JWS5015/RA
JWS5015/RA
    TDK(东电化)
    SWITCHINGPOWERSUPPLIES
JWS5015/RA 数据手册
JWS Series Single Output Industrial Power Supplies Features u 5 Year Warranty u Power factor Corrected u Approved to VDE0160 Machinery Directive u Universal Input (85 - 265VAC) u Level B EMI Key Market Segments & Applications u Factory Automation Process Control, NC-Machining, Automotive, Packaging Equipment, Materials Handling, Chemical Processing, Robots u Test & Measurement Burn-in & Test, Automated Test, Instrumentation, Measurement, Detection Not recommended for new designs - see HWS series Specifications Model Input Voltage range Inrush Current (100 / 200VAC) Power Factor Temperature Coefficient Overcurrent Protection Overvoltage Protection Hold Up Time (Typ) Leakage Current (max) Remote Sense Remote On / Off AC Power Fail Parallel Connection Operating Temp. (open frame) Operating Temp. (with cover) Storage Temperature Operating Humidity Storage Humidity Cooling Withstand Voltage (1) (1) Isolation Resistance Vibration (non operating) Shock Safety Agency Approvals Conducted & Radiated EMI Recommended EMI Filter Weight (Typ) Size (WxHxD) Warranty JWS50 A V ms mA g mm - JWS75 JWS100 JWS150 JWS300 JWS600 85 - 265VAC (47 - 63Hz) or 120 - 330VDC 14 / 28 25 / 50 20 / 40 Meets EN61000-3-2 105% Yes 20 0.75 No Yes Specify as Option /R Standard Not Available Standard Not Available Avail. JWS300 & 600 only -10ºC~+60ºC, derate linearly to 60% load from 50ºC~60ºC -10ºC~+50ºC, derate linearly to 60% load from 40ºC~50ºC (JWS50-150) -10ºC~+65ºC, derate linearly to 55% load from 50ºC~65ºC (JWS300-600) -30 to +85ºC 30 - 90% RH 10 - 90% RH 10 - 95% RH JWS50 - JWS150 Convection, JWS300 & JWS600 Internal fan Input to Ground 2kVAC (20mA), Input to Output 3kVAC (20mA), Output to Ground 500VAC (100mA) for 1 min. >100M at 25ºC & 70%RH, Output to Ground 500VDC 10 - 55Hz (1 minute sweep), 19.6m/s2 constant X, Y, Z 1 hour < 196.1 m/s2 UL60950-1, CSA C22.2 No. 60950-1, EN60950-1, VDE0160, CE Mark, Built to meet DENTORI EN55011 / EN55022-B, FCC Class B, VCCI-B MAW1202-22 MAW1203-22 MB1210 MB1216 350 450 650 850 1900 3000 See side 2 Five Years (1) Non condensing 1-800-526-2324 • www.us.tdk-lambda.com/lp/ 11 Disclaimer: us.tdk-lambda.com/lp/legal.htm JWS Series Model Derating* Model JWS300-2 JWS600-2 JWS50-3/A JWS75-3/A JWS100-3/A JWS150-3/A JWS300-3 JWS600-3 JWS50-5/A JWS75-5/A JWS100-5/A JWS150-5/A JWS300-5 JWS600-5 JWS100-6/A JWS300-6 JWS600-6 JWS600-8 JWS50-9/A JWS100-9/A JWS300-9 JWS600-9 JWS50-12/A JWS75-12/A JWS100-12A JWS150-12/A JWS300-12 JWS600-12 JWS50-15/A JWS75-15/A JWS100-15/A JWS150-15/A JWS300-15 JWS600-15 JWS50-24/A JWS75-24/A JWS100-24/A JWS150-24/A JWS300-24 JWS600-24 JWS50-28/A JWS100-28/A JWS150-28/A JWS300-28 JWS600-28 JWS50-48/A JWS75-48/A JWS100-48/A JWS150-48/A JWS300-48 JWS600-48 Voltage Adjust Range 2.0V 2.0V 3.3V 3.3V 3.3V 3.3V 3.3V 3.3V 5.0V 5.0V 5.0V 5.0V 5.0V 5.0V 6.0V 6.0V 6.0V 8.0V 9.0V 9.0V 9.0V 9.0V 12.0V 12.0V 12.0V 12.0V 12.0V 12.0V 15.0V 15.0V 15.0V 15.0V 15.0V 15.0V 24.0V 24.0V 24.0V 24.0V 24.0V 24.0V 28.0V 