 and DATA2 lines shown in Figure 1 are two halves of the single physical DATA signal. Figure 8 shows a diagram of the two stereo channels sharing a common DATA line. CLK DATA2 (L) DATA DATA1 (R) DATA2 (L) DATA1 (R) Figure 8. Stereo PDM Format If only one microphone is connected to the DATA signal, the output is clocked on a single edge only (See Figure 9.) CLK DATA DATA1 (R) DATA1 (R) DATA1 (R) Figure 9. Mono PDM Format For example, a left channel microphone is never clocked on the rising edge of CLK. In a single microphone application, each bit of the DATA signal is typically held for the full CLK period until the next transition of the CLK signal because the leakage of the DATA line is not sufficient to discharge the line while the driver is tristated. The channel assignments are determined by the logic level on the L/R SELECT pin (see Table 6.) TABLE 6. INMP522 CHANNEL SETTING L/R SELECT Pin Setting Low (tie to GND) High (tie to VDD) Document Number: DS-INMP522-00 Revision: 1.1 Rev Date: 02/06/2014 Channel Right (DATA1) Left (DATA2) Page 10 of 21 INMP522 For PDM data, the density of the pulses indicates the signal amplitude. A high density of high pulses indicates a signal near positive full scale, and a high density of low pulses indicates a signal near negative full scale. A perfect zero (dc) audio signal is indicated by an alternating pattern of high and low pulses. The output PDM data signal has a small dc offset of approximately 5% of full scale. A high-pass filter in the codec that is connected to the digital microphone typically removes this dc signal and does not affect the performance of the microphone. PDM MICROPHONE SENSITIVITY The sensitivity of a PDM output microphone is specified in units of dBFS (decibels relative to a full-scale digital output). A 0 dBFS sine wave is defined as a signal whose peak just touches the full-scale code of the digital word (see Figure 10). This measurement convention means that signals with a different crest factor may have an RMS level higher than 0 dBFS. For example, a full-scale square wave has an RMS level of 3 dBFS. 1.0 0.8 DIGITAL AMPLITUDE (D) 0.6 0.4 0.2 0 –0.2 –0.4 –0.6 –0.8 –1.0 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 TIME (ms) Figure 10. 1 kHz, 0 dBFS Sine Wave The definition of a 0 dBFS signal must be understood when measuring the sensitivity of the inMP522. An acoustic input signal of a 1 kHz sine wave at 94 dB SPL applied to the INMP522 results in an output signal with a −26 dBFS level. This means that the output digital word peaks at −26 dB below the digital full-scale level. A common misunderstanding is that the output has an RMS level of −29 dBFS; however, this is not the case because of the definition of a 0 dBFS sine wave. There is no commonly accepted unit of measurement to express the instantaneous level of a digital signal output from the microphone, as opposed to the RMS level of the signal. Some measurement systems express the instantaneous level of an individual sample in units of D, where 1.0 D is digital full scale (see Figure 10). In this case, a −26 dBFS sine wave has peaks at 0.05 D. For more information about digital microphone sensitivity, see the AN-1112 Application Note, Microphone Specifications Explained. Document Number: DS-INMP522-00 Revision: 1.1 Rev Date: 02/06/2014 Page 11 of 21 INMP522 CONNECTING PDM MICROPHONES A PDM output microphone is typically connected to a codec with a dedicated PDM input. This codec separately decodes the left and right channels and filters the high sample rate modulated data back to the audio frequency band. The codec also generates the clock for the PDM microphones or is synchronous with the source that generates the clock. Figure 11 and Figure 12 show mono and stereo connections between the INMP522 and a codec. The mono connection shows an INMP522 set to output data on the right channel. To output data on the left channel, tie the L/R SELECT pin to VDD instead of GND. 1.8V TO 3.3V 0.1µF CODEC VDD INMP522 L/R SELECT CLK CLOCK OUTPUT