• Small Size & Lightweight
• PCB Board Mountable
• Wide Range Input
• Medical Safety Certifications (4kVAC Input - Output)
• Class II (No ground needed)
Key Market Segments & Applications
KM Series
Portable Medical Equipment
General Low Power Applications
Not Recommended for New Designs
15 to 40W Medical AC-DC
PCB - Mount Power Supplies
KM Features and Benefits
Features
Benefits
• Small Size
• Wide Input Range
• High efficiency
Specifications
ITEMS
Input Voltage Range
Inrush Current Limiting
Input Current (115 / 230VAC)
Internal Fuse (live line) (1)
Temperature Coefficient (O/PV)
Ripple and Noise (pk-pk)
Overcurrent Protection
Overvoltage Protection
Hold-up Time (typical)
Touch Current
Operating Temperature
Storage Temperature
Humidity
Cooling
Withstand Voltage
Immunity
Safety Agency Certification
Conducted EMI
Switching Frequency
Weight
Size (LxWxH)
Mounting & Case
MTBF
Warranty
Notes:
• Minimises PCB Space
• Global use with no manual intervention
• Lower Heat Dissipated in System
MODELS
A
mA
mV
ms
mA
%RH
VAC
kHz
g
mm
hrs
yrs
KMS15
KMD15
KMT15
KMS40
KMD40
KMT40
90-264VAC 47-440Hz or 100-375VDC
10 / 20A, cold start, 25°C ambient (115 / 230VAC)
220 / 118mA
860 / 460mA
250V/T2A
250V/T3.15A
±0.01%/°C
50mV or 1%, whichever is greater
105-200%, hiccup mode, automatic recovery
Yes, Zener diode clamp
20ms
18ms
< 0.1
-25°C to 70°C, derate linearly to 50% load from 50°C to 70°C. Max case temperature 95°C
-40°C to 100°C
20% to 95% RH (non-condensing)
Convection, over temperature protected ~100°C case temperature)
Input to output: 4kVAC
EN60601-1-2
IEC/EN62368-1, IEC/EN60950-1, ANSI/AAMI ES60601-1, IEC/EN60601-1, CE Mark
EN55011, EN55032 Class B
EN55011, EN55032 Class A (2)
132kHz
120
280
64 x 46 x 24
89.0 x 63.5 x 27.6
PC board mountable. Plastic resin fibreglass case (UL 94V-0)
200,000 to 400,000 hours, model dependent
2
(1) For medical applications an equivalent external fuse should be installed in the neutral line
(2) Class I Applications: An external filter can be added to meet EN55011 Class B - see application notes
KM Series
1
Model Selector
Model
Single Output
Output
Voltage
(V)
Minimum
Current
(A)
Maximum
Current)
(A)
Power
(W)
Output Set
Line
Load
Cross
Accuracy Regulation Regulation (1) Regulation Efficiency
KMS15-3P3
KMS40-3P3
KMS15-5
KMS40-5
KMS15-9
KMS40-9
KMS15-12
KMS40-12
KMS15-15
KMS40-15
KMS15-24
KMS40-24
V1
V1
V1
V1
V1
V1
V1
V1
V1
V1
V1
V1
3.3V
3.3V
5V
5V
9V
9V
12V
12V
15V
15V
24V
24V
0A
80mA
0A
80mA
0A
44mA
0A
33mA
0A
26.7mA
0A
16.7mA
3.00A
8.00A
3.00A
8.00A
1.67A
4.44A
1.25A
3.33A
1.00A
2.67A
0.62A
1.67A
9.9W
26.4W
15W
40W
15W
40W
15W
40W
15W
40W
15W
40W
±2%
±2%
±2%
±2%
±2%
±2%
±2%
±2%
±2%
±2%
±2%
±2%
0.5%
0.5%
0.5%
0.5%
0.5%
0.5%
0.5%
0.5%
0.5%
0.5%
0.5%
0.5%
1%
1%
1%
1%
1%
1%
1%
1%
1%
1%
1%
1%
74%
75%
78%
79%
79%
82%
81%
83%
81%
83%
83%
83%
KMD15-55
V1
V2
V1
V2
V1
V2
V1
V2
V1
V2
V1
V2
V1
V2
V1
V2
+5V
-5V
+5V
-5V
5V(2)
12V(2)
5V(2)
24V(2)
+12V
-12V
+12V
-12V
+15V
-15V
+15V
-15V
150mA
150mA
400mA
400mA
1250mA
312mA
1250mA
156mA
62.5mA
62.5mA
166mA
166mA
50mA
50mA
133mA
133mA
1.5A
1.5A
4A
4A
5A
1.25A
5A
0.625A
0.625A
0.625A
1.66A
1.66A
0.5A
0.5A
1.33A
1.33A
15W
±2%
±2%
±2%
±2%
±3%
±5%
±3%
±5%
±2%
±2%
±2%
±2%
±2%
±2%
±2%
±2%
0.5%
0.5%
0.5%
0.5%
0.5%
5.0%
0.5%
5.0%
0.5%
0.5%
0.5%
0.5%
0.5%
0.5%
0.5%
0.5%
1%
1%
1%
1%
2%
6%
2%
6%
1%
1%
1%
1%
1%
1%
1%
1%
5%
5%
5%
5%
1%
7%
1%
7%
3%
3%
5%
5%
3%
3%
5%
5%
78%
KMT15-51212 V1
V2
V3
KMT40-51212 V1
V2
V3
KMT15-51515 V1
