LS200-12
LS200-12
    TDK(东电化)
    AC/DC CONVERTER 12V 200W
LS200-12 数据手册
LS200 Series Single Output 150 - 200W General Purpose Power Supplies Very low cost Small Size Wide Range AC Input Convection or Fan Cooled Three year warranty 1.6" high (For 1U racking) Key Market Segments & Applications Light Industrial Automated Service Test & Measurement Kiosks Specifications MODEL ITEMS AC Input Voltage (300VAC for 5s) VAC Input Frequency Hz DC Input Voltage VDC Inrush Current (230VAC, cold start) A Power Factor Input Current (115/230VAC) A Temperature Coefficient Overcurrent Protection Overvoltage Protection (2) V Overtemperature Protection (2) Hold Up Time (115/230V input) Leakage Current (230VAC 60Hz) Remote Sense Remote On/Off LED Indicator Operating Temperature Storage Temperature Operating Humidity Storage Humidity Cooling Withstand Voltage Isolation Resistance Vibration (non operating) Shock Immunity Safety Agency Approvals Conducted & Radiated EMI Weight (Typ) Size (LxWxH) Warranty (1) (2) (3) LS200 (Enclosed style with internal fan) 85 - 264VAC LS200/L (U channel style - no internal fan) ms mA °C g in yrs 85 - 264VAC (3) 47 - 63Hz 120 - 373VDC 60 Meets EN61000-3-2, -3 (Typical PF 0.98/0.95)(1) 3.5 / 1.7 (typical) 105% of nominal or peak. Constant current style 3.3V: 3.8 - 4.45V, 5V: 5.75 - 6.75V, 7.5V: 8.6 - 10.1V, 12V: 15.1 - 17.75V 15V: 17.25 - 20.25V, 24V: 30.25 - 35.5V, 36V: 41.4 - 48.6V, 48V: 60 - 69.6V Yes 20ms 100M at 25°C & 70%RH, Output to Ground 500VDC 10 - 55Hz: 19.6m/s2 constant sweep 1 min X, Y, Z for 1 hour < 196.1 m/s2 (20G) IEC61000-4-2, -3, -4, -5, -6, -8, -11 UL60950-1, CSA60950-1 (cUL), IEC60950-1 2nd Edition, CE Mark EN55011/EN55022-B, FCC--B 700 600 7.8 x 3.9 x 1.61" Three Years 115 / 230VAC input Recycle AC to reset (Derate linearly to 65% load from 115VAC to 85VAC) 3055 Del Sol Blvd • San Diego, CA 92154 • 1-800-526-2324 75 LS200 Series Model Selector Model LS200-3.3 LS200-5 LS200-7.5 LS200-12 LS200-15 LS200-24 LS200-36 LS200-48 LS200-3.3/L LS200-5/L LS200-7.5/L LS200-12/L LS200-15/L LS200-24/L LS200-36/L LS200-48/L Voltage 3.3V 5V 7.5V 12V 15V 24V 36V 48V 3.3V 5V 7.5V 12V 15V 24V 36V 48V Adjust Range Max Current Max Current (V) Forced Air(A)(4) Convect.(A)(5) 3.0 - 3.6 4.75 - 5.5 6.8 - 8.2 10.8 - 14.4 13.5 - 16.5 22 - 28.8 32 - 40 42 - 57.6 3.0 - 3.6 4.75 - 5.5 6.8 - 8.2 10.8 - 14.4 13.5 - 16.5 22 - 28.8 32 - 40 42 - 57.6 40.0 40.0 26.7 16.7 13.4 8.4 5.6 4.2 40.0 40.0 26.7 16.7 13.4 8.4 5.6 4.2 N/A N/A N/A N/A N/A N/A N/A N/A 32.0 32.0 21.36 15.0 12.0 7.5 5.0 3.78 Peak Current (A) 10.4 6.9 10.4 6.9 - Load Reg Line Reg Ripple Noise Efficiency (mV) (mV) (mV) (typ) %(1) 40 40 40 96 120 192 288 384 40 40 40 96 120 192 288 384 16 20 20 48 60 96 144 192 16 20 20 48 60 96 144 192 80 80 80 120 120 120 150 200 80 80 80 120 120 120 150 200 67 72 74 76 80 82 82 82 67 72 74 76 80 82 82 82 / / / / / / / / / / / / / / / / 68 75 77 79 83 84 85 85 68 75 77 79 83 84 85 85 (4) With internal fan version LS200-xx or LS200-xx/L version with external airflow. (5) See Installation manual for derating curve. Outline Drawing Other Related Products LS25 - 150 HWS15 - 1800 SWS300 - 1000 25W to 150W low cost 15W to 1800W limited lifetime warranty 300 to 1000W single output Options Suffix /L Blank Description No cover or fan (U channel) Cover and fan For Additional Information, please visit us.tdk-lambda.com/lp/products/ls-series.htm 76 3055 Del Sol Blvd • San Diego, CA 92154 • 1-800-526-2324 Revision A3: Jan 2011
LS200-12 价格&库存
很抱歉,暂时无法提供与“LS200-12”相匹配的价格&库存,您可以联系我们找货