DATA DATA INPUT GND Figure 11. Mono PDM Microphone (Right Channel) Connection to Codec Document Number: DS-INMP522-00 Revision: 1.1 Rev Date: 02/06/2014 Page 12 of 21 INMP522 1.8V TO 3.3V 0.1µF CODEC VDD CLK INMP522 CLOCK OUTPUT DATA L/R SELECT DATA INPUT GND 1.8V TO 3.3V 0.1µF VDD INMP522 L/R SELECT CLK DATA GND Figure 12. Stereo PDM Microphone Connection to Codec Decouple the VDD pin of the INMP522 to GND with a 0.1 µF capacitor. Place this capacitor as close to VDD as the printed circuit board (PCB) layout allows. Do not use a pull-up or pull-down resistor on the PDM data signal line because the resistor can pull the signal to an incorrect state during the period that the signal line is tristated. Document Number: DS-INMP522-00 Revision: 1.1 Rev Date: 02/06/2014 Page 13 of 21 INMP522 The DATA signal does not need to be buffered in normal use when the INMP522 microphones are placed close to the codec on the PCB. If the INMP522 must drive the DATA signal over a long cable (>15 cm) or other large capacitive load, a digital buffer may be needed. Use a signal buffer on the DATA line only when one microphone is in use or after the point where two microphones are connected (see Figure 13.) INMP522 CODEC CLOCK OUTPUT CLK DATA DATA INPUT INMP522 CLK DATA Figure 13. Buffered Connection Between stereo INMP522 Devices and a Codec The DATA output of each microphone in a stereo configuration cannot be individually buffered because the two buffer outputs cannot drive a single signal line. If a buffer is used, take care to select a buffer with low propagation delay so that the timing of the data connected to the codec is not corrupted. When long wires are used to connect the codec to the INMP522, a 100 Ω source termination resistor can be used on the clock output of the codec instead of a buffer to minimize signal over-shoot or ringing. Depending on the drive capability of the codec clock output, a buffer may still be needed, as shown in Figure 13. SLEEP MODE The microphone enters sleep mode when the clock frequency falls below 1 kHz. In sleep mode, the microphone data output is in a high impedance state. The current consumption of the INMP522 in sleep mode is less than 2 µA at VDD = 1.8 V. The INMP522 enters sleep mode within 1ms of the clock frequency falling below 1 kHz. The microphone wakes up from sleep mode 32,768 cycles after the clock becomes active. For a 2.4 MHz clock, the microphone begins to output data in 13.7 ms. The wake-up time, as specified in Table 2, indicates the time from when the clock is enabled to when the INMP522 is consuming its specified current. START-UP TIME The start-up time of the INMP522 from when the clock is active is the same as the wake-up time from sleep mode. The microphone starts up 32,768 cycles after the clock is active. Document Number: DS-INMP522-00 Revision: 1.1 Rev Date: 02/06/2014 Page 14 of 21 INMP522 SUPPORTING DOCUMENTS For additional information, see the following documents. EVALUATION BOARD USER GUIDE UG-326, PDM Digital Output MEMS Microphone Evaluation Board APPLICATION NOTE (PRODUCT SPECIFIC) AN-0078, High Performance Digital MEMS Microphone Simple Interface to a SigmaDSP Audio Codec APPLICATION NOTES (GENERAL) AN-1003, Recommendations for Mounting and Connecting the Invensense, Bottom-Ported MEMS Microphones AN-1068, Reflow Soldering of the MEMS Microphone AN-1112, Microphone Specifications Explained AN-1124, Recommendations for Sealing Invensense, Bottom-Port MEMS Microphones from Dust and Liquid Ingress AN-1140, Microphone Array Beamforming Document Number: DS-INMP522-00 Revision: 1.1 Rev Date: 02/06/2014 Page 15 of 21 INMP522 PCB DESIGN AND LAND PATTERN LAYOUT Lay out the PCB land pattern for the inMP522 at a 1:1 ratio to the solder pads on the microphone package (see Figure 14.) Take care to avoid applying solder paste to the sound hole in the PCB. Figure 15 shows a suggested solder paste stencil pattern layout. The response of the inMP522 is not affected by the PCB hole size, as long as the hole is not smaller than the sound port of the microphone (0.25 mm, or 0.010 inch, in diameter). A 0.5 mm to 1 mm (0.020 inch to 0.040 inch) diameter for the hole is recommended. Align the hole in the microphone package with the hole in the PCB. The exact degree of the alignment does not affect the performance of the microphone as long as the holes are not partially or completely blocked. 