V2
V3
KMT40-51515 V1
V2
V3
5V(3)
+12V
-12V
5V(3)
+12V
-12V
5V(3)
+15V
-15V
5V(3)
+15V
-15V
500mA
50mA
50mA
1250mA
150mA
150mA
500mA
37.5mA
37.5mA
1250mA
125mA
125mA
2A
0.2A
0.2A
5A
0.6A
0.6A
2A
0.15A
0.15A
5A
0.5A
0.5A
15W
±2%
±3%
±3%
±3%
±5%
±5%
±2%
±3%
±3%
±3%
±5%
±5%
0.5%
2.0%
2.0%
0.5%
5.0%
5.0%
0.5%
2.0%
2.0%
0.5%
5.0%
5.0%
1%
5%
5%
3%
7%
7%
1%
5%
5%
3%
7%
7%
1%
5%
5%
3%
7%
7%
1%
5%
5%
3%
7%
7%
78%
Dual Output
KMD40-55
KMD40-512
KMD40-524
KMD15-1212
KMD40-1212
KMD15-1515
KMD40-1515
Triple Output
Pinout KM15
PIN #
1
2
3
4
5
6
7
8
9
2
Single O/P
No Pin
AC (L)
AC (N)
-DC
No Pin
No Pin
+DC
No Pin
No Pin
Function
Dual O/P
No Pin
AC (L)
AC (N)
-DC
GND
No Pin
+DC
No Pin
No Pin
Triple O/P
No Pin
AC (L)
AC (N)
+5V GND
+5V
-DC
No Pin
GND
+DC
40W
40W
40W
15W
40W
15W
40W
40W
15W
40W
Pinout KM40
PIN #
1
2
3
4
5
6
7
KM Series
Single O/P
AC (L)
AC (N)
+DC
No Pin
-DC
No Pin
No Connection
Function
Dual O/P
AC (L)
AC (N)
+DC
No Pin
GND
No Pin
-DC
5S/12&24S
79%
80%
80%
80%
83%
81%
81%
80%
78%
80%
Triple O/P
AC (L)
AC (L)
AC (N)
AC (N)
+O/P2
+DC
+O/P1
+5V
GND1
GND
GND2
+5V GND
No Connection
-DC
Outline Drawing KM15 Series
M
(Top View)
Viewed from
Top Side
Tolerance ± 0.5mm
Derating Curves KM15 Series
100%
90%
80%
70%
Load
60%
50%
Load
40%
30%
D
20%
10%
0%
40
50
60
70
80
Ambient temperature °C
KM Series
3
Outline Drawing KM40 Series
M
Viewed from
Top Side
Tolerance ± 0.5mm
(Height Tolerance ± 1.0mm)
Notes: (1) Symmetrical loading, from minimum to maximum load
Derating Curves KM40 Series
(2) Output V1 is isolated from output V2
100%
90%
80%
70%
Load
60%
50%
Load
40%
30%
20%
10%
0%
40
50
60
70
80
4
KM Series
(3) Output V1 is isolated from outputs V2 & V3
TDK-Lambda France SAS
TDK-Lambda Americas
Tel: +33 1 60 12 71 65
tlf.fr.powersolutions@tdk.com
Tel: +1 800-LAMBDA-4 or 1-800-526-2324
tla.powersolutions@tdk.com
www.us.lambda.tdk.com
www.emea.lambda.tdk.com/fr
Italy Sales Office
Tel: +39 02 61 29 38 63
tlf.it.powersolutions@tdk.com
www.emea.lambda.tdk.com/it
TDK Electronics do Brasil Ltda
Tel: +55 11 3289-9599
sales.br@tdk-electronics.tdk.com
www.tdk-electronics.tdk.com/en
Netherlands
tlf.nl.powersolutions@tdk.com
www.emea.lambda.tdk.com/nl
TDK-Lambda Germany GmbH
TDK-Lambda Corporation
Tel: +49 7841 666 0
tlg.powersolutions@tdk.com
www.emea.lambda.tdk.com/de
Tel: +81-3-6778-1113
www.jp.lambda.tdk.com
TDK-Lambda (China) Electronics Co. Ltd.
Tel: +86 21 6485-0777
tlc.powersolutions@tdk.com
www.lambda.tdk.com.cn
Austria Sales Office
Tel: +43 2256 655 84
tlg.at.powersolutions@tdk.com
TDK-Lambda Singapore Pte Ltd.
Tel: +65 6251 7211
tls.marketing@tdk.com
www.sg.lambda.tdk.com
www.emea.lambda.tdk.com/at
Switzerland Sales Office
Tel: +41 44 850 53 53
tlg.ch.powersolutions@tdk.com
TDK India Private Limited, Power Supply Division
www.emea.lambda.tdk.com/ch
Tel: +91 80 4039-0660
mathew.philip@tdk.com
Nordic Sales Office
Tel: +45 8853 8086
tlg.dk.powersolutions@tdk.com
www.emea.lambda.tdk.com/dk
TDK-Lambda UK Ltd.
Tel: +44 (0) 12 71 85 66 66
tlu.powersolutions@tdk.com
www.emea.lambda.tdk.com/uk
TDK-Lambda Ltd.
Tel: +9 723 902 4333
tli.powersolutions@tdk.com
www.emea.lambda.tdk.com/il-en
KM May23 v7
KM Series
For Additional Information, please visit
https://product.tdk.com/en/power/
5
很抱歉,暂时无法提供与“KMD40-512”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+872.823411+112.91304
- 10+814.0462210+105.30931
- 25+791.7607425+102.42634
- 50+775.3074050+100.29785
- 100+759.19825100+98.21389
