IQE48040A033V-001-R
IQE48040A033V-001-R
    TDK(东电化)
    DC DC CONVERTER 3.3V 132W
IQE48040A033V-001-R 数据手册
iQE Series 96 - 204W Quarter Brick Converter Features u Standard Quarter Brick Footprint u 18-36, 36-75VDC Inputs u 3.3V 40A - 15V 10A Nominal Outputs u Through Hole Mounting u Low 10.41mm Profile u 1500VDC Basic Isolation u High operating efficiency (>90%) u Constant switching frequency u Low component count Key Market Segments & Applications Specifications Model Nominal Output Voltage VDC 3.3 5 8 12 15 Input Voltage Range VDC See Model Selector Input Current (max) A 10 Efficiency Typically 90% at full load Output Voltage Tolerance VDC 3.2 - 3.4 4.85 - 5.15 7.76 - 8.24 11.58 - 12.42 14.48 - 15.52 Ripple & Noise (max)(pk to pk) (1) mV 150 150 150 150 150 Line Regulation (max) mV 10 15 25 30 30 Load Regulation (max) mV 10 30 25 30 30 Overload Protection (typ) % Inception- 133-158% of rated output; Short circuit - auto recovery Overvoltage Protection VDC 3.8 - 4.6 5.7 - 6.7 8.9 - 11 13.6 - 16.5 16.7 - 21 Remote Sense Yes Remote On / Off Positive or Negative Logic available, see Model Selector Temperature (operating) °C -40 to 125 Temperature (storage) °C -55 to 125 Humidity (operating) 20-95% RH Non condensing Humidity (storage) 10-95% RH Non condensing Cooling Convection or forced air Isolation Voltage VDC 1500 Vibration (non operating) - 5 to 50Hz @ 0.5g (4.9m/s2), and 50 to 500Hz @ 1.5g (14.7m/s2) per Bellcore TR-EOP-000063-5.4.4 Shock 196.1m/s2 Safety Agency Approvals UL60950 (US and Canada), VDE0805 (IEC60950), CB scheme (IEC60950) Weight (max) g 50 Size mm 57.9 x 36.8 x 10.41 Warranty 3 Years Notes: See website for detailed specifications (1) Measured across one 22µF and one 0.1µF ceramic capacitor; BW = 20MHz 1-800-526-2324 • www.us.tdk-lambda.com/lp/ 206 Disclaimer: us.tdk-lambda.com/lp/legal.htm iQE Series Model Selector Model iQE24030A033V-001-R iQE24030A033V-007-R iQE48040A033V-000-R iQE48040A033V-001-R iQE48040A033V-007-R iQE24024A050V-001-R iQE24024A050V-007-R iQE48030A050V-000-R iQE48030A050V-001-R iQE24012A080V-001-R iQE24012A080V-007-R iQE48014A080V-001-R iQE24009A120V-001-R iQE24009A120V-007-R iQE4W011A120V-001-R iQE48017A120V-000-R iQE48017A120V-001-R iQE48017A120V-007-R iQE24007A150V-001-R iQE24007A150V-007-R iQE48010A150V-001-R iQE48010A150V-007-R Input Output Voltage (V) Voltage (V) 18 - 36 3.3 18 - 36 3.3 36 - 75 3.3 36 - 75 3.3 36 - 75 3.3 18 - 36 5 18 - 36 5 36 - 75 5 36 - 75 5 18 - 36 8 18 - 36 8 36 - 75 8 18 - 36 12 18 - 36 12 18 - 60 12 36 - 75 12 36 - 75 12 36 - 75 12 18 - 36 15 18 - 36 15 36 - 75 15 36 - 75 15 Adjust Range (V) 2.97 - 3.63 2.97 - 3.63 2.97 - 3.63 2.97 - 3.63 2.97 - 3.63 4.5 - 5.5 4.5 - 5.5 4.5 - 5.5 4.5 - 5.5 7.2 - 8.8 7.2 - 8.8 7.2 - 8.8 10.8 - 13.2 10.8 - 13.2 10.8 - 13.2 10.8 - 13.2 10.8 - 13.2 10.8 - 13.2 13.5 - 16.5 13.5 - 16.5 13.5 - 16.5 13.5 - 16.5 Recommended Footprint (Top View) 1 2 3 8 7 6 5 4 Max. Curr. (A) 30 30 40 40 40 24 24 30 30 12 12 14 9 9 11 17 17 17 7 7 10 10 Max. Output Power (W) 99 99 132 132 132 120 120 150 150 96 96 112 108 108 132 204 204 204 105 105 150 150 On/Off Polarity Neg Neg Pos Neg Neg Neg Neg Pos Neg Neg Neg Neg Neg Neg Neg Pos Neg Neg Neg Neg Neg Neg Pin Length 0.145 0.180 0.145 0.145 0.180 0.145 0.180 0.145 0.145 0.145 0.180 0.145 0.145 0.180 0.145 0.145 0.145 0.180 0.145 0.180 0.145 0.180 Pinout PIN 1 2 3 4 5 6 7 8 Function Vin (+) On / Off Vin (-) Vout (-) Sense (-) Trim Sense (+) Vout (+) For Additional Information, please visit us.tdk-lambda.com/lp/products/iqe-series.htm 1-800-526-2324 • www.us.tdk-lambda.com/lp/ 207 Revision A5: Dec 2011
IQE48040A033V-001-R 价格&库存
很抱歉,暂时无法提供与“IQE48040A033V-001-R”相匹配的价格&库存,您可以联系我们找货