3.80 ø1.70 CENTER LINE (0.30) 0.40 × 0.60 (4×) 0.35 (1.000) 0.90 (0.30) 2.80 ø1.10 (0.30) 0.70 (0.30) (0.550) 2× R0.10 2.05 0.35 Figure 14. Suggested PCB Land Pattern Layout Dimensions shown in millimeters 2.45 1.498 × 0.248 0.9 0.248 × 0.948 (2×) 0.398 × 0.298 (4×) 1.849 0.35 1.45 CENTER LINE 0.7 1.000 1.525 1.849 0.248 × 1.148 (2×) 0.375 24° 1.17 24° 0.248 × 0.498 (2×) 1.498 0.205 WIDE 0.362 CUT (3×) Figure 15. Suggested Solder Paste Stencil Pattern Layout Dimensions shown in millimeters Document Number: DS-INMP522-00 Revision: 1.1 Rev Date: 02/06/2014 Page 16 of 21 INMP522 ALTERNATIVE PCB LAND PATTERNS The standard PCB land pattern of the INMP522 has a solid rectangle around the edge of the footprint (see Figure 14). In some board designs, this rectangle can make routing the microphone signals more difficult. The rectangle is used to improve the RF immunity performance of the INMP522; however, it is not necessary to have the full rectangle connected for electrical functionality. If a design can tolerate reduced RF immunity, this rectangle can either be broken or removed completely from the PCB footprint. Figure 16 shows an example PCB land pattern with no enclosing rectangle around the edge of the part. Figure 16. Example PCB Land Pattern with No Enclosing Rectangle Figure 17 shows an example PCB land pattern with the rectangle broken on two sides so that the inner pads can be more easily routed on the PCB. Figure 17. Example PCB Land Pattern with Broken Enclosing Rectangle Note that in both of these patterns, the solid ring around the sound port is still present; this ring is needed to ground the microphone and for acoustic performance. The pad on the package connected to this ring is ground and still needs a solid electrical connection to the PCB ground. If a land pattern similar to Figure 16 or Figure 17 is used on a PCB, make sure that the unconnected rectangle on the bottom of the INMP522 is not placed directly over any exposed copper. The rectangle on the microphone is still at ground, and any PCB traces routed beneath it must be properly masked to avoid short circuits. PCB MATERIAL AND THICKNESS The performance of the INMP522 is not affected by PCB thickness. The INMP522 can be mounted on either a rigid or flexible PCB. A flexible PCB with the microphone can be attached directly to the device housing with an adhesive layer. This mounting method offers a reliable seal around the sound port, while providing the shortest acoustic path for good sound quality. Document Number: DS-INMP522-00 Revision: 1.1 Rev Date: 02/06/2014 Page 17 of 21 INMP522 HANDLING INSTRUCTIONS PICK AND PLACE EQUIPMENT The MEMS microphone can be handled using standard pick-and-place and chip shooting equipment. Take care to avoid damage to the MEMS microphone structure as follows: • Use a standard pickup tool to handle the microphone. Because the microphone hole is on the bottom of the package, the pickup tool can make contact with any part of the lid surface. • Do not pick up the microphone with a vacuum tool that makes contact with the bottom side of the microphone. Do not pull air out of or blow air into the microphone port. • Do not use excessive force to place the microphone on the PCB. REFLOW SOLDER For best results, the soldering profile must be in accordance with the recommendations of the manufacturer of the solder paste used to attach the MEMS microphone to the PCB. It is recommended that the solder reflow profile not exceed the limit conditions specified in Figure 2 and Table 4. BOARD WASH When washing the PCB, ensure that water does not make contact with the microphone port. Do not use blow-off procedures or ultrasonic cleaning. Document Number: DS-INMP522-00 Revision: 1.1 Rev Date: 02/06/2014 Page 18 of 21 INMP522 OUTLINE DIMENSIONS 4.10 4.00 3.90 0.95 REF 2.05 1.70 DIA. REFERENCE CORNER 3.54 REF 0.70 0.40 × 0.60 (Pins 1, 2, 4, 5) PIN 1 0.30 REF 0.90 2.48 REF 3 1 2 5 4 0.30 REF 3.10 3.00 2.90 R 0.10 (2 ×) 2.80 1.05 REF TOP VIEW 0.35 0.35 1.10 1.00 0.90 1.10 DIA. 1.50 0.25 DIA. (THRU HOLE) 0.30 REF 0.30 REF 0.72 REF SIDE VIEW 04-19-2012-G 3.80 BOTTOM VIEW 0.24 REF Figure 18. 