MLG0402Q-1
MLG0402Q-1
    TDK(东电化)
    KIT RF INDUCT 1NH-3.9NH 600 PCS
MLG0402Q-1 数据手册
MLG0402Q Series Inductor Kit Consumer Grade High Frequency Inductor Kit The TDK MLG0402Q Series High Frequency Inductors are High Q type inductors for highfrequency circuits. Their advanced monolithic structure is formed using a multilayering and sintering process with ceramic and conductive materials for high-frequency. This series has an operating temperature range of –55°C to +125°C. High-Frequency Features  Unique ceramic material and configuration allows for High Q characteristics that are equivalent to that of air core wound inductors  Compared with existing products, the size was greatly reduced, making it optimal for fine-pitch circuits Consumer Datasheet Applications  Smart phones  W-LAN  Bluetooth  High frequency modules (PAs, VCOs, FEMs)  UWB  Other mobile communication circuits  Tablets MLG0402Q Series Inductor Kit Includes: Case Size: 0402 Inductance Range: 1.0nH-33nH (standard tolerance) Current Rating: 250mA-120mA SRF: 10GHz-1.7GHz Note that two part numbers are needed to order the complete range of inductance: Digi-Key Part Number 445-172406-KIT-ND 445-172407-KIT-ND Now Available at: Inductance Range 1.0-3.9nH 4.0-33nH Number of Pieces in Kit 20 pieces per value - 600 pcs total 20 pieces per value - 340 pcs total 445-172406-KIT-ND & 445-172407-KIT-ND Click the links above for ordering information. MLG0402Q Series Inductor Kit Includes: Digi-Key Part Number 445‐172406‐KIT‐ND  445‐172407‐KIT‐ND  TDK Item List MLG0402Q1N0ST000 MLG0402Q1N1ST000 MLG0402Q1N2ST000 MLG0402Q1N3ST000 MLG0402Q1N4ST000 MLG0402Q1N5ST000 MLG0402Q1N6ST000 MLG0402Q1N7ST000 MLG0402Q1N8ST000 MLG0402Q1N9ST000 MLG0402Q2N0ST000 MLG0402Q2N1ST000 MLG0402Q2N2ST000 MLG0402Q2N3ST000 MLG0402Q2N4ST000 MLG0402Q2N5ST000 MLG0402Q2N6ST000 MLG0402Q2N7ST000 MLG0402Q2N8ST000 MLG0402Q2N9ST000 MLG0402Q3N0ST000 MLG0402Q3N1ST000 MLG0402Q3N2ST000 MLG0402Q3N3ST000 MLG0402Q3N4ST000 MLG0402Q3N5ST000 MLG0402Q3N6ST000 MLG0402Q3N7ST000 MLG0402Q3N8ST000 MLG0402Q3N9ST000 MLG0402Q4N0ST000 MLG0402Q4N3ST000 MLG0402Q4N7ST000 MLG0402Q5N1ST000 MLG0402Q5N6ST000 MLG0402Q6N2ST000 MLG0402Q6N8JT000 MLG0402Q7N5JT000 MLG0402Q8N2JT000 MLG0402Q9N1JT000 MLG0402Q10NJT000 MLG0402Q12NJT000 MLG0402Q15NJT000 MLG0402Q18NJT000 MLG0402Q22NJT000 MLG0402Q27NJT000 MLG0402Q33NJT000 Item Description 0402 1.0nH ± 0.3nH 0402 1.1nH ± 0.3nH 0402 1.2nH ± 0.3nH 0402 1.3nH ± 0.3nH 0402 1.4nH ± 0.3nH 0402 1.5nH ± 0.3nH 0402 1.6nH ± 0.3nH 0402 1.7nH ± 0.3nH 0402 1.8nH ± 0.3nH 0402 1.9nH ± 0.3nH 0402 2.0nH ± 0.3nH 0402 2.1nH ± 0.3nH 0402 2.2nH ± 0.3nH 0402 2.3nH ± 0.3nH 0402 2.4nH ± 0.3nH 0402 2.5nH ± 0.3nH 0402 2.6nH ± 0.3nH 0402 2.7nH ± 0.3nH 0402 2.8nH ± 0.3nH 0402 2.9nH ± 0.3nH 0402 3.0nH ± 0.3nH 0402 3.1nH ± 0.3nH 0402 3.2nH ± 0.3nH 0402 3.3nH ± 0.3nH 0402 3.4nH ± 0.3nH 0402 3.5nH ± 0.3nH 0402 3.6nH ± 0.3nH 0402 3.7nH ± 0.3nH 0402 3.8nH ± 0.3nH 0402 3.9nH ± 0.3nH 0402 4.0nH ± 0.3nH 0402 4.3nH ± 0.3nH 0402 4.7nH ± 0.3nH 0402 5.1nH ± 0.3nH 0402 5.6nH ± 0.3nH 0402 6.2nH ± 0.3nH 0402 6.8nH ± 5% 0402 7.5nH ± 5% 0402 8.2nH ± 5% 0402 9.1nH ± 5% 0402 10.0nH ± 5% 0402 12.0nH ± 5% 0402 15.0nH ± 5% 0402 18.0nH ± 5% 0402 22.0nH ± 5% 0402 27.0nH ± 5% 0402 33.0nH ± 5%
MLG0402Q-1
物料型号为TDK MLG0402Q系列,这是一个高频电感器套件,适用于高频电路。
以下是该PDF文档中提供的一些关键信息:
- 器件简介:TDK MLG0402Q系列高频电感器采用先进的单体结构,通过陶瓷和导电材料的多层堆叠和烧结工艺形成,具有高Q特性,与空气芯绕制电感器相当。
- 引脚分配:0402封装,具体引脚分配未在文档中明确说明。
- 参数特性:电感范围从1.0nH到33nH,标准公差为±0.3nH,电流额定值从250mA到120mA,自谐频率(SRF)从10GHz到1.7GHz。
- 功能详解:这些电感器具有高Q特性,适用于智能手机、蓝牙、UWB、W-LAN、高频模块(如功率放大器、压控振荡器、前端模块)以及其他移动通信电路。
- 应用信息:适用于智能手机、平板电脑、蓝牙设备、UWB设备、W-LAN设备等。
- 封装信息:0402封装,总共有600件和340件两种套件,分别对应不同的电感值。
如需进一步详细信息,可以访问Digi-Key网站,使用提供的Digi-Key部件编号进行查询。
MLG0402Q-1 价格&库存
很抱歉,暂时无法提供与“MLG0402Q-1”相匹配的价格&库存,您可以联系我们找货
