TDK Multi-Sensor Solutions
by InvenSense®
SmartBug
Smart Multi-Sensor Wireless Module for IoT Applications
Overview
TDK’s SmartBug (MD-42688-P) is a multi-sensor wireless module that leverages
TDK MEMS sensors and algorithms for a wide range of IoT applications.
This module combines six sensors, a powerful wireless (BLE) MCU, seven
algorithm driven features and a rechargeable battery, all in a small lady-bug
enclosure. It also comes with the option of an Add-On board that includes a WiFi
module, an SD card slot and an ultrasonic sensor from TDK.
Key Features
• All-In-One Sensor Module including a
combination of sensors and algorithms
• Out-of-Box Solution
• Pre-programmed. No soldering or
programming needed.
• Dedicated source of raw and intelligent
sensor data
• Small size (50 × 36.6 × 18 mm) lets you
stick this module almost anywhere
• BLE, USB, WiFi and SD data logging
• Reliable and quality data from highperformance sensors and algorithms
• Over the Air (OTA) Firmware upgrade
• Visualization Software available
• Optional Add-On Board adds WiFi,
SD card and an ultrasonic range
sensor (shown below):
It is the go-to-module for quick and easy access to reliable and smart sensor
data. The data from each sensor and algorithm can be accessed “Out-of-Box”
without the need for any programming, soldering or extra modifications. This
makes it a perfect enabler for IoT product developers, algorithm developers
and sensor data enthusiasts to better understand real application signatures,
environment variations and multi-sensor/algorithm behaviors.
It includes ICM-42688-P 6-axis IMU, ICP-10101 pressure sensor with humidity
sensor, temperature sensor, magnetic sensor and an optional CH-101 ultrasonic
sensor from TDK, creating an All-in-one sensor solution. A unique feature of this
module is the provision of smart sensor data from IoT sensor algorithms with
customized tuning parameters. The algorithms include Door Open/Close Detect,
6 and 9-axis sensor fusion, Asset Monitoring, HVAC Filter Monitoring, Pedometer,
Activity classification, Gestures and Air Mouse Monitoring.
The SmartBug data and outputs can be easily visualized, streamed and recorded
on a Windows 10 Application – SmartBug. This application is available for
free to download on the Microsoft Store. The application offers great flexibility
to acquire data from BLE, WiFi or USB, depending on the use-case. SD card
logging feature in addition allows autonomous logging of data (upto 32GB)
without any Windows 10 Application.
Add-On Board with optional Chirp
Ultrasonic Time-of-Flight Sensor
invensense.tdk.com/smartbug
很抱歉,暂时无法提供与“MD-42688-P-XB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+341.567591+44.20065