28.0V 28.0V 28.0V 28.0V 48.0V 48.0V 48.0V 48.0V 48.0V 48.0V 1.8 - 2.4 1.8 - 2.4 2.85 - 3.63 2.85 - 3.63 2.85 - 3.63 2.85 - 3.63 2.97 - 3.96 2.97 - 3.96 4.5 - 5.5 4.5 - 5.5 4.5 - 5.5 4.5 - 5.5 4.5 - 6.0 4.5 - 6.0 5.4 - 6.6 5.4 - 7.2 5.4 - 7.2 7.2 - 9.6 8.1 - 9.9 8.1 - 9.9 8.1 - 10.8 8.1 - 10.8 10.8 - 13.2 10.8 - 13.2 10.8 - 13.2 10.8 - 13.2 10.8 - 14.4 10.8 - 14.4 13.5 - 16.5 13.5 - 16.5 13.5 - 16.5 13.5 - 16.5 13.5 - 18.0 13.5 - 18.0 21.6 - 26.4 21.6 - 26.4 21.6 - 26.4 21.6 - 26.4 21.6 - 28.8 21.6 - 28.8 25.2 - 30.8 25.2 - 30.8 25.2 - 30.8 25.2 - 33.6 25.2 - 33.6 43.2 - 52.8 43.2 - 52.8 43.2 - 52.8 43.2 - 52.8 43.2 - 52.8 43.2 - 52.8 JWS Outline Drawing Max Load Line Ripple Eff. Curr. Reg mV Reg mV Noise (typ)% 60 120 10 15 20 30 60 120 10 15 20 30 60 120 16.7 50 100 68 5.6 11.2 34 68 4.3 6.3 8.5 13 27 53 3.5 5 7 10 22 43 2.2 3.2 4.5 6.5 14 27 2 3.6 5.5 12 23 1.1 1.6 2.1 3.3 6.5 13 20 30 40 40 40 40 20 30 40 40 40 40 20 30 48 36 36 48 76 72 54 54 96 96 96 96 48 72 120 120 120 120 60 90 150 150 150 150 144 144 160 160 160 168 168 240 240 240 240 288 288 20 20 20 20 20 20 20 20 20 20 20 20 20 20 24 24 24 32 36 36 36 36 48 48 48 48 48 48 60 60 60 60 60 60 96 96 96 96 96 96 112 112 112 112 112 192 192 192 192 192 192 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 150 120 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 200 200 200 200 350 350 60 61 65 67 67 67 68 70 74 74 75 75 74 75 75 74 75 77 74 75 76 77 76 76 76 77 76 80 77 77 77 78 77 81 79 79 79 80 80 82 79 79 80 80 82 79 79 79 80 80 83 W H FRONT VIEW H (BOTH SIDES) SIDE VIEW W MOUNTING SURFACE D See website for detailed drawing. Dimensions Table JWS50 JWS75 JWS100 JWS150 JWS300 JWS600 Height (H) Width (W) Depth (D) 1.45” 1.65” 1.97” 2.56” 3.62” 3.62” 3.35” 3.62” 3.62” 3.62” 4.72” 6.29” 6.25” 6.88” 7.40” 7.80” 7.48” 7.90” Other Industrial Products Options HWS LZSA DLP/DSP/DPP Suffix Description Blank /A* /B /C /R Screw terminals, no cover (JWS50 - JWS150) Screw terminals, cover (JWS50 - JWS150) Molex terminals, no cover (JWS50 & JWS75) Molex terminals, cover (JWS50 & JWS75) Remote On / Off (JWS50 - JWS150) Example Note: JWS50-5/RA * Standard US stock item. 15W to 1800W Single output 500 to 1500W Single output 10 to 480W DIN Rail Mount For Additional Information, please visit us.tdk-lambda.com/lp/products/jws-series.htm Not recommended for new designs - see HWS series 1-800-526-2324 • www.us.tdk-lambda.com/lp/ 12 Revision A7: Feb 2012
JWS5015/RA
物料型号:JWS系列,包括JWS50, JWS75, JWS100, JWS150, JWS300, JWS600等型号。
器件简介:JWS系列是单输出工业电源,具有5年保修期,功率因数校正,符合VDE0160机械指令,通用输入(85 - 265VAC),B级电磁干扰(EMI)等特性。
引脚分配:文档中未明确提供引脚分配信息,但提到了远程开启/关闭功能和并联连接选项。
参数特性: - 输入电压范围:85 - 265VAC(47 - 63Hz) 或 120 - 330VDC。 - 过电流保护:超过105%时启动。 - 过电压保护:具备。 - 漏电流:最大0.75mA。 - 远程感应和远程开启/关闭功能:可选。
功能详解: - 适用于工厂自动化、过程控制、数控机械、汽车、包装设备、物料搬运、化学处理、机器人等领域。 - 测试和测量、老化和测试、自动化测试、仪器、测量、检测等应用。
应用信息:适用于多种工业应用,包括工厂自动化、测试和测量等。
封装信息:提供了JWS系列电源的尺寸表,包括高度、宽度和深度。
其他信息: - 符合RoHS标准。 - 不推荐用于新设计,建议查看HWS系列。 - 提供了安全机构认证、传导和辐射EMI标准、推荐的EMI滤波器型号、重量、尺寸和保修信息。
JWS5015/RA 价格&库存
很抱歉,暂时无法提供与“JWS5015/RA”相匹配的价格&库存,您可以联系我们找货
