KMS-A Series
https://product.tdk.com/en/power/kms-a
https://www.emea.lambda.tdk.com/kms-a
15-60W Medical AC-DC
PCB-Mount Power Supplies
The encapsulated KMS-A PCB-Mount power supplies are certified to IEC/ES/EN 60601-1, IEC/EN 62368-1 and meet EN55011 Class B for conducted and
radiated emissions. Requiring no earth ground, the KMS-A series is ideally suited for a wide range of medical and industrial applications, including dental,
home healthcare and test and measurement.
Features
Benefits
• 4kVac Input to Output Isolation (2 x MoPP)
• Suitable for B & BF Applications Worldwide
• Wide Temperature Range (up to -40 to +80°C)
• Suitable for Harsh Environments
• Low No Load Power Consumption
• Energy Saving
• Class II Double Insulated Construction
• No Ground Connection Needed
• Epoxy Encapsulated
• Improved Shock and Vibration Performance
Model Selector
Model
KMS15A-5
KMS30A-5
KMS60A-5
KMS15A-9
KMS60A-9
KMS15A-12
KMS30A-12
KMS60A-12
KMS15A-15
KMS30A-15
KMS60A-15
KMS15A-24
KMS30A-24
KMS60A-24
Output Voltage
(V)
Maximum Current
(A)
Maximum Power
(W)
Ripple & Noise
(mVpk-pk)
Efficiency
(at 230Vac) (%)
Maximum Load
Capacitance (uF)
5
5
5.1
9
9
12
12
12
15
15
15
24
24
24
3
5
10
1.666
6.666
1.25
2.5
5
1
2
4
0.625
1.25
2.5
15
25
51
15
60
15
30
60
15
30
60
15
30
60
120
100
100
120
100
120
150
120
150
150
150
240
240
240
79
84
86
80
87
84
89
88
84
86
86
85
86
87
7,000
6,800
10,000
5,000
5,000
1,500
1,600
5,000
1,000
1,200
4,000
470
470
2,000
KMS 15A -24
15A 15W Output Power
30A 30W Output Power
60A 60W Output Power
-5
-9
-12
-15
-24
5V Output (5.1V for 60W Model)
9V Output (15W and 60W Models)
12V Output
15V Output
24V Output
KMS-A Series
/SC
Blank PCB mount standard model
/SC Screw terminals
(Not sold in the Americas)
1
Specifications
Model
KMS15A
KMS30A
KMS60A
Input
Input Voltage Range (Operating)(1)
Vac
90 - 264
Nominal Input Voltage Range
Vac
100 - 240
Input Frequency
Hz
47 - 440 (Note: Safety certified for 47-63Hz only)
DC Input Voltage Range
Vdc
120 - 370 (Note: Safety certified for AC input only)
Input Current (115 / 230Vac)
A
0.385 / 0.25
0.65 / 0.4
1.5 / 1
Inrush Current (115 / 230Vac, 25°C)
A
20 / 40
30 / 60
55 / 95
Leakage Current (264Vac)
mA
很抱歉,暂时无法提供与“KMS15A-5”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+542.987061+70.27470
- 10+520.0242710+67.30280
- 国内价格 香港价格
- 1+495.112241+64.07863
- 10+461.7624210+59.76241
- 25+449.1193325+58.12611
- 50+439.7902150+56.91872
- 100+430.65348100+55.73622
- 250+359.05704250+46.47004
