KPS10-12
KPS10-12
    TDK(东电化)
    DIP4 模块
    开放框架 AC DC 转换器 1 输出 12V 840mA 85 ~ 264 VAC 输入
KPS10-12 数据手册
• Small Size & Lightweight • PCB Board Mountable • Low Cost • Universal Input Voltage • RoHS Compliant Key Market Segments & Applications Factory Automation Telecom Datacom Printers and motor drives Instruments KPS Series 5 to 15W AC-DC Board Mount Power Supplies KPS Features and Benefits Features Benefits • Small Size • Wide Input Range • No External Components Needed • Minimises PCB Space • Global use with no manual intervention • Easy to use Specifications MODEL ITEMS Input Voltage range Inrush Current (115 / 230VAC) Input Current (115/230VAC) Temperature Coefficient Voltage Accuracy Minimum Load Load Regulation Line Regulation (1) Ripple & Noise (2) Short Circuit Protection Overvoltage Protection Hold Up Time (Typ@115VAC) LED Indicator Operating Temperature Storage Temperature Humidity (non condensing) Cooling Withstand Voltage Vibration (non operating) Shock Safety Agency Approvals Conducted & Radiated EMI Immunity Weight (Typ) Size (WxLxH; H above pcb) Warranty KPS-5 A A A mV V ms - g mm KPS-10 KPS-15 85 - 264VAC (47 - 440Hz) or 110 - 370VDC 20 / 40 0.13 / 0.07 0.27 / 0.13 0.4 / 0.2 ±0.05%/°C ±1% None ±1% (10% to 100% load) ±0.5% 1% or 50mV whichever is greater Continuous - hiccup mode 130-150% 8 16 16 Green LED = OK 0 to +70°C with derating -20 to +85°C 10 - 95% RH Convection Input to Output 3kVAC 23.52m/s2 (10 - 55Hz: constant sweep 1 min X, Y, Z for 1 hour) < 196.1 m/s2 (20G) UL60950-1, CSA60950-1, EN60950-1 Class II, CE Mark EN55022-B, FCC Class B EN61000-4 -2, -3, -4, -5, -6 29g 60g 80g 55 X 35 X 20 64 X 45 X 23 70 X 48 X 23 2 Year Notes: (1) KPS-5 Measured from 100 - 240VAC (2) Measured with 0.1uF ceramic & 10uF electrolytic at 20MHz BW KPS Series 1 Model Selector Model KPS5-3R3 KPS5-5 KPS5-12 KPS5-15 KPS5-24 KPS10-3R3 KPS10-5 KPS10-12 KPS10-15 KPS10-24 KPS15-3R3 KPS15-5 KPS15-12 KPS15-15 KPS15-24 Output Voltage (V) Maximum Output (A) Peak Load (A) Output Pwr (W) Eff (typ)% 3.3 5.0 12.0 15.0 24.0 3.3 5.0 12.0 15.0 24.0 3.3 5.0 12.0 15.0 24.0 1.25 1.00 0.42 0.33 0.23 2.50 2.00 0.84 0.67 0.42 3.00 3.00 1.25 1.00 0.63 3.80 2.80 1.20 1.00 0.65 4.50 4.50 1.80 1.50 0.95 4.1 5.0 5.0 5.0 5.5 8.3 10.0 10.1 10.1 10.1 9.9 15.0 15.0 15.0 15.1 70 70 70 70 77 65 70 75 75 78 70 73 80 80 82 Derating Curve KPS Series Outline Drawing KPS5 Series 2 KPS Series Outline Drawing KPS10 Series Outline Drawing KPS15 Series KPS Series 3 TDK-LAMBDA EMEA www.emea.tdk-lambda.com TDK-Lambda France SAS TDK-Lambda UK Ltd. Route de Grivery ZAC des Delaches CS 41077 91978 Courtaboeuf Cedex France Tel: +33 1 60 12 71 65 Fax: +33 1 60 12 71 66 france@fr.tdk-lambda.com www.fr.tdk-lambda.com Kingsley Avenue Ilfracombe Devon EX34 8ES United Kingdom Tel: +44 (0) 12 71 85 66 66 Fax: +44 (0) 12 71 86 48 94 powersolutions@uk.tdk-lambda.com www.uk.tdk-lambda.com Italy Sales Office Nemic Lambda Ltd. Via dei Lavoratori 128/130 20092 Cinisello Balsamo (MI) Italy Tel: +39 02 61 29 38 63 Fax: +39 02 61 29 09 00 info.italia@it.tdk-lambda.com www.it.tdk-lambda.com Kibbutz Givat Hashlosha 48800 Israel Tel: +9 723 902 4333 Fax: +9 723 902 4777 info@nemic.co.il www.nemic.co.il TDK-Lambda Germany GmbH Russia Karl-Bold-Strasse 40 77855 Achern Germany Tel: +49 7841 666 0 Fax: +49 7841 5000 info.germany@de.tdk-lambda.com www.de.tdk-lambda.com Technical Support: St Petersburg Tel: +7 (812) 6580463 Sales: Moscow Tel: +7 (499) 7557732 info@tdk-lambda.ru www.tdk-lambda.ru Austria Sales Office Aredstrasse 22 2544 Leobersdorf Austria Tel: +43 2256 655 84 Fax: +43 2256 645 12 info.germany@de.tdk-lambda.com www.de.tdk-lambda.com LOCAL DISTRIBUTION KPS June11 v3 4 KPS Series
KPS10-12 价格&库存
很抱歉,暂时无法提供与“KPS10-12”相匹配的价格&库存,您可以联系我们找货
KPS10-12
    • 4+256.98217
    库存:5
