MHQ0603P-1-KIT
MHQ0603P-1-KIT
    TDK(东电化)
    L 0603 1000-240MA 0.6NH-11NH
MHQ0603P-1-KIT 数据手册
MHQ0603P Series Inductor Kit Consumer Grade High Frequency Inductor Kit The TDK MHQ0603P Series High Frequency Inductors are made up of thin sheets of unique ceramic material layered together. A coil pattern is printed onto each layer of material with metallic paste (normally silver). The sheets are then layered so a spiral-shaped internal electrode pattern is created, which eliminates the need to wind wire onto a core. This multilayer configuration allows for high Q characteristics that are equivalent to that of air core wound inductors, while allowing for miniaturization and mass production. Features  High Q factor contributes to reduced losses in RF circuits  Dimensions: 0.65 x 0.35 x 0.35mm (L x W x H)  Operating temperature range of –55°C to +125°C  Storage temperature range of –55°C to +125°C (after PC board mounting) High-Frequency Consumer Applications Datasheet  Smart phones  W-LAN  Bluetooth  High frequency modules (PAs, VCOs, FEMs)  UWB  Other mobile communication circuits  Tablet terminals MHQ0603P Series Inductor Kit Includes: Case Size: 0603 Metric (0201Inch) Inductance Range: 0.6nH—39nH (standard tolerance) Current Rating (max): 1000mA—160mA SRF (min): 10GHz –1.6Ghz Note that two part numbers are needed to order the complete range of inductance: Digi-Key Part Number 445-173065-KIT-ND 445-173084-KIT-ND Now Available at: Inductance Range 0.6-11nH 12-39nH Number of Pieces in Kit 20 pieces per value - 600 pcs total 20 pieces per value - 260 pcs total 445-173065-KIT-ND & 445-173084-KIT-ND MHQ0603P Series Inductor Kit Includes: Digi-Key Part Number 445‐173065‐KIT‐ND     445‐173084‐KIT‐ND   TDK Item List MHQ0603P0N6CT000  MHQ0603P0N7CT000  MHQ0603P0N8CT000  MHQ0603P0N9CT000  MHQ0603P1N0CT000  MHQ0603P1N1CT000  MHQ0603P1N2CT000  MHQ0603P1N3CT000  MHQ0603P1N5CT000  MHQ0603P1N6CT000  MHQ0603P1N8CT000  MHQ0603P2N0CT000  MHQ0603P2N2CT000  MHQ0603P2N4CT000  MHQ0603P2N7CT000  MHQ0603P3N0CT000  MHQ0603P3N3CT000  MHQ0603P3N6CT000  MHQ0603P3N9CT000  MHQ0603P4N3ST000  MHQ0603P4N7ST000  MHQ0603P5N1ST000  MHQ0603P5N6ST000  MHQ0603P6N2ST000  MHQ0603P6N8JT000  MHQ0603P7N5JT000  MHQ0603P8N2JT000  MHQ0603P9N1JT000  MHQ0603P10NJT000  MHQ0603P11NJT000  MHQ0603P12NJT000  MHQ0603P13NJT000  MHQ0603P15NJT000  MHQ0603P16NJT000  MHQ0603P18NJT000  MHQ0603P20NJT000  MHQ0603P22NJT000  MHQ0603P24NJT000  MHQ0603P27NJT000  MHQ0603P30NJT000  MHQ0603P33NJT000  MHQ0603P36NJT000  MHQ0603P39NJT000  Item Description 0603 0.6±0.2nH  0603 0.7±0.2nH  0603 0.8±0.2nH  0603 0.9±0.2nH  0603 1.0±0.2nH  0603 1.1±0.2nH  0603 1.2±0.2nH  0603 1.3±0.2nH  0603 1.5±0.2nH  0603 1.6±0.2nH  0603 1.8±0.2nH  0603 2.0±0.2nH  0603 2.2±0.2nH  0603 2.4±0.2nH  0603 2.7±0.2nH  0603 3.0±0.2nH  0603 3.3±0.2nH  0603 3.6±0.2nH  0603 3.9±0.2nH  0603 4.3±0.3nH  0603 4.7±0.3nH  0603 5.1±0.3nH  0603 5.6±0.3nH  0603 6.2±0.3nH  0603 6.8±5%  0603 7.5±5%  0603 8.2±5%  0603 9.1±5%  0603 10±5%  0603 11±5%  0603 12±5%  0603 13±5%  0603 15±5%  0603 16±3%  0603 18±5%  0603 20±5%  0603 22±5%  0603 24±5%  0603 27±5%  0603 30±5%  0603 33±5%  0603 36±5%  0603 39±5%
MHQ0603P-1-KIT 价格&库存
很抱歉,暂时无法提供与“MHQ0603P-1-KIT”相匹配的价格&库存,您可以联系我们找货
