KWS-A Series
https://product.tdk.com/en/power/kws-a
Single output 5-25W AC-DC
Board Mount Power Supplies
www.emea.lambda.tdk.com/kws-a
The industrial grade KWS-A series of 5W, 10W, 15W and 25W board mount power supplies offer high efficiency levels of up to 88% in compact package
sizes and footprints. The KWS-A has a wide operating temperature range of -40 (start up) to +85°C with derating above 45/55°C and less than 0.5W off-load
power consumption. These converters are Class II double insulated, allowing operation without an earth ground connection.
Features
Benefits
• High Efficiency, Up to 88%
• Lower Operating Costs, Improved Thermal Performance
• Class B EMI with an External X Capacitor
• Minimal External Components Required
• Low No Load Power Consumption
• Energy Saving
• Wide Operating Temperature
• Operation In Harsh Environments
• Class II, Wide Range Input (85-265Vac)
• Global Application, No Earth Required
Model Selector
Model
KWS5A-5
KWS10A-5
KWS15A-5
KWS25A-5
KWS5A-12
KWS10A-12
KWS15A-12
KWS25A-12
KWS5A-15
KWS10A-15
KWS15A-15
KWS25A-15
KWS5A-24
KWS10A-24
KWS15A-24
KWS25A-24
Output Voltage Maximum Current
(V)
(A)
5
5
5
5
12
12
12
12
15
15
15
15
24
24
24
24
1
2
3
5
0.45
0.9
1.3
2.2
0.35
0.7
1
1.7
0.22
0.5
0.7
1.1
Maximum Power
(W)
Load Reg
(mV)
Line Reg
(mV)
Ripple /Noise
(mV)
Efficiency (typ)%
115/230Vac
5
10
15
25
5.4
10.8
15.6
26.4
5.3
10.5
15
25.5
5.3
12
16.8
26.4
40
40
40
40
96
96
96
96
120
120
120
120
150
150
150
150
48
48
48
60
60
60
60
96
96
96
96
200
200
200
200
240
240
240
240
240
240
240
240
240
240
240
240
76 / 74
76 / 77
77 / 78
81 / 82
78 / 75
80 / 81
81 / 83
84 / 86
79 / 75
81 / 82
82 / 84
85 / 87
80 / 77
82 / 84
82 / 85
86 / 88
KWS25A
-24
Series Name and Output Power
KWS5A - 5W
KWS10A - 10W
KWS15A - 15W
KWS25A - 25W
Output Voltage
5, 12, 15 or 24V
KWS-A Series
1
Specifications
KWS10A KWS15A
KWS25A
Model KWS5A
Input
AC Input Voltage Range (Operating)
Vac
85 - 265. Derate to 80% load from 100 to 85 input (KWS5A 90% load from 90 to 85)
Nominal Input Voltage Range
Vac
100 - 240 (Note: Safety certified for 90-264Vac only)
DC Input Voltage Range
Vdc
120 - 370 (Note: Safety certified for AC input only)
Input Current (115/230Vac)
A
0.13 / 0.07
0.25 / 0.13
0.33 / 0.24
0.56 / 0.34
Inrush Current at 200Vac (typ) (Cold Start) A
30
Leakage Current (264Vac)
uA
100 at 25°C, 70%RH & 500VDC
Vibration (non operating)
10-55Hz (Sweep for 1min.) Amplitude 1.65 mm (Max 10G, 98m/s2) Constant X,Y,Z 1 hour each
Shock (non operating)
Less than 50G (490m/s2), 11ms, ±X, ±Y, ±Z 3 times each
Other
Weight (Typ)
g
35
35
60
85
Size (LxWxH)
mm
38.1 x 25.4 x 21.5
38.1 x 25.4 x 21.5
50.8 x 25.4 x 24
63.5 x 25.4 x 29
Size (LxWxH)
Inches
1.5 x 1.0 x 0.85
1.5 x 1.0 x 0.85
2.0 x 1.0 x 0.94
2.5 x 1.0 x 1.14
Case Material
Plastic, UL94V0
MTBF - Telcordia SR-332 issue 3* Hours
14,416,059
7,784,121
8,202,502
5,747,627
Warranty
yrs
3
Notes:
See website for detailed specifications, test methods and installation manual
*24V model, 25°C ambient, full load, 230Vac Input
(1) At 100Vac and 115Vac with 80% load (70% load for KWSA10), 200Vac and 230Vac with 100% load
(2) KWS10A-5, KWS15A-5, KWS25A-5: Derate linearly to 10% load from +45 to +85°C
KWS5A, KWS10A Outline Drawing
KWS-A Series
3
KWS15A Outline Drawings & Pin Out
KWS25A Outline Drawings & Pin Out
4
KWS-A Series
TDK-Lambda France SAS
TDK-Lambda Americas
Tel: +33 1 60 12 71 65
tlf.fr.powersolutions@tdk.com
Tel: +1 800-LAMBDA-4 or 1-800-526-2324
tla.powersolutions@tdk.com
www.us.lambda.tdk.com
www.emea.lambda.tdk.com/fr
Italy Sales Office
Tel: +39 02 61 29 38 63
tlf.it.powersolutions@tdk.com
www.emea.lambda.tdk.com/it
TDK Electronics do Brasil Ltda
Tel: +55 11 3289-9599
sales.br@tdk-electronics.tdk.com
www.tdk-electronics.tdk.com/en
Netherlands
tlf.nl.powersolutions@tdk.com
www.emea.lambda.tdk.com/nl
TDK-Lambda Germany GmbH
TDK-Lambda Corporation
Tel: +49 7841 666 0
tlg.powersolutions@tdk.com
www.emea.lambda.tdk.com/de
Tel: +81-3-6778-1113
www.jp.lambda.tdk.com
TDK-Lambda (China) Electronics Co. Ltd.
Tel: +86 21 6485-0777
tlc.powersolutions@tdk.com
www.lambda.tdk.com.cn
Austria Sales Office
Tel: +43 2256 655 84
tlg.at.powersolutions@tdk.com
TDK-Lambda Singapore Pte Ltd.
Switzerland Sales Office
Tel: +65 6251 7211
tls.marketing@tdk.com
www.sg.lambda.tdk.com
Tel: +41 44 850 53 53
tlg.ch.powersolutions@tdk.com
TDK India Private Limited, Power Supply Division
www.emea.lambda.tdk.com/at
www.emea.lambda.tdk.com/ch
Tel: +91 80 4039-0660
mathew.philip@tdk.com
Nordic Sales Office
Tel: +45 8853 8086
tlg.dk.powersolutions@tdk.com
www.emea.lambda.tdk.com/dk
TDK-Lambda UK Ltd.
Tel: +44 (0) 12 71 85 66 66
tlu.powersolutions@tdk.com
www.emea.lambda.tdk.com/uk
TDK-Lambda Ltd.
Tel: +9 723 902 4333
tli.powersolutions@tdk.com
www.emea.lambda.tdk.com/il-en
For additional information, please visit
KWS-A_ 260873_October 25th, 2022 V2
KWS-A Series
5
很抱歉,暂时无法提供与“KWS10A-5”相匹配的价格&库存,您可以联系我们找货
