iQL Series
https://product.tdk.com/en/power/iQL
www.emea.lambda.tdk.com/uk/products/iql
72-308W, 18 to 36V or 36 to 75V Input
Isolated DC-DC Quarter Brick
The iQL series of isolated DC-DC converters deliver up to 308W in a compact and high-performance industry standard quarter footprint. Capable
of operating from nominal input voltages of 24V (18-36V) or 48V (36 to 75V), the converter provides fully regulated outputs from 1.2V up to 28V for
demanding environments in telecom, datacom, computing and industrial applications. The output voltage can be adjusted from -20 to +10% of
nominal using the trim connection to accomodate non-standard voltages.
Features
Benefits
• High Operating Efficiency up to 94%
• Reduces Heat Losses/Dissipation in System
• Open frame or Baseplate Construction
• Mounting Flexibility for Low profile or Conduction Cooling
• Available from 1.2V up to 28V outputs
• Flexible and wide output voltage coverage for various loads
• Constant Switching Frequency
• Predictable EMI
• Monotonic Start-Up Into a Pre-Bias Output
• Reliable and Stable Output in Multi-Load conditions
Model Selector
Model
iQL24021A120V-001-R
iQL24021A120V-009-R
iQL24040A050V-001-R
iQL24040A050V-009-R
iQL24050A033V-009-R
iQL48011A280V-008-R
iQL48011A280V-009-R
iQL48011A280V-0A9-R *
iQL48025A120V-001-R
iQL48025A120V-009-R
iQL48025A120V-0B9-R
iQL48045A050V-001-R
iQL48045A050V-009-R
iQL48045A050V-0B3-R **
iQL48045A050V-0B9-R
iQL48060A033V-003-R **
iQL48060A033V-009-R
iQL48060A033V-0B9-R
iQL48060A025V-008-R
iQL48060A025V-0B3-R **
iQL48060A025V-0B9-R
iQL48060A012V-0B3-R **
Input
Output
Output Adjust
Max
Max
Voltage (V) Voltage (V) Range (V) Current (A) Power (W) Efficiency
20 - 36
20 - 36
18 - 36
18 - 36
18 - 36
36 - 75
36 - 75
36 - 75
36 - 75
36 - 75
36 - 75
36 - 75
36 - 75
36 - 75
36 - 75
36 - 75
39 - 75
39 - 75
36 - 75
36 - 75
36 - 75
36 - 75
12
12
5
5
3.3
28
28
28
12
12
12
5
5
5
5
3.3
3.3
3.3
2.5
2.5
2.5
1.2
9.6 - 13.2
9.6 - 13.2
4.0 - 5.5
4.0 - 5.5
2.64 - 3.63
22.4 - 30.8
22.4 - 30.8
16.8 - 30.8
9.6 - 13.2
9.6 - 13.2
9.6 - 13.2
4.0 - 5.5
4.0 - 5.5
4.0 - 5.5
4.0 - 5.5
2.64 - 3.63
2.64 - 3.63
2.64 - 3.63
2.0 - 2.75
2.0 - 2.75
2.0 - 2.75
0.96 - 1.32
21
21
40
40
50
11
11
11
25
25
25
45
45
45
45
60
60
60
60
60
60
60
252
252
200
200
165
308
308
308
300
300
300
225
225
225
225
198
198
198
150
150
150
72
92.0%
92.0%
91.0%
91.0%
90.5%
92.5%
92.5%
92.5%
94.0%
94.0%
94.0%
91.0%
91.0%
91.0%
91.0%
91.0%
91.0%
91.0%
89.0%
89.0%
89.0%
83.5%
On/Off Pic Length
Polarity (inch) Baseplate
Neg
Neg
Neg
Neg
Neg
Pos
Neg
Neg
Neg
Neg
Neg
Neg
Neg
Neg
Neg
Neg
Neg
Neg
Pos
Neg
Neg
Neg
0.145”
0.180”
0.145”
0.180”
0.180”
0.180”
0.180”
0.180”
0.145”
0.180”
0.180”
0.145”
0.180”
0.145”
0.180”
0.145”
0.180”
0.180”
0.180”
0.145”
0.180”
0.145”
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
No
Yes
Yes
No
No
Yes
Yes
No
Yes
No
No
No
Notes
* With higher OCP limit up to 15A
** Non Latching OVP
iQL Series
1
Related Products
