JWS60024/508
JWS60024/508
    TDK(东电化)
    SWITCHING POWER SUPPLIES
JWS60024/508 数据手册
JWS508 Series Single Output Industrial Power Supplies Features u 5 Year Warranty u Power factor Corrected u Approved to UL508 u Universal Input (85 - 265VAC) u 200% Peak power capable (JWS-P models) u Level B EMI Key Market Segments & Applications u Factory Automation Process Control, NC-Machining, Automotive, Packaging Equipment, Chemical Processing, Robots Not recommended for new designs - see HWS series Specifications Model Input Voltage range Inrush Current (100 / 200VAC) Power Factor Temperature Coefficient Overcurrent Protection Overvoltage Protection Hold Up Time (Typ) Leakage Current (max) Remote Sense Remote On / Off AC Power Fail Parallel Connection Operating Temperature Storage Temperature Operating Humidity (1) Storage Humidity (1) Cooling Withstand Voltage JWS50 A V ms mA °C - Isolation Resistance Vibration (non operating) Shock Safety Agency Approvals Conducted & Radiated Weight (Typ) Recommended EMI Filter EMI g - Size (WxHxD) Cover Warranty mm - 400 JWS70P JWS120P JWS240P JWS480P JWS75 JWS100 JWS150 JWS300 JWS600 85 - 265VAC (47 - 63Hz) or 120 - 330VDC (no DC input on JWS-P) 14 / 28 25 / 50 20 / 40 Meets EN61000-3-2 105% Yes 20 0.75 No Yes Not Available Standard Not Available Standard Not Available Avail. JWS300 & 600 only See derating table -30 to +85°C 30 - 90% RH (10 - 90% RH on JWS300 & 600 only) 10 - 95% RH JWS50 - JWS150 Convection, JWS240 - JWS600 Internal fan Input to Ground 2kVAC (20mA), Input to Output 3kVAC (20mA) Output to Ground 500VAC (100mA) for 1 min. >100M at 25C & 70%RH, Output to Ground 500VDC 10 - 55Hz (1 minute sweep), 19.6m/s2 constant X, Y, Z 1 hour < 196.1 m/s2 UL508 EN55011 / EN55022-B, FCC Class B, VCCI-B 500 700 900 1900 3000 MAW1202-22 MAW1202-22 MAW1205-22 MB1210 MAW1203-22 MB1210 MB1216 See sheet 2 Standard Five Years (1) Non condensing 1-800-526-2324 • www.us.tdk-lambda.com/lp/ 11 Disclaimer: us.tdk-lambda.com/lp/legal.htm JWS508 Series 1 CaseSelector Model Codes Code CA1500 Model Wattage Max Slots 1500 8 Voltage Size (H x W x L) Input Voltage Max Avg. Peak Load 2.5” x 8” x 11” 150 Current - 264VAC Current Current Reg mV Adjustment Range JWS50-24/508 24V 21.6 - 26.4 2.2 JWS70P-24/508 24V 21.6 - 26.4 JWS75-24/508 24V 21.6 - 26.4 3.2 JWS100-24/508 24V 21.6 - 26.4 4.5 JWS120P-24/508 24V 21.6 - 26.4 JWS150-24/508 24V 21.6 - 26.4 6.5 JWS240P-24/508 24V 21.6 - 28.8 JWS300-24/508 24V 21.6 - 28.8 14 JWS480P-24/508 24V 21.6 - 28.8 JWS600-24/508 24V 21.6 - 28.8 27 Note 1: Peak current for up to 10 seconds with a 50% duty cycle Model Derating* Model 40°C 3 5 10 20 - 6 10 20 40 - 150 192 150 150 192 150 192 144 192 144 Line Reg mV Ripple Noise mV Efficiency (typ) % 96 96 96 96 96 96 96 96 96 96 150 240 150 150 240 150 240 150 240 150 79 80 79 79 80 80 80 80 80 82 JWS Outline Drawing 55°C 60°C 65°C JWS50-24/508 100% 100% 80% 60% JWS70P-24/508 100% 100% 100% 80% JWS75-24/508 100% 80% 60% JWS100-24/508 100% 100% 100% 60% JWS120P-24/508 100% 100% 100% 80% JWS150-24/508 100% 100% 100% 60% JWS240P-24/508 100% 100% 100% 85% JWS300-24/508 100% 100% 100% 85% JWS480P-24/508 100% 100% 100% 85% JWS600-24/508 100% 100% 100% 85% * % of full power rating at specified temperature 45°C 50°C 60% 60% 70% 70% 70% 70% 55% 55% 55% 55% W H FRONT VIEW Dimensions Table JWS50 JWS75 JWS70P, JWS100 JWS120P, JWS150 JWS240P, JWS300 JWS480P, JWS600 Height (H) Width (W) Depth (D) 1.45” 1.65” 1.97” 2.56” 3.62” 3.62” 3.35” 3.62” 3.62” 3.62” 4.72” 6.29” 6.25” 6.88” 7.40” 7.80” 7.48” 7.90” H (BOTH SIDES) SIDE VIEW Other Industrial Products HWS JWS, JWS-P & JWT LZSa JFS DLP/DSP/DPP W 15 to 1500W Single output 50 to 600W Single and triple output 500 to 1500W Single output 500 to 2000W Single output 10 to 480W DIN Rail Mount MOUNTING SURFACE D For Additional Information, please visit us.tdk-lambda.com/lp/products/jws-series.htm See website for detailed drawing. Not recommended for new designs - see HWS series 1-800-526-2324 • www.us.tdk-lambda.com/lp/ 12 Revision A7: Feb 2012
JWS60024/508 价格&库存
很抱歉,暂时无法提供与“JWS60024/508”相匹配的价格&库存,您可以联系我们找货
