LS35-24
LS35-24
    TDK(东电化)
    LS35-24
LS35-24 数据手册
LS25-150 Series 25-150W Single Output General Purpose Power Supplies https://product.tdk.com/en/power/ls www.emea.lambda.tdk.com/ls The LS series offers economically priced 25 to 150W power supplies for general purpose light industrial use. With output voltages ranging from 3.3 to 48V, the products have a five-year warranty (3) and conservatively rated electrolytic capacitor temperatures for longer field life. These compact products have a wide -25 to +70°C temperature range and are capable of withstanding a 300Vac surge for up to five seconds. Features Benefits • Compact Package Sizes • Space Saving in End Equipment • Low Cost • Suitable for General Purpose Light Industrial Use • Withstands 300Vac Input Surges • Can Operate on Unstable Input Voltages • Conservative Electrolytic Capacitor Temperatures • Long Field Life • Five Year Warranty • Lower Cost of Ownership (3) LS25-150 Series 1 Model Selector Model Voltage (V) Adjustable Range (V) Max Current (A) Load Reg (mV) Line Reg (mV) Ripple Noise (mV) 3.3 3.3 3.3 3.3 3.3 3.3 5 5 5 5 5 5 12 12 12 12 12 12 15 15 15 15 15 15 24 24 24 24 24 24 36 36 36 36 36 36 48 48 48 48 48 48 2.85 - 3.6 2.85 - 3.6 3.0 - 3.6 3.0 - 3.6 3.0 - 3.6 3.0 - 3.6 4.75 - 5.5 4.75 - 5.5 4.75 - 5.5 4.75 - 5.5 4.75 - 5.5 4.75 - 5.5 10.8 - 13.2 10.8 - 13.2 10.8 - 13.2 10.8 - 13.2 10.8 - 13.2 10.8 - 13.2 13.5 - 16.5 13.5 - 16.5 13.5 - 16.5 13.5 - 16.5 13.5 - 16.5 13.5 - 16.5 22 - 27.2 22 - 27.2 22 - 27.2 22 - 27.2 22 - 27.2 22 - 27.2 32 - 40 32 - 40 32 - 40 32 - 40 32 - 40 32 - 40 42 - 54 42 - 54 42 - 54 42 - 54 42 - 54 42 - 54 6 7 10 15 20 30 5 7 10 12 16 26 2.1 3 4.2 6 8.5 12.5 1.7 2.4 3.4 5 7 10 1.1 1.5 2.2 3.2 4.5 6.5 0.75 1 1.4 2.1 3 4.3 0.57 0.8 1.1 1.6 2.3 3.3 66 66 40 40 66 66 50 50 40 40 50 50 60 60 96 96 60 60 75 75 120 120 75 75 120 120 192 192 120 120 150 150 288 288 150 150 180 180 384 384 180 180 16.5 16.5 20 20 16.5 16.5 25 25 20 20 25 25 60 60 48 48 60 60 75 75 60 60 75 75 120 120 96 96 120 120 150 150 144 144 150 150 180 180 192 192 180 180 80 80 80 80 80 80 80 80 80 80 80 80 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 150 150 150 150 150 150 200 200 200 200 200 200 LS25-3.3 LS35-3.3 LS50-3.3 LS75-3.3 LS100-3.3 LS150-3.3 LS25-5 LS35-5 LS50-5 LS75-5 LS100-5 LS150-5 LS25-12 LS35-12 LS50-12 LS75-12 LS100-12 LS150-12 LS25-15 LS35-15 LS50-15 LS75-15 LS100-15 LS150-15 LS25-24 LS35-24 LS50-24 LS75-24 LS100-24 LS150-24 LS25-36 LS35-36 LS50-36 LS75-36 LS100-36 LS150-36 LS25-48 LS35-48 LS50-48 LS75-48 LS100-48 LS150-48 Related Products Type Higher power LS Higher power 7 yr warranty DIN rail mounting bracket DIN rail mounting bracket DIN rail mounting bracket 2 Part Number Description LS200 RWSB LS-DIN-1 LS-DIN-2 LS-DIN-3 150W to 200W LS models 50W to 1500W single output AC-DC power supplies LS25, LS35, LS50 DIN rail bracket LS75 DIN rail bracket LS100, LS150 DIN rail bracket LS25-150 Series Efficiency (typ) % 72 73 75 75 74 74 77 77 80 79 77 78 79 81 84 84 81 93 82 83 85 85 82 84 84 84 86 86 84 86 85 84 86 86 84 86 85 84 86 87 84 87 Specifications Model LS25 LS35 LS50 LS75 LS100 LS150 Input AC Input Voltage Range Vac 88 - 264 88-132/176-264(1) Nominal Input Voltage Range Vac LS25-100: 100-240 (Note: Safety certified for 90-264Vac only), LS150: 100-120, 200-240 (Certified for 90-132, 180-264Vac only) Input Frequency Hz 47 - 63 DC Input Voltage Range Vdc Contact Technical Support (Note: Safety certified for AC input only) Input Current (115/230Vac) A 0.7 / 0.4 0.8 / 0.55 1.3 / 0.8 1.6 / 1.0 2.2 / 1.2 3.5 / 2 Inrush Current at 230Vac (Cold Start) A 30 40 60 40 Leakage Current (230Vac 60Hz) mA 100 at 25°C, 70%RH & 500VDC Vibration (Non operating) - 10 - 55Hz: 19.6m/s2 constant sweep 1 min X, Y, Z for 1 hour Shock - < 196.1 m/s2 (20G) Other Weight (Typ) g 170 270 350 410 600 700 Size (LxWxH) mm 79 x 51 x 28 99 x 82 x 36 99 x 97 x 36 129 x 98 x 38 159 x 97 x 38 199 x 98 x 38 Size (LxWxH) Inches 3.1 x 2.0 x 1.1 3.9 x 3.2 x 1.4 3.9 x 3.8 x 1.4 5.1 x 3.8 x 1.5 6.3 x 3.8 x 1.5 7.8 x 3.9 x 1.5 Connectors Screw terminals Case Material - Metal MTBF - MIL-HDBK-217F Hrs 906,997 706,464 712,890 648,786 545,375 505,393 Warranty Yrs 3 or 5 (see note 3) Notes: See website for detailed specifications, test methods and installation manual (1) Switch selectable for 115 or 230Vac (2) LS25-3 Derate linearly to 60% load from +40 to +70°C. LS50, LS75-3 & -5 Derate linearly to 70% load from +50 to +70°C. LS25-5 to 48, LS75-12 to 48 Derate linearly to 60% load from +50 to +70°C. LS100-3 & -5 Derate linearly to 60% load from +45 to +70°C. Derate linearly to 80% load from 115V to 88Vac input. LS100-12, -15, -24, -36, -48 Derate linearly to 60% load from +50 to +70°C. Derate linearly to 80% load from 115V to 88Vac input. LS150-3 & -5, Derate linearly to 50% load from +40 to +70°C. LS150-12, -15, -24, -36, -48 Derate linearly to 70% load from +50 to +70°C. (3) The Americas and EMEA regions: 5 years. Other regions: 3 years. See applicable regional terms of sale. 4 LS25-150 Series Outline Drawing LS25 Outline Drawing LS35 LS25-150 Series 5 Outline Drawing LS50 Outline Drawing LS75 6 LS25-150 Series Outline Drawing LS100 Outline Drawing LS150 LS25-150 Series 7 TDK-Lambda France SAS TDK-Lambda Americas Tel: +33 1 60 12 71 65 tlf.fr.powersolutions@tdk.com Tel: +1 800-LAMBDA-4 or 1-800-526-2324 tla.powersolutions@tdk.com www.us.lambda.tdk.com www.emea.lambda.tdk.com/fr Italy Sales Office Tel: +39 02 61 29 38 63 tlf.it.powersolutions@tdk.com www.emea.lambda.tdk.com/it TDK Electronics do Brasil Ltda Tel: +55 11 3289-9599 sales.br@tdk-electronics.tdk.com www.tdk-electronics.tdk.com/en Netherlands tlf.nl.powersolutions@tdk.com www.emea.lambda.tdk.com/nl TDK-Lambda Germany GmbH Tel: +49 7841 666 0 tlg.powersolutions@tdk.com www.emea.lambda.tdk.com/de TDK-Lambda Corporation Tel: +81-3-6778-1113 www.jp.lambda.tdk.com TDK-Lambda (China) Electronics Co. Ltd. Tel: +86 21 6485-0777 tlc.powersolutions@tdk.com www.lambda.tdk.com.cn Austria Sales Office Tel: +43 2256 655 84 tlg.at.powersolutions@tdk.com TDK-Lambda Singapore Pte Ltd. Switzerland Sales Office Tel: +65 6251 7211 tls.marketing@tdk.com www.sg.lambda.tdk.com Tel: +41 44 850 53 53 tlg.ch.powersolutions@tdk.com TDK India Private Limited, Power Supply Division www.emea.lambda.tdk.com/at www.emea.lambda.tdk.com/ch Tel: +91 80 4039-0660 mathew.philip@tdk.com www.sg.lambda.tdk.com Nordic Sales Office Tel: +45 8853 8086 tlg.dk.powersolutions@tdk.com www.emea.lambda.tdk.com/dk TDK-Lambda UK Ltd. Tel: +44 (0) 12 71 85 66 66 tlu.powersolutions@tdk.com www.emea.lambda.tdk.com/uk TDK-Lambda Ltd. Tel: +9 723 902 4333 tli.powersolutions@tdk.com www.emea.lambda.tdk.com/il-en For Additional Information, please visit https://product.tdk.com/en/power/ LS25-150_260864 February 18th, 2023 V3 8 LS25-150 Series
LS35-24 价格&库存
很抱歉,暂时无法提供与“LS35-24”相匹配的价格&库存,您可以联系我们找货
LS35-24
  • 1+324.865201+41.99228
  • 10+302.9629010+39.16117
  • 25+294.6657625+38.08868
  • 50+288.5443450+37.29742
  • 100+282.54984100+36.52257
  • 250+274.81520250+35.52278
库存:226
LS35-24
  • 1+201.90348
库存:132
