MD-42688-P
MD-42688-P
    TDK(东电化)
    ICM-42688-P,ICP-10101 - 加速计,陀螺仪,湿度,磁力仪,压力,温度 评估板 - 传感器
MD-42688-P 数据手册
TDK Multi-Sensor Solutions by InvenSense® SmartBug Smart Multi-Sensor Wireless Module for IoT Applications Overview TDK’s SmartBug (MD-42688-P) is a multi-sensor wireless module that leverages TDK MEMS sensors and algorithms for a wide range of IoT applications. This module combines six sensors, a powerful wireless (BLE) MCU, seven algorithm driven features and a rechargeable battery, all in a small lady-bug enclosure. It also comes with the option of an Add-On board that includes a WiFi module, an SD card slot and an ultrasonic sensor from TDK. Key Features • All-In-One Sensor Module including a combination of sensors and algorithms • Out-of-Box Solution • Pre-programmed. No soldering or programming needed. • Dedicated source of raw and intelligent sensor data • Small size (50 × 36.6 × 18 mm) lets you stick this module almost anywhere • BLE, USB, WiFi and SD data logging • Reliable and quality data from highperformance sensors and algorithms • Over the Air (OTA) Firmware upgrade • Visualization Software available • Optional Add-On Board adds WiFi, SD card and an ultrasonic range sensor (shown below): It is the go-to-module for quick and easy access to reliable and smart sensor data. The data from each sensor and algorithm can be accessed “Out-of-Box” without the need for any programming, soldering or extra modifications. This makes it a perfect enabler for IoT product developers, algorithm developers and sensor data enthusiasts to better understand real application signatures, environment variations and multi-sensor/algorithm behaviors. It includes ICM-42688-P 6-axis IMU, ICP-10101 pressure sensor with humidity sensor, temperature sensor, magnetic sensor and an optional CH-101 ultrasonic sensor from TDK, creating an All-in-one sensor solution. A unique feature of this module is the provision of smart sensor data from IoT sensor algorithms with customized tuning parameters. The algorithms include Door Open/Close Detect, 6 and 9-axis sensor fusion, Asset Monitoring, HVAC Filter Monitoring, Pedometer, Activity classification, Gestures and Air Mouse Monitoring. The SmartBug data and outputs can be easily visualized, streamed and recorded on a Windows 10 Application – SmartBug. This application is available for free to download on the Microsoft Store. The application offers great flexibility to acquire data from BLE, WiFi or USB, depending on the use-case. SD card logging feature in addition allows autonomous logging of data (upto 32GB) without any Windows 10 Application. Add-On Board with optional Chirp Ultrasonic Time-of-Flight Sensor invensense.tdk.com/smartbug
MD-42688-P 价格&库存
很抱歉,暂时无法提供与“MD-42688-P”相匹配的价格&库存,您可以联系我们找货
MD-42688-P
库存:55
