JWS600-24
JWS600-24
    TDK(东电化)
    JWS600-24
JWS600-24 数据手册
JWS-SERIES Single output 50W ~ 600W Unit Type Power Supply 䡵 Model name JWS 50-5/ JWS300 Blank: Open frame, Barrier Strip (JWS300,JWS600 with cover&Barrier Strip) Name of series Nominal output A: With cover, Barrier Strip voltage (JWS50,JWS75,JWS100& Output power JWS150 only) type B: Open frame, Connector terminal (JWS50 & JWS75 only) C: With cover, Connector terminal (JWS50 & JWS75 only) R: With remote on/off control (JWS50 ~ JWS150) JWS600 䡵 Features JWS50 JWS75 JWS100 JWS150 (Low Voltage Directive) 5 year warranty 䢇 marking (Low Voltage Directive) 䢇 Wide input voltage range: Universal input 85 ~ 265VAC 䢇 PFHC (EN61000-3-2) 䢇 EMI (EN55011-B, EN55022-B, VCCI-B, FCC-B) 䢇 EMC (EN61000-4-2, -3, -4, -5, -6) 䢇 5 year warranty 䡵 Specifications 1. Input voltage range 2. Power factor 3. Cooling 4. Operating ambient temperature 5. Withstand voltage 6. EMI 7. EMS 8. PFHC 9. Safety standard 10. Functions 11. Option 85 ~ 265VAC (47 ~ 63Hz), DC120 ~ 330V universal input 0.99 (typ) 100VAC at full load, 0.95 (typ) 200VAC at full load JWS50 ~ JWS150: Convection cooling / JWS300 & JWS600: Forced air cooling by internal fan JWS50 ~ JWS150: –10 ~ +60°C (Standard mounting) Output derating: 100% at –10 ~ +50°C, 60% at +60°C JWS300 ~ JWS600: 100% at –10 ~ +50°C, 60% : +60°C, 55% at +65°C Input–output: 3kVAC, Input–chassis : 2kVAC, Output–chassis: 500VAC for 1 min. Conforms to EN55011-B, EN55022-B, VCCI-class 2 and FCC-B Conforms to EN55011-B, EN55022-B, VCCI-class 2 and FCC-B Conforms to EN61000-3-2 class D Approved by UL1950 , CSA950 , EN60950 and VDE0160 Over voltage protection, Over current protection, Remote sensing (JWS100 ~ JWS600), Remote on/off control (JWS300 ~ 600) Remote on/off control, Input/output connector (JWS50, 75), Cover, Mounting sheet metal 䡵 Product lineup Model name JWS50 JWS75 JWS100 JWS150 JWS300 JWS600 JWS50-3 JWS50-5 JWS50-12 JWS50-15 JWS50-24 JWS50-48 JWS75-3 JWS75-5 JWS75-12 JWS75-15 JWS75-24 JWS75-48 JWS100-3 JWS100-5 JWS100-12 JWS100-15 JWS100-24 JWS100-48 JWS150-3 JWS150-5 JWS150-12 JWS150-15 JWS150-24 JWS150-48 JWS300-2 JWS300-3 JWS300-5 JWS300-12 JWS300-15 JWS300-24 JWS300-48 JWS600-2 JWS600-3 JWS600-5 JWS600-12 JWS600-15 JWS600-24 JWS600-48 Nominal output voltage 3.3V 5V 12V 15V 24V 48V 3.3V 5V 12V 15V 24V 48V 3.3V 5V 12V 15V 24V 48V 3.3V 5V 12V 15V 24V 48V 2V 3.3V 5V 12V 15V 24V 48V 2V 3.3V 5V 12V 15V 24V 48V 䢇 Request customer specification for further details of specification, outline, characteristics, etc. Read the instruction manual before usage. 䢇 Contact us about delivery before ordering. Max. output current 10A 10A 4.3A 3.5A 2.2A 1.1A 15A 15A 6.3A 5.0A 3.2A 1.6A 20A 20A 8.5A 7.0A 4.5A 2.1A 30A 30A 13A 10A 6.5A 3.3A 60A 60A 60A 27A 22A 14A 6.5A 120A 120A 120A 53A 43A 27A 13A Max. output power 33W 50W 51.6W 52.5W 52.8W 52.8W 49.5W 75W 75.6W 75W 76.8W 76.8W 66W 100W 102W 105W 108W 100.8W 99W 150W 156W 150W 156W 158.4W 120W 198W 300W 324W 330W 336W 312W 240W 396W 600W 636W 645W 648W 624W UL CSA EN 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 䡬 : Safety standard approved ∆ : Conforms to safety standard web191203 28 JWS-SERIES Unit Type Power Supply 䡵 JWS50 (50W type) VOLTAGE ADJUSTMENT REMOTE ON/OFF CONTROL (OPTION) COVER (OPTION) 2-M3 MOUNTING HOLES (DEPTH 6mm MAX) TERMINAL COVER 3-M3 MOUNTING HOLES (DEPTH 6mm MAX) NAME PLATE (Unit: mm) 䡵 JWS50 (50W connector type) VOLTAGE ADJUSTMENT REMOTE ON/OFF CONTROL (OPTION) COVER (OPTION) OUTPUT CONNECTOR 2-M3 MOUNTING HOLES (DEPTH 6mm MAX) INPUT CONNECTOR 3-M3 MOUNTING HOLES (DEPTH 6mm MAX) NAME PLATE (Unit: mm) 29 JWS-SERIES Unit Type Power Supply 䡵 JWS75 (75W type) (Unit: mm) 䡵 JWS75 (75W connector type) VOLTAGE ADJUSTMENT REMOTE ON/OFF CONTROL (OPTION) COVER (OPTION) OUTPUT CONNECTOR 2-M3 MOUNTING HOLES (DEPTH 6mm MAX) INPUT CONNECTOR 3-M3 MOUNTING HOLES (DEPTH 6mm MAX) NAME PLATE (Unit: mm) 30 JWS-SERIES Unit Type Power Supply 䡵 JWS100 (100W type) (Unit: mm) 䡵 JWS150 (150W) (Unit: mm) 31 JWS-SERIES Unit Type Power Supply 䡵 JWS300 (300W type) A A NOTE A: M4 tapped holes (20) for customer chassis mounting. [Screws must not protrude into power supply by more than 6m/m.] A (Unit: mm) 䡵 JWS600 (600W) A A A NOTE A: M4 tapped holes (16) for customer chassis mounting. [Screws must not protrude into power supply by more than 6m/m.] (Unit: mm) 32
JWS600-24 价格&库存
很抱歉,暂时无法提供与“JWS600-24”相匹配的价格&库存,您可以联系我们找货
