KMS60A-12
KMS60A-12
    TDK(东电化)
    插件,89x63.5mm
    15-60W 医疗级 AC-DC电源模块
KMS60A-12 数据手册
KMS-A Series https://product.tdk.com/en/power/kms-a https://www.emea.lambda.tdk.com/kms-a 15-60W Medical AC-DC PCB-Mount Power Supplies The encapsulated KMS-A PCB-Mount power supplies are certified to IEC/ES/EN 60601-1, IEC/EN 62368-1 and meet EN55011 Class B for conducted and radiated emissions. Requiring no earth ground, the KMS-A series is ideally suited for a wide range of medical and industrial applications, including dental, home healthcare and test and measurement. Features Benefits • 4kVac Input to Output Isolation (2 x MoPP) • Suitable for B & BF Applications Worldwide • Wide Temperature Range (up to -40 to +80°C) • Suitable for Harsh Environments • Low No Load Power Consumption • Energy Saving • Class II Double Insulated Construction • No Ground Connection Needed • Epoxy Encapsulated • Improved Shock and Vibration Performance Model Selector Model KMS15A-5 KMS30A-5 KMS60A-5 KMS15A-9 KMS60A-9 KMS15A-12 KMS30A-12 KMS60A-12 KMS15A-15 KMS30A-15 KMS60A-15 KMS15A-24 KMS30A-24 KMS60A-24 Output Voltage (V) Maximum Current (A) Maximum Power (W) Ripple & Noise (mVpk-pk) Efficiency (at 230Vac) (%) Maximum Load Capacitance (uF) 5 5 5.1 9 9 12 12 12 15 15 15 24 24 24 3 5 10 1.666 6.666 1.25 2.5 5 1 2 4 0.625 1.25 2.5 15 25 51 15 60 15 30 60 15 30 60 15 30 60 120 100 100 120 100 120 150 120 150 150 150 240 240 240 79 84 86 80 87 84 89 88 84 86 86 85 86 87 7,000 6,800 10,000 5,000 5,000 1,500 1,600 5,000 1,000 1,200 4,000 470 470 2,000 KMS 15A -24 15A 15W Output Power 30A 30W Output Power 60A 60W Output Power -5 -9 -12 -15 -24 5V Output (5.1V for 60W Model) 9V Output (15W and 60W Models) 12V Output 15V Output 24V Output KMS-A Series /SC Blank PCB mount standard model /SC Screw terminals (Not sold in the Americas) 1 Specifications Model KMS15A KMS30A KMS60A Input Input Voltage Range (Operating)(1) Vac 90 - 264 Nominal Input Voltage Range Vac 100 - 240 Input Frequency Hz 47 - 440 (Note: Safety certified for 47-63Hz only) DC Input Voltage Range Vdc 120 - 370 (Note: Safety certified for AC input only) Input Current (115 / 230Vac) A 0.385 / 0.25 0.65 / 0.4 1.5 / 1 Inrush Current (115 / 230Vac, 25°C) A 20 / 40 30 / 60 55 / 95 Leakage Current (264Vac) mA
KMS60A-12 价格&库存
很抱歉,暂时无法提供与“KMS60A-12”相匹配的价格&库存,您可以联系我们找货