5-Terminal Chip Array Small Outline No Lead Cavity [LGA_CAV] 4 mm × 3 mm Body Dimensions shown in millimeters PART NUMBER PIN 1 INDICATION 522 YY XXXX DATE CODE LOT TRACEABILITY CODE Figure 19. Package Marking Specification (Top View) Document Number: DS-INMP522-00 Revision: 1.1 Rev Date: 02/06/2014 Page 18 of 21 INMP522 ORDERING GUIDE PART INMP522ACEZ-R0 TEMP RANGE −40°C to +85°C PACKAGE 5-Terminal LGA_CAV* QUANTITY 5,000 INMP522ACEZ-R7 −40°C to +85°C 5-Terminal LGA_CAV† 1,000 EV_INMP522-FX — Flexible Evaluation Board — * – 13” Tape and Reel † – 7” Tape and reel to be discontinued. Check with sales@invensense.com for availability. REVISION HISTORY REVISION DATE REVISION DESCRIPTION 02/06/2014 1.0 Initial Release 05/14/2014 1.1 Corrected typo in EC Table Document Number: DS-INMP522-00 Revision: 1.1 Rev Date: 02/06/2014 Page 19 of 21 INMP522 Compliance Declaration Disclaimer InvenSense believes the environmental and other compliance information given in this document to be correct but cannot guarantee accuracy or completeness. Conformity documents substantiating the specifications and component characteristics are on file. InvenSense subcontracts manufacturing, and the information contained herein is based on data received from vendors and suppliers, which has not been validated by InvenSense. This information furnished by InvenSense is believed to be accurate and reliable. However, no responsibility is assumed by InvenSense for its use, or for any infringements of patents or other rights of third parties that may result from its use. Specifications are subject to change without notice. InvenSense reserves the right to make changes to this product, including its circuits and software, in order to improve its design and/or performance, without prior notice. InvenSense makes no warranties, neither expressed nor implied, regarding the information and specifications contained in this document. InvenSense assumes no responsibility for any claims or damages arising from information contained in this document, or from the use of products and services detailed therein. This includes, but is not limited to, claims or damages based on the infringement of patents, copyrights, mask work and/or other intellectual property rights. Certain intellectual property owned by InvenSense and described in this document is patent protected. No license is granted by implication or otherwise under any patent or patent rights of InvenSense. This publication supersedes and replaces all information previously supplied. Trademarks that are registered trademarks are the property of their respective companies. InvenSense sensors should not be used or sold in the development, storage, production or utilization of any conventional or mass-destructive weapons or for any other weapons or life threatening applications, as well as in any other life critical applications such as medical equipment, transportation, aerospace and nuclear instruments, undersea equipment, power plant equipment, disaster prevention and crime prevention equipment. ©2014 InvenSense, Inc. All rights reserved. InvenSense, MotionTracking, MotionProcessing, MotionProcessor, MotionFusion, MotionApps, DMP, AAR, and the InvenSense logo are trademarks of InvenSense, Inc. Other company and product names may be trademarks of the respective companies with which they are associated. ©2014 InvenSense, Inc. All rights reserved. Document Number: DS-INMP522-00 Revision: 1.1 Rev Date: 02/06/2014 Page 20 of 21
INMP522ACEZ-R7 价格&库存
很抱歉,暂时无法提供与“INMP522ACEZ-R7”相匹配的价格&库存,您可以联系我们找货