Type
Part Number
Isolated DC-DC Converter
iQG
iEH
iEA
GQA
Non-Isolated DC-DC Converter
iBH
iCH
Non-Isolated DC-DC Buck-Boost Converter
i7C
Input Filter
iDQ
Evaluation Board
FQX-HQA-EVK-D0
Description
300W-504W, Input 36-75V, Isolated Quarter Brick
300W, Input 36-75V, Isolated Eighth Brick
78W, Input 36-75V, Isolated Eighth Brick
120W Industrial, Input 9-36V, Isolated Quarter Brick
80W/20A, 3.5-14Vin, 0.7 - 5.5Vout, DOSA Compatible
85W/12A, 4.5-14Vin, 0.7 - 8.5Vout, DOSA Compatible
300W, Input 9-53V or 9-36V, Output 9.6-48V 8A, 5-28V 12.5A or 8-24V 20A
75V / 10A Filter
Evaluation board (no modules) that fits standard Eighth or Quarter brick
and FQx or iDQ input filters
Specifications
Model
1.2V
2.5V
3.3V 5V
12V
28V
Input
Input Voltage Range
(iQL24) Vdc
18 - 36
20 - 36
(iQL48)
36 - 75
Input Transient, 100 ms
Vdc 50 (iQL24); 100 (iQL48)
Input Current (max
(iQL24)
A
12
13
14.5
(iQL48)
3
5.2
7
7.5
10
10.5
Turn-ON Input Voltage (typ) (iQL24) Vdc
16.9
19.9
(iQL48) 34.2 - 34.9
Turn-OFF Input Voltage (typ) (iQL24) Vdc
16.0
18.8
(iQL48)
32.4 - 33.2
Efficiency (typical)
Refer to Model Selector Table
Safety Certifications and Markings
IEC/UL/CSA/EN 62368-1, 60950-1, CE Mark and UKCA Mark
Output
Output Voltage Initial Setpoint (iQL24) Vdc
11.3 - 11.9
3.23 - 3.37
4.88 - 5.12
(iQL48)
1.17 - 1.23
2.45 - 2.55
11.7 - 12.3
27.4 - 28.6
Output Voltage Tolerance
(iQL24) Vdc
3.20 - 3.40
11.2 - 12.0
4.85 - 5.15
(iQL48)
1.16 - 1.24
2.42 - 2.58
3.23 - 3.37
11.6 - 12.4
27.2 - 28.8
Line Regulation
(iQL24)
mV
2 4
40
(iQL48)
1
1.5
2
3
2
50
Load Regulation
(iQL24)
mV
2 4
70
(iQL48)
1
1.5
3
3
5
40
Remote Sense
Yes
Yes
Yes
Yes
Yes (3)
Yes
External Load Capacitance
(iQL24) uF
470 - 5,000
488 - 40,000
488 - 25,000
(iQL48)
488 - 60,000 488 - 40,000
488 - 8,000
480 - 3,300
Ripple & Noise (typ)
(iQL24) mVpp
27
27
65
(iQL48)
30
30
35
40
25
310
Switching Frequency (fixed)
(iQL24) kHz
125
130
120
(iQL48)
110
125
130
125
145
125
Overcurrent Protection (hiccup) (iQL24)
A
57
44
23
(iQL48)
71
69
70
54
31.5
12.5
Over Voltage Protection (2)
Vdc 1.5
3.1
4.1 6.1
14.5
33.2
Over Temperature Protection
Auto recovery
Environmental
Operating Temperature (Tc)
°C
-40 up to 125 (maximum temperature is model dependent, check the product specifications)
Storage Temperature
°C
-55 to 125
Humidity (non condensing)
%RH
10 - 95
Cooling
Conduction, convection or forced air (See product specifications for derating)
Isolation Voltage
Vdc
1500 (Input to Output; Output to Baseplate)
Shock
MIL-STD-202G, Method 213B, Test Condition 1
Vibration
5 to 50 Hz (0.5g); 50 to 500 Hz (1.5g); three axes; Bellcore TR-EOP-000063-5.4.4
2
iQL Series
Specifications
Model
1.2V
2.5V
Other
Weight (max)
g
Size (LxWxH)
mm
Size (LxWxH)
Inches
MTBF - Telcordia SR-332 (100% Load, 40°C) MHrs
Warranty
yrs
3.3V 5V
12V
28V
70 (baseplate); 55 (open frame)
57.91 x 36.83 x ≤13.21
2.28 x 1.45 x ≤0.52
>3
3
Notes
(1) See website for detailed product specifications.
