KPSA10-15
KPSA10-15
    TDK(东电化)
    DIP4 模块
    开放框架 AC DC 转换器 1 输出 15V 85 ~ 264 VAC 输入
KPSA10-15 数据手册
• Small Size & Lightweight • PCB Board Mountable • Low Cost • Universal Input Voltage • RoHS Compliant Key Market Segments & Applications KPSA Series Factory Automation Telecom Datacom Printers and motor drives Instruments 5 to 15W AC-DC Board Mount Power Supplies KPSA Features and Benefits Features • Small Size • Wide Input Range • No External Components Needed Specifications MODEL ITEMS Input Voltage range Inrush Current (115 / 230VAC) A Input Current A Temperature Coefficient Voltage Accuracy Minimum Load A Load Regulation Line Regulation (1) Ripple & Noise (2) mV Short Circuit Protection Overvoltage Protection V Hold Up Time (Typ@115VAC) ms LED Indicator Operating Temperature °C Storage Temperature °C Humidity (non condensing) %RH Cooling Withstand Voltage Vibration (non operating) Shock Safety Agency Approvals Conducted & Radiated EMI Immunity Weight (Typ) g Size (WxLxH; H above pcb) mm Warranty yrs Notes: Benefits • Minimises PCB Space • Global use with no manual intervention • Easy to use KPSA-5 KPSA-10 KPSA-15 85 - 264VAC (47 - 63Hz) or 100 - 370VDC 30A Max at 230VAC 0.13 / 0.07 0.27 / 0.13 0.4 / 0.2 ±0.05%/°C ±1% None ±1% (10% to 100% load) ±0.5% 1% or 50mV whichever is greater Continuous - hiccup mode 130-150% 12 12 12 Green LED = OK 0 to +70 with derating -20 to +85 10 - 95 Convection Input to Output 3kVAC 23.52m/s2 (10 - 55Hz: constant sweep 1 min X, Y, Z for 1 hour) < 196.1 m/s2 (20G) IEC/UL/CSA/EN62368-1, 60950-1, Class II, CE Mark EN55022-B, FCC Class B EN61000-4 -2, -3, -4, -5, -6 28 40 48 55 X 33 X 21 61 X 40 X 20 70 X 45 X 20 2 (1) KPSA-5 Measured from 100 - 240VAC (2) Measured with 0.1µF ceramic & 10µF electrolytic at 20MHz BW KPSA Series 1 Model Selector Model KPSA5-3R3 KPSA5-5 KPSA5-12 KPSA5-15 KPSA5-24 KPSA10-3R3 KPSA10-5 KPSA10-12 KPSA10-15 KPSA10-24 KPSA15-3R3 KPSA15-5 KPSA15-12 KPSA15-15 KPSA15-24 Output Voltage (V) 3.3 5.0 12.0 15.0 24.0 3.3 5.0 12.0 15.0 24.0 3.3 5.0 12.0 15.0 24.0 Maximum Output (A) 1.25 1.00 0.42 0.33 0.23 2.50 2.00 0.84 0.67 0.42 3.00 3.00 1.25 1.00 0.63 Derating Curve KPSA Series Outline Drawing KPSA5 Series 2 KPSA Series Output Pwr (W) 4.1 5.0 5.0 5.0 5.5 8.3 10.0 10.1 10.1 10.1 9.9 15.0 15.0 15.0 15.1 Eff (typ)% 70 70 70 70 76 65 70 75 75 76 70 73 80 80 82 Outline Drawing KPSA10 Series Note: All Dimensions are in inches (mm) Tolererances: XX±0.2 (.X±.5) unless otherwise noted Outline Drawing KPSA15 Series Note: All Dimensions are in inches (mm) Tolererances: XX±0.2 (.X±.5) unless otherwise noted INTERMEDIATE VOLTAGES AVAILABLE PLEASE CONSULT SALES KPSA Series 3 TDK-Lambda France SAS TDK-Lambda Americas Tel: +33 1 60 12 71 65 tlf.fr.powersolutions@tdk.com Tel: +1 800-LAMBDA-4 or 1-800-526-2324 tla.powersolutions@tdk.com www.us.lambda.tdk.com www.emea.lambda.tdk.com/fr Italy Sales Office Tel: +39 02 61 29 38 63 tlf.it.powersolutions@tdk.com www.emea.lambda.tdk.com/it TDK Electronics do Brasil Ltda Tel: +55 11 3289-9599 sales.br@tdk-electronics.tdk.com www.tdk-electronics.tdk.com/en Netherlands tlf.nl.powersolutions@tdk.com www.emea.lambda.tdk.com/nl TDK-Lambda Germany GmbH TDK-Lambda Corporation Tel: +49 7841 666 0 tlg.powersolutions@tdk.com www.emea.lambda.tdk.com/de Tel: +81-3-6778-1113 www.jp.lambda.tdk.com TDK-Lambda (China) Electronics Co. Ltd. Tel: +86 21 6485-0777 tlc.powersolutions@tdk.com www.lambda.tdk.com.cn Austria Sales Office Tel: +43 2256 655 84 tlg.at.powersolutions@tdk.com TDK-Lambda Singapore Pte Ltd. Switzerland Sales Office Tel: +65 6251 7211 tls.marketing@tdk.com www.sg.lambda.tdk.com Tel: +41 44 850 53 53 tlg.ch.powersolutions@tdk.com TDK India Private Limited, Power Supply Division www.emea.lambda.tdk.com/at www.emea.lambda.tdk.com/ch Tel: +91 80 4039-0660 mathew.philip@tdk.com www.sg.lambda.tdk.com Nordic Sales Office Tel: +45 8853 8086 tlg.dk.powersolutions@tdk.com www.emea.lambda.tdk.com/dk TDK-Lambda UK Ltd. Tel: +44 (0) 12 71 85 66 66 tlu.powersolutions@tdk.com www.emea.lambda.tdk.com/uk TDK-Lambda Ltd. Tel: +9 723 902 4333 tli.powersolutions@tdk.com www.emea.lambda.tdk.com/il-en 4 KPSA Mar22 v5 KPSA Series For Additional Information, please visit https://product.tdk.com/en/power/
KPSA10-15 价格&库存
很抱歉,暂时无法提供与“KPSA10-15”相匹配的价格&库存,您可以联系我们找货
KPSA10-15
  • 1+276.439981+35.76805
