MMZ1005-COMM-KIT
MMZ1005-COMM-KIT
    TDK(东电化)
    铁氧体磁珠和贴片 工具箱 260 件(26 个值 - 每个值 10 件) 表面贴装型
MMZ1005-COMM-KIT 数据手册
MMZ1005 Series Ferrite Bead Kit Consumer Grade Standard Ferrite Chip Bead Kit The TDK MMZ1005 Series ferrite chip beads are used to suppress noise in signal line circuits. They are effective at reducing noise simply by being placed into the circuit in series. Multilayer chip beads consist of ferrite material and a conductive paste layered together. Static characteristics of a chip bead are typically described as the impedance value Z at a frequency of 100MHz. While several different chip beads could provide the same impedance value at 100MHz, it is important to look at their individual frequency characteristics to determine which bead will work best for the circuit within the required frequency range. TDK offers several material types which provide various frequency characteristics for the MMZ1005 series chip beads. Features General Signal Line  Noise reduction solution for general signal line  Various frequency characteristics with different materials  Countermeasures from general signals to high-speed signals  Conforms to RoHS directive, halogen free, & compatible with lead-free soldering  Standard operating temperature range of –55°C to +125°C  Storage temperature range of –55°C to +125°C (after PC board mounting) Consumer Datasheet Applications  Household Appliances  Industrial Equipment  Smart Meters  Recorders  STBs  Mobile Devices, such as Smartphones and Tablet PCs MMZ1005 Series Ferrite Chip Bead Kit Includes: Case Size: 1005 (1.0 x 0.5mm) Impedance Range: 10-1800Ω (±25%) Current Rating: 100-550mA Kit contains 270 pieces total—10 pieces per value Now Available at: 445-174587-KIT-ND Click the links above for ordering information. MMZ1005 Series Ferrite Chip Bead Kit Includes: Digi‐Key Part Number   445‐174587‐KIT‐ND   TDK Item List  Item Descrip on  MMZ1005B800CT000  1005, Bead,80Ω±25%  MMZ1005B121CT000  1005, Bead,120Ω±25%  MMZ1005B601CT000  1005, Bead,600Ω±25%  MMZ1005S800CT000  1005, Bead,80Ω±25%  MMZ1005S121CT000  1005, Bead,120Ω±25%  MMZ1005S241CT000  1005, Bead,240Ω±25%  MMZ1005S601CT000  1005, Bead,600Ω±25%  MMZ1005S102CT000  1005, Bead,1000Ω±25%  MMZ1005Y400CT000  1005, Bead,40Ω±25%  MMZ1005Y800CT000  1005, Bead,80Ω±25%  MMZ1005Y121CT000  1005, Bead,120Ω±25%  MMZ1005Y241CT000  1005, Bead,240Ω±25%  MMZ1005Y301CT000  1005, Bead,300Ω±25%  MMZ1005Y471CT000  1005, Bead,470Ω±25%  MMZ1005Y601CT000  1005, Bead,600Ω±25%  MMZ1005Y102CT000  1005, Bead,1000Ω±25%  MMZ1005Y152CT000  1005, Bead,1500Ω±25%  MMZ1005Y182CT000  1005, Bead,1800Ω±25%  MMZ1005D100CT000  1005, Bead,10Ω±5ΩΩ  MMZ1005D220CT000  1005, Bead,22Ω±25%  MMZ1005D330CT000  1005, Bead,33Ω±25%  MMZ1005D680CT000  1005, Bead,68Ω±25%  MMZ1005D121CT000  1005, Bead,120Ω±25%  MMZ1005D241CT000  1005, Bead,240Ω±25%  MMZ1005F330CT000  1005, Bead,33Ω±25%  MMZ1005F470CT000  1005, Bead,47Ω±25%  MMZ1005F560CT000  1005, Bead,56Ω±25%
MMZ1005-COMM-KIT 价格&库存
很抱歉,暂时无法提供与“MMZ1005-COMM-KIT”相匹配的价格&库存,您可以联系我们找货
