IQL48011A280V-0A9-R
IQL48011A280V-0A9-R
    TDK(东电化)
    CONVRTRDC/DC
IQL48011A280V-0A9-R 数据手册
iQL Series 72-308W Quarter Brick Converter Features  Standard Quarter Brick Footprint  18-36, 36-75VDC Inputs  1.2V 60A, 28V 11A Nominal Outputs  Through Hole Mounting  1500VDC Basic Isolation  Baseplate cooling  High operating efficiency (up to 93.5%)  Constant switching frequency Key Market Segments & Applications Specifications Model Nominal Output Voltage Input Voltage Range Ripple & Noise (max)(pk-pk) Line Regulation (max) Load Regulation (max) Overload Protection Threshold Overvoltage Protection (Typ) Overtemperature Protection Remote Sense Remote On / Off Temperature (operating) Temperature (storage) Humidity (operating) Humidity (storage) Cooling Isolation Voltage Vibration (non operating) Shock Safety Agency Approvals Weight (max) Size Warranty (1) (2) (3) (4) (5) (6) IQL (1) (3) (6) (3) VDC 1.2 2.5 3.3 5 12 28 VDC See Model Selector mV 60 30 100 80 120 500 mV 1 5 6.6 10 60 100 mV 1 5 15 10 60 100 A 71 69 70 50 27.5 12.4 VDC 1.4 3.1 4.1 6.1 14.7 33.6 Yes Yes Yes Yes No No(4) No Negative Logic (5) °C -40 to 115 -40 to 115 -40 to 125 -40 to 119 -40 to 118 -40 to 115 °C -55 to 125 20 to 95% (non-condensing) 10 to 95% (non-condensing) Conduction, convection, or forced air VDC 1500 Input - Output, 1500 Input - Baseplate 5 to 50Hz@0.5g (4.9m/s2), and 50 to 500Hz@1.5g (14.7m/s2) per Bellcore TR-EOP-000063-5.4.4 50 G at 6 ms pulse in three axes UL60950 (US and Canada), VDE0805, CB scheme (IEC950), CE Mark (EN60950) g 55g open frame, 70g with base plate mm 57.9 x 36.8 x 13.21 yrs 3 Years See website for detailed specification and test methods. Latching. Non-latching. iQL24021A120V has remote sense. iQL48011A 280V-008-R has positive logic. All models have the latching type except for model numbers with note (3). 1-800-526-2324 • www.us.tdk-lambda.com/lp/ 165 Disclaimer: us.tdk-lambda.com/lp/legal.htm iQL Series Model Selector Model iQL48060A012V-0B3-R iQL48060A025V-0B3-R iQL48060A025V-0B9-R iQL24050A033V-009-R iQL48060A033V-003-R iQL48060A033V-009-R iQL48060A033V-0B9-R iQL24040A050V-001-R iQL24040A050V-009-R iQL48045A050V-001-R iQL48045A050V-0B3-R iQL48045A050V-009-R iQL48045A050V-0B9-R iQL24021A120V-001-R iQL24021A120V-009-R iQL48025A120V-009-R iQL48025A120V-0B9-R iQL48025A120V-001-R iQL48011A280V-0A9-R iQL48011A280V-008-R iQL48011A280V-009-R (3) (3) (3) (2) (3) (2) Input Voltage (V) 36 - 75 36 - 75 36 - 75 18 - 36 36 - 75 36 - 75 36 - 75 18 - 36 18 - 36 36 - 75 36 - 75 36 - 75 36 - 75 20 - 36 20 - 36 36 - 75 36 - 75 36 - 75 36 - 75 36 - 75 36 - 75 Output Voltage (V) 1.2 2.5 2.5 3.3 3.3 3.3 3.3 5.0 5.0 5.0 5.0 5.0 5.0 12.0 12.0 12.0 12.0 12.0 28.0 28.0 28.0 Adjust Max. Max. Output Range (V) Curr. (A) Power (W) 0.96 - 1.32 60 72.0 2.0 - 2.75 60 150.0 2.0 - 2.75 60 150.0 2.64 - 3.63 50 165.0 2.64 - 3.63 60 198.0 2.64 - 3.63 60 198.0 2.64 - 3.63 60 198.0 4.0 - 5.5 40 200.0 4.0 - 5.5 40 200.0 4.0 - 5.5 45 225.0 4.0 - 5.5 45 225.0 4.0 - 5.5 45 225.0 4.0 - 5.5 45 225.0 9.6 - 13.2 21 252.0 9.28 - 12.76 21 252.0 9.6 - 13.2 25 300.0 9.6 - 13.2 25 300.0 9.6 - 13.2 25 300.0 16.8 - 30.8 11 308.0 22.4 - 30.8 11 308.0 27.4 - 28.6 11 308.0 Base Plate No No No Yes Yes Yes No Yes Yes Yes No Yes No Yes Yes Yes No Yes Yes Yes Yes Efficiency at Pin Full Load (%) Length (in) 83.5 0.145 89.0 0.145 89.0 0.180 90.5 0.180 91.0 0.145 91.0 0.180 91.0 0.180 91.0 0.145 91.0 0.180 91.0 0.145 91.0 0.145 91.0 0.180 91.0 0.180 92.0 0.145 92.0 0.180 93.5 0.180 93.5 0.180 94.0 0.145 92.5 0.180 92.5 0.180 92.5 0.180 (2) Latching. (3) Non-latching. Preferred Model Recommended Footprint (Bottom View) 3 4 2 1 8 Pinout PIN 1 2 3 4 Function Vin (+) On / Off Vin (-) Vo (-) PIN 5 6 7 8 Function Sense (-)(if applicable) Trim Sense (+)(if applicable) Vo (+) For Additional Information, please visit us.tdk-lambda.com/lp/products/iql-series.htm 1-800-526-2324 • www.us.tdk-lambda.com/lp/ 166 Revision A7.2: Apr 2015
IQL48011A280V-0A9-R 价格&库存
很抱歉,暂时无法提供与“IQL48011A280V-0A9-R”相匹配的价格&库存,您可以联系我们找货