(2) Default Over Voltage Protection is Latching unless otherwise indicated. Refer to Model Selector Table.
(3) iQL24021A120V has remote sense, iQL48025A120V does not have remote sense.
Mechanical Specification
iQL Series
3
components, do not
exceed 4.83 [0.190]
depth with M3 screw
2 places
1.57 [0.062] DIA Pin
2.59 [0.102] DIA Stand-off
2 Places
1.02 [0.040] DIA Pin
1.83 [0.072] DIA Stand-off
6 Places
Recommended PCB Hole Pattern
4
3
2
1
8
PIN Assignment
Pin Function Pin Function
1 Vin(+)
2
On/Off
3
Vin(-)
4
Vo(-)
Pin base material is brass with gold over nickel plating.
4
iQL Series
5
Sense (+) (if applicable)
6
Trim
7
8
Vo(+)
TDK-Lambda France SAS
TDK-Lambda Americas
Tel: +33 1 60 12 71 65
tlf.fr-powersolutions@tdk.com
Tel: +1 800-LAMBDA-4 or 1-800-526-2324
tla.powersolutions@tdk.com
www.us.lambda.tdk.com
www.emea.lambda.tdk.com/fr
Italy Sales Office
Tel: +39 02 61 29 38 63
tlf.it-powersolutions@tdk.com
www.emea.lambda.tdk.com/it
TDK Electronics do Brasil Ltda
Tel: +55 11 3289-9599
sales.br@tdk-electronics.tdk.com
www.tdk-electronics.tdk.com/en
Netherlands
tlf.nl-powersolutions@tdk.com
www.emea.lambda.tdk.com/nl
TDK-Lambda Germany GmbH
TDK-Lambda Corporation
Tel: +49 7841 666 0
tlg.powersolutions@tdk.com
www.emea.lambda.tdk.com/de
Tel: +81-3-6778-1113
www.jp.lambda.tdk.com
TDK-Lambda (China) Electronics Co. Ltd.
Tel: +86 21 6485-0777
tlc.powersolutions@tdk.com
www.lambda.tdk.com.cn
Austria Sales Office
Tel: +43 2256 655 84
tlg.at-powersolutions@tdk.com
TDK-Lambda Singapore Pte Ltd.
Switzerland Sales Office
Tel: +65 6251 7211
tls.marketing@tdk.com
www.sg.lambda.tdk.com
Tel: +41 44 850 53 53
tlg.ch-powersolutions@tdk.com
TDK India Private Limited, Power Supply Division
www.emea.lambda.tdk.com/at
www.emea.lambda.tdk.com/ch
Tel: +91 80 4039-0660
mathew.philip@tdk.com
Nordic Sales Office
Tel: +45 8853 8086
tlg.dk-powersolutions@tdk.com
www.emea.lambda.tdk.com/dk
TDK-Lambda UK Ltd.
Tel: +44 (0) 12 71 85 66 66
tlu.powersolutions@tdk.com
TDK-Lambda Ltd.
Tel: +9 723 902 4333
tli.powersolutions@tdk.com
www.emea.lambda.tdk.com/il-en
For additional information, please visit
iQL_260936_July 27th, 2023 V2
iQL Series
5
IQL48011A280V-008-R 价格&库存
很抱歉,暂时无法提供与“IQL48011A280V-008-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 72+797.6903172+103.32880
