JWT Series
Triple Output Industrial Power Supplies
Features
5 Year Warranty
Power factor Corrected
Approved to VDE0160 Machinery Directive
Universal Input (85 - 265VAC)
Level B EMI
Key Market Segments & Applications
Factory Automation Process Control, NC-Machining, Automotive,
Packaging Equipment, Materials Handling,
Chemical Processing, Robots
Test & Measurement Burn-in & Test, Automated Test,
Instrumentation, Measurement, Detection
Not recommended for new designs - see CUT series
Specifications
Model
Max Output Power
Efficiency (Typ)
Input Voltage range
Input Current Typ
Inrush Current
Power Factor
Output Voltage Accuracy
Temperature Coefficient
Overcurrent Protection
Overvoltage Protection
Hold Up Time (Typ)
Leakage Current
Operating Temperature
Storage Temperature
Humidity
Cooling
Withstand Voltage
Isolation Resistance
Vibration (non operating)
Shock
Safety Agency Approvals
Conducted & Radiated EMI
Recommended EMI Filter
Weight (Typ)
Size (WxHxD)
Warranty
JWT75
W
A
A
V
ms
g
mm
JWT100
75
100
72
85 - 265VAC (47 - 63Hz) or 120 - 330VDC
1.2 / 0.6
1.4 / 0.7
14A at 100VAC, 28A at 200VAC input
Meets EN61000-3-2
V1 variable, V2 & V3 +/-5%
V1 & V2 100M at 25ºC & 70%RH, Output to Ground 500VDC
10 - 55Hz (1 minute sweep), 2G constant X, Y, Z 1 hour
很抱歉,暂时无法提供与“JWT75-5FF/A”相匹配的价格&库存,您可以联系我们找货